Software Upgrade error : Webex Desk Pro
BC-contractor
Trying to upgrade software versions for my WebEx Desk Pro units. I pulled the software version from the TMS software manager, and locally downloaded it to my main machine. When I go in to Software Upgrade and then select the local pkg file, it begins to upgrade but then fails. I looked in the SYS Logs under the software upgrade log, and it gives me
XAPI :: set_notification() SoftwareUpgradeFailed,ERROR Signature verification failed !
I looked in the the community forums but found nothing, any help would be appreciated.
Jonathan Schulenberg
See the product documentation, specifically the software upgrade section of the target version’s release notes.
