How can i send SMS and WhatsApp messages at a faster rate?
Vivek12
I have registered multiple test numbers and want to send messages at a faster rate.
Connect - Tanuj
Hi @Vivek12 - Since the Sandbox accounts are aimed at enabling you to prototype solutions using various platform capabilities, the throughput is limited as mentioned in docs here
Though higher throughput is available on enterprise plans of imiconnect. You can fill this form here to request upgrade and get more information about the available options.
Tanuj Goyal
Webex Connect
Finding a detail you might have missed on the first listen can be difficult while listening to a 10-minute message at ordinary speed, especially if you can't recall where in the message the detail was revealed. geometry dash
Hi @ColleenHauck32683 - Please can you share more info on your use case and the Webex Connect feature that you're referring to?
Tanuj Goyal
Webex Connect
Connect - Tanuj
Tanuj Goyal
Webex Connect
