Adding CBW143 to CBW240 network fails.
RobCow
Trying to add the 143, and I add the MAC address, but it does not show up in the list as an extender, and I also can't get the update software selection to work either. I get the error "Connection failure: 60, Peer certificate cannot be authenticated with given CA certificates".
The 143 is showing "sending Association Request to join the network" with the response "authorization is failed.".
RobCow
Now they are on the network (who thought adding POE ports and not allowing wired backhaul?) but I still can't get them to pre-load the latest update. I keep getting errors about certificates. Same as before, but they are at least connected now.
