Wireless - Small Business
Stay connected on-the-go with our Wireless solutions, designed for small businesses to boost productivity.
Don't miss this Cisco Catalyst 8000 offer
Labels
Hello!   This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.    Virtual Assistant- Discover support content and options for your gearSupport page index - Contains a ...
CoreyP319 by Cisco Employee
  • 3057 Views
  • 1 replies
  • 5 Helpful votes
Trying to join my first AP which will the the primary AP. During the boot process the I am able to almost Go Live using the Cisco Business app but after creating the management SSID and the device reboots it gives error message that it cannot find th...
Hello everybody,I have a cluster of 6 CBW150AX access points, yesterday I was upgrading the firmware from version 10.5.2.0 to 10.6.2.0 and after the reboot one of the AP got stuck in a boot loop (the other five were updated correctly).The LED on the ...
Hi everyone,I’m having the following issue with my CBW150AX access points:Recently, I changed the Channel Width setting from 20MHz to Best. After that, 9 out of 11 APs successfully switched to 80MHz, as expected. However, 2 APs remain stuck on 20MHz,...
I have a new set of CBW 240AC AP's and two CBS250-8FP-E-2G switches. I am having a problem with when clients roam between AP's connected to the different switches. There is no issue when all of the AP's are connected to a single switch, roaming works...
Since a couple of days my AP started disassociating my clients (this happens both to computers and mobile phones) over and over, every minute or so. I could not find any explanation for the logs I was able to collect, and are completely unaware about...
leonixyz by Level 1
  • 572 Views
  • 1 replies
