Hello!
This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.
Virtual Assistant- Discover support content and options for your gearSupport page index - Contains a ...
Hi,I have been trying to use a freeradius server to authenticate wifi users with WPA2 entreprise.The AP connects to the radius server but the users are always refused.Are there attributes ( like Cisco-AVPair ?) that need to be added to the user in fr...
Hi,I was looking for the latest firmware for the WAP121 AccessPoint. However on www.cisco.com under support I couldn't find any software for the WAP121 - all other Cisco WLAN APs seem to have their software there, but not the WAP121.Aren't the firmwa...
I have two WAP4410N wireless access points powered using Power-Over-Ethernet. Both are running the latest available firmware version (2.0.5.3)They are both connected to the same LAN and broadcasting the same SSID with a WPA2 password.One is using cha...
I have one WET200 Wireless Brigde, connected to internet router... I can't use the infraestructure mode to broadcast the ssid to wireless cliente like laptops, Only can use the ad hoc mode, but the wireless clients dont reach the internet from adhoc ...
We have three WAP4410N that loses the connection. We've updated the firmware, changed the equipment, repeatedly reconfigured, but the problem persists.Is used the firmware 2.0.5.3 with WPA2 Enterprise Mixed authentication.Every day, at least twice d...
Hello, I want to know what is the maximum range of WAP200E. I found in an overview of the family of access points "CISCO SMB" that could reach up 4kms. Is that true? Thanks for the help!. Joel.
Hello everyone,We purchased five WAP4410n access points three months ago to be used in a medical practice. Two of them are currently used at the main office, which is a fairly large building (just under 12,000 sf on one floor, though the areas that n...
Is there a recvomended Power Injector for the<TR style="HEIGHT: 12.75pt" mcestyle="height: 12.75pt;"><TD style="WIDTH: 125pt; HEIGHT: 12.75pt" height=17 width=166 mcestyle="width: 125pt; height: 12.75pt;">AP541N-E-K9</TD></TR><TR style="HEIGHT: 12.75...
When the customer open wireless adapter connection --> Properties. In Security Tab he saw a check box " Show characters ". he checked it so Network security key is showHow can I configure the Cisco Controller to prevent the Customer from showing the...
I've set this up on my AP (latest firmware installed)However none of my (Windows xp/vista) will go to that page when they first attach to the Wireless networkWindows Browser (IE7) settings are for auto-detect, and I can browse to other places so Ikno...
Hi, Was looking at purchasing WAP321 however after looking at the spec's I see it has not got concurrent dual band (2.45Ghz/5Ghz) is there any simular access points with dual band and captive portal?Thank You
Hello,I have a client with several locations that all connect to the central location via VPN Tunnel using either SonicWall or Cisco ASA5505. At the main location there are several virtual servers hosting their EMR application "eClinicalWorks". Any...
Now that Comcast is in the process of rolling out IPv^ to their customers nationwide, will there be a firmware update that properly displays the IPv6 /64 address as provided by the cable provider? Currently the only IPv6 address displayed is on the ...
