Hello!
This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.
Virtual Assistant- Discover support content and options for your gearSupport page index - Contains a ...
Hi guys.About a week or so ago i bought a Cisco WRV210 and since then i've come accross a number of issues which resulted in spending about 2 hours trying to get it going again.My first issue is this, whenever anyone in the house tries to use anythin...
This is in reference to the 2 year old post located at https://supportforums.cisco.com/message/3117946#3117946Contrary to the information contained in the link above, these two parts do not play well together. I purchased both and plugged them in and...
Hi,I'm having trouble setting up an AP541N cluster with Windows 2008R2 NPS as radius server which is a member server in AD. The problem is the EAP type since I keep getting this error message: "The client could not be authenticated because the Extens...
We have 2 of these in the office one is connected into RVS4000 and another one is in repeater mode.Been having various issues with these 2 such as NAS disappearing from network and being inaccessable until we actually turn WAP4410N off and on, loss o...
I received WAP4410N-G5 AP with 2.0.2.1 firmware and set up it very easily. Never experienced a single signal drop in a few days.After updating firmware to 2.0.4.2 version I am completly unable to make any changes! If I press on "Enable" or "Disable" ...
I have done a wireless site survey at a library and one AP541N will cover everything pretty well. They do have one spot where the radio strenth is not quite as strong, but you would never buy a second access point for just that one area. I did the SI...
Hi, We are looking into the possibility of putting in some public wireless access in the public areas of our organisation. Its a fairly small building in terms of public access and it needs to span 3 rooms in total. We have a spare BT line into the b...
Hello everyone!I'm doing a pre-sales activity for a customer that wants to cover the building with wireless signal.We make a wireless site survey and discovered a very noisy enviroment, because the building is very close to an university campus that ...
I am looking to deploy 3, maybe 4 WAP4410N access points to cover a large home. I will be connecting these back to a Cisco RV042 router. Does anyone know if I can set these APs up to share one SSID? In other words, I would like only one SSID to sh...
Hello,My name is Abayomi Olatidoye. I am recently engaged by a client to convert his network to wireless network. My client operates in an office with 8 floors and also concrete walls. On making my research i came about your product Cisco AP500 Serie...
Hi, I need your help to send me wireless bridge settings for WAP 4410N.I have purchased two sets of WAP4410N and i need this to connect as wireless bridge to use our external office users(1 or Max 2) which is just beside our office building to surf o...
Small wireless network means - for the near future - a maximum of 4 wireless access points connected to a POE capable switch.Besides POE, we require VLAN - multiple VLANs in fact - and RADIUS authentication.We want multiple VLANs - and multiple SSIDs...
Hello everyoneI enabled SNMP on my 2 APs to check the bandwidth usage, it works only for a moment, i mean .. SNMP is still enabled, but i don t know why when i check the OID, in a command line it s like it doens t exist anymore .. Then i disable ==> ...
