Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful. Virtual Assistant- Discover support content and options for your gearSupport page index - Contains a ...
I called yesterday about getting my V2 RMA and they said that's fine.I sent it in and I hope to get my replacement by next week.
Just saw the notice that the WLC526 is at End of Life and is looking to be replaced with the 2100 series of WLAN Controller. Will CCA 2.2.1 support wireless configuration using the 2100 series WLC or is there another product that will be released to...
Its been a while now, I'm still waiting to hear when I can call again for my RMA.Some one said they would respond back to this thread when the V2 HW was ready.
I have tried everything on this thing to get it to give me 802.11N speeds.The highest speed I can get is 54Mbps.Yet using this same laptop connecting to an 881W router, I can easily get 300Mbps on 802.11N mode.I have tried using it in 5Ghz and 2.4Ghz...
Where can I find the latest firmware for the AP541N? I checked the usual Cisco download site but it is not listed. I can find references to it in documentation like the wireless design guide and release notes but no listing for the AP.
Sorry if the title seems to be a combination of acronyms!Anyhow I am looking to deploy 10 WAP4410N's in a building. I am going to deploy with three different network SSIDs - guest access, office network and voice. These will be fed by three seperat...
Hi All,I have got 2 x 4410n and I have them setup as 1 x AP mode and 1 x Repeater (connected to a firewall just out of the box).Can I confirm the following -For the 4410n AP - I have to select Acces Point and then tick allow wireless signal to be rep...
What frequency does the WAP operate in when in N-Only mode? It appears that 802.11n runs in 5GHz and/or 2.4GHz. http://en.wikipedia.org/wiki/IEEE_802.11n-2009. However, when choosing N-Only, the channel drop-down only shows 2.4GHz frequencies. Is ...
Hey guys,I've got a WAP4410n that I'm having trouble reaching the web admin on. I've since hard reset it, however the web interface I cannot access. I've tried both Mac and PC as well as multiple browsers. I've also tried from the wired and wireles...
I have an AP541N connected to a SA540 router. I have several computers that connect wirelessly including Apple iTouches and a PS3. I am using WPA personnel with WPA2/AES checked in the configuration. I do not broadcast the SSID but each computer h...
Cisco Guys,So I just got my 541's and was pretty excited... but I have now had some 'waning' of excitement.So this looks like quite a capable unit, and has some good features for an smb ap, especially the clustering.Unfortunately, a deal breaker for ...
Hello,I have to crosspost a thread I recently posted on http://forums.linksysbycisco.com/ (which i found out is not checked by Dev's):---------I have a major Problem with a Huge WIFI Installation (18x WAP200e).SSID1 is a WPA2/PSK Network (VLAN 1 -def...
Customer recently purchase WAP4410N, the signal strength only can achieve to 54Mbp ( even using the newer laptop with N-wireless card). I would think the signal at least can get 100-200 Mbp for N-router. Please help to check on this issue, because...
Just bought a Compaq Mini 110C for my wife. After initial setup, and by providing the relevant encryption key, it successfully connected to my new WAP4410N no problem. Wireless Connection Control for the SSID is Disabled.The AP has been configured wi...
here's our current setup50Mbps Docsis 3.0 cable -->ASA5505 -->SMC 802.11n bridge --->Cisco AP1252 -->2960G 8 port - with a 24 port unmanaged daisychained to it ...right now clients only connect on the 5ghz only using MSRADIUS PEAP to MSFT WIN2008V2...
