Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful. Virtual Assistant- Discover support content and options for your gearSupport page index - Contains a ...
Hello,I recently purchased 3 CBW150AX access points along with a CBS110-8PP switch. The switch is connected to a router, and I currently have one access point connected to the switch. The access point has been assigned 2 IP addresses by the router as...
The site advises on the EOL (End of Life) for Cisco 5520:https://www.cisco.com/c/en/us/products/collateral/wireless/5520-wireless-controller/eos-eol-notice-c51-744430.htmlSeeing this is only App SW (Application Software), does this mean the firmware ...
Dear Wireless Experts,I had tried to make the factory reset a AP (AIR-CAP3602I-N-K9) and I pressed over the time on MODE button.Now, I boot the AP every time and the console is only showed as Ranma. Any idea to reset it back to normally?
Hi everyone.I tried to do software update on my wi-fi network. I have set of 8 primary AP without mesh.Every time when pre-downloading for first AP was complete it show error "Invalid tarfile or extraction"Now I have 10.2.2.0 version.I tried to load ...
Good day everyone. I have an AP that can't get POE from switch. I have tested to see if the AP can get POE direct from the switch port with a shorter cable, and it is. So, when I connect it to the other end of the cable it doesn't power up. But when ...
Hi team,I have 3 cisco small business 150AX AP, have configured 1 as master and want to join rest 2 APs in the master AP but i am not able to join rest 2 in master as other APs also broadcasting SETUP SSID, which they should not TIA!!!!
On a customer site I have installed 5 CBW150AX in a VLAN (mgmt VLAN is primary on switch port).However, after some time, some access points are no longer seen by the primary AP.Network connectivity is there (verified). IP-Adresses are:primary: 192.16...
Hi folks,my network simplified is a 150AX connected to SG350 SB Switch connected to a pfSense (which provides the VLANs) connected to Telekom Fiber Channel - works so far.Unfortunately the 150AX has not enough Power to deliver WLAN in all our rooms. ...
I bought Cisco Business Wireless 150AX Access Point and found that my virtual machine configured with bridge mode over the wifi network doesn't get IP via DHCP.It seems that "Passive Client" setting is related to this issue, but I cannot find the set...
Dear Cisco TeamI trust you're fine. I have been unable to associate my ccoid to partner portal. Each time I try I get the attached error. I have also tried using diffferent browser and even going to in cognito mode but the probem has still persisted....
Hello everybody,My name is Spyros and i am working in Marine industry. On board the ships we have Cisco WAP121 WIFI Access Points.In every ship i face the same difficult situation.I can’t receive any notification in any app when i am connected, unles...
I own a small business - power dealz llc - and I buy pallets of goods and resell - I have a Meraki z4 tv and I have customers wanting to know if it’s claimed or unclaimed - could someone please assist me in figuring out how to check this so I will ha...
Hi there,Trying to access to the config terminal, I get error % Invalid input detected at '^' marker. Here is my process :Login to my access point via ssh login as :adminUsing keyboard-interactive authentication.Password:xxxxxxxxxxxAP>enablePassword...
Hello all, I have a set of Cisco 240ac AP's that I am unable to access the web GUI from the device IP's or the management (cluster) IP. I have tried Safari, Chrome, Edge, Firefox, Edge in IE mode and IE itself with HTTP and HTTPSI have tried to fact...
I have a question about our CBW 150AX's and 151AXM's. We installed them two months ago, and on occasion, wireless devices will lose connection to the network. The only thing I've seen that is suspicious is on the Software Update page. The same two de...
