Hello!
This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.
Virtual Assistant- Discover support content and options for your gearSupport page index - Contains a ...
Hey, I am new to installing AP's, and my house has a router and we run 5.0 GHZ, which dosen't exactly go through walls very well. And so I decided to purchase two Cisco Air-CAP2702I-K9. I purchased them from a small business that was upgrading to new...
i have a cbw 150ax wap. single wap, no extenders. i have many clients connected. i have one client that refuses to connect. it is a win11 msft surface pro 7+ running an intel wifi 6 ax201 chip. i have updated all drivers firmware for the machine and ...
Hello everyone,We are using the 240AC in a relatively small environment but we noticed that even with one person in the office video calls (zoom and meet) some times gets stuck.The AP is connected to a Zyxel 200 firewall and using a TP Link PoE injec...
so I was changing the region configuration on my ap. after the last edit, the ap no longer shows up on its own management page. the led is blinking Green Red off. This really seems weird to me. Any one knows what's going on with my ap?Thanks for any ...
i have a 150ax that boots up and connects. ssid wlan shows up and clients are connected. the led lights are stuck in green, red, off cycle. when i log into the gui, there are 0 access points (this is the only ap at the moment), there are 0 clients, b...
Hi, I am getting the below warning notifications on our cisco aironet 1700 series AP. Please let us know how to resolve this.Due to insufficient inline power. Upgrade inline power source or install power injector.
I installed a few CBW150AX into a customers network. MAnagement VLAN is distinct, the switch ports are set to Trunk with the management VLAN as the Primary VLAN ID.I created 2 WLANs, one with tagged VLAN ID 19 (which works correctly, the devices get ...
Hi, I've posted a message in the wireless forum and I've been suggested to ask hereThis was my original messagehttps://community.cisco.com/t5/wireless/need-to-replace-wap150-in-a-simple-configuration/m-p/4550630#M238336I'm looking for a replacement f...
Hello, everyone.I have not been able to use the proper service for the past three months due to the problem.Even if I searched the community and tried to use the feedback service, I couldn't find any action taken on the issue.Even if I wrote it to gi...
Is the Cisco 2702i series access point constructed and suitable for "Clean Room" (Healthcare environment) so that it can handle the daily chemical cleaning process like the Cisco 3602i and 3702i series access points are constructed to handle?
we have inherited a bunch of Aironet AIR-CAP2702E-B-K9 AP'S and need to figure out how to configure and set them up. is there some server level management software for this that we can get a download link for ? I searched and found some note about n...
Hello,I have recently installed a WAP371 access point for a customer. It's the first time I installed this model. When I tested it everything seemed fine, but the customer reports that he very often has problems connecting to the access point and he ...
Hello CommunityI have two Cisco WAP361 Wireless Access Point , How can this scenario be applied?- I take the first device IP 172.16.0.3/23- I take the second device IP 172.16.0.4/23when connect two device such as image , the second device reset the...
