Wireless - Small Business
Stay connected on-the-go with our Wireless solutions, designed for small businesses to boost productivity.
Don't miss this Cisco Catalyst 8000 offer
Labels
Update - We have completed the relabeling project for the wireless board. We will be lifting read-only mode today the Sixth of May. Thank you all for your patience and feedback.   We are approaching our latest step in relabelling posts across the Sma...
CoreyP319 by Cisco Employee
  • 488 Views
  • 0 replies
  • 1 Helpful votes
Hello!   This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.    Virtual Assistant- Discover support content and options for your gearSupport page index - Contains a ...
  • 2786 Views
  • 1 replies
  • 5 Helpful votes
I just purchased a Cisco WAP571 access point.  I want to upload a configuration file to the AP to set it up for my network. When I first connect it to the switch and try to configure it, it won't allow me to cancel the setup wizard. When I complete t...
by Not applicable
  • 883 Views
  • 0 replies
Hello everyone. I have several WAP321 access points deployed in the network as standalone units and they're working well. Now I'm trying to set up centralized RADIUS server authentication (WPA2-Enterprise) for wireless users using FreeRADIUS. WAP321 ...
Flanger23 by Level 1
  • 2474 Views
  • 2 replies
hi i have a problem with the cisco wap561  it gives a verry weak wifi signal at 2.4 and 5 gig network ( apple time capsul is twice as powerfull) power is set to full at both networks and after about 10m the signal is useless cheked it at 3 clients. p...
perdonkor by Level 1
  • 968 Views
  • 0 replies
Hello, I'm trying to write a script to hit my 371s via SNMP and pull client associations (specifically their MAC addresses). I've tried most of the OIDs I've found mentioned in similar threads / google to no avail. Does anyone know the magic (if t...
