Hello!
This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.
Virtual Assistant- Discover support content and options for your gearSupport page index - Contains a ...
I have 3 Cisco CBW240AC access points configured in mesh topology however for some reasons these access points have started timing out intermittently, mostly twice almost every now and then. I have updated the firmware for all access points to to 10...
no way to add a brand new CBW142ACM to a brand new CBW145AC. Attempted both ways with an app and through GUI, added the extender MAC address to local table, upgraded and downgraded to all firmware versions from 10.4.1 through 10.7.1, factory r...
In the COVID/work from home world, I have been working to affordably segment my SOHO network between work, home, and IOT devices. So far, I have been able to successfully segment my wired network (it works) and am now working on my wireless. For wir...
WAP571 x 9 AP cluster. All AP's are working however the cluster controller IP is not availablethe Controller AP is the only one that shows on the network scans and you can login to the APbut not the AP controller ip to manage the cluster. no idea wh...
Hi, I am trying to setup a 140ac accesspoint to transmit syslog information to a barracuda web filter. We have radius setup so whenever someone joins the wifi network, they login with their Active Directory credentials, however, the 140ac outputs the...
Hello,We have a network where Cisco WAP150 and RV110 Wireless Router roaming the same SSIDs which is same network, same vlan, same password and same security type. Recently, there is some problem in accessing other devices in the network. When we reb...
Hello,I have 8 APs WAP150 installed in an office since 11/2020, all feeded with POE from linksys SW 24 ports, this network considers as a secondary network in the office with its own IP range, some users connect with their mobiles or laptops. I faced...
Hi, I have several sites that have clusters of Cisco Business 240AC. These are configured with a management portal on VLAN1 and I can remotely access the management portal across the company WAN, however, due to recent shortages, I have had to use t...
HiI have a CBW 240 WLAN consisting of 16 number of AC240 model since One year,then I want to increase the coverage by adding more APs,I didn't found the supported models in local market so I ordered 5 ac140 pack online from US, I tried to add The New...
Hello,I am having major issues setting up a CBW140AC-B out of the box. I have it plugged into the PoE port of my router and per the instructions, I waited until it cycled to flashing green light. Then again per the instructions, I am supposed to co...
Dear Friends,I am running a single point setup of 6 WAP571 with 2 vlans, each using 2.4 and 5 GHz. Firmware is 1.1.0.3Now since a few days someting very strange happens every few hours or days: one or few of the APs drop out of the single point setup...
Hello all, In short: I have two Cisco Small Business AC140 wireless access points that get stuck flashing red after zero day setup. Neither will broadcast after initial restart. Both accept factory reset and bring up zero day setup. Specifics:I go th...
Hi.We have 3504 Cisco controller configured with a 1832 AP.Authentication/connection to the configured WLAN fails and we can see the following messages in the 3504 controller.*radiusTransportThread: Apr 07 09:00:51.379: %AAA-3-INVALID_REQUEST: radius...
