This adapter configuration is GUI based, so the OS should not matter. You may have to try a couple of different browsers and or versions. This has been out for a while so you would have the best results with an older browser like IE8 and not 10 or 11.
Here is a link to the quick start quide. This should help you with the initial steps of configuration.
http://www.cisco.com/c/dam/en/us/td/docs/voice_ip_comm/csbpva/wbpn/quick_start/guide/wbpn_qsg.pdf
Eric Moyers
.:|:.:|:. CISCO | Cisco Presales Technical Support | Wireless Subject Matter Expert
Please rate helpful Posts and Let others know when your Question has been answered.
