04-09-2024 04:16 AM - edited 04-09-2024 04:49 AM
hello,
I am trying to monitor MESH link between 2 APs on 9800.
there are two problems:
1. no working OID to give me up/down status of the mesh link, or SNR for the link, channel utilization.
this should be clMeshNeighborLinkSnr, but does not return anything.
2. no way of getting traffic count from dot11 radio slot 1, from MIB files can get Tx/Rx data frame count, mgmt, control, retry... but I want simple Rx/Tx Bytes from sh interfaces dot11Radio 1 on the AP.
This should be cLApDot11RadioRateStatsRxBytes, but that does not return anything.
BR
M
04-09-2024 06:04 AM
- General answer only : check software version, go for 17.9.5 and test again , if you are on an older release (e.g.)
M.
04-09-2024 11:35 PM
I am on 17.12.x.
do you have an OID for radio slotX bytes Tx Rx?
