04-08-2023 04:31 AM
I have a cisco air-cap702w-e-k9 access point, I want to use it without a controller, I want to enter the interface and make settings from there, what should I do, thanks
04-08-2023 04:55 AM
- Ref : https://www.cisco.com/c/en/us/td/docs/wireless/access_point/700/quick/guide/ap700getstart.html
>....The 700 series access point models for controller-based operation is AIR-CAP702I-x-K9 and for autonomous configuration is AIR-SAP702I-x-K9. Each configuration provides two 2.4-GHz/5-GHz dual-band radios, with integrated single-band antennas.
It looks like your model can only work with a controller
M.
04-08-2023 05:28 AM
How can I do a complete reset of the device?
04-08-2023 10:24 AM
Like what was mentioned previously, do you have a console cable, because you need one to start to do anything. Look for a FTDI USB-C to RJ45 cable. You can find this on Amazon and eBay along with other online stores.
04-08-2023 12:56 PM
yes we have a cable mode button is red ap typed on the screen
04-08-2023 02:58 PM
Please post the output of what you see. It's very hard to help without data.
04-09-2023 11:23 PM
Cisco IOS Software, C702 Software (ap1g1-RCVK9W8-M), Version 15.2(4)JB5, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2014 by Cisco Systems, Inc.
Compiled Thu 01-May-14 20:05 by prod_rel_team
Initializing flashfs...
Ath Nand ID: 1D:80:F1:C2:1D
Using driver version 1 for media type 2
Valid buffers 461
total461 461
success found all blocks
start end 244 43
found in range
high low end 1388 7832 43
U-Boot 1.1.4 - RNAQ-C1 V1.3.1.0 (Nov 15 2013 - 11:59:59)
DRAM: 128 MB
CPU: 560 MHz
Top of RAM usable for U-Boot at: 88000000
Reserving 287k for U-Boot at: 87fb8000
Reserving 144k for malloc() at: 87f94000
Reserving 44 Bytes for Board Info at: 87f93fd4
Reserving 36 Bytes for Global Data at: 87f93fb0
Reserving 128k for boot params() at: 87f73fb0
Stack Pointer at: 87f73f98
Now running in RAM - U-Boot at: 87fb8000
Flash: 1 MB
athrs17_reg_init: complete
eth0: f0:9e:63:1a:24:80
Checking Ethernet link status...
Ethernet link up - 1000Mbps Full
Ether initialization ok!
NAND: Macronix[128MB]
Test Size=0x8000000, Start!!
RAM test complete!
PTD Init: 802.3at Power Type Detected!!
MAC address check ok!
boot method:3
Hit "ESC" to stop autoboot: 0
Uncompressed size: 329787 = 0x5083B
Loading .text @ 0x84000000 (211520 bytes)
Loading .rodata @ 0x84033a40 (39392 bytes)
Loading .data @ 0x8403d420 (3296 bytes)
Loading .data.rel.local @ 0x8403e100 (1084 bytes)
Loading .data.rel @ 0x8403e53c (124 bytes)
Loading .data.rel.ro @ 0x8403e5b8 (960 bytes)
Clearing .bss @ 0x8403e980 (161116 bytes)
Clearing .scommon @ 0x84065edc (60 bytes)
## Starting application at 0x84000000 ...
IOS Secondary Bootloader - Starting system.HW Test Status(0)
Ath Nand ID: 1d:80:f1:c2:1d
Valid buffers 461
total461 461
start end 244 43
found in range
Xmodem file system is available.
mifs[0]: 274 files, 15 directories
mifs[0]: Total bytes : 131334144
mifs[0]: Bytes used : 34875392
mifs[0]: Bytes available : 96458752
mifs[0]: mifs fsck took 0 seconds.
Base Ethernet MAC address: f0:9e:63:1a:24:80
Setup MAC....
Sardinia platform
WASP ----> F1 PHY *
current phyID is 1302
Ethernet speed is 1000 Mb - FULL duplex
Setting Drop CRC Errors, Pause Frames and Length Error frames
: cfg1 0xf cfg2 0x7215
Loading "flash:/ap1g1-rcvk9w8-mx.152-4.JB5/ap1g1-rcvk9w8-mx.152-4.JB5"...####################################################################################################################################################################################################################################################################################################################################################
File "flash:/ap1g1-rcvk9w8-mx.152-4.JB5/ap1g1-rcvk9w8-mx.152-4.JB5" uncompressed and installed, entry point: 0x60080000
executing...
Stop MAC.
Starting IOS...
cp0 timer begin value is set as 1000
prid= 1974C
Starts main.
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
Valid buffers 461
total461 461
start end 244 43
found in range
mifs[3]: 274 files, 15 directories
mifs[3]: Total bytes : 131334144
mifs[3]: Bytes used : 34875392
mifs[3]: Bytes available : 96458752
mifs[3]: mifs fsck took 7 seconds.
mifs[3]: Initialization complete.
...done Initializing flashfs.
Sardinia platform
current platform is 2
Base Ethernet MAC address: F0:9E:63:1A:24:80
WASP ----> F1 PHY *
no ip http server
% Invalid input detected at '^' marker.
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco AIR-CAP702W-E-K9 (MIPS74k) processor (revision 02) with 81920K/49152K bytes of memory.
Processor board ID KWC183203MH
MIPS74k CPU at 560MHz, revision number 0x0000
Last reset from power-on
LWAPP image version 7.6.100.0
1 Gigabit Ethernet interface
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: F0:9E:63:1A:24:80
Part Number : 74-12289-01
PCA Assembly Number : 000-00000-00
PCA Revision Number :
PCB Serial Number : -----------
Top Assembly Part Number : 000-00000-00
Top Assembly Serial Number : ------------
Top Revision Number : A0
Product/Model Number : AIR-CAP702W-E-K9
% Please define a domain-name first.
Press RETURN to get started!
: Mac unit : 0
: Max segments per packet : 1
: Max tx descriptor count : 128
: Max rx descriptor count : 256
: Mac capability flags : 4400
athr_gmac_hw_setup mac: 0x61A8A2E0
: cfg1 0xF cfg2 0x7214
*Mar 1 00:00:22.891: Failed to remove config file flash:/lan_port_cfg.txt
*Mar 1 00:00:22.891: %LWAPP-3-CLIENTERRORLOG: Config load from flash failed. Initialising Cfg
*Mar 1 00:00:23.295: %LINK-6-UPDOWN: Interface GigabitEthernet0, changed state to up
*Mar 1 00:00:26.271: %SYS-5-RESTART: System restarted --
*Mar 1 00:00:26.391: Failed to remove config file flash:/lan_port_cfg.txt
*Mar 1 00:00:26.443: *** not invoke
*Mar 1 00:00:26.463: %LWAPP-3-CLIENTERRORLOG: Config load from flash failed. Initialising Cfg
*Mar 1 00:00:26.463: %CAPWAP-3-ERRORLOG: Failed to load configuration from flash. Resetting to default configlwapp_crypto_init: MIC Present and Parsed Successfully
Ethernet link changed to speed: 3, duplex 1
*Mar 1 00:00:26.647: %SSH-5-ENABLED: SSH 2.0 has been enabled
*Mar 1 00:00:27.403: %LINEPROTO-5-UPDOWN: Line protocol on Interface BVI1, changed state to up
*Mar 1 00:00:29.643: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0, changed state to up
no bridge-group 1 source-learning
%Default route without gateway, if not a point-to-point interface, may impact performance
*Mar 1 00:00:44.443: %LWAPP-3-CLIENTERRORLOG: Config load from flash failed. Initialising Cfg
transport input telnet
*Mar 1 00:01:01.267: %DHCP-6-ADDRESS_ASSIGN: Interface BVI1 assigned DHCP address 192.168.2.102, mask 255.255.255.0, hostname APf09e.631a.2480
Translating "CISCO-CAPWAP-CONTROLLER"...domain server (192.168.2.2)
*Mar 1 00:01:12.203: %CAPWAP-3-ERRORLOG: Did not get log server settings from DHCP.
*Mar 1 00:01:12.243: %CAPWAP-3-ERRORLOG: Could Not resolve CISCO-CAPWAP-CONTROLLER
04-08-2023 04:57 AM - edited 04-08-2023 05:01 AM
Hello @yalcinsoft
First of all you need to have connection to the AP in case you have not yet. You need to use a console cable for that.
Figure out which kind of software it is running. If the software is for autonomous mode, all you have to do is setup IP address and start building the configuration.
If the software is capwap, then you need to convert the AP to autonomous in order to config.
Use the command show version, if you see k9w7 is autonomous IOS if you see k9w8 is capwap.
However, if you need to convert you need software and the only way to download the software is from Cisco site which requires a Service contract.
04-08-2023 05:27 AM
Thank you very much for your answer, ap1g1-k9w7-tar.153-3.JK9.tar software was sent to me by cisco. I installed it with tft server, but the previous flash comes into play again
04-08-2023 08:17 AM
Can you share the show running-conf?
04-09-2023 03:47 AM
How did you "install" it?
Using the "archive download-sw" command?
If you did then the boot variable would have been automatically updated to use the new software on the next reboot.
If not then you did not install it - maybe you just copied the file to flash?
As others have said we need to see the actual details to understand what's happening. For starters:
- show ver
- show boot
- dir flash:
Attach full AP console log from power on as a text file.
04-09-2023 11:34 PM
tar -xtract tftp://192.168.1.10/ap1g1-k9w7-tar.153-3.JK9.tar flash:
this is how uploaded it
04-10-2023 03:04 AM
archive download-sw /overwrite /reload tftp://192.168.1.10/ap1g1-k9w7-tar.153-3.JK9.tar
04-10-2023 07:13 AM
ap: archive download-sw /overwrite /reload tftp://192.168.2.101/ap1g1-k9w7-tar.153-3.JK9.tar
Unknown cmd: archive
04-10-2023 09:03 AM
Ok the recovery image you're running doesn't support the archive command.
So you'll have to set the boot variable yourself.
It's a while since I worked in recovery image mode so not 100% on the commands but "show boot" (which I already ASKED you for above) will show the current boot variable setting. Normally to set it you would do:
conf t
boot system flash:/ap1g1-k9w7-mx.153-3.JK9/ap1g1-k9w7-mx.153-3.JK9
end
wr
As you seem to be trying to do it from ROMMON try this:
boot flash:/ap1g1-k9w7-mx.153-3.JK9/ap1g1-k9w7-mx.153-3.JK9
Then when IOS has booted and running then set the boot variable as per above.
If you had installed the IOS correctly before deleting the CAPWAP image you wouldn't have found yourself in this situation.
