Does anyone know with Boardcom acquiring VMWare, will Cisco still come out with the latest ESxi 7.0U3p, that contain the security fix for ESXi 7.0U3o?Thanks,
We purchased BE6K-M6 and VMW-VSP-STD-1A.I upgraded esxi to 8.0u2 and tried to apply the Vsphere 8 standard license, but an error window appeared asking me to apply the correct license. Is there any way? "Please provide a valid license key" From what...
After the issue waiting for Cisco provided drivers for RedHat 8.4 last year, I have the same issue with RedHat 8.8!I need driver for ucs-cxxx-drivers.4.x/Linux/Storage/Intel/Intel/LSI/C600Drivers are limited to RedHat 8.6 in the 4.2 series of drivers...
I'm unable to continue installing the Red Hat Enterprise Linux RHEL 8.4 operating system when the system is stuck on black screen after reboot. I am using vKVM from CIMC and booting from vKVM-Mapped vDVD. As part of troubleshooting, I came across thi...
Hi,In the same way that ACI, when integrated with Kubernetes can load balance outside requests to a particular exposed service, is it possible to manually configure ACI for basic L3/L4 load-balancing of regular of servers, announcing the /32 IP to th...
Only output from the first command is written to the file.How do I make it write output from all of the commands to the file?--- - name: run show commands hosts: nexus1 gather_facts: False tasks: - name: run show commands on nexus nxos...
Installing a single node ND to replicate what DCNM gave us. DCNM was used to monitor nexus switches. During ND cluster bring up I have Fabric Controller or Orchestrator options. Neither seem to fit monitoring of the environment. Which is the best opt...
Introduction We published the CLICommandCollector App and it was introduced in another document. Although the original app (Version 1.0) enables users to search CLI commands and collect command outputs from multiple ACI nodes in parallel, we had a f...
Hi experts, TLDR; How do I get the same information as shown in the screendumps below (of a UCS Chassis managed by UCS Manager) for our sparkling new UCS-X which can only be managed in Intersight? Specifically: How much power is being consumed/suppli...
I have a UCS C series server and its serial console is connected to a KVM switch. I SSH to the KVM switch to access UCS server console to try to get into CIMC utility during server bootup...But I typed CIMC password wrong multiple times and CIMC util...
Hello,I am working on some legacy gear which we do not have support for but are not ready to decommission. Two questions:Questions 1:Our FI's and blade are running on older firmware: 4.0(4d)Which does appears does not support 7.0.3, but is this irrel...
All, We have deployed many VMware vSphere / vSAN clusters over the years on UCS M5 and M6 hardware. In those cases, the Cisco HBAs were always on the VMware vSAN HCL. In the case of the UCS M7 series, the only HBA available is the UCSC-SAS-T-D, and...
After upgrading 7.0.1 to 8.0.1 I see this message: BIOS_FIRMWARE_TYPE_WARNING: legacy boot detected ..... Not sure if I can ignore it or if should I change BOOT to UEFI?
We have a few domains of 6536 FIs managed by Intersight. We want to move the FIs in one of our domains in the rack, which will cause a brief outage. I think that enabling fabric evacuation before shutting down an FI before moving it would be the wa...
Hello. I our Organization we have Cisco UCS C240 M5S servers with these sw installed: Firmware Version: 4.2(3i)ESXi Version: 7.0 Update 3i Currently the latest custom version of ESXi 7.0 available for download is 7.0 Update 3o (File name: "VMware-ESX...
