Kureli Sankar
Documentation
This configuration example is meant to be  interpreted with the aid of the official documentation from the  configuration guide located here: https://www.cisco.com/c/en/us/td/docs/routers/asr1000/configuration/guide/chassis/asrswcfg/Packet_Trace.html
Prerequisite
The ASR must be running minimum XE 3.10 code to be able to use this feature. Cisco IOS-XE Software Release 3.10S (15.3(3)S) and later has this capability.
Scenario One
Topology
Problem Description
Neither Employee 1 or Employee 2 is able to go load social media, streaming or gaming websites.
Steps
Using packet trace is very straightforward. All you need to do is:
1. Write the condition for which you would like to gather the data
2. Specify what packets to capture and how many
3. Start, run the test and stop the condition
4. Save the data
5. Cleanup
Commands to enable packet tracer
Conditions to capture data
Configure the interesting ACL
ip access-list extended debug
 10 permit ip host 192.168.101.2 any
 20 permit ip any host 192.168.101.2
Define the conditional debug/packet capture settings using the ACL from above:
debug platform condition ipv4 access-list debug both
[OR]
debug platform condition interface g0/0/0 ipv4 access-list debug both
These two lines are to troubleshoot firewall debug platform condition feature fw dataplane submode policy drop layer4 event level verbose debug platform condition feature fw dataplane submode all level verbose
These two lines are to troubleshoot Snort IPS
debug platform condition feature utd data sub all level verbose
debug platform condition feature service-divert dataplane submode all level verbose
Specify what packets to trace
debug platform packet-trace packet 256 circular fia-trace
debug platform packet-trace copy packet both l2
debug platform packet-trace drop
Start the condition
Start the capture, test the broken flow and then stop the capture.
Begin the packet capture:
debug platform condition start
Run the problematic traffic for a few seconds
Then stop the packet capture:
debug platform condition stop
See the packets captured
kusankar-1121X#show platform packet-trace summary | i DROP
0 Gi0/1/0 Gi0/0/0 DROP 189 (FirewallL7)
3 Gi0/1/0 Vl101 DROP 215 (UnconfiguredIpv4Fia)
4 Gi0/1/0 Vl101 DROP 215 (UnconfiguredIpv4Fia)
5 Gi0/1/0 Vl101 DROP 215 (UnconfiguredIpv4Fia)
6 Gi0/1/0 Gi0/0/0 DROP 189 (FirewallL7)
7 Gi0/1/0 Vl101 DROP 215 (UnconfiguredIpv4Fia)
8 Gi0/1/0 Vl101 DROP 215 (UnconfiguredIpv4Fia)
9 Gi0/1/0 Gi0/0/0 DROP 189 (FirewallL7)
10 Gi0/1/0 Vl101 DROP 215 (UnconfiguredIpv4Fia)
.... many more drops is seen...
Now let us try to see why packet 0 was dropped. The output is rather exhaustive but let us just scroll through and see what in the world is going on...
kusankar-1121X#shwo platform packet-trace packet 0
Packet: 0           CBUG ID: 62803
Summary
  Input     : GigabitEthernet0/1/0
  Output    : GigabitEthernet0/0/0
  State     : DROP 189 (FirewallL7)
  Timestamp
    Start   : 130004634161440 ns (06/04/2022 15:58:25.804986 UTC)
    Stop    : 130004634758360 ns (06/04/2022 15:58:25.805583 UTC)
Path Trace
  Feature: IPV4(Input)
    Output      : <unknown>
    Source      : 192.168.101.2
    Destination : 4.2.2.2
    Protocol    : 17 (UDP)
      SrcPort   : 55952
      DstPort   : 53  ================> DNS packet
  Feature: DEBUG_COND_INPUT_PKT
    Entry       : Input - 0x113f876c
    Output      : <unknown>
    Lapsed time : 600 ns
  Feature: L2_ES_INPUT_CONTROL_CHECK
    Entry       : Input - 0x114174c0
    Output      : <unknown>
    Lapsed time : 2640 ns
  Feature: L2_INPUT_SVI_LOOKUP
    Entry       : Input - 0x114174c8
    Input       : Vlan101
    Output      : <unknown>
    Lapsed time : 2960 ns
  Feature: CBUG_INPUT_FIA
    Entry       : Input - 0x113f8750
    Input       : Vlan101
    Output      : <unknown>
    Lapsed time : 280 ns
    Input       : Vlan101
    Output      : <unknown>
    Lapsed time : 320 ns
  Feature: IPV4_INPUT_DST_LOOKUP_ISSUE
    Entry       : Input - 0x114165fc
    Input       : Vlan101
    Output      : <unknown>
    Lapsed time : 1160 ns
  Feature: IPV4_INPUT_ARL_SANITY
    Entry       : Input - 0x113fa370
    Input       : Vlan101
    Output      : <unknown>
    Lapsed time : 2080 ns
  Feature: IPV4_INPUT_DST_LOOKUP_CONSUME
    Entry       : Input - 0x114165f8
    Input       : Vlan101
    Output      : <unknown>
    Lapsed time : 760 ns
  Feature: IPV4_INPUT_FOR_US_MARTIAN
    Entry       : Input - 0x11416604
    Input       : Vlan101
    Output      : <unknown>
    Lapsed time : 560 ns
  Feature: CFT
    API                   : cft_handle_pkt
    packet capabilities   : 0x0000018c
    input vrf_idx         : 0
    calling feature       : STILE
    direction             : Input
    triplet.vrf_idx       : 0
    triplet.network_start : 0x01003f92
    triplet.triplet_flags : 0x00000000
    triplet.counter       : 129
    cft_bucket_number     : 56692
    cft_l3_payload_size   : 38
    cft_pkt_ind_flags     : 0x00000203
    cft_pkt_ind_valid     : 0x0000dbff
    tuple.src_ip          : 192.168.101.2
    tuple.dst_ip          : 4.2.2.2
    tuple.src_port        : 55952
    tuple.dst_port        : 53
    tuple.vrfid           : 0
    tuple.l4_protocol     : UDP
    tuple.l3_protocol     : IPV4
    vrf_nums              : 1
    pkt_sb.num_flows      : 1
    pkt_sb.tuple_epoch    : 129
    returned cft_error    : 0
    returned fid          : 0x41d31dc0
  Feature: NBAR
    Packet number in flow: 1
    Classification state: Final
    Classification name: facebook
    Classification ID: 1454 [CANA-L7:518]
    Candidate classification sources:
      DPI: facebook [1454]
      L3-Cache: dns [72]
    Classification visibility name: facebook
    Classification visibility ID: 1454 [CANA-L7:518]
    Number of matched sub-classifications: 0
    Number of extracted fields: 0
    Is PA (split) packet: False
    TPH-MQC bitmask value: 0x8
    Source MAC address: 60:EB:69:51:3B:3A
    Destination MAC address: 00:B7:71:B6:65:F4
    Traffic Categories:
      ms-office-365/category: unset
      ms-office-365/service-area: unset
      sdavc/feed-id:   0
  Feature: IPV4_INPUT_STILE_LEGACY
    Entry       : Input - 0x113e40fc
    Input       : Vlan101
    Output      : <unknown>
    Lapsed time : 201720 ns
  Feature: DEBUG_COND_APPLICATION_IN
    Entry       : Input - 0x113f875c
    Input       : Vlan101
    Output      : <unknown>
    Lapsed time : 160 ns
  Feature: DEBUG_COND_APPLICATION_IN_CLR_TXT
    Entry       : Input - 0x113f8758
    Input       : Vlan101
    Output      : <unknown>
    Lapsed time : 200 ns
  Feature: IPV4_INPUT_VFR
    Entry       : Input - 0x11416b68
    Input       : Vlan101
    Output      : <unknown>
  Feature: IPV4_INPUT_LOOKUP_PROCESS
    Entry       : Input - 0x11416610
    Input       : Vlan101
    Lapsed time : 3120 ns
  Feature: IPV4_INPUT_IPOPTIONS_PROCESS
    Entry       : Input - 0x11416b28
    Input       : Vlan101
    Lapsed time : 360 ns
  Feature: IPV4_INPUT_GOTO_OUTPUT_FEATURE
    Entry       : Input - 0x113fa4d0
    Input       : Vlan101
    Lapsed time : 1880 ns
  Feature: CBUG_OUTPUT_FIA
    Entry       : Output - 0x113f8754
    Input       : Vlan101
    Lapsed time : 640 ns
  Feature: IPV4_OUTPUT_VFR
    Entry       : Output - 0x11416b74
    Input       : Vlan101
    Lapsed time : 1240 ns
  Feature: ALG PARSER
    Type   : DNS ALG
    Caller : NAT
    Action : OK
  Feature: ALG PARSER
    Type   : DNS ALG
    Caller : FW
    Action : NO L7 ACTIONS
  Feature: ZBFW
    Action  : Drop
    Reason  : AVC Policy drop:classify result
    Zone-pair name         : IN_OUT
    Class-map name         : INSIDE-TO-OUTSIDE-CLASS
    Policy    name         : INSIDE-TO-OUTSIDE-POLICY
    Input interface        : Vlan101
    Egress interface       : GigabitEthernet0/0/0
    Input  VPN ID          : 65535
    Output VPN ID          : 65535
    Input  VRF ID:Name     : 0:
    Output VRF ID:Name     : 0:
    AVC Classification ID  : 1454
    AVC Classification name: facebook
    UTD Context ID         : 0
  Feature: OUTPUT_FNF_DROP_SDWAN
    Entry       : Output - 0x113fd270
    Input       : Vlan101
    Lapsed time : 1080 ns
  Feature: OUTPUT_DROP
    Entry       : Output - 0x113f6c98
    Input       : Vlan101
  Feature: IPV4_OUTPUT_INSPECT
    Entry       : Output - 0x114155c0
    Input       : Vlan101
    Lapsed time : 358960 ns
Packet Copy In
  00b771b6 65f460eb 69513b3a 81000065 08004500 003a7594 00008011 9970c0a8
  65020402 0202da90 00350026 232f5aed 01000001 00000000 00000866 61636562
Packet Copy Out
  00b771b6 65f460eb 69513b3a 08004500 003a7594 00007f11 9a70c0a8 65020402
  0202da90 00350026 232f5aed 01000001 00000000 00000866 61636562 6f6f6b03
It is very clear that the AVC feature tied to Zone Based Firewall is the one that has caused the drop.  Upon looking at the config here is the section of the configuration that contributed to the drop.
zone-pair security IN_OUT source INSIDE destination OUTSIDE
 service-policy type inspect INSIDE-TO-OUTSIDE-POLICY
policy-map type inspect INSIDE-TO-OUTSIDE-POLICY
 class type inspect INSIDE-TO-OUTSIDE-CLASS
  inspect
  service-policy avc AVC-POLICY
 class class-default
  drop
class-map type inspect match-any INSIDE-TO-OUTSIDE-CLASS
 match protocol ftp
 match protocol http
 match protocol dns
 match protocol tcp
 match protocol udp
 match protocol icmp
policy-map type inspect avc AVC-POLICY
 class AVC-CLASS
  deny
 class class-default
  allow
class-map match-any AVC-CLASS
 match protocol yahoo
 match protocol amazon
 match protocol attribute category consumer-streaming
 match protocol attribute category gaming
 match protocol attribute category social-networking  ===> This is the cause of the problem
As you can see AVC has blocked social-networking application.
Save the data
Save the packet trace details to the flash:
show platform packet-trace summary | redirect bootflash:pkt_summary.txt
show platform packet-trace packet all | redirect bootflash:pkt_all.txt
Cleanup
Clear the packet trace output:
clear platform packet-trace statistics
clear platform packet-trace configuration
Cleanup:
clear platform condition all
conf t
no ip access-list extended debug
end
Scenario Two
Topology
Problem Description
Let us say that the PC at 14.36.109.13 is unable to telnet to 172.18.124.1.  How can one troubleshoot this problem using packet tracer tool what steps are needed to configure it and capture the data.
Steps
4. Save the data
5. Cleanup
The command will match any packets coming in interface g0/0/0
kusankar-ASR1002#debug platform condition interface g0/0/0 ingress
This command will match any IPv4 packets coming in interface g0/0/3 with a src or dst IP 172.18.124.1.
kusankar-ASR1002#debug platform condition interface g0/0/0 ipv4 14.36.109.13/32 ingress
This command will collect 128 packets that matches what we defined to trace in the above step.
kusankar-ASR1002#debug platform packet-trace packet 128
Start the condition
Start the packet collection with the following command.  Send the test traffic or try the telnet that fails then, stop the data collection.
kusankar-ASR1002#debug platform condition start
kusankar-ASR1002#debug platform condition stop
Once you find out what is being dropped we can focus on that particular packet to get more details.  In this case packet 17,20 and 28 are dropped due to firewall policy. Let us see if this is the telnet packet from 14.36.109.13 destined to 172.18.124.1.
kusankar-ASR1002#sh platform packet-trace sum | i DROP
Pkt   Input                 Output           State            Reason
17    Gi0/0/0          Gi0/0/3          DROP   183 (FirewallPolicy)
20    Gi0/0/0          Gi0/0/3          DROP   183 (FirewallPolicy)
28    Gi0/0/0          Gi0/0/3          DROP   183 (FirewallPolicy)
This command below will give more detail about packet no: 17. Clearly the feature ZBFW is dropping the packet.
Now let us look closely into packet 17 and understand the input interface, output interface, source IP, destination IP, protocol and port.
kusankar-ASR1002#sh platform packet-trace packet 17
Packet: 17          CBUG ID: 3019
Summary
  Input     : GigabitEthernet0/0/0
  Output    : GigabitEthernet0/0/3
  State     : DROP 183 (FirewallPolicy)
  Timestamp
    Start   : 15071588347061
    Stop    : 15071588471841
Path Trace
  Feature: IPV4
    Source      : 14.36.109.13
    Destination : 172.18.124.1
    Protocol    : 6 (TCP)
      SrcPort : 52273
      DstPort : 23 ===> This is the telnet traffic that is being dropped
  Feature: ZBFW
    Action  : Drop
    Reason  : Policy drop due to classification result
Now examining the ZBF config closely the relevant config is as follows: Clearly tcp traffic is not allowed from the inside host 14.36.109.13
interface GigabitEthernet0/0/0
ip address 14.36.109.114 255.255.0.0
ip nat inside
zone-member security INSIDE
negotiation auto
end
interface GigabitEthernet0/0/3
ip address 172.18.124.41 255.255.255.0
ip nat outside
zone-member security OUTSIDE
negotiation auto
end
zone-pair security INSIDE-OUTSIDE source INSIDE destination OUTSIDE
service-policy type inspect INSIDE-pm
zone-pair security OUTSIDE-INSIDE source OUTSIDE destination INSIDE
service-policy type inspect OUTSIDE-pm
policy-map type inspect INSIDE-pm
class type inspect in-out-class
  inspect
class class-default
class-map type inspect match-any in-out-class
match protocol udp
match protocol icmp
match protocol ftp
<====> Only udp icmp and ftp traffic is allowed.  No tcp traffic is allowed and that is the reason telnet is breaking.
end
Cleanup
Cleanup:
