"Vlans in spanning tree forwarding state and not pruned" empty on Nexus 5600 switch?
michaelbs
Dear all,
I've connected one Cisco Nexux 5672 switch to our Catalyst 3750 core using a trunk link on both sides which allows all vlans and has vlan 1 configured as native vlan.
When issuing the "show interface trunk" command on the Nexus device, the line "Vlans in spanning tree forwarding state and not pruned" does not show any vlans where I would expect VLAN 1:
sw-rz-5672-01# show interface trunk
Port          Native  Status        Port
              Vlan                  Channel
Eth1/1        1       trunking      --
Port          Vlans Allowed on Trunk
Eth1/1        1-4094
Port          Vlans Err-disabled on Trunk
Eth1/1        none
Port          STP Forwarding
Eth1/1        1
Port          Vlans in spanning tree forwarding state and not pruned
Port          Vlans Forwarding on FabricPath
Eth1/1        None
When issuing this on Catalyst switches, the line always shows the VLANs allowed on the trunk. We are not using VTP in our Network. Does it indicate a problem that the Nexus Switch Shows no information here? The Nexus Switch has another active Access port in VLAN 1!
Michael
BenBen
Hi Michael,
I encountered the same issue. Did you finally find out the reason? In my case the, even the vlan is missing, the communication is OK.
interface port-channel100
switchport
switchport mode trunk
switchport trunk native vlan 999
switchport trunk allowed vlan 100,106,140
vpc 100
Eth1/19 none
Eth1/20 192
Eth1/21 none
Eth1/22 100-102,106,108,115,140-141
Eth1/23 100-102,106,108,115,140-141
Eth1/24 100-102,106,108,115,140-141
Eth1/25 none
Po1 100-102,106,108,115,140-141
Po2 192
Po3 100-102,106,108,115,140-141
Po100 none
Thanks.
-Frank
Hi Frank,
no I still haven't found the reason yet but I haven't looked any further tbh.
Best Regards,
Michael
Hi Michael,
Thank you for replying back. I rebooted the Nexus VDC, now the vlans showing up as "Vlans in spanning tree forwarding state and not pruned". I didn't open TAC case since I have other things to do at this moment.
Thanks.
