Hello,I was wondering, whether it is possible instead of creating three separate tasks, one processing one element of an array, to actually loop through an array. Example: vars: ansible_become_pass: "{{ vault_sudo_password }}" ansible_pyt...
Proxmox is a free and open-source virtualization management platform that simplifies the deployment and management of virtual machines (VMs) and containers. This comprehensive solution utilizes the Linux operating system, KVM hypervisor, and LXC cont...
The following is inspired by Chapter 9 'Mindfulness at Work: Interviews, Meetings and Presentations' from the book Mindfulness, by Gill Hasson. “How’s work?” For many, the answer is often, “Stressful. My manager calls meeting after meeting withou...
Are you searching for answers to any of these questions? What are the key pillars of AI readiness? How do the organizations in the Retail sector compare in terms of AI readiness? What are the primary skills that organizations are lacking ...
In conversations about artificial intelligence (AI) and machine learning (ML), the terms ML model and ML algorithm are often used interchangeably. However, they refer to different concepts in the context of machine learning. ML Algorithm A...
I wanted to know if there was a way for pyats to only look at specific vrf rather than all BGP tables in on a router. current; pyats learn bgp --testbed-file wan_router.yaml --output current wanted; pyats learn bgp --vrf xxx --testbed-file wan_ro...
I have been reading up on pyats and would like to know how to create a topology file as a dict like {'hostname':'ip"} instead of the yaml file shown in the examples. I am trying to connect to multiples devices to run specific show commands and store...
Hi All, This is my first time writing an ansible playbook. Please can anyone help me with the following error. I'm just trying to run a basic show ver to a cisco ios switch. ansible-playbook new.yml PLAY [cisco] *************************************...
I am building a script to create WLAN profile report querying with API. I know 9800 uses policy tag instead of AP groups, I couldn't fetch list of SSID in 9800 controller with policy tag details from any of the API in prime, not sure what I am miss...
I had been trying out POST request on the Cisco IOS-XE always on sandbox, in order to create a new interface using RESTCONF AP. I am getting a 403 error code. Quite a while back, I was able to successfully create a POST request using YANG but is no ...
I would like to be able to have DNA run commands using command runner with an issues pops up. As an example if DNA sees " Netwrok Device Interface Connectivity - EIGRP Adjacency Failure " I would like it to run some show commands and email me the...
I'm attempting the Cisco Umbrella Learning Module ( Getting Started with an Umbrella DevNet Sandbox - Cisco DevNet Learning Center ). I received an email stating my sandbox lab was ready. The email has Umbrella login information but, there is no log...
Like several posts I've read in the Community, I have this problem: raise HTTPError(http_error_msg, response=self) requests.exceptions.HTTPError: 403 Client Error: Forbidden for url: https://api.cisco.com/supporttools/eox/rest/5/EOXByProductID/1/WS-...
