Telephony on cisco 4000 ISR
samuelogalli
Hi Team
Since CCP was retired if I am to implement Telephony on the ISR 4000 series is there a replacement or will i have to do all configuration via CLI? thanks
Telephony on Cisco Routers with SIP phones is consistently CLI-based. The GUI for the CME (router-based IPT) was exclusively available with SCCP phones.
The CCP served as the GUI for router configurations but was not utilized for CME configurations. To my knowledge, the GUI for CME was different.
Additionally, the ISR4000 series has announced its End of Life (EOL). It is advisable to consider the 8200 or 8300 series routers for your CME requirements
Response Signature
Response Signature
Thank you soo much this is very helpful
