취소
다음에 대한 결과 표시
다음에 대한 검색
다음을 의미합니까?
VIEWS
답글
IE3400 SFP compatibility question
I’m going to use the IE-3400. The compatible SFPs are listed here:
https://www.cisco.com/c/en/us/products/collateral/switches/industrial-ethernet-3000-series-switches/data_sheet_c78-440930.pdf?utm_source
The same goes for Cisco’s Optics Compatibility Matrix
However, only Cisco SFPs are shown—can I use third-party SFPs? Will they work properly?
2 응답 2
Cisco does not test third-party optics in its products. You can use them in Cisco products, but if you run into an issue that does not occur with Cisco-branded optics, you must contact the third-party vendor for support. TAC will not troubleshoot issues with third-party optics in scenarios where Cisco-branded optics function properly.
Disclaimers: I am long in CSCO. Bad answers are my own fault as they are not AI generated.
Leo Laohoo
Our switches, including IE3k and IE4k, all use 3rd party optics.
빠른 링크
