cancelar
Mostrando los resultados de
Buscar en lugar de
Quiere decir:
Visitas
ÚTIL
Respuestas
Cisco 2811 PVDM2 FXO y FXS
Buenas!
Tengo una pequeña duda referente a los PVDM2 y los canales
Con un PVDM2-16:
C2811#sh diag | Begin PVDM
        PVDM Slot 0:
        16-channel (G.711) Voice/Fax PVDMII DSP SIMM PVDM daughter card
         Product (FRU) Number     : PVDM2-16
Cuantos canales analogicos puedo poner en el router? Hablo de tarjetas FXO y FXS
Ahora tiene una VIC2-2FXO y necesito saber si podria poner una VIC2-2FXS con un modulo PVDM2-16
En este otro hilo: https://supportforums.cisco.com/document/123126/cisco-pvdm2-and-pvdm3-dsp-creditmips-allocation
vi esto:
PVDM2-16 - Signaling
- 16 calls for G711 (flex mode only)
- 8 calls for the other medium complexity codecs and g711 in medium complexity mode
- 6 calls per DSP for high complexity codecs
- 240 MIPS in flex mode
- G711 uses 15 MIPS per call (240 MIPS / 15 MIPS per call = 16 calls per DSP)
- The codecs under the High Complexity category use 40 MIPS per call.
- The codecs under the medium complexity category use 30 MIPS per call.
- The D channel doesn't count for resources
- Each FXO or FXS port takes 1 channel
- Each Pri slots also count for 1 channel
Pero no me queda claro.
No soy capaz de ver los canales sin asignar con comandos:
C2811#show voice dsp group all
DSP groups on slot 0:
dsp 1:
  State: UP, firmware: 24.3.6
  Max signal/voice channel: 16/16
  Max credits: 240
  num_of_sig_chnls_allocated: 2
  Transcoding channels allocated: 0
  Group: FLEX_GROUP_VOICE, complexity: FLEX
    Shared credits: 240, reserved credits: 0
    Signaling channels allocated: 2 <--------------------------------- Canales ASIGNADOS
    Voice channels allocated: 0
    Credits used: 0
C2811#show voice dsp detailed
*DSP SIGNALING CHANNELS*
DSP   DSP                 DSPWARE CURR  BOOT                         PAK   TX/RX
TYPE  NUM CH CODEC        VERSION STATE STATE   RST AI VOICEPORT TS ABRT PACK COUNT
C5510 001 01 {flex}        24.3.6 alloc idle      0  0 0/2/0     02    0         36/0
C5510 001 02 {flex}        24.3.6 alloc idle      0  0 0/2/1     06    0         36/0
------------------------END OF FLEX VOICE CARD 0 ----------------------------
Un saludo
3 RESPUESTAS 3
asigachev
El uso de DSPs depende de codec. Creo que lo importante no son los canales que te muestra el comando "show voice DSP" sino la maxima cantidad de llamadas simultaneas. G711 es el más sencillo, con el va a ser 16 llamadas (FXO-VoIP o FXS-VoIP) simultaneas usando PVDM2-16. Otros codecs son más complejos, así que menos llamadas serán posibles.
Lo mejor es consultar DSP Calculator http://www.cisco.com/web/applicat/dsprecal/dsp_calc.html te va a calcular cuantos DSPs y que modulos PVDM necesitarás para ciertas tarjetas de FXS/FXO/E1 y ciertos codecs.
Los VIC2-FXO y VIC2-FXS seguro que van a funcionar juntos con G.711.
Vale, por lo que veo en la calculadora, tendira canales libres para poner incluso mas bocas fxo o fxs hasta completar un maximo de 16 canales. Podria poner 4 tarjetas vic2-4fxo que van a funcionar las 4 tarjetas con un modulo pvdm2-16 no? siempre y cuando el codec sea el g711 no?
Entonces podria tener 16 telefonos IP haciendo 16 llamadas a la PSTN no (con 4 tarjetas vic2-4fxo)? (no es un escenario real, solo un ejemplo)
alaricthorne
¡Ah, lo que recuerdo después de leer este hilo! ¡Trabajamos con el enrutador Cisco 2811 y un par de tarjetas VIC2-2FXO/FXS! ¡Qué momento tan maravilloso! Estábamos trabajando en un sitio de calculadoras (que luego cerró) similar a calculadoradediasfechasanos.com para calcular días, semanas y años. A menudo nos quedábamos atascados con el problema de las limitaciones de recursos del DSP. ¡Qué momento tan maravilloso!
