取消
显示结果
搜索替代
您的意思是:
查看次数
43
有帮助
6
评论
haifzhan
本次【专家面对面】在线问答活动,是与2月10日上午十点开始的 第八期 CSC 公开课 活动同步举办的。
活动内容:
我们的技术支持专家 Haifeng Zhang会在此回答您关于”Wireless 产品故障诊断及最佳实践“的相关问题。
活动时间:2015年02月10日-13日
参与方式:在本主题下跟帖提出您的问题,我们的专家会予以解答。
专家介绍:Haifeng Zhang
职称:Technical Support Expert
认证:CCIE RS,Wireless
客户领域:FSI,OTT,Enterprise,Commercial
如果专家的解答对您有帮助的话,记得为本帖或者专家答复进行星级评分哦。
6 评论
jipengfei
重新学习了
haifzhan
本来还有些demo环节 ,但是因为篇幅和时间原因没有来及做。
希望对大家有些帮助, 有问题请在CSC 论坛提交。我们会尽力帮助找到答案。谢谢!
donglei888999
Hi Haifeng,
怎么没有早上培训的视频呢?
wanghaitao
Xin Lei
haifzhan,能讲解下AP如何注册到WLC的过程吗?:lol
haifzhan
https://supportforums.cisco.com/document/11936146/joining-process-cisco-access-point
Steps
(Every device on a network needs to have an ip address, and a LAP is no exception)
1. AP needs ip address in the said order
(1. it has on its own already 2.static 3.dhcp )
(After getting ip address, to join to the WLC, the LAP needs to know what all are those WLCs to which it can join)
2. AP needs to discover WLC via either of the two mechanisms in the said order
[ 1.lyr2 2.lyr3 (makes list of discovered WLCs via 5 mandatory steps) ] <-- Hunting for the WLC
(Once the LAP has list of all those WLCs to which it can join, the LAP can decide the WLC , it will like to join.
The logic for that decision can either be customized by the user or can be left to the default-logic).
The order of execution of logic is preferred with the customized logic first, else with default-logic.
3. AP needs to select one of the discovered WLCs.
4. AP needs to join the selected WLC.
入门指南
使用上面的搜索栏输入关键字、短语或问题,搜索问题的答案。
