楼主参考一下
Cisco ASA 5506-X Series Quick Start Guide
https://www.cisco.com/c/en/us/td/docs/security/asa/quick_start/5506X/5506x-quick-start.html#id_66976Enable the Wireless Access Point (ASA 5506W-X)
The ASA 5506W-X wireless access point is disabled by default. Connect to the access point GUI so you can enable the wireless radios and configure the SSID and security settings.
Before you begin
This procedure requires you to use the default configuration.
Procedure
Step 1
On the computer connected to the ASA inside network, launch a web browser.
Step 2
In the Address field, enter
http://192.168.10.2. You are prompted for the username and password.
Note
If you are unable to reach the access point, and the ASA has the default configuration and other networking issues are not found, then you may want to restore the access point default configuration. You must access the ASA CLI (connect to the ASA console port, or configure Telnet or SSH access using ASDM). From the ASA CLI, enter hw-module module wlan recover configuration . If you need to troubleshoot the access point further, connect to the access point CLI using the session wlan console command.
Step 3
Enter the username cisco and the password Cisco. The access point GUI appears.
Step 4
On the left, click Easy Setup > Network Configuration.
Step 5
In the Radio Configuration area, for each of the Radio 2.4GHz and Radio 5GHz sections, set the following parameters and click Apply for each section:
SSID
Broadcast SSID in Beacon
Universal Admin Mode: Disable
Security (of your choosing)
Step 6
On the left, click Summary, and then on the main page under Network Interfaces, click the hotlink for the 2.4 GHz radio.
Step 7
Click the Settings tab.
Step 8
For the Enable Radio setting, click the Enable radio button, and then click Apply at the bottom of the page.
Step 9
Repeat for the 5 GHz radio.
Step 10
For more information, see the following manuals:
For details about using the wireless LAN controller, see the Cisco Wireless LAN Controller Software documentation.
For details about the wireless access point hardware and software, see the Cisco Aironet 700 Series documentation.
Rockyw | If it solves your problem, please mark as answer. Thanks !
