取消
显示结果
搜索替代
您的意思是:
查看次数
有帮助
回复
AnyConnect was not able to establish a connection to the gateway.
mychen111
Anyconnect在电脑上连接时,始终显示:AnyConnect was not able to establish a connection to the specified secure gateway. Please try connecting again.
用手机连接时正常,表明不是账号的问题,更换电脑连接网络,还是显示上述问题。
电脑版本:Mac OS catalina 10.15.7
Cisco版本:4.10.07061
log:
下午2:44:50 Ready to connect.
下午2:44:52 Contacting vpn.xxxx.xx.
下午2:45:05 User credentials entered.
下午2:45:08 Establishing VPN session...
下午2:48:18 Connection attempt has failed.
之前是正常的,突然就上不去了,已经好几天上不去网了,急求大神解决问题
2 条回复2
  • This points to firewall or other security software not allowing this connection. Try disabling the security software ...
看是否有什么安全软件影响,可以关闭试试。
Rps-Cheers | If it solves your problem, please mark as answer. Thanks !
谢谢回答,但是没有任何安全软件,电脑都没有装安全管家什么的,就是某一天突然就连不上去了,之前都好好的
快捷链接
