在一些小企业,PPPOE 拨号上网是最常见的上网方式,ASA 作为安全网关出口,配置PPPoE 也是非常常见的配置之一,这里我总结一下ASA 8.3前后版本 的PPPoE 配置:
新版本pppoe配置
hostname(config)# vpdn group group_name request dialout pppoe
hostname(config)# vpdn group group_name ppp authentication {chap | mschap | pap}
hostname(config)# vpdn group group_name localname username
hostname(config)# vpdn username username password password [store-local]
Step 1
Enable the PPPoE client by entering the following command from interface configuration mode:
hostname(config-if)# ip address pppoe [setroute]
hostname(config)# interface gigabitethernet 0/0
Step 2
Specify a VPDN group for the PPPoE client to use with the following command from interface configuration mode (optional):
hostname(config-if)# pppoe client vpdn group grpname
8.25 前版本的PPPoE 配置:
interface Vlan1 //默认VLAN1 里的接口都是内网接口
nameif inside
security-level 100
interface Vlan2 //在这里VLAN2 为外网接口
nameif outside
security-level 0
ip address pppoe setroute ////启动拨号,如果没有配默认路由,则必须加上
mtu outside 1400
global (outside) 1 interface //NAT地址转换
nat (inside) 1 0.0.0.0 0.0.0.0
interface Vlan2
nameif outside
security-level 0
pppoe client vpdn group adsl
vpdn enable
vpdn group adsl request dialout pppoe
vpdn group adsl localname fsLAN58236333
vpdn group adsl ppp authentication pap
vpdn username fsLAN58236333 password *****
dhcpd dns 202.96.128.166 202.96.128.86
dhcpd address 192.168.20.50-192.168.20.200 inside
dhcpd dns 221.228.255.1
dhcpd enable inside
