取消
显示结果
搜索替代
您的意思是:
查看次数
有帮助
回复
新ap无法上线怎么办
pengfeipei5705
CAPWAP State: DTLS Teardown
[*12/17/2019 13:04:16.4069] Dropping dtls packet since session is not established. Peer 10.27.100.251-5246, Local 10.27.100.103-5256, conn (nil)
[*12/17/2019 13:04:21.2036]
[*12/17/2019 13:04:21.2037] CAPWAP State: Discovery
[*12/17/2019 13:04:21.2060] Discovery Request sent to 255.255.255.255, discovery type UNKNOWN(0)
[*12/17/2019 13:04:21.2070] Discovery Response from 10.27.100.251
[*12/17/2019 13:04:30.0000] can't find the Ip from discoveryRequest array
[*12/17/2019 13:04:30.0001]
[*12/17/2019 13:04:30.0001] CAPWAP State: DTLS Setup
[*12/17/2019 13:04:30.3902]
[*12/17/2019 13:04:30.3902] CAPWAP State: Join
[*12/17/2019 13:04:30.3916] Sending Join request to 10.27.100.251 through port 5256
[*12/17/2019 13:04:30.3947] Join Response from 10.27.100.251
[*12/17/2019 13:04:30.4748] HW CAPWAP tunnel is ADDED
[*12/17/2019 13:04:30.4897]
[*12/17/2019 13:04:30.4897] CAPWAP State: Image Data
[*12/17/2019 13:04:30.5268] do PRECHECK, part1 is active part
[*12/17/2019 13:04:30.5759] UBIFS error (pid 19589): ubifs_mount: cannot open "/dev/ubivol/part2", error -22
[*12/17/2019 13:04:30.5919] libubi: error!: cannot get information about "/dev/ubivol/part2"
[*12/17/2019 13:04:30.5920] error 2 (No such file or directory)
[*12/17/2019 13:04:30.5920] ubiupdatevol: error!: error while probing "/dev/ubivol/part2"
[*12/17/2019 13:04:30.5951] UBIFS error (pid 19594): ubifs_mount: cannot open "/dev/ubivol/part2", error -22
[*12/17/2019 13:04:30.5955] Error: UBI volume /dev/ubivol/part2 could not be formated as UBIFS
[*12/17/2019 13:04:30.5958] Pre-conditions for image download not met! Cannot download image.
[*12/17/2019 13:04:30.5958] Failed to get controller image details.
[*12/17/2019 13:04:30.5958] CAPWAP SM handler: Failed to process message type 4 state 10.
[*12/17/2019 13:04:30.5959] Failed to handle capwap control message from controller - status 2
[*12/17/2019 13:04:30.5959] Failed to process encrypted capwap packet 0x2475000 from 10.27.100.251
[*12/17/2019 13:04:30.5959] Failed to send message to CAPWAP state machine, msgId 0
[*12/17/2019 13:04:30.5959] Failed to send capwap message 0 to the state machine. Packet already freed.
[*12/17/2019 13:04:30.5959] IPv4 wtpProcessPacketFromSocket returned 2
新ap,其他都没问题,就这个有问题,
[*12/17/2019 13:04:34.7744] Discarding msg CAPWAP_WTP_EVENT_REQUEST(type 9) in CAPWAP state: Image Data(10)
4 条回复4
请问这个AP是室外AP吗?例如AP1562,AP1572什么的。
如果是话,可以尝试根据如下链接操作:
-添加AP MAC地址
-修改AP的mode未local
(如果一种没有解决,建议另一种方式也尝试一下)
https://www.cnblogs.com/MomentsLee/p/9992991.html
如果不是室外AP的话,是不是8系列的AP?是否版本不支持:
-AP型号
-WLC型号
-可以在WLC采集一下如下信息:
show sysinfo
show time
show msglog
Rps-Cheers | If it solves your problem, please mark as answer. Thanks !
HaifengLi
建议开个TAC Case
Rockyw
楼主可以参考一下下面的文档
Solved: Access Point not joing with WLC
https://community.cisco.com/t5/wireless-and-mobility/access-point-not-joing-with-wlc/td-p/3073993
Rockyw | If it solves your problem, please mark as answer. Thanks !
18653465190
我原来碰到过类似情况,因为瘦AP自带胖AP的系统,在自己启动时,加载了胖AP的BOOT文件,
这个情况,楼主可以参考一下。
快捷链接
