取消
显示结果
搜索替代
您的意思是:
查看次数
有帮助
回复
无线控制器5520风扇问题
nightcauld11252
在控制器界面看风扇状态是正常的,但是时不时的就会有很响的声音,持续时间也不长。控制器在机房里面,温度正常,大佬们,这可能有哪些原因啊?属于正常情况还是异常情况啊?
4 条回复4
zhengwei272
正常情况 show出来的或者web界面看到的数据正常就没事
LxL9905
目前风扇转着,属正常,还没形成故障,它应该是有2个风扇,可以看下是哪个发出异响,有可能是转着不流畅导致
将来的你,
   将要感谢现在努力拼搏奋斗的自己!
你好,我认为这个可能是存在已知的bug,5520和8540可能都会出现,如下列举两个bug:这都和FAN异响有关系,建议升级到suggested版本。
DN1/DN2: Need closed loop 5520/8540-Cavium fan control
CSCuu86587
Description
Symptom:
Excessively loud fan noise complaints
Conditions:
Worst case thermal condition is observed with low fan speeds while DN Intel CPU is idled or under light loading while the Cavium CPU is under 100% load. Fans adjust to Intel thermal conditions but do not account for Cavium card conditions
Cavium die temperatures increase at higher altitudes, but fan speeds do not track accordingly
Workaround:
Further Problem Description:
Anomalous Fan Speed/Temp reading for 8540
CSCux93468
Description
Symptom:
Customer 8540 on 8.2.100.0, reports high speed noise, even when power profile is low temp
Fanloop stats shows negative max temp, and extremely high avg temp reading
Conditions:
8540 controller
The reading of test command, shows invalid temperature range:
Cisco Controller) >test imm chassis fanloop-stats
Fan Policy : Low power
Max Temp read : -1 <---here
Min Temp read : 25
Avg Temp read : 270002 <--- here
Poll Durtaion : 3
Workaround:
possibly a reboot
Rps-Cheers | If it solves your problem, please mark as answer. Thanks !
Rockyw
将外壳打开看看出现很响声音时,风扇有没有异常情况。
Rockyw | If it solves your problem, please mark as answer. Thanks !
快捷链接
