取消
显示结果
搜索替代
您的意思是:
查看次数
有帮助
24
回复
求wlc2504升级失败的解决方法?
sxczwxf
GUI下由7.4.1升级到8.0.121 文件名为: AIR-CT2500-K9-8-0-121-0.aes,升级完毕后,保存重启动后,无法进入登陆到GUI和CLI界面,用超级终端登陆后,看到系统启动停留在launching...
之后尝试1-4选项方法,均不能启动
最后选择第6项“manually update images"
提示:do you want to update RTOS? y
    do you want to update primary or secondary image(p/s) P
Enter filename for RTOS update: AIR-CT2500-K9-1-9-0-0-FUS.aes
RTOS update Done
Enter filename for FP update :AIR-CT2500-K9-1-9-0-0-FUS.aes
FP update Done
Do you want to update an AP image(Y/n)? N
重新启动后:
   loading primary image(Bad image type)
之后一直停留在 launching....
   GUI和CLI仍无法登陆
问题:上面提示do you wantto update RTOS,这个RTOS是那个文件?
上面提示enter filename for FP update,这个FP是那个文件?
哪里可以下载到以上正确的文件,或还有其他的解决方案?
24 条回复24
大神,AS_5500_RTOS-7.0.116.0和AS_5500_cavium_main-7.0.116.0  这两个文件可以发我一份吗,我的机器被我搞坏了,谢谢495551791@qq.com
AS_5500_RTOS-7.0.116.0和AS_5500_cavium_main-7.0.116.0  帮帮忙,可以发我这两文件吗
Hello,可以分享给我这两个包吗?873420575@qq.com,谢谢了
stoneyeye
13817778909 发表于 2016-4-11 22:53 back.gif
13817778909,我给你RTOS软件和升级方法。
你好,大神,我想知道RTOS如何升级,请大神发邮箱cisco_zpl@126.com
chonglin
The two files you need can be found in below links:
AS_5500_RTOS-7.0.116.0 = load for 'RTOS'
AS_5500_cavium_main-7.0.116.0 = load for ‘FP'
The provided RTOS images are compatible with 2504, 5508, WiSM2.
I also list the procedure below for your reference:
1. Copy the both RTOS files to a reachable TFTP server.
2. Reset your controller.
3. Keep pressing ESC until you're at the Bootloader Menu.
4. From the Bootloader menu, choose 6 (Manually update images).
Proof of life:
Boot Loader Menu
1. Run primary image (Image not found) - Active
2. Run backup image (Image not found)
3. Change active boot image
4. Clear configuration
5. Format FLASH Drive
6. Manually update images
Enter selection: 6
Launching...
Launching images...
init started: BusyBox v1.6.0 (2009-02-03 04:56:32 EST) multi-call binary
Mount failed for selinuxfs on /selinux: No such file or directory
starting pid 655, tty '': '/etc/init.d/rcS'
Use DHCP for ip configuration (Y/n)? n
5. Enter your controller Management IP address, Subnet Mask, Gateway, and
TFTP server IP address.
Enter switch IP address: 192.168.1.100
Enter switch netmask: 255.255.255.0
Enter switch gateway: 192.168.1.1
Enter TFTP server IP address: 192.168.5.157
You have entered:
IP Address : 192.168.1.100
Netmask : 255.255.255.0
Gateway : 192.168.1.1
Server Ip Addr : 192.168.5.157
Is this correct(y/N)? y
!!! WARNING updating using .aes or unapproved files will disable this unit
Do you want to update RTOS (y/N)? y
Do you want to update Primary Or Secondary Image (P/s)?
6. When it prompts you to enter a filename for RTOS update, enter the name
"AS_5500_RTOS-7.0.116.0"
Enter filename for RTOS update: AS_5500_RTOS-7.0.116.0 RTOS update Done
7. When it prompts you to enter a filename for RTOS update, enter the name
"AS_5500_cavium_main-7.0.116.0"
Enter filename for FP update: AS_5500_cavium_main-7.0.116.0
FP update Done
Do you want to update an AP image (y/N)?
AP Images Not Updated
Done. Restarting...
Restarting system.
Then you're done, all you need to do is wait for the upgrade to be finished.
Please feel free to let me know if you face any issues in the upgrade.
zhiyexu439071
能给我发个RTOS跟FP 吗 7839488@qq.com
zhiyexu439071
给我发个wlc2500 的 RTOS跟FP 吗 7839488@qq.com
shjuefan1
可以给一份2504的吗?18648614181@163.com
mis0000016
能给一份吗,谢谢!etiger_xu@163.com
cisco_servier
我用论坛上提供的AS_5500_cavium_main-7.0.250.0和AS_5500_RTOS-7.0.250.0把系统恢复到7.0.250后,还是停留在lunching这里不会再有任何进展,请问怎么办???
快捷链接
