取消
显示结果
搜索替代
您的意思是:
查看次数
有帮助
回复
AIR-CAP3702E-H-K9 一段时间自动重启
729723791
以下为log
SSC-AP10#show logging
Syslog logging: enabled (0 messages dropped, 8 messages rate-limited, 0 flushes, 0 overruns, xml disabled, filtering disabled)
No Active Message Discriminator.
No Inactive Message Discriminator.
Console logging: level debugging, 500 messages logged, xml disabled,
filtering disabled
Monitor logging: level debugging, 0 messages logged, xml disabled,
filtering disabled
Buffer logging: level debugging, 508 messages logged, xml disabled,
filtering disabled
Exception Logging: size (4096 bytes)
Count and timestamp logging messages: disabled
Persistent logging: disabled
Trap logging: level emergencies, 20 message lines logged
Logging to 255.255.255.255 (udp port 514, audit disabled,
link down),
0 message lines logged,
0 message lines rate-limited,
0 message lines dropped-by-MD,
xml disabled, sequence number disabled
filtering disabled
Logging Source-Interface: VRF Name:
Log Buffer (1048576 bytes):
*Mar 1 00:00:25.639: %SOAP_FIPS-2-SELF_TEST_IOS_SUCCESS: IOS crypto FIPS self test passed (15)
*Mar 1 00:00:26.099: Registering HW DTLS
*Mar 1 00:00:29.275: %LINK-6-UPDOWN: Interface GigabitEthernet0, changed state to up
*Mar 1 00:00:31.779: %SOAP_FIPS-2-SELF_TEST_RAD_SUCCESS: RADIO crypto FIPS self test passed on interface Dot11Radio 0 (4)
*Mar 1 00:00:31.895: loading Power Tables from ram:/R2.bin. Class = E
*Mar 1 00:00:31.895: record size of 3ss: 1168 read_ptr: 5E13E4E
*Mar 1 00:00:37.091: %SOAP_FIPS-2-SELF_TEST_RAD_SUCCESS: RADIO crypto FIPS self test passed on interface Dot11Radio 1 (4)
*Mar 1 00:00:37.139: loading Power Tables from ram:/R5.bin. Class = H
*Mar 1 00:00:37.171: record size of vht: 2904 read_ptr: 5E13E4E
APAVC Registering AVC licences on the AP to make sure we enable advanced PP
*Mar 1 00:00:38.619: SCHED: Ethernet Bridge Process: install watched boolean System Initialized(5DFC088), os:1 ah:0APAVC Protocol list already initialized.
*Mar 1 00:00:38.619: Start STILE Activation
APAVC: Succeeded to activate all the STILE protocols.
APAVC: Registering with CFT
*Mar 1 00:00:38.867: APAVC: CFT registration of delete callback succeeded
APAVC: Reattaching Original Buffer pool for system use
capwap_read_version_info: Info file flash:/ap3g2-k9w8-mx.153-3.JF/info not find
*Mar 1 00:00:40.571: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0, changed state to down
*Mar 1 00:00:41.567: %DOT11-5-EXPECTED_RADIO_RESET: Restarting Radio interface Dot11Radio0 due to the reason code 39
*Mar 1 00:00:41.567: %DOT11-5-EXPECTED_RADIO_RESET: Restarting Radio interface Dot11Radio1 due to the reason code 39
*Mar 1 00:00:41.575: %SYS-5-RESTART: System restarted --
Cisco IOS Software, C3700 Software (AP3G2-K9W8-M), Version 15.3(3)JF9, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2018 by Cisco Systems, Inc.
Compiled Sun 25-Nov-18 00:39 by prod_rel_team
*Mar 1 00:00:41.575: %SNMP-5-COLDSTART: SNMP agent on host SSC-AP10 is undergoing a cold start
*Mar 1 00:00:42.051: SCHED: Ethernet Bridge Process: remove watched boolean System Initialized(5DFC088)
*Mar 1 00:00:42.051: SCHED: Ethernet Bridge Process: install watched queue Soap BVI input queue(CD82E90), os:0 ah:0
*Mar 1 00:00:43.299: %LINEPROTO-5-UPDOWN: Line protocol on Interface BVI1, changed state to up
*Mar 1 00:00:44.203: %DOT11-5-EXPECTED_RADIO_RESET: Restarting Radio interface Dot11Radio0 due to the reason code 10
*Mar 1 00:00:44.203: %DOT11-5-EXPECTED_RADIO_RESET: Restarting Radio interface Dot11Radio1 due to the reason code 10
*Mar 1 00:00:44.203: %CDP_PD-4-POWER_OK: Full power - HIGH_POWER inline power source
*Mar 1 00:00:49.727: %SOAP_FIPS-2-SELF_TEST_HW_SUCCESS: HW crypto FIPS self test passed (2-16)
*Mar 1 00:00:49.727: DPAA Initialization Complete
*Mar 1 00:00:49.727: %SYS-3-HARIKARI: Process DPAA INIT top-level routine exited
*Mar 1 00:00:49.783: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0, changed state to up
*Mar 1 00:00:54.307: %CAPWAP-5-AP_EASYADMIN_INFO: AP Easy Admin information - EASY_ADMIN is not set, turn off easy admin service!
*Mar 1 00:00:54.307: %CAPWAP-5-AP_EASYADMIN_INFO: AP Easy Admin information - Easy Admin is not enabled, turn it off!
*Mar 1 00:00:54.323: %DOT11-5-EXPECTED_RADIO_RESET: Restarting Radio interface Dot11Radio0 due to the reason code 39
*Mar 1 00:00:54.323: %DOT11-5-EXPECTED_RADIO_RESET: Restarting Radio interface Dot11Radio1 due to the reason code 39
*Mar 1 00:00:54.343: %DOT11-5-EXPECTED_RADIO_RESET: Restarting Radio interface Dot11Radio0 due to the reason code 10
*Mar 1 00:00:54.347: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
*Mar 1 00:00:54.351: %DOT11-5-EXPECTED_RADIO_RESET: Restarting Radio interface Dot11Radio1 due to the reason code 10
*Mar 1 00:00:54.367: Starting Ethernet promiscuous mode
*Mar 1 00:00:54.551: %SSH-5-ENABLED: SSH 2.0 has been enabled
*Mar 1 00:00:54.551: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to uplwapp_crypto_init: MIC Present and Parsed Successfully
*Mar 1 00:00:55.347: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
*Mar 1 00:00:55.551: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to down
*Mar 1 00:00:59.927: Currently running a Release Image
*Mar 1 00:00:59.951: Using SHA-2 signed certificate for image signing validation.
*Mar 1 00:01:12.223: AP image integrity check PASSED
*Mar 1 00:01:12.231: Non-recovery image. PNP Not required.
*Mar 1 00:01:12.239: Cert ISSUER (39): cn=Cisco Manufacturing CA SHA2,o=Cisco
*Mar 1 00:01:12.259: %DOT11-5-EXPECTED_RADIO_RESET: Restarting Radio interface Dot11Radio0 due to the reason code 10
*Mar 1 00:01:12.263: %DOT11-5-EXPECTED_RADIO_RESET: Restarting Radio interface Dot11Radio1 due to the reason code 10
*Mar 1 00:01:12.275:
Note: A random mac address of 0000.0cb0.1a54
has been chosen for BVI in bridge group 3 since the selected mac address
is already being used by Bridge Group 2.
Ensure that this address is unique.
*Mar 1 00:01:12.283:
Note: A random mac address of 0000.0cb0.1a5c
has been chosen for BVI in bridge group 4 since the selected mac address
*Mar 1 00:01:12.287: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Mar 1 00:01:13.395: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
*Mar 1 00:01:13.403: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to reset
*Mar 1 00:01:14.395: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
*Mar 1 00:01:14.631: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to up
*Mar 1 00:01:15.287: %LINEPROTO-5-UPDOWN: Line protocol on Interface BVI2, changed state to up
*Mar 1 00:01:15.287: %LINEPROTO-5-UPDOWN: Line protocol on Interface BVI3, changed state to up
*Mar 1 00:01:15.287: %LINEPROTO-5-UPDOWN: Line protocol on Interface BVI4, changed state to up
*Mar 1 00:01:15.631: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to upcreating PnP template view
*Mar 1 00:01:22.583: Logging LWAPP message to 255.255.255.255.
*Mar 1 00:01:22.587: %SYS-6-LOGGINGHOST_STARTSTOP: Logging to host 255.255.255.255 port 0 CLI Request Triggered
*Mar 1 00:02:01.595: AP has SHA2 MIC certificate - Using SHA2 MIC certificate for DTLS.
*Nov 23 01:08:24.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 172.20.21.243 peer_port: 5246
*Nov 23 01:08:24.359: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully peer_ip: 172.20.21.243 peer_port: 5246
*Nov 23 01:08:24.359: %CAPWAP-5-SENDJOIN: sending Join Request to 172.20.21.243
*Nov 23 01:08:29.359: %CAPWAP-5-SENDJOIN: sending Join Request to 172.20.21.243
*Nov 23 01:08:29.547: %LWAPP-4-CLIENTEVENTLOG:
Checksum required saved version = 8.5.140.0, file flash:/lwapp_reap.cfg
*Nov 23 01:08:29.775: %DOT11-5-EXPECTED_RADIO_RESET: Restarting Radio interface Dot11Radio0 due to the reason code 42
*Nov 23 01:08:29.783: %DOT11-5-EXPECTED_RADIO_RESET: Restarting Radio interface Dot11Radio0 due to the reason code 56
*Nov 23 01:08:29.787: %DOT11-5-EXPECTED_RADIO_RESET: Restarting Radio interface Dot11Radio0 due to the reason code 21
*Nov 23 01:08:29.787: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to down
*Nov 23 01:08:29.795: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Nov 23 01:08:29.803: %DOT11-5-EXPECTED_RADIO_RESET: Restarting Radio interface Dot11Radio1 due to the reason code 42
*Nov 23 01:08:29.803: %DOT11-5-EXPECTED_RADIO_RESET: Restarting Radio interface Dot11Radio1 due to the reason code 27
*Nov 23 01:08:29.807: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to administratively down
*Nov 23 01:08:30.419: %DOT11-5-EXPECTED_RADIO_RESET: Restarting Radio interface Dot11Radio1 due to the reason code 56
*Nov 23 01:08:30.419: %DOT11-5-EXPECTED_RADIO_RESET: Restarting Radio interface Dot11Radio1 due to the reason code 21
*Nov 23 01:08:30.419: %DOT11-5-EXPECTED_RADIO_RESET: Restarting Radio interface Dot11Radio0 due to the reason code 10
*Nov 23 01:08:30.419: %DOT11-5-EXPECTED_RADIO_RESET: Restarting Radio interface Dot11Radio1 due to the reason code 10
*Nov 23 01:08:30.439: %LWAPP-4-CLIENTEVENTLOG: OfficeExtend Localssid saved in AP flash
*Nov 23 01:08:30.619: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
*Nov 23 01:08:30.619: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to up
*Nov 23 01:08:30.819: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
*Nov 23 01:08:31.623: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to down
*Nov 23 01:08:31.823: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to reset
*Nov 23 01:08:32.071: %CAPWAP-5-JOINEDCONTROLLER: AP has joined controller ap20021243WLAN id 1, SSID SHIMADZU, L2ACL , L2ACL AP
WLAN id 2, SSID SSC, L2ACL , L2ACL AP
*Nov 23 01:08:32.423: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to upcapwap_delete_all_l2Acls_in_nacl_list:336. Deleting all L2Acls in AP config
*Nov 23 01:08:32.627: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to down
*Nov 23 01:08:32.663: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to up
*Nov 23 01:08:32.671: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to down
*Nov 23 01:08:32.687: %DOT11-5-EXPECTED_RADIO_RESET: Restarting Radio interface Dot11Radio1 due to the reason code 10
*Nov 23 01:08:32.703: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Nov 23 01:08:33.663: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to up
*Nov 23 01:08:33.671: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
*Nov 23 01:08:33.711: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
*Nov 23 01:08:33.723: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to down
*Nov 23 01:08:33.731: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to reset
*Nov 23 01:08:33.747: %DOT11-5-EXPECTED_RADIO_RESET: Restarting Radio interface Dot11Radio0 due to the reason code 10
*Nov 23 01:08:33.759: %DOT11-5-EXPECTED_RADIO_RESET: Restarting Radio interface Dot11Radio1 due to the reason code 10
*Nov 23 01:08:33.891: %DOT11-5-EXPECTED_RADIO_RESET: Restarting Radio interface Dot11Radio0 due to the reason code 27
*Nov 23 01:08:33.903: %DOT11-5-EXPECTED_RADIO_RESET: Restarting Radio interface Dot11Radio0 due to the reason code 10
*Nov 23 01:08:34.711: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
*Nov 23 01:08:34.723: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to down
*Nov 23 01:08:34.771: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to up
*Nov 23 01:08:34.779: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to down
*Nov 23 01:08:34.787: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Nov 23 01:08:35.771: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to up
*Nov 23 01:08:35.779: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
*Nov 23 01:08:35.815: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
*Nov 23 01:08:35.823: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to down
*Nov 23 01:08:35.831: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to reset
*Nov 23 01:08:37.011: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
*Nov 23 01:08:37.011: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to down
*Nov 23 01:08:37.239: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to up
*Nov 23 01:08:38.255: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to up
*Nov 23 01:08:39.279: %WIDS-6-ENABLED: IDS Signature is loaded and enabled
*Nov 23 01:08:42.011: %LINEPROTO-5-UPDOWN: Line protocol on Interface NVI0, changed state to up
*Nov 23 01:08:56.395: %CLEANAIR-6-STATE: Slot 0 enabled
*Nov 23 01:08:58.167: %CLEANAIR-6-STATE: Slot 1 enabled
*Nov 23 01:11:21.239: %DOT11-6-ASSOC: Interface Dot11Radio1, Station 3a10.eb95.4795 REAP Associated KEY_MGMT[Open]
*Nov 23 01:11:34.351: %DOT11-6-DISASSOC: Interface Dot11Radio1, Deauthenticating Station 3a10.eb95.4795 Sending station has left the BSS
*Nov 23 01:11:34.447: %DOT11-6-ASSOC: Interface Dot11Radio0, Station 3a10.eb95.4795 REAP Associated KEY_MGMT[Open]
*Nov 23 01:11:49.219: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 3a10.eb95.4795 Sending station has left the BSS
*Nov 23 01:12:17.659: %DOT11-6-ASSOC: Interface Dot11Radio0, Station 3a10.eb95.4795 REAP Associated KEY_MGMT[Open]
*Nov 23 01:13:15.591: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 3a10.eb95.4795 Sending station has left the BSS
*Nov 23 01:16:16.047: %DOT11-6-ASSOC: Interface Dot11Radio1, Station fc42.032c.1643 REAP Associated KEY_MGMT[Open]
*Nov 23 01:16:53.131: %DOT11-6-DISASSOC: Interface Dot11Radio1, Deauthenticating Station fc42.032c.1643 Sending station has left the BSS
*Nov 23 01:25:14.379: %DOT11-6-ASSOC: Interface Dot11Radio1, Station fc42.032c.1643 REAP Associated KEY_MGMT[Open]
*Nov 23 01:25:26.335: %DOT11-6-DISASSOC: Interface Dot11Radio1, Deauthenticating Station fc42.032c.1643 Sending station has left the BSS
*Nov 23 01:28:18.919: %DOT11-6-ASSOC: Interface Dot11Radio1, Station 4c31.2dd8.71b6 REAP Associated KEY_MGMT[Open]
*Nov 23 01:31:07.519: %DOT11-6-ASSOC: Interface Dot11Radio1, Station 4e81.68d8.e097 REAP Associated KEY_MGMT[Open]
*Nov 23 01:31:10.315: %DOT11-6-DISASSOC: Interface Dot11Radio1, Deauthenticating Station 4e81.68d8.e097 Sending station has left the BSS
*Nov 23 01:35:58.835: %DOT11-6-ASSOC: Interface Dot11Radio1, Station c231.e079.8bdc REAP Associated KEY_MGMT[Open]
*Nov 23 01:37:22.263: %DOT11-6-DISASSOC: Interface Dot11Radio1, Deauthenticating Station c231.e079.8bdc Sending station has left the BSS
*Nov 23 01:37:22.355: %DOT11-6-ASSOC: Interface Dot11Radio0, Station c231.e079.8bdc REAP Associated KEY_MGMT[Open]
*Nov 23 01:37:53.451: %DOT11-6-ASSOC: Interface Dot11Radio1, Station e2ce.2969.625a REAP Associated KEY_MGMT[Open]
*Nov 23 01:37:54.179: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station c231.e079.8bdc Sending station has left the BSS
*Nov 23 01:37:54.271: %DOT11-6-ASSOC: Interface Dot11Radio1, Station c231.e079.8bdc REAP Associated KEY_MGMT[Open]
*Nov 23 01:38:38.303: %DOT11-6-ASSOC: Interface Dot11Radio0, Station 2261.c8c1.d5cd REAP Associated KEY_MGMT[Open]
*Nov 23 01:39:15.999: %DOT11-6-ASSOC: Interface Dot11Radio0, Station 3a10.eb95.4795 REAP Associated KEY_MGMT[Open]
*Nov 23 01:39:18.367: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 3a10.eb95.4795 Sending station has left the BSS
*Nov 23 01:39:24.095: %DOT11-6-ASSOC: Interface Dot11Radio0, Station 3a10.eb95.4795 REAP Associated KEY_MGMT[Open]
*Nov 23 01:39:52.883: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 3a10.eb95.4795 Sending station has left the BSS
*Nov 23 01:39:57.151: %DOT11-6-ASSOC: Interface Dot11Radio0, Station 3a10.eb95.4795 REAP Associated KEY_MGMT[Open]
*Nov 23 01:39:58.015: %DOT11-4-CCMP_REPLAY: Client 3a10.eb95.4795 had 1 AES-CCMP TSC replays
*Nov 23 01:39:58.275: %DOT11-6-DISASSOC: Interface Dot11Radio1, Deauthenticating Station e2ce.2969.625a Sending station has left the BSS
*Nov 23 01:40:22.075: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 3a10.eb95.4795 Sending station has left the BSS
*Nov 23 01:42:19.183: %DOT11-6-DISASSOC: Interface Dot11Radio1, Deauthenticating Station c231.e079.8bdc Sending station has left the BSS
*Nov 23 01:44:40.255: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 2261.c8c1.d5cd Sending station has left the BSS
*Nov 23 01:49:55.479: %DOT11-6-ASSOC: Interface Dot11Radio0, Station 9cbc.f0e3.23a4 REAP Associated KEY_MGMT[Open]
*Nov 23 01:50:09.859: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 9cbc.f0e3.23a4 Sending station has left the BSS
*Nov 23 01:51:35.767: %DOT11-6-ASSOC: Interface Dot11Radio1, Station 7a18.eb43.0ac3 REAP Associated KEY_MGMT[Open]
*Nov 23 01:51:52.375: %DOT11-6-DISASSOC: Interface Dot11Radio1, Deauthenticating Station 7a18.eb43.0ac3 Sending station has left the BSS
*Nov 23 01:56:47.763: %DOT11-6-ASSOC: Interface Dot11Radio0, Station 1e7d.3546.6cac REAP Associated KEY_MGMT[Open]
*Nov 23 02:04:32.735: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 1e7d.3546.6cac Sending station has left the BSS
*Nov 23 02:04:42.055: %DOT11-6-ASSOC: Interface Dot11Radio1, Station 4e81.68d8.e097 REAP Associated KEY_MGMT[Open]
*Nov 23 02:04:42.951: %DOT11-6-DISASSOC: Interface Dot11Radio1, Deauthenticating Station 4e81.68d8.e097 Sending station has left the BSS
*Nov 23 02:07:37.591: %DOT11-6-ASSOC: Interface Dot11Radio1, Station e2ce.2969.625a REAP Associated KEY_MGMT[Open]
*Nov 23 02:12:05.847: %DOT11-6-DISASSOC: Interface Dot11Radio1, Deauthenticating Station e2ce.2969.625a Sending station has left the BSS
*Nov 23 02:13:28.171: %DOT11-6-ASSOC: Interface Dot11Radio0, Station e2ce.2969.625a REAP Associated KEY_MGMT[Open]
*Nov 23 02:13:31.163: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station e2ce.2969.625a Sending station has left the BSS
*Nov 23 02:15:18.895: %DOT11-6-ASSOC: Interface Dot11Radio0, Station 1e7d.3546.6cac REAP Associated KEY_MGMT[Open]
*Nov 23 02:20:06.931: %DOT11-6-ASSOC: Interface Dot11Radio0, Station 387a.0e8b.5d26 REAP Associated KEY_MGMT[Open]
*Nov 23 02:21:11.655: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 387a.0e8b.5d26 Sending station has left the BSS
*Nov 23 02:25:46.487: %DOT11-4-CCMP_REPLAY: Client 1e7d.3546.6cac had 1 AES-CCMP TSC replays
*Nov 23 02:25:49.335: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 1e7d.3546.6cac Sending station has left the BSS
*Nov 23 02:26:00.815: %DOT11-6-ASSOC: Interface Dot11Radio0, Station 3a10.eb95.4795 REAP Associated KEY_MGMT[Open]
*Nov 23 02:27:34.235: %DOT11-6-ASSOC: Interface Dot11Radio1, Station 387a.0e8b.5d26 REAP Associated KEY_MGMT[Open]
*Nov 23 02:29:55.067: %DOT11-6-DISASSOC: Interface Dot11Radio1, Deauthenticating Station 387a.0e8b.5d26 Sending station has left the BSS
*Nov 23 02:31:20.515: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 3a10.eb95.4795 Sending station has left the BSS
*Nov 23 02:35:14.047: %DOT11-6-ASSOC: Interface Dot11Radio0, Station 3a10.eb95.4795 REAP Associated KEY_MGMT[Open]
*Nov 23 02:35:15.551: %DOT11-4-CCMP_REPLAY: Client 3a10.eb95.4795 had 1 AES-CCMP TSC replays
*Nov 23 02:40:40.987: %DOT11-6-ASSOC: Interface Dot11Radio1, Station e2ce.2969.625a REAP Associated KEY_MGMT[Open]
*Nov 23 02:43:43.779: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 3a10.eb95.4795 Sending station has left the BSS
*Nov 23 02:44:29.159: %DOT11-6-DISASSOC: Interface Dot11Radio1, Deauthenticating Station e2ce.2969.625a Sending station has left the BSS
*Nov 23 02:52:52.167: %DOT11-6-ASSOC: Interface Dot11Radio0, Station 3a10.eb95.4795 REAP Associated KEY_MGMT[Open]
*Nov 23 02:53:13.703: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 3a10.eb95.4795 Sending station has left the BSS
*Nov 23 02:53:36.299: %DOT11-6-ASSOC: Interface Dot11Radio1, Station 7a18.eb43.0ac3 REAP Associated KEY_MGMT[Open]
*Nov 23 02:55:02.031: %DOT11-6-ASSOC: Interface Dot11Radio0, Station 1e7d.3546.6cac REAP Associated KEY_MGMT[Open]
*Nov 23 02:57:35.747: %DOT11-6-ASSOC: Interface Dot11Radio1, Station 961e.a39f.8ae8 REAP Associated KEY_MGMT[Open]
*Nov 23 02:57:42.951: %DOT11-6-DISASSOC: Interface Dot11Radio1, Deauthenticating Station 961e.a39f.8ae8 Sending station has left the BSS
*Nov 23 02:58:23.723: %DOT11-6-ASSOC: Interface Dot11Radio1, Station 66ea.9690.c3f8 REAP Associated KEY_MGMT[Open]
*Nov 23 02:58:35.767: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 1e7d.3546.6cac Sending station has left the BSS
*Nov 23 02:58:41.711: %DOT11-6-DISASSOC: Interface Dot11Radio1, Deauthenticating Station 66ea.9690.c3f8 Sending station has left the BSS
*Nov 23 02:58:54.951: %DOT11-6-DISASSOC: Interface Dot11Radio1, Deauthenticating Station 7a18.eb43.0ac3 Sending station has left the BSS
*Nov 23 02:59:53.355: %DOT11-6-ASSOC: Interface Dot11Radio1, Station 66ea.9690.c3f8 REAP Associated KEY_MGMT[Open]
*Nov 23 03:00:03.383: %DOT11-6-DISASSOC: Interface Dot11Radio1, Deauthenticating Station 66ea.9690.c3f8 Sending station has left the BSS
*Nov 23 03:02:14.195: %DOT11-6-ASSOC: Interface Dot11Radio0, Station 1e7d.3546.6cac REAP Associated KEY_MGMT[Open]
*Nov 23 03:03:05.503: %DOT11-6-ASSOC: Interface Dot11Radio0, Station 4e81.68d8.e097 REAP Associated KEY_MGMT[Open]
*Nov 23 03:03:13.483: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 1e7d.3546.6cac Sending station has left the BSS
*Nov 23 03:03:15.911: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 4e81.68d8.e097 Sending station has left the BSS
*Nov 23 03:06:33.111: %DOT11-6-ASSOC: Interface Dot11Radio0, Station bea7.d4ff.350a REAP Associated KEY_MGMT[Open]
*Nov 23 03:06:52.023: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station bea7.d4ff.350a Sending station has left the BSS
*Nov 23 03:08:01.423: %DOT11-6-ASSOC: Interface Dot11Radio0, Station bea7.d4ff.350a REAP Associated KEY_MGMT[Open]
*Nov 23 03:09:00.943: %DOT11-6-ASSOC: Interface Dot11Radio0, Station 1e7d.3546.6cac REAP Associated KEY_MGMT[Open]
*Nov 23 03:09:09.039: %DOT11-6-ASSOC: Interface Dot11Radio1, Station aa12.19d7.ab31 REAP Associated KEY_MGMT[Open]
*Nov 23 03:09:29.927: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 1e7d.3546.6cac Sending station has left the BSS
*Nov 23 03:09:39.935: %DOT11-6-ASSOC: Interface Dot11Radio0, Station 1e7d.3546.6cac REAP Associated KEY_MGMT[Open]
*Nov 23 03:10:02.535: %DOT11-6-ASSOC: Interface Dot11Radio1, Station a059.506c.befc REAP Associated KEY_MGMT[Open]
*Nov 23 03:10:21.547: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 1e7d.3546.6cac Sending station has left the BSS
*Nov 23 03:10:34.535: %DOT11-6-DISASSOC: Interface Dot11Radio1, Deauthenticating Station a059.506c.befc Sending station has left the BSS
*Nov 23 03:11:47.727: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station bea7.d4ff.350a Sending station has left the BSS
*Nov 23 03:17:07.103: %DOT11-6-ASSOC: Interface Dot11Radio1, Station 1e7d.3546.6cac REAP Associated KEY_MGMT[Open]
*Nov 23 03:17:09.427: %DOT11-6-DISASSOC: Interface Dot11Radio1, Deauthenticating Station 1e7d.3546.6cac Sending station has left the BSS
*Nov 23 03:18:00.947: %DOT11-6-ASSOC: Interface Dot11Radio1, Station 3a10.eb95.4795 REAP Associated KEY_MGMT[Open]
*Nov 23 03:18:58.699: %DOT11-6-DISASSOC: Interface Dot11Radio1, Deauthenticating Station aa12.19d7.ab31 Sending station has left the BSS
*Nov 23 03:18:58.799: %DOT11-6-ASSOC: Interface Dot11Radio0, Station aa12.19d7.ab31 REAP Associated KEY_MGMT[Open]
*Nov 23 03:19:01.411: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station aa12.19d7.ab31 Sending station has left the BSS
*Nov 23 03:19:01.503: %DOT11-6-ASSOC: Interface Dot11Radio1, Station aa12.19d7.ab31 REAP Associated KEY_MGMT[Open]
*Nov 23 03:20:47.651: %DOT11-6-DISASSOC: Interface Dot11Radio1, Deauthenticating Station aa12.19d7.ab31 Sending station has left the BSS
*Nov 23 03:20:47.743: %DOT11-6-ASSOC: Interface Dot11Radio0, Station aa12.19d7.ab31 REAP Associated KEY_MGMT[Open]
*Nov 23 03:20:55.591: %DOT11-6-ASSOC: Interface Dot11Radio0, Station 1e7d.3546.6cac REAP Associated KEY_MGMT[Open]
*Nov 23 03:22:00.951: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 1e7d.3546.6cac Sending station has left the BSS
*Nov 23 03:22:03.183: %DOT11-6-DISASSOC: Interface Dot11Radio1, Deauthenticating Station 3a10.eb95.4795 Sending station has left the BSS
*Nov 23 03:26:15.607: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station aa12.19d7.ab31 Sending station has left the BSS
*Nov 23 03:26:56.327: %DOT11-6-ASSOC: Interface Dot11Radio0, Station 4276.897e.ba77 REAP Associated KEY_MGMT[Open]
*Nov 23 03:27:40.167: %DOT11-6-ASSOC: Interface Dot11Radio1, Station 4e81.68d8.e097 REAP Associated KEY_MGMT[Open]
*Nov 23 03:28:08.147: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 4276.897e.ba77 Sending station has left the BSS
*Nov 23 03:28:11.927: %DOT11-6-ASSOC: Interface Dot11Radio0, Station 4276.897e.ba77 REAP Associated KEY_MGMT[Open]
*Nov 23 03:28:19.935: %DOT11-6-DISASSOC: Interface Dot11Radio1, Deauthenticating Station 4e81.68d8.e097 Sending station has left the BSS
*Nov 23 03:28:30.611: %DOT11-4-CCMP_REPLAY: Client 4276.897e.ba77 had 1 AES-CCMP TSC replays
*Nov 23 03:28:39.331: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 4276.897e.ba77 Sending station has left the BSS
*Nov 23 03:28:51.419: %DOT11-6-ASSOC: Interface Dot11Radio0, Station 4276.897e.ba77 REAP Associated KEY_MGMT[Open]
*Nov 23 03:29:09.203: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 4276.897e.ba77 Sending station has left the BSS
*Nov 23 03:29:18.971: %DOT11-6-ASSOC: Interface Dot11Radio1, Station 4276.897e.ba77 REAP Associated KEY_MGMT[Open]
*Nov 23 03:33:58.923: %DOT11-6-ASSOC: Interface Dot11Radio0, Station 1e7d.3546.6cac REAP Associated KEY_MGMT[Open]
*Nov 23 03:35:06.619: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 1e7d.3546.6cac Sending station has left the BSS
*Nov 23 03:37:01.639: %DOT11-6-DISASSOC: Interface Dot11Radio1, Deauthenticating Station 4276.897e.ba77 Sending station has left the BSS
*Nov 23 03:37:01.731: %DOT11-6-ASSOC: Interface Dot11Radio0, Station 4276.897e.ba77 REAP Associated KEY_MGMT[Open]
*Nov 23 03:39:59.051: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 4276.897e.ba77 Sending station has left the BSS
*Nov 23 03:39:59.139: %DOT11-6-ASSOC: Interface Dot11Radio1, Station 4276.897e.ba77 REAP Associated KEY_MGMT[Open]
*Nov 23 03:40:05.475: %DOT11-6-DISASSOC: Interface Dot11Radio1, Deauthenticating Station 4276.897e.ba77 Sending station has left the BSS
*Nov 23 03:40:05.567: %DOT11-6-ASSOC: Interface Dot11Radio0, Station 4276.897e.ba77 REAP Associated KEY_MGMT[Open]
*Nov 23 03:44:40.627: %DOT11-6-ASSOC: Interface Dot11Radio0, Station 1e7d.3546.6cac REAP Associated KEY_MGMT[Open]
*Nov 23 03:44:57.819: %DOT11-6-ASSOC: Interface Dot11Radio0, Station 6479.f048.5049 REAP Associated KEY_MGMT[Open]
*Nov 23 03:45:31.147: %DOT11-6-ASSOC: Interface Dot11Radio0, Station bea7.d4ff.350a REAP Associated KEY_MGMT[Open]
*Nov 23 03:45:33.371: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 6479.f048.5049 Sending station has left the BSS
*Nov 23 03:48:36.167: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station bea7.d4ff.350a Sending station has left the BSS
*Nov 23 03:49:07.807: %DOT11-6-ASSOC: Interface Dot11Radio0, Station bea7.d4ff.350a REAP Associated KEY_MGMT[Open]
*Nov 23 03:49:17.475: LWAPP IPV6 IAPP [ERROR!]: Failed to make IAPP Packet, Respective IPv6 client is dead!
*Nov 23 03:49:17.475: LWAPP IPV6 IAPP [ERROR!]: 2nd retry failed! for client[bea7.d4ff.350a]
*Nov 23 03:51:57.551: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 1e7d.3546.6cac Sending station has left the BSS
*Nov 23 03:55:05.563: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station bea7.d4ff.350a Sending station has left the BSS
*Nov 23 03:58:19.947: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 4276.897e.ba77 Sending station has left the BSS
*Nov 23 03:58:20.039: %DOT11-6-ASSOC: Interface Dot11Radio1, Station 4276.897e.ba77 REAP Associated KEY_MGMT[Open]
*Nov 23 04:01:05.035: %DOT11-6-DISASSOC: Interface Dot11Radio1, Deauthenticating Station 4276.897e.ba77 Sending station has left the BSS
*Nov 23 04:01:05.127: %DOT11-6-ASSOC: Interface Dot11Radio0, Station 4276.897e.ba77 REAP Associated KEY_MGMT[Open]
*Nov 23 04:02:59.587: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 4276.897e.ba77 Sending station has left the BSS
*Nov 23 04:02:59.679: %DOT11-6-ASSOC: Interface Dot11Radio1, Station 4276.897e.ba77 REAP Associated KEY_MGMT[Open]
*Nov 23 04:03:49.551: %DOT11-6-DISASSOC: Interface Dot11Radio1, Deauthenticating Station 4276.897e.ba77 Sending station has left the BSS
*Nov 23 04:03:51.335: %DOT11-6-ASSOC: Interface Dot11Radio0, Station 4276.897e.ba77 REAP Associated KEY_MGMT[Open]
*Nov 23 04:09:58.871: %DOT11-6-ASSOC: Interface Dot11Radio1, Station 2261.c8c1.d5cd REAP Associated KEY_MGMT[Open]
*Nov 23 04:10:04.627: %DOT11-6-DISASSOC: Interface Dot11Radio1, Deauthenticating Station 2261.c8c1.d5cd Sending station has left the BSS
*Nov 23 04:10:08.971: %DOT11-6-ASSOC: Interface Dot11Radio1, Station 54eb.e9de.cc38 REAP Associated KEY_MGMT[Open]
*Nov 23 04:10:31.843: %DOT11-6-DISASSOC: Interface Dot11Radio1, Deauthenticating Station 54eb.e9de.cc38 Sending station has left the BSS
*Nov 23 04:14:01.247: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 4276.897e.ba77 Sending station has left the BSS
*Nov 23 04:16:12.719: %DOT11-6-ASSOC: Interface Dot11Radio1, Station 4276.897e.ba77 REAP Associated KEY_MGMT[Open]
*Nov 23 04:17:23.119: %DOT11-6-ASSOC: Interface Dot11Radio0, Station 1e7d.3546.6cac REAP Associated KEY_MGMT[Open]
*Nov 23 04:18:48.603: %DOT11-6-ASSOC: Interface Dot11Radio0, Station 387a.0e8b.5d26 REAP Associated KEY_MGMT[Open]
*Nov 23 04:19:56.651: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 387a.0e8b.5d26 Sending station has left the BSS
*Nov 23 04:19:56.747: %DOT11-6-ASSOC: Interface Dot11Radio1, Station 387a.0e8b.5d26 REAP Associated KEY_MGMT[Open]
*Nov 23 04:19:57.939: %DOT11-6-ASSOC: Interface Dot11Radio0, Station bea7.d4ff.350a REAP Associated KEY_MGMT[Open]
*Nov 23 04:20:58.267: %DOT11-6-DISASSOC: Interface Dot11Radio1, Deauthenticating Station 4276.897e.ba77 Sending station has left the BSS
*Nov 23 04:21:44.587: %DOT11-6-ASSOC: Interface Dot11Radio0, Station 4276.897e.ba77 REAP Associated KEY_MGMT[Open]
*Nov 23 04:21:47.283: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 4276.897e.ba77 Sending station has left the BSS
*Nov 23 04:21:47.375: %DOT11-6-ASSOC: Interface Dot11Radio1, Station 4276.897e.ba77 REAP Associated KEY_MGMT[Open]
*Nov 23 04:22:17.051: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station bea7.d4ff.350a Sending station has left the BSS
*Nov 23 04:23:31.135: %DOT11-6-DISASSOC: Interface Dot11Radio1, Deauthenticating Station 4276.897e.ba77 Sending station has left the BSS
*Nov 23 04:23:31.227: %DOT11-6-ASSOC: Interface Dot11Radio0, Station 4276.897e.ba77 REAP Associated KEY_MGMT[Open]
*Nov 23 04:24:08.295: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 4276.897e.ba77 Sending station has left the BSS
*Nov 23 04:24:08.387: %DOT11-6-ASSOC: Interface Dot11Radio1, Station 4276.897e.ba77 REAP Associated KEY_MGMT[Open]
*Nov 23 04:24:10.939: %DOT11-6-DISASSOC: Interface Dot11Radio1, Deauthenticating Station 4276.897e.ba77 Sending station has left the BSS
*Nov 23 04:24:11.031: %DOT11-6-ASSOC: Interface Dot11Radio0, Station 4276.897e.ba77 REAP Associated KEY_MGMT[Open]
*Nov 23 04:24:13.715: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 4276.897e.ba77 Sending station has left the BSS
*Nov 23 04:24:13.807: %DOT11-6-ASSOC: Interface Dot11Radio1, Station 4276.897e.ba77 REAP Associated KEY_MGMT[Open]
*Nov 23 04:24:16.271: %DOT11-6-DISASSOC: Interface Dot11Radio1, Deauthenticating Station 4276.897e.ba77 Sending station has left the BSS
*Nov 23 04:24:16.363: %DOT11-6-ASSOC: Interface Dot11Radio0, Station 4276.897e.ba77 REAP Associated KEY_MGMT[Open]
*Nov 23 04:24:16.451: LWAPP IPV6 IAPP [ERROR!]: Failed to make IAPP Packet, Respective IPv6 client is dead!
*Nov 23 04:24:16.451: LWAPP IPV6 IAPP [ERROR!]: 2nd retry failed! for client[4276.897e.ba77]
*Nov 23 04:24:25.091: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 4276.897e.ba77 Sending station has left the BSS
*Nov 23 04:24:25.187: %DOT11-6-ASSOC: Interface Dot11Radio1, Station 4276.897e.ba77 REAP Associated KEY_MGMT[Open]
*Nov 23 04:24:34.443: %DOT11-6-DISASSOC: Interface Dot11Radio1, Deauthenticating Station 4276.897e.ba77 Sending station has left the BSS
*Nov 23 04:24:34.531: %DOT11-6-ASSOC: Interface Dot11Radio0, Station 4276.897e.ba77 REAP Associated KEY_MGMT[Open]
*Nov 23 04:24:37.095: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 4276.897e.ba77 Sending station has left the BSS
*Nov 23 04:24:37.187: %DOT11-6-ASSOC: Interface Dot11Radio1, Station 4276.897e.ba77 REAP Associated KEY_MGMT[Open]
*Nov 23 04:25:34.695: %DOT11-6-ASSOC: Interface Dot11Radio1, Station 2261.c8c1.d5cd REAP Associated KEY_MGMT[Open]
*Nov 23 04:25:44.287: %DOT11-6-DISASSOC: Interface Dot11Radio1, Deauthenticating Station 4276.897e.ba77 Sending station has left the BSS
*Nov 23 04:25:53.707: %DOT11-6-DISASSOC: Interface Dot11Radio1, Deauthenticating Station 387a.0e8b.5d26 Sending station has left the BSS
*Nov 23 04:27:12.075: %DOT11-6-DISASSOC: Interface Dot11Radio1, Deauthenticating Station 2261.c8c1.d5cd Sending station has left the BSS
*Nov 23 04:31:28.779: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 1e7d.3546.6cac Sending station has left the BSS
*Nov 23 04:34:28.211: %DOT11-6-ASSOC: Interface Dot11Radio0, Station bea7.d4ff.350a REAP Associated KEY_MGMT[Open]
*Nov 23 04:36:24.927: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station bea7.d4ff.350a Sending station has left the BSS
*Nov 23 04:37:13.447: %DOT11-6-ASSOC: Interface Dot11Radio0, Station bea7.d4ff.350a REAP Associated KEY_MGMT[Open]
*Nov 23 04:38:35.443: %DOT11-6-ASSOC: Interface Dot11Radio0, Station 1e7d.3546.6cac REAP Associated KEY_MGMT[Open]
*Nov 23 04:39:52.687: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station bea7.d4ff.350a Sending station has left the BSS
*Nov 23 04:41:56.507: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 1e7d.3546.6cac Sending station has left the BSS
*Nov 23 04:43:13.387: %DOT11-6-ASSOC: Interface Dot11Radio1, Station 4e81.68d8.e097 REAP Associated KEY_MGMT[Open]
*Nov 23 04:43:16.747: %DOT11-6-DISASSOC: Interface Dot11Radio1, Deauthenticating Station 4e81.68d8.e097 Sending station has left the BSS
*Nov 23 04:47:43.955: %DOT11-6-ASSOC: Interface Dot11Radio1, Station 32b8.280e.fd5b REAP Associated KEY_MGMT[Open]
*Nov 23 04:47:52.083: %DOT11-6-DISASSOC: Interface Dot11Radio1, Deauthenticating Station 32b8.280e.fd5b Sending station has left the BSS
*Nov 23 04:50:12.635: %DOT11-6-ASSOC: Interface Dot11Radio0, Station fc42.032c.1643 REAP Associated KEY_MGMT[Open]
*Nov 23 04:50:21.779: %DOT11-6-ASSOC: Interface Dot11Radio0, Station bea7.d4ff.350a REAP Associated KEY_MGMT[Open]
*Nov 23 04:50:25.707: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station fc42.032c.1643 Sending station has left the BSS
*Nov 23 04:51:07.935: %DOT11-6-ASSOC: Interface Dot11Radio0, Station 4e81.68d8.e097 REAP Associated KEY_MGMT[Open]
*Nov 23 04:55:32.363: %DOT11-6-ASSOC: Interface Dot11Radio1, Station 3a10.eb95.4795 REAP Associated KEY_MGMT[Open]
*Nov 23 04:55:36.403: %DOT11-6-ASSOC: Interface Dot11Radio1, Station 1e7d.3546.6cac REAP Associated KEY_MGMT[Open]
*Nov 23 04:55:37.611: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 4e81.68d8.e097 Sending station has left the BSS
*Nov 23 04:55:38.251: %DOT11-6-DISASSOC: Interface Dot11Radio1, Deauthenticating Station 1e7d.3546.6cac Sending station has left the BSS
*Nov 23 04:55:41.299: %DOT11-6-DISASSOC: Interface Dot11Radio1, Deauthenticating Station 3a10.eb95.4795 Sending station has left the BSS
*Nov 23 04:55:41.391: %DOT11-6-ASSOC: Interface Dot11Radio0, Station 3a10.eb95.4795 REAP Associated KEY_MGMT[Open]
*Nov 23 04:55:59.595: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 3a10.eb95.4795 Sending station has left the BSS
*Nov 23 04:56:10.067: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station bea7.d4ff.350a Sending station has left the BSS
*Nov 23 04:57:50.419: %DOT11-6-ASSOC: Interface Dot11Radio1, Station 6c94.66dc.3e2b REAP Associated KEY_MGMT[Open]
*Nov 23 04:58:13.511: %DOT11-6-DISASSOC: Interface Dot11Radio1, Deauthenticating Station 6c94.66dc.3e2b Sending station has left the BSS
*Nov 23 05:03:53.979: %DOT11-6-ASSOC: Interface Dot11Radio1, Station 387a.0e8b.5d26 REAP Associated KEY_MGMT[Open]
*Nov 23 05:04:20.251: %DOT11-6-DISASSOC: Interface Dot11Radio1, Deauthenticating Station 387a.0e8b.5d26 Sending station has left the BSS
*Nov 23 05:07:16.723: %DOT11-6-ASSOC: Interface Dot11Radio1, Station e2ce.2969.625a REAP Associated KEY_MGMT[Open]
*Nov 23 05:07:30.035: %DOT11-6-DISASSOC: Interface Dot11Radio1, Deauthenticating Station e2ce.2969.625a Sending station has left the BSS
*Nov 23 05:09:46.319: %DOT11-6-ASSOC: Interface Dot11Radio0, Station 2261.c8c1.d5cd REAP Associated KEY_MGMT[Open]
*Nov 23 05:10:35.631: %DOT11-6-ASSOC: Interface Dot11Radio1, Station 387a.0e8b.5d26 REAP Associated KEY_MGMT[Open]
*Nov 23 05:10:36.719: %DOT11-6-DISASSOC: Interface Dot11Radio1, Deauthenticating Station 387a.0e8b.5d26 Sending station has left the BSS
*Nov 23 05:14:16.067: %DOT11-6-ASSOC: Interface Dot11Radio0, Station 4276.897e.ba77 REAP Associated KEY_MGMT[Open]
*Nov 23 05:16:07.219: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 4276.897e.ba77 Sending station has left the BSS
*Nov 23 05:24:49.103: %DOT11-6-ASSOC: Interface Dot11Radio1, Station 387a.0e8b.5d26 REAP Associated KEY_MGMT[Open]
*Nov 23 05:26:15.127: %DOT11-6-DISASSOC: Interface Dot11Radio1, Deauthenticating Station 387a.0e8b.5d26 Sending station has left the BSS
*Nov 23 05:27:00.515: %DOT11-6-ASSOC: Interface Dot11Radio1, Station 387a.0e8b.5d26 REAP Associated KEY_MGMT[Open]
*Nov 23 05:28:11.759: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 2261.c8c1.d5cd Sending station has left the BSS
*Nov 23 05:31:18.887: %DOT11-6-ASSOC: Interface Dot11Radio1, Station 1e7d.3546.6cac REAP Associated KEY_MGMT[Open]
*Nov 23 05:31:27.403: %DOT11-6-DISASSOC: Interface Dot11Radio1, Deauthenticating Station 1e7d.3546.6cac Sending station has left the BSS
*Nov 23 05:31:54.947: %DOT11-6-ASSOC: Interface Dot11Radio0, Station 32b8.280e.fd5b REAP Associated KEY_MGMT[Open]
*Nov 23 05:32:49.079: %DOT11-6-ASSOC: Interface Dot11Radio1, Station 121d.b542.7107 REAP Associated KEY_MGMT[Open]
*Nov 23 05:32:53.031: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 32b8.280e.fd5b Sending station has left the BSS
*Nov 23 05:32:59.687: %DOT11-6-ASSOC: Interface Dot11Radio1, Station 8efd.ddb7.c641 REAP Associated KEY_MGMT[Open]
*Nov 23 05:33:33.855: %DOT11-6-DISASSOC: Interface Dot11Radio1, Deauthenticating Station 8efd.ddb7.c641 Sending station has left the BSS
*Nov 23 05:33:33.947: %DOT11-6-ASSOC: Interface Dot11Radio0, Station 8efd.ddb7.c641 REAP Associated KEY_MGMT[Open]
*Nov 23 05:33:44.063: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 8efd.ddb7.c641 Sending station has left the BSS
*Nov 23 05:33:44.155: %DOT11-6-ASSOC: Interface Dot11Radio1, Station 8efd.ddb7.c641 REAP Associated KEY_MGMT[Open]
*Nov 23 05:34:05.123: %DOT11-6-DISASSOC: Interface Dot11Radio1, Deauthenticating Station 8efd.ddb7.c641 Sending station has left the BSS
*Nov 23 05:34:05.215: %DOT11-6-ASSOC: Interface Dot11Radio0, Station 8efd.ddb7.c641 REAP Associated KEY_MGMT[Open]
*Nov 23 05:34:17.271: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 8efd.ddb7.c641 Sending station has left the BSS
*Nov 23 05:34:17.363: %DOT11-6-ASSOC: Interface Dot11Radio1, Station 8efd.ddb7.c641 REAP Associated KEY_MGMT[Open]
*Nov 23 05:35:24.991: %DOT11-6-DISASSOC: Interface Dot11Radio1, Deauthenticating Station 387a.0e8b.5d26 Sending station has left the BSS
*Nov 23 05:35:46.807: %DOT11-6-DISASSOC: Interface Dot11Radio1, Deauthenticating Station 8efd.ddb7.c641 Sending station has left the BSS
*Nov 23 05:35:46.899: %DOT11-6-ASSOC: Interface Dot11Radio0, Station 8efd.ddb7.c641 REAP Associated KEY_MGMT[Open]
*Nov 23 05:35:54.979: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 8efd.ddb7.c641 Sending station has left the BSS
*Nov 23 05:35:55.071: %DOT11-6-ASSOC: Interface Dot11Radio1, Station 8efd.ddb7.c641 REAP Associated KEY_MGMT[Open]
*Nov 23 05:35:57.159: %DOT11-6-DISASSOC: Interface Dot11Radio1, Deauthenticating Station 8efd.ddb7.c641 Sending station has left the BSS
*Nov 23 05:35:57.251: %DOT11-6-ASSOC: Interface Dot11Radio0, Station 8efd.ddb7.c641 REAP Associated KEY_MGMT[Open]
*Nov 23 05:35:57.999: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 8efd.ddb7.c641 Sending station has left the BSS
*Nov 23 05:36:04.999: %DOT11-6-ASSOC: Interface Dot11Radio1, Station 8efd.ddb7.c641 REAP Associated KEY_MGMT[Open]
*Nov 23 05:36:07.451: %DOT11-6-ASSOC: Interface Dot11Radio0, Station 32b8.280e.fd5b REAP Associated KEY_MGMT[Open]
*Nov 23 05:39:28.479: %DOT11-6-DISASSOC: Interface Dot11Radio1, Deauthenticating Station 8efd.ddb7.c641 Sending station has left the BSS
*Nov 23 05:39:28.567: %DOT11-6-ASSOC: Interface Dot11Radio0, Station 8efd.ddb7.c641 REAP Associated KEY_MGMT[Open]
*Nov 23 05:40:22.951: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 8efd.ddb7.c641 Sending station has left the BSS
*Nov 23 05:40:28.231: %DOT11-6-ASSOC: Interface Dot11Radio1, Station 8efd.ddb7.c641 REAP Associated KEY_MGMT[Open]
*Nov 23 05:40:57.459: %DOT11-6-DISASSOC: Interface Dot11Radio1, Deauthenticating Station 8efd.ddb7.c641 Sending station has left the BSS
*Nov 23 05:40:57.887: %DOT11-6-DISASSOC: Interface Dot11Radio1, Deauthenticating Station 121d.b542.7107 Sending station has left the BSS
*Nov 23 05:42:14.891: %DOT11-6-ASSOC: Interface Dot11Radio1, Station e2ce.2969.625a REAP Associated KEY_MGMT[Open]
*Nov 23 05:42:23.971: %DOT11-6-DISASSOC: Interface Dot11Radio1, Deauthenticating Station e2ce.2969.625a Sending station has left the BSS
*Nov 23 05:43:37.447: %DOT11-6-ASSOC: Interface Dot11Radio0, Station 1e7d.3546.6cac REAP Associated KEY_MGMT[Open]
*Nov 23 05:45:12.171: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 1e7d.3546.6cac Sending station has left the BSS
*Nov 23 05:45:54.115: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 32b8.280e.fd5b Sending station has left the BSS
*Nov 23 05:46:07.987: %DOT11-6-ASSOC: Interface Dot11Radio1, Station 3a10.eb95.4795 REAP Associated KEY_MGMT[Open]
*Nov 23 05:46:09.535: %DOT11-6-DISASSOC: Interface Dot11Radio1, Deauthenticating Station 3a10.eb95.4795 Sending station has left the BSS
*Nov 23 05:50:35.731: %DOT11-6-ASSOC: Interface Dot11Radio0, Station bea7.d4ff.350a REAP Associated KEY_MGMT[Open]
*Nov 23 05:51:25.719: %DOT11-6-ASSOC: Interface Dot11Radio0, Station 3a10.eb95.4795 REAP Associated KEY_MGMT[Open]
*Nov 23 05:51:46.035: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 3a10.eb95.4795 Sending station has left the BSS
*Nov 23 05:51:46.123: %DOT11-6-ASSOC: Interface Dot11Radio1, Station 3a10.eb95.4795 REAP Associated KEY_MGMT[Open]
*Nov 23 05:51:49.183: %DOT11-6-DISASSOC: Interface Dot11Radio1, Deauthenticating Station 3a10.eb95.4795 Sending station has left the BSS
*Nov 23 05:51:49.271: %DOT11-6-ASSOC: Interface Dot11Radio0, Station 3a10.eb95.4795 REAP Associated KEY_MGMT[Open]
*Nov 23 05:54:30.055: %DOT11-6-ASSOC: Interface Dot11Radio1, Station e2ce.2969.625a REAP Associated KEY_MGMT[Open]
*Nov 23 05:54:36.411: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station bea7.d4ff.350a Sending station has left the BSS
*Nov 23 05:54:51.695: %DOT11-6-DISASSOC: Interface Dot11Radio1, Deauthenticating Station e2ce.2969.625a Sending station has left the BSS
*Nov 23 05:56:10.111: %DOT11-6-ASSOC: Interface Dot11Radio0, Station 4e81.68d8.e097 REAP Associated KEY_MGMT[Open]
*Nov 23 05:59:56.483: %DOT11-6-ASSOC: Interface Dot11Radio1, Station 0ada.a7fd.f46b REAP Associated KEY_MGMT[Open]
*Nov 23 06:00:01.435: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 3a10.eb95.4795 Sending station has left the BSS
*Nov 23 06:01:55.291: %DOT11-6-ASSOC: Interface Dot11Radio0, Station 387a.0e8b.5d26 REAP Associated KEY_MGMT[Open]
*Nov 23 06:03:38.123: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 387a.0e8b.5d26 Sending station has left the BSS
*Nov 23 06:03:38.215: %DOT11-6-ASSOC: Interface Dot11Radio1, Station 387a.0e8b.5d26 REAP Associated KEY_MGMT[Open]
*Nov 23 06:04:11.707: %DOT11-6-DISASSOC: Interface Dot11Radio1, Deauthenticating Station 387a.0e8b.5d26 Sending station has left the BSS
*Nov 23 06:04:14.955: %DOT11-6-DISASSOC: Interface Dot11Radio1, Deauthenticating Station 0ada.a7fd.f46b Sending station has left the BSS
*Nov 23 06:04:26.359: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 4e81.68d8.e097 Sending station has left the BSS
*Nov 23 06:07:59.819: %DOT11-6-ASSOC: Interface Dot11Radio1, Station 3a10.eb95.4795 REAP Associated KEY_MGMT[Open]
*Nov 23 06:08:06.859: %DOT11-6-DISASSOC: Interface Dot11Radio1, Deauthenticating Station 3a10.eb95.4795 Sending station has left the BSS
*Nov 23 06:10:21.859: %DOT11-6-ASSOC: Interface Dot11Radio1, Station 4e81.68d8.e097 REAP Associated KEY_MGMT[Open]
*Nov 23 06:11:17.807: %DOT11-6-DISASSOC: Interface Dot11Radio1, Deauthenticating Station 4e81.68d8.e097 Sending station has left the BSS
*Nov 23 06:12:22.635: %DOT11-6-ASSOC: Interface Dot11Radio1, Station 32b8.280e.fd5b REAP Associated KEY_MGMT[Open]
*Nov 23 06:12:25.471: %DOT11-4-CCMP_REPLAY: Client 32b8.280e.fd5b had 11 AES-CCMP TSC replays
*Nov 23 06:12:37.219: %DOT11-6-DISASSOC: Interface Dot11Radio1, Deauthenticating Station 32b8.280e.fd5b Sending station has left the BSS
*Nov 23 06:12:44.991: %DOT11-6-ASSOC: Interface Dot11Radio1, Station 32b8.280e.fd5b REAP Associated KEY_MGMT[Open]
*Nov 23 06:12:47.619: %DOT11-6-DISASSOC: Interface Dot11Radio1, Deauthenticating Station 32b8.280e.fd5b Sending station has left the BSS
*Nov 23 06:14:53.675: %DOT11-6-ASSOC: Interface Dot11Radio0, Station 2261.c8c1.d5cd REAP Associated KEY_MGMT[Open]
*Nov 23 06:17:02.347: %DOT11-6-ASSOC: Interface Dot11Radio1, Station 12d8.6e2f.2e8a REAP Associated KEY_MGMT[Open]
*Nov 23 06:18:02.263: %DOT11-6-DISASSOC: Interface Dot11Radio1, Deauthenticating Station 12d8.6e2f.2e8a Sending station has left the BSS
*Nov 23 06:18:02.351: %DOT11-6-ASSOC: Interface Dot11Radio0, Station 12d8.6e2f.2e8a REAP Associated KEY_MGMT[Open]
*Nov 23 06:18:04.747: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 12d8.6e2f.2e8a Sending station has left the BSS
*Nov 23 06:18:12.915: %DOT11-6-ASSOC: Interface Dot11Radio1, Station 12d8.6e2f.2e8a REAP Associated KEY_MGMT[Open]
*Nov 23 06:18:15.135: %DOT11-6-DISASSOC: Interface Dot11Radio1, Deauthenticating Station 12d8.6e2f.2e8a Sending station has left the BSS
*Nov 23 06:18:28.367: %DOT11-6-ASSOC: Interface Dot11Radio1, Station 12d8.6e2f.2e8a REAP Associated KEY_MGMT[Open]
*Nov 23 06:19:13.083: %DOT11-6-DISASSOC: Interface Dot11Radio1, Deauthenticating Station 12d8.6e2f.2e8a Sending station has left the BSS
*Nov 23 06:19:25.331: %DOT11-6-ASSOC: Interface Dot11Radio1, Station 12d8.6e2f.2e8a REAP Associated KEY_MGMT[Open]
*Nov 23 06:19:38.247: %DOT11-6-DISASSOC: Interface Dot11Radio1, Deauthenticating Station 12d8.6e2f.2e8a Sending station has left the BSS
*Nov 23 06:19:50.123: %DOT11-6-ASSOC: Interface Dot11Radio1, Station 12d8.6e2f.2e8a REAP Associated KEY_MGMT[Open]
*Nov 23 06:20:22.087: %DOT11-6-DISASSOC: Interface Dot11Radio1, Deauthenticating Station 12d8.6e2f.2e8a Sending station has left the BSS
*Nov 23 06:20:30.335: %DOT11-6-ASSOC: Interface Dot11Radio1, Station 12d8.6e2f.2e8a REAP Associated KEY_MGMT[Open]
*Nov 23 06:21:40.179: %DOT11-6-ASSOC: Interface Dot11Radio1, Station 1e7d.3546.6cac REAP Associated KEY_MGMT[Open]
*Nov 23 06:21:42.023: %DOT11-6-DISASSOC: Interface Dot11Radio1, Deauthenticating Station 1e7d.3546.6cac Sending station has left the BSS
*Nov 23 06:21:43.311: %DOT11-6-DISASSOC: Interface Dot11Radio1, Deauthenticating Station 12d8.6e2f.2e8a Sending station has left the BSS
*Nov 23 06:21:52.915: %DOT11-6-ASSOC: Interface Dot11Radio1, Station 4e81.68d8.e097 REAP Associated KEY_MGMT[Open]
*Nov 23 06:21:59.947: %DOT11-6-ASSOC: Interface Dot11Radio1, Station 12d8.6e2f.2e8a REAP Associated KEY_MGMT[Open]
*Nov 23 06:22:04.499: %DOT11-6-DISASSOC: Interface Dot11Radio1, Deauthenticating Station 4e81.68d8.e097 Sending station has left the BSS
*Nov 23 06:22:09.735: %DOT11-6-DISASSOC: Interface Dot11Radio1, Deauthenticating Station 12d8.6e2f.2e8a Sending station has left the BSS
*Nov 23 06:22:22.267: %DOT11-6-ASSOC: Interface Dot11Radio1, Station 12d8.6e2f.2e8a REAP Associated KEY_MGMT[Open]
*Nov 23 06:22:32.567: %DOT11-6-DISASSOC: Interface Dot11Radio1, Deauthenticating Station 12d8.6e2f.2e8a Sending station has left the BSS
*Nov 23 06:22:40.587: %DOT11-6-ASSOC: Interface Dot11Radio1, Station 12d8.6e2f.2e8a REAP Associated KEY_MGMT[Open]
*Nov 23 06:24:15.831: %DOT11-6-DISASSOC: Interface Dot11Radio1, Deauthenticating Station 12d8.6e2f.2e8a Sending station has left the BSS
*Nov 23 06:24:15.927: %DOT11-6-ASSOC: Interface Dot11Radio0, Station 12d8.6e2f.2e8a REAP Associated KEY_MGMT[Open]
*Nov 23 06:24:43.779: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 12d8.6e2f.2e8a Sending station has left the BSS
*Nov 23 06:24:50.515: %DOT11-6-ASSOC: Interface Dot11Radio0, Station 12d8.6e2f.2e8a REAP Associated KEY_MGMT[Open]
*Nov 23 06:25:10.139: %DOT11-6-ASSOC: Interface Dot11Radio1, Station 4e81.68d8.e097 REAP Associated KEY_MGMT[Open]
*Nov 23 06:25:12.395: %DOT11-6-DISASSOC: Interface Dot11Radio1, Deauthenticating Station 4e81.68d8.e097 Sending station has left the BSS
*Nov 23 06:25:55.419: %DOT11-6-ASSOC: Interface Dot11Radio1, Station 6479.f048.5049 REAP Associated KEY_MGMT[Open]
*Nov 23 06:26:43.815: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 12d8.6e2f.2e8a Sending station has left the BSS
*Nov 23 06:26:43.907: %DOT11-6-ASSOC: Interface Dot11Radio1, Station 12d8.6e2f.2e8a REAP Associated KEY_MGMT[Open]
*Nov 23 06:28:18.419: %DOT11-6-DISASSOC: Interface Dot11Radio1, Deauthenticating Station 12d8.6e2f.2e8a Sending station has left the BSS
*Nov 23 06:28:20.375: %DOT11-6-ASSOC: Interface Dot11Radio1, Station 12d8.6e2f.2e8a REAP Associated KEY_MGMT[Open]
*Nov 23 06:28:34.411: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 2261.c8c1.d5cd Sending station has left the BSS
*Nov 23 06:29:04.067: %DOT11-6-DISASSOC: Interface Dot11Radio1, Deauthenticating Station 12d8.6e2f.2e8a Sending station has left the BSS
*Nov 23 06:29:05.331: %DOT11-6-ASSOC: Interface Dot11Radio1, Station 12d8.6e2f.2e8a REAP Associated KEY_MGMT[Open]
*Nov 23 06:29:29.031: %DOT11-6-DISASSOC: Interface Dot11Radio1, Deauthenticating Station 12d8.6e2f.2e8a Sending station has left the BSS
*Nov 23 06:29:31.539: %DOT11-6-ASSOC: Interface Dot11Radio1, Station 12d8.6e2f.2e8a REAP Associated KEY_MGMT[Open]
*Nov 23 06:29:38.463: %DOT11-6-DISASSOC: Interface Dot11Radio1, Deauthenticating Station 12d8.6e2f.2e8a Sending station has left the BSS
*Nov 23 06:29:49.319: %DOT11-6-ASSOC: Interface Dot11Radio1, Station 12d8.6e2f.2e8a REAP Associated KEY_MGMT[Open]
*Nov 23 06:30:29.931: %DOT11-6-DISASSOC: Interface Dot11Radio1, Deauthenticating Station 12d8.6e2f.2e8a Sending station has left the BSS
*Nov 23 06:30:32.467: %DOT11-6-ASSOC: Interface Dot11Radio1, Station 12d8.6e2f.2e8a REAP Associated KEY_MGMT[Open]
*Nov 23 06:30:33.323: %DOT11-6-ASSOC: Interface Dot11Radio1, Station 4e81.68d8.e097 REAP Associated KEY_MGMT[Open]
*Nov 23 06:30:35.759: %DOT11-6-DISASSOC: Interface Dot11Radio1, Deauthenticating Station 4e81.68d8.e097 Sending station has left the BSS
*Nov 23 06:30:35.851: %DOT11-6-ASSOC: Interface Dot11Radio0, Station 4e81.68d8.e097 REAP Associated KEY_MGMT[Open]
*Nov 23 06:30:36.987: %DOT11-4-CCMP_REPLAY: Client 4e81.68d8.e097 had 1 AES-CCMP TSC replays
*Nov 23 06:30:44.663: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 4e81.68d8.e097 Sending station has left the BSS
*Nov 23 06:30:59.163: %DOT11-6-ASSOC: Interface Dot11Radio1, Station 4e81.68d8.e097 REAP Associated KEY_MGMT[Open]
*Nov 23 06:31:22.071: %DOT11-6-DISASSOC: Interface Dot11Radio1, Deauthenticating Station 4e81.68d8.e097 Sending station has left the BSS
*Nov 23 06:32:33.787: %DOT11-6-ASSOC: Interface Dot11Radio0, Station 32b8.280e.fd5b REAP Associated KEY_MGMT[Open]
*Nov 23 06:33:03.367: %DOT11-6-ASSOC: Interface Dot11Radio0, Station 4e81.68d8.e097 REAP Associated KEY_MGMT[Open]
*Nov 23 06:33:04.335: %DOT11-6-DISASSOC: Interface Dot11Radio1, Deauthenticating Station 12d8.6e2f.2e8a Sending station has left the BSS
*Nov 23 06:33:11.243: %DOT11-6-ASSOC: Interface Dot11Radio0, Station 12d8.6e2f.2e8a REAP Associated KEY_MGMT[Open]
*Nov 23 06:33:21.823: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 4e81.68d8.e097 Sending station has left the BSS
*Nov 23 06:33:40.391: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 32b8.280e.fd5b Sending station has left the BSS
*Nov 23 06:33:43.255: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 12d8.6e2f.2e8a Sending station has left the BSS
*Nov 23 06:33:43.351: %DOT11-6-ASSOC: Interface Dot11Radio1, Station 12d8.6e2f.2e8a REAP Associated KEY_MGMT[Open]
*Nov 23 06:34:06.179: %DOT11-6-DISASSOC: Interface Dot11Radio1, Deauthenticating Station 12d8.6e2f.2e8a Sending station has left the BSS
*Nov 23 06:34:08.991: %DOT11-6-ASSOC: Interface Dot11Radio0, Station 12d8.6e2f.2e8a REAP Associated KEY_MGMT[Open]
*Nov 23 06:34:26.179: %DOT11-6-ASSOC: Interface Dot11Radio0, Station 8a4a.0580.ccc6 REAP Associated KEY_MGMT[Open]
*Nov 23 06:34:34.371: %DOT11-6-ASSOC: Interface Dot11Radio0, Station bea7.d4ff.350a REAP Associated KEY_MGMT[Open]
*Nov 23 06:34:45.795: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 8a4a.0580.ccc6 Sending station has left the BSS
*Nov 23 06:35:23.007: %DOT11-6-ASSOC: Interface Dot11Radio0, Station 32b8.280e.fd5b REAP Associated KEY_MGMT[Open]
*Nov 23 06:35:23.467: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 32b8.280e.fd5b Sending station has left the BSS
*Nov 23 06:35:43.407: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 12d8.6e2f.2e8a Sending station has left the BSS
*Nov 23 06:35:43.499: %DOT11-6-ASSOC: Interface Dot11Radio1, Station 12d8.6e2f.2e8a REAP Associated KEY_MGMT[Open]
*Nov 23 06:36:48.471: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station bea7.d4ff.350a Sending station has left the BSS
*Nov 23 06:37:24.043: %DOT11-4-FLUSH_DEAUTH: Consecutive tx fail 500+: deauth 6479.f048.5049
*Nov 23 06:37:24.043: %DOT11-6-DISASSOC: Interface Dot11Radio1, Deauthenticating Station 6479.f048.5049 Sending station has left the BSS
*Nov 23 06:38:36.663: %DOT11-6-DISASSOC: Interface Dot11Radio1, Deauthenticating Station 12d8.6e2f.2e8a Sending station has left the BSS
*Nov 23 06:38:38.495: %DOT11-6-ASSOC: Interface Dot11Radio1, Station 12d8.6e2f.2e8a REAP Associated KEY_MGMT[Open]
*Nov 23 06:38:47.487: %DOT11-6-DISASSOC: Interface Dot11Radio1, Deauthenticating Station 12d8.6e2f.2e8a Sending station has left the BSS
*Nov 23 06:38:49.967: %DOT11-6-ASSOC: Interface Dot11Radio1, Station 12d8.6e2f.2e8a REAP Associated KEY_MGMT[Open]
*Nov 23 06:40:02.983: %DOT11-6-DISASSOC: Interface Dot11Radio1, Deauthenticating Station 12d8.6e2f.2e8a Sending station has left the BSS
*Nov 23 06:40:21.827: %DOT11-6-ASSOC: Interface Dot11Radio1, Station 12d8.6e2f.2e8a REAP Associated KEY_MGMT[Open]
*Nov 23 06:40:53.979: %DOT11-6-DISASSOC: Interface Dot11Radio1, Deauthenticating Station 12d8.6e2f.2e8a Sending station has left the BSS
*Nov 23 06:45:09.219: %DOT11-6-ASSOC: Interface Dot11Radio1, Station fc42.032c.1643 REAP Associated KEY_MGMT[Open]
*Nov 23 06:45:24.115: %DOT11-6-DISASSOC: Interface Dot11Radio1, Deauthenticating Station fc42.032c.1643 Sending station has left the BSS
*Nov 23 06:53:05.127: %DOT11-6-ASSOC: Interface Dot11Radio1, Station 387a.0e8b.5d26 REAP Associated KEY_MGMT[Open]
*Nov 23 06:53:34.575: %DOT11-6-DISASSOC: Interface Dot11Radio1, Deauthenticating Station 387a.0e8b.5d26 Sending station has left the BSS
*Nov 23 07:10:24.883: %DOT11-6-ASSOC: Interface Dot11Radio0, Station bea7.d4ff.350a REAP Associated KEY_MGMT[Open]
*Nov 23 07:13:41.587: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station bea7.d4ff.350a Sending station has left the BSS
*Nov 23 07:15:35.039: %DOT11-6-ASSOC: Interface Dot11Radio0, Station c231.e079.8bdc REAP Associated KEY_MGMT[Open]
*Nov 23 07:15:41.875: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station c231.e079.8bdc Sending station has left the BSS
*Nov 23 07:16:09.091: %DOT11-6-ASSOC: Interface Dot11Radio0, Station 4e81.68d8.e097 REAP Associated KEY_MGMT[Open]
*Nov 23 07:22:04.355: %DOT11-6-ASSOC: Interface Dot11Radio0, Station 32b8.280e.fd5b REAP Associated KEY_MGMT[Open]
*Nov 23 07:23:08.983: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 32b8.280e.fd5b Sending station has left the BSS
*Nov 23 07:28:26.319: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 4e81.68d8.e097 Sending station has left the BSS
*Nov 23 07:31:00.091: %DOT11-6-ASSOC: Interface Dot11Radio0, Station c231.e079.8bdc REAP Associated KEY_MGMT[Open]
*Nov 23 07:31:06.663: %DOT11-6-ASSOC: Interface Dot11Radio1, Station e2ce.2969.625a REAP Associated KEY_MGMT[Open]
*Nov 23 07:31:10.003: %DOT11-6-DISASSOC: Interface Dot11Radio1, Deauthenticating Station e2ce.2969.625a Sending station has left the BSS
*Nov 23 07:31:26.243: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station c231.e079.8bdc Sending station has left the BSS
*Nov 23 07:34:00.495: %DOT11-6-ASSOC: Interface Dot11Radio1, Station c231.e079.8bdc REAP Associated KEY_MGMT[Open]
*Nov 23 07:36:29.715: %DOT11-6-ASSOC: Interface Dot11Radio1, Station 4e81.68d8.e097 REAP Associated KEY_MGMT[Open]
*Nov 23 07:36:40.643: %DOT11-6-DISASSOC: Interface Dot11Radio1, Deauthenticating Station 4e81.68d8.e097 Sending station has left the BSS
*Nov 23 07:39:06.159: %DOT11-6-DISASSOC: Interface Dot11Radio1, Deauthenticating Station c231.e079.8bdc Sending station has left the BSS
SSC-AP10#show version
ROM: Bootstrap program is C3700 boot loader
BOOTLDR: C3700 Boot Loader (AP3G2-BOOT-M) LoaderVersion 15.2(4)JB, RELEASE SOFTWARE (fc1)
SSC-AP10 uptime is 6 hours, 36 minutes
System image file is "flash:/ap3g2-k9w8-mx.153-3.JF9/ap3g2-k9w8-xx.153-3.JF9"
Last reload reason: Reset Command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco AIR-CAP3702E-H-K9 (PowerPC) processor (revision A0) with 376814K/134656K bytes of memory.
Processor board ID FGL2027X7QS
PowerPC CPU at 800Mhz, revision number 0x2151
Last reset from power-on
LWAPP image version 8.5.140.0
1 Gigabit Ethernet interface
2 802.11 Radios
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 00:2A:10:22:33:34
Part Number : 73-15397-01
PCB Serial Number : FOC20261J2V
Top Assembly Part Number : 068-05055-07
Top Assembly Serial Number : FGL2027X7QS
Top Revision Number : A0
Product/Model Number : AIR-CAP3702E-H-K9
Configuration register is 0xF
求大神解答!
2 条回复2
Last reset from power-on <<AP启动显示是power-on,可以一下AP供电情况是否稳定。
  • 如为power injector,可以换一个观察
  • 如为PoE供电,可以更换SW的接口和网线
Rps-Cheers | If it solves your problem, please mark as answer. Thanks !
您好:
谢谢您的解答,AP为外部电源供电,现在显示为DC / Full Power
我换一个电源试试,持续观察一下。
快捷链接
