取消
显示结果
搜索替代
您的意思是:
查看次数
有帮助
27
回复
AP反复加入控制器,然后反复断开.求助。
AlexChan21895
console口输出显示在下方,vWLC虚拟控制器版本为: 8.5.161,AP为AIR-OEAP1810-CRD,在控制器内识别为AIR-OEAP1810-B-K9,恢复出厂后,它会自动升级适合控制器的固件版本,自动加入等等一切正常,但是加入后很快它又会闪红黄绿三色灯,表示又在重新连接控制器,而这时候它在控制器的状态是加入中,而等上一会,它就会成功地加入到控制器,并且在控制器的已加入AP列表中出现,那时候会闪绿灯,但很快又会回到闪红黄绿三色灯的状态去。这样反反复复。
其他连在这控制器的几个3602正常工作没有问题。尝试过capwap ap erase all 命令恢复出厂,它也能自动加入到控制器,但加入控制器后就开始断开,然后反复加入。看console口输出显示看不到有什么问题。
以下是console口输出显示,后面那些相同的部分就是一直在反复加入和断开。附图为控制器上的出错信息。
Welcome to Cisco.
Usage of this device is governed by Cisco's End User License Agreement,
available at:
http://www.cisco.com/c/en/us/td/docs/general/warranty/English/EU1KEN_.html.
Restricted Rights Legend
Use, duplication, or disclosure by the Government is subject to
restrictions as set forth in subparagraph (c) of the Commercial
Computer Software - Restricted Rights clause at FAR sec. 52.227-19 and
subparagraph (c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
Cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
This product contains some software licensed under the
"GNU General Public License, version 2" provided with
ABSOLUTELY NO WARRANTY under the terms of
"GNU General Public License, version 2", available here:
http://www.gnu.org/licenses/old-licenses/gpl-2.0.html
"GNU Library General Public License, version 2" provided
with ABSOLUTELY NO WARRANTY under the terms of "GNU Library
http://www.gnu.org/licenses/old-licenses/lgpl-2.0.html
"GNU Lesser General Public License, version 2.1" provided
with ABSOLUTELY NO WARRANTY under the terms of "GNU Lesser
General Public License, version 2.1", available here:
http://www.gnu.org/licenses/old-licenses/lgpl-2.1.html
"GNU General Public License, version 3" provided with
"GNU General Public License, Version 3", available here:
http://www.gnu.org/licenses/gpl.html.
"GNU Affero General Public License, version 3" provided
"GNU Affero General Public License, version 3", available here:
http://www.gnu.org/licenses/agpl-3.0.html.
init started: BusyBox v1.23.2 (2020-02-17 12:14:41 PST)
[*01/01/1970 00:00:28.2913] GCM-128 POST passed
[*01/01/1970 00:00:28.2913] GCM-256 POST passed
[*01/01/1970 00:00:28.4113] === 5G radio domain is 41, COPY 5G BDF files from non_ETSI_BDF folder ===
[*01/01/1970 00:00:28.4612] 0
[*01/01/1970 00:00:28.6712] Active version: 8.5.161.0
[*01/01/1970 00:00:28.6712] Backup version: 8.5.151.0
Jan 1 00:00:28 FIPS[1659]: *** shell: FIPS Mode = disabled ***
[*01/01/1970 00:00:28.8611]
[*01/01/1970 00:00:28.8611] led pattern module start
User Access Verification
Username: [*01/01/1970 00:00:28.9211] AP1810
[*01/01/1970 00:00:29.0111] nss_driver - Turbo Support 1
[*01/01/1970 00:00:29.0111] Supported Frequencies - 110Mhz 550Mhz 733Mhz
[*01/01/1970 00:00:29.0411] NSS firmware booted
[*01/01/1970 00:00:29.0611] NSS firmware booted
[*01/01/1970 00:00:35.1891] ssdk_plat_init start
[*01/01/1970 00:00:35.1891] Register QCA PHY driver
[*01/01/1970 00:00:35.1991] PHY ID is 0x4dd036
[*01/01/1970 00:00:35.3691] qca probe f1 phy driver succeeded!
[*01/01/1970 00:00:35.3691] qca-ssdk module init succeeded!
[*01/01/1970 00:00:35.3791] Chip version 0x1302
[*01/01/1970 00:00:35.9789]
[*01/01/1970 00:00:35.9789] Swtich config done.
[*01/01/1970 00:00:37.9183] Current value of FACTORY_RESET=0
[*11/08/2016 23:59:59.0099] Last reload time: Apr 8 03:50:37 2020
[*04/08/2020 03:50:37.0000] Setting system time Wed Apr 8 03:50:37 UTC 2020
[*04/08/2020 03:50:37.0599] device wired0 entered promiscuous mode
[*04/08/2020 03:50:37.0899] device eth1 entered promiscuous mode
[*04/08/2020 03:50:38.6595] stile module dp init successfully
[*04/08/2020 03:50:38.6595] NBAR Label:BLD_V155_3_S_XE316_THROTTLE_LATEST_20180404_162221 NBAR VERSION:module build date: Feb 17 2020 at 12:28:56
[*04/08/2020 03:50:39.2993] miibus get dd50fc00!
[*04/08/2020 03:50:39.3293]
[*04/08/2020 03:50:39.3393] boot 26 build T-eaf8c9a5819ff90fa88df9b4045e20adf0d0a259-geaf8c9a5-vipendya board corsica mac 00:B0:E1:88:0C:C0
[*04/08/2020 03:50:39.3393] Module: mbedtls .text=0xbf000000 data=0xbf007e18 bss=0xbf008070
[*04/08/2020 03:50:39.3393] Module: aptrace .text=0xbf00c000 data=0xbf018834 bss=0xbf018cc0
[*04/08/2020 03:50:39.3393] Module: led_module .text=0xbf020000 data=0xbf0204e0 bss=0xbf020b48
[*04/08/2020 03:50:39.3393] Module: qca_nss_gmac .text=0xbf024000 data=0xbf02abd4 bss=0xbf02b098
[*04/08/2020 03:50:39.3393] Module: qca_nss_drv .text=0xbf034000 data=0xbf04f9e8 bss=0xbf050798
[*04/08/2020 03:50:39.3393] Module: qca_nss_capwapmgr .text=0xbf071000 data=0xbf075ad4 bss=0xbf075c28
[*04/08/2020 03:50:39.3393] Module: nssmgrctl .text=0xbf07c000 data=0xbf07d728 bss=0xbf07da4c
[*04/08/2020 03:50:39.3393] Module: qca_nss_portifmgr .text=0xbf083000 data= bss=0xbf083dcc
[*04/08/2020 03:50:39.3393] Module: qca_ssdk .text=0xbf088000 data=0xbf11e544 bss=0xbf123ecc
[*04/08/2020 03:50:39.3393] Module: proclikefs .text=0xbf172000 data= bss=0xbf172b40
[*04/08/2020 03:50:39.3393] Module: stile_lm_ft .text= data= bss=
[*04/08/2020 03:50:39.3393] Module: stile_lm_dp .text= data= bss=
[*04/08/2020 03:50:39.3393] Module: ipv6 .text=0xbfb01000 data=0xbfb31fc0 bss=0xbfb3386c
[*04/08/2020 03:50:39.3393] Module: bonding .text=0xbfb4d000 data=0xbfb5e640 bss=0xbfb5ea6c
[*04/08/2020 03:50:39.3393] Module: lowmemorykiller .text=0xbfb6b000 data=0xbfb6b2c0 bss=0xbfb6b44c
[*04/08/2020 03:50:39.3393] Module: qca_nss_profile:41.3886] ol_transfer_bin_file: flash data file defined
[*04/08/2020 03:50:41.3886] Cal location [0]: 00000000
[*04/08/2020 03:50:41.3886] Wifi0 NAND FLASH Select OFFSET 0x1000
[*04/08/2020 03:50:41.4086] qc98xx_verify_checksum: flash checksum passed: 0xd618
[*04/08/2020 03:50:41.4086] ol_transfer_bin_file 3979: Download Flash data len 12064
[*04/08/2020 03:50:41.4286]
[*04/08/2020 03:50:41.4286] Board data initialized
[*04/08/2020 03:50:41.4786] ol_ath_download_firmware :First OTP download and Execute is good address:0xd800 return param 4660
[*04/08/2020 03:50:41.4786] ol_ath_download_firmware:##Board Id 22 , CHIP Id 1
[*04/08/2020 03:50:41.4786] ol_transfer_bin_file: Board Data File download to address=0xc0000 file name=AR900B/hw.2/boardData_AR900B_CUS260_negative_pwr_offset_2G_2X2_022.bin
[*04/08/2020 03:50:41.5586]
[*04/08/2020 03:50:41.5586] [Flash] : Ignore Module param
[*04/08/2020 03:50:41.5586] ol_ath_download_firmware : Second OTP download and Execute is good, param=0x0
[*04/08/2020 03:50:41.5786] ol_transfer_bin_file: Downloading firmware file: AR900B/hw.2/athwlan.bin
[*04/08/2020 03:50:42.7482] HTC Rx: insufficient length, got:4 expected =8
[*04/08/2020 03:50:42.7482] Startup Mode-0 set
[*04/08/2020 03:50:42.7482] HTC Service:0x0300 ep:1 TX flow control disabled
[*04/08/2020 03:50:42.7482] HTC Service:0x0100 ep:2 TX flow control disabled
[*04/08/2020 03:50:42.7482] Firmware_Build_Number:70
[*04/08/2020 03:50:42.7482] num_rf_chain:0x00000002 ht_cap_info:0x0000185b vht_cap_info:0x339979b2 vht_supp_mcs:0x0000fffa
[*04/08/2020 03:50:42.7482] RES CFG Support wmi_service_bitmap 9778
[*04/08/2020 03:50:42.7482] Sending Ext resource cfg: HOST PLATFORM as 0 and fw_feature_bitmap as 50 to TGT
[*04/08/2020 03:50:42.7482] ol_ath_service_ready_event: sw_cal_support_check_flag: 1
[*04/08/2020 03:50:42.8282] wmi_ready_event_rx: WMI UNIFIED READY event
[*04/08/2020 03:50:42.8282] htt_h2t_frag_desc_bank_cfg_msg - HTT_H2T_MSG_TYPE_FRAG_DESC_BANK_CFG sent to FW for radio ID = 0
[*04/08/2020 03:50:42.8282] ACS not enabled
[*04/08/2020 03:50:42.8282] ol_ath_thermal_mitigation_attach: --
[*04/08/2020 03:50:42.8282] __ol_ath_attach() Allocated scn d7a40480
[*04/08/2020 03:50:42.8382] ol_ath_attach interface_id 1
[*04/08/2020 03:50:42.8482] Chip id: 0x9, chip version: 0x1000000
[*04/08/2020 03:50:42.8482] Target Version is 1000000
[*04/08/2020 03:50:42.8482] Flash Download Address c0000
[*04/08/2020 03:50:42.8482] ol_transfer_bin_file: flash data file defined
[*04/08/2020 03:50:42.8482] Cal location [1]: 00004000
[*04/08/2020 03:50:42.8482] wifi1 NAND FLASH Select OFFSET 0x5000
[*04/08/2020 03:50:42.8682] qc98xx_verify_checksum: flash checksum passed: 0xae3f
[*04/08/2020 03:50:42.8682] ol_transfer_bin_file 3979: Download Flash data len 12064
[*04/08/2020 03:50:42.8882]
[*04/08/2020 03:50:42.8882] Board data initialized
[*04/08/2020 03:50:42.9381] ol_ath_download_firmware :First OTP download and Execute is good address:0xd400 return param 4660
[*04/08/2020 03:50:42.9381] ol_ath_download_firmware:##Board Id 21 , CHIP Id 1
[*04/08/2020 03:50:42.9381] ol_transfer_bin_file: Board Data File download to address=0xc0000 file name=AR900B/hw.2/boardData_AR900B_CUS239_negative_pwr_offset_5G_2X2_021.bin
[*04/08/2020 03:50:43.0081]
[*04/08/2020 03:50:43.0081] [Flash] : Ignore Module param
[*04/08/2020 03:50:43.0081] ol_ath_download_firmware : Second OTP download and Execute is good, param=0x0
[*04/08/2020 03:50:43.0281] ol_transfer_bin_file: Downloading firmware file: AR900B/hw.2/athwlan.bin
[*04/08/2020 03:50:43.7479] FWLOG: [44601] WAL_DBGID_TX_AC_BUFFER_SET ( 0x3, 0xdeb001, 0x94c, 0x94c, 0x0 )
[*04/08/2020 03:50:43.7479] FWLOG: [44601] WAL_DBGID_TX_AC_BUFFER_SET ( 0x12, 0x1e, 0x94c, 0x94c, 0x0 )
[*04/08/2020 03:50:43.7479] FWLOG: [44601] WAL_DBGID_TX_AC_BUFFER_SET ( 0x45, 0x1e, 0x94c, 0x94c, 0x0 )
[*04/08/2020 03:50:43.7479] FWLOG: [44601] WAL_DBGID_TX_AC_BUFFER_SET ( 0x67, 0x1e, 0x94c, 0x94c, 0x0 )
[*04/08/2020 03:50:44.1977] HTC Rx: insufficient length, got:4 expected =8
[*04/08/2020 03:50:44.1977] Startup Mode-0 set
[*04/08/2020 03:50:44.1977] HTC Service:0x0300 ep:1 TX flow control disabled
[*04/08/2020 03:[*04/08/2020 03:51:01.0625] Loading sha2...
[*04/08/2020 03:51:01.0625] Dumpping sha1...
[*04/08/2020 03:51:02.5421] Loading MIC cert and key
[*04/08/2020 03:51:02.5421] Dumpping sha2...
[*04/08/2020 03:51:04.0216] Loading MIC cert and key
[*04/08/2020 03:51:04.4315] Generating key, this may take a while...
[*04/08/2020 03:51:08.7301] Public key portion is:
[*04/08/2020 03:51:08.7301] ssh-rsa AAAAB3NzaC1yc2EAAAADAQABAAABAQC26TxfEJHrGWUvetqKwWdOtKvFydoMRSV565vNfaCsIQonXzYM/JroWmHml2X7BhlcCRiT29xCRXhoYXEgqIz53t2VyAzU1zjAg/NSqUB/3N753WMkD35fCXN0oW8KsIZmCI48wOZc/kU8JpkzujaMPiow3A/kQ+/a8g6bAiFiAr2whntoyvmc57VuB8IKeWU1wBpKp5uOqns8ZXconFo2cyjBwubEg60h+5OKq8t6VXlYt7tBZbzVoF9XKiAA/zpVF73m04wem5Aq+GNHnEmiJjMW9Tk7a/Fm5/b9k8Vsxt1ddm3bUkTu5f4I4UVY1Hl1Ykfeg7shYxIGVa3mBC4V root@m00B0E1880CC0
[*04/08/2020 03:51:08.7301] Fingerprint: sha1!! b4:84:be:2f:dc:01:71:16:e8:fd:9f:7b:57:c0:1e:8d:13:1f:35:7a
[*04/08/2020 03:51:08.7701] pid 3997's current affinity mask: 3
[*04/08/2020 03:51:08.7701] pid 3997's new affinity mask: 1
[*04/08/2020 03:51:09.2800] Password for user changed
[*04/08/2020 03:51:09.4299] gzip -dc /etc/wcp.usermodule.template.gz | sed -e 's/__TX_POWER_2G_FILE__/\/radio_fw\/H2.csv/g' -e 's/__TX_POWER_5G_FILE__/\/radio_fw\/H5.csv/g' -e 's/__EVM_POWER_2G_FILE__/\/radio_fw\/EVM_2.csv/g' -e 's/__EVM_POWER_5G_FILE__/\/radio_fw\/EVM_5.csv/g' -e 's/__DOMAIN_2G__/0/g' -e 's/__DOMAIN_5G__/41/g' -e 's/__PWR_TABLE_49G__/0/g' -e 's/__PRODUCT_ID__/AIR-OEAP1810-B-K9/g' -e 's/__AP_TYPE__/63/g' -e 's/__WIRELESS_MAC__/00:B0:E1:88:99:80/g' -e 's/__WIRED_MAC__/00:B0:E1:88:0C:C0/g' -e 's/__WIRED1_MAC__/00:B0:E1:88:0C:C0/g' | DMALLOC_OPTIONS=debug=0x400003,inter=1000,log=/tmp/wcp.dmalloc.log,limit=40000000 wcpd &
[*04/08/2020 03:51:11.0094] DOT11_DRV[1]: Init Radio1
[*04/08/2020 03:51:11.0294] DOT11_DRV[1]: Stop Radio1
[*04/08/2020 03:51:11.0394] DOT11_DRV[1]: set_channel Channel set to 36
[*04/08/2020 03:51:11.0494] DOT11_DRV[0]: Init Radio0
[*04/08/2020 03:51:11.0794] DOT11_DRV[0]: Stop Radio0
[*04/08/2020 03:51:11.0794] DOT11_DRV[0]: set_channel Channel set to 6
[*04/08/2020 03:51:11.5293] DOT11_CFG[0] Radio Mode is changed from Local to FlexConnect
[*04/08/2020 03:51:11.5393] DOT11_DRV[0]: Start Radio0
[*04/08/2020 03:51:11.5393] DOT11_CFG[1] Radio Mode is changed from Local to FlexConnect
[*04/08/2020 03:51:11.5393] DOT11_DRV[1]: Start Radio1
[*04/08/2020 03:51:11.5592] ADDRCONF(NETDEV_CHANGE): wired3: link becomes ready
[*04/08/2020 03:51:11.5692] DOT11_DRV[0]: Stop Radio0
[*04/08/2020 03:51:11.7592] DOT11_DRV[0]: set_channel Channel set to 1
[*04/08/2020 03:51:11.7692] DOT11_DRV[0]: Start Radio0
[*04/08/2020 03:51:11.7692] DOT11_DRV[0]: Channel set to 1, width 20
[*04/08/2020 03:51:11.7692] DOT11_DRV[0]: Stop Radio0
[*04/08/2020 03:51:11.9891] DOT11_DRV[0]: Channel set to 1, width 20
[*04/08/2020 03:51:11.9991] DOT11_DRV[1]: Stop Radio1
[*04/08/2020 03:51:12.0091] DOT11_DRV[1]: set_channel Channel set to 36
[*04/08/2020 03:51:12.0091] DOT11_DRV[1]: Start Radio1
[*04/08/2020 03:51:12.0191] DOT11_DRV[1]: Stop Radio1
[*04/08/2020 03:51:12.1990] DOT11_DRV[1]: Start Radio1
[*04/08/2020 03:51:12.1990] DOT11_DRV[1]: Channel set to 36, width 80
[*04/08/2020 03:51:12.1990] DOT11_DRV[1]: Stop Radio1
[*04/08/2020 03:51:12.2090] DOT11_DRV[1]: Channel set to 36, width 80
[*04/08/2020 03:51:12.2290] /usr/sbin/capwapd: opening /click/cli_h/apr_bypass/active failed!: No such file or directory
[*04/08/2020 03:51:12.2290] !!!!! {/usr/sbin/capwapd} failed writing /click/cli_h/apr_bypass/active len 1 data: "1"
[*04/08/2020 03:51:16.9875] Waiting for uplink IPv4 configuration
[*04/08/2020 03:51:21.9860] Waiting for uplink IPv4 configuration
[*04/08/2020 03:51:22.7657] ethernet_port wired0, ip 192.168.1.247, netmask 255.255.255.0, gw 192.168.1.1, mtu 1500, bcast 192.168.1.255, dns1 192.168.1.1, domain lan, vid 0, static_ip_failover false, dhcp_vlan_failover false
[*04/08/2020 03:51:28.1141] DOT11_CFG[0] Radio Mode is changed from FlexConnect to FlexConnect
[*04/08/2020 03:51:28.1141] DOT11_CFG[1] Radio Mode is changed from FlexConnect to FlexConnect
[*04/08/2020 03:51:28.1641] AP IPv4 Address updated from 0.0.0.0 to 192.168.1.247
[*04/08/2020 03:51:28.1840] dtls_init: Use MIC certificate
[*04/08/2020 03:51:28.1840] CAPWAP State: Init
[*04/08/2020 03:51:28.1840] PNP is not required,
[*04/08/2020 03:51:28.1840] Starting CAPWAP discovery
[*04/08/2020 03:51:28.1840] CAPWAP State: Discovery
[*04/08/2020 03:51:28.1940] Discovery Request sent to 192.168.1.3, discovery type STATIC_CONFIG(1)
[*04/08/2020 03:51:28.1940] IP DNS query for CISCO-CAPWAP-CONTROLLER.lan
[*04/08/2020 03:51:28.6639] Discovery Request sent to 192.168.1.3, discovery type STATIC_CONFIG(1)
[*04/08/2020 03:51:28.6739] Discovery Request sent to 255.255.255.255, discovery type UNKNOWN(0)
[*04/08/2020 03:51:28.6739] CAPWAP State: Discovery
[*04/08/2020 03:51:28.6739] Discovery Response from 192.168.1.3
[*04/08/2020 03:51:28.7039] Discovery Response from 192.168.1.3
[*04/08/2020 03:51:28.7239] Discovery Response from 192.168.1.3
[*04/08/2020 03:53:49.0000]
[*04/08/2020 03:53:49.0000] CAPWAP State: DTLS Setup
[*04/08/2020 03:53:49.0199] First connect to vWLC, accept vWLC by default
[*04/08/2020 03:53:49.0399]
[*04/08/2020 03:53:49.0399] CAPWAP State: Join
[*04/08/2020 03:53:49.0399] Sending Join request to 192.168.1.3 through port 5248
[*04/08/2020 03:53:49.0599] Join Response from 192.168.1.3
[*04/08/2020 03:53:49.1499] nss_capwapmgr_enable_tunnel[1661]:ddf0e000: tunnel 0 is already enabled
[*04/08/2020 03:53:49.1699]
[*04/08/2020 03:53:49.1699] CAPWAP State: Image Data
[*04/08/2020 03:53:49.2099] do NO_UPGRADE, part2 is active part
[*04/08/2020 03:53:49.2199]
[*04/08/2020 03:53:49.2199] CAPWAP State: Configure
[*04/08/2020 03:53:49.2199] DOT11_CFG[0] Radio Mode is changed from FlexConnect to FlexConnect
[*04/08/2020 03:53:49.2199] DOT11_CFG[1] Radio Mode is changed from FlexConnect to FlexConnect
[*04/08/2020 03:53:52.0390] Re-Tx Count=1, Max Re-Tx Value=5, SendSeqNum=1, NumofPendingMsgs=1
[*04/08/2020 03:53:54.8882] Re-Tx Count=2, Max Re-Tx Value=5, SendSeqNum=1, NumofPendingMsgs=1
[*04/08/2020 03:53:57.7473] Re-Tx Count=3, Max Re-Tx Value=5, SendSeqNum=1, NumofPendingMsgs=1
[*04/08/2020 03:54:00.5964] Re-Tx Count=4, Max Re-Tx Value=5, SendSeqNum=1, NumofPendingMsgs=1
[*04/08/2020 03:54:03.4455] Re-Tx Count=5, Max Re-Tx Value=5, SendSeqNum=1, NumofPendingMsgs=1
[*04/08/2020 03:54:06.3046] Re-Tx Count=6, Max Re-Tx Value=5, SendSeqNum=1, NumofPendingMsgs=1
[*04/08/2020 03:54:06.3046] Max retransmission count exceeded, going back to DISCOVER mode.
[*04/08/2020 03:54:06.3146] DOT11_DRV[0]: Channel set to 1, width 20
[*04/08/2020 03:54:06.3246] DOT11_DRV[1]: Channel set to 36, width 80
[*04/08/2020 03:54:06.4345] Flexconnect Switching to Standalone Mode!
[*04/08/2020 03:54:06.7145]
[*04/08/2020 03:54:06.7145] CAPWAP State: DTLS Teardown
[*04/08/2020 03:54:11.5729] Discovery Response from 192.168.1.3
[*04/08/2020 03:54:11.5929] Discovery Response from 192.168.1.3
[*04/08/2020 03:54:11.6129] Discovery Response from 192.168.1.3
[*04/08/2020 03:54:22.0000]
[*04/08/2020 03:54:22.0000] CAPWAP State: DTLS Setup
[*04/08/2020 03:54:22.0399]
[*04/08/2020 03:54:22.0399] CAPWAP State: Join
[*04/08/2020 03:54:22.0399] Sending Join request to 192.168.1.3 through port 5248
[*04/08/2020 03:54:22.0499] Join Response from 192.168.1.3
[*04/08/2020 03:54:22.1499]
[*04/08/2020 03:54:22.1499] CAPWAP State: Image Data
[*04/08/2020 03:54:22.1999] do NO_UPGRADE, part2 is active part
[*04/08/2020 03:54:22.1999] CAPWAP State: Configure
[*04/08/2020 03:54:22.1999] DOT11_CFG[0] Radio Mode is changed from FlexConnect to FlexConnect
[*04/08/2020 03:54:22.1999] DOT11_CFG[1] Radio Mode is changed from FlexConnect to FlexConnect
[*04/08/2020 03:54:25.0291] Re-Tx Count=1, Max Re-Tx Value=5, SendSeqNum=1, NumofPendingMsgs=1
[*04/08/2020 03:54:27.8882] Re-Tx Count=2, Max Re-Tx Value=5, SendSeqNum=1, NumofPendingMsgs=1
[*04/08/2020 03:54:30.7473] Re-Tx Count=3, Max Re-Tx Value=5, SendSeqNum=1, NumofPendingMsgs=1
[*04/08/2020 03:54:33.5964] Re-Tx Count=4, Max Re-Tx Value=5, SendSeqNum=1, NumofPendingMsgs=1
[*04/08/2020 03:54:36.4455] Re-Tx Count=5, Max Re-Tx Value=5, SendSeqNum=1, NumofPendingMsgs=1
[*04/08/2020 03:54:39.3046] Re-Tx Count=6, Max Re-Tx Value=5, SendSeqNum=1, NumofPendingMsgs=1
[*04/08/2020 03:54:39.3046] Max retransmission count exceeded, going back to DISCOVER mode.
[*04/08/2020 03:54:39.3046] CAPWAP State: DTLS Teardown
[*04/08/2020 03:54:44.1931] Discovery Response from 192.168.1.3
[*04/08/2020 03:54:44.2231] Discovery Response from 192.168.1.3
[*04/08/2020 03:54:44.2330] Discovery Response from 192.168.1.3
[*04/08/2020 03:54:53.0000]
[*04/08/2020 03:54:53.0000] CAPWAP State: DTLS Setup
[*04/08/2020 03:54:53.0399]
[*04/08/2020 03:54:53.0399] CAPWAP State: Join
[*04/08/2020 03:54:53.0399] Sending Join request to 192.168.1.3 through port 5248
[*04/08/2020 03:54:53.0399] Join Response from 192.168.1.3
[*04/08/2020 03:54:53.1599]
[*04/08/2020 03:54:53.1599] CAPWAP State: Image Data
[*04/08/2020 03:54:53.2099] do NO_UPGRADE, part2 is active part
[*04/08/2020 03:54:53.2099] CAPWAP State: Configure
[*04/08/2020 03:54:53.2099] DOT11_CFG[0] Radio Mode is changed from FlexConnect to FlexConnect
[*04/08/2020 03:54:53.2099] DOT11_CFG[1] Radio Mode is changed from FlexConnect to FlexConnect
[*04/08/2020 03:54:56.0390] Re-Tx Count=1, Max Re-Tx Value=5, SendSeqNum=1, NumofPendingMsgs=1
[*04/08/2020 03:54:58.8882] Re-Tx Count=2, Max Re-Tx Value=5, SendSeqNum=1, NumofPendingMsgs=1
[*04/08/2020 03:55:01.7373] Re-Tx Count=3, Max Re-Tx Value=5, SendSeqNum=1, NumofPendingMsgs=1
[*04/08/2020 03:55:04.5964] Re-Tx Count=4, Max Re-Tx Value=5, SendSeqNum=1, NumofPendingMsgs=1
[*04/08/2020 03:55:07.4455] Re-Tx Count=5, Max Re-Tx Value=5, SendSeqNum=1, NumofPendingMsgs=1
[*04/08/2020 03:55:10.2946] Re-Tx Count=6, Max Re-Tx Value=5, SendSeqNum=1, NumofPendingMsgs=1
[*04/08/2020 03:55:10.2946] Max retransmission count exceeded, going back to DISCOVER mode.
[*04/08/2020 03:55:10.3046]
[*04/08/2020 03:55:10.3046] CAPWAP State: DTLS Teardown
[*04/08/2020 03:55:15.1831] Discovery Response from 192.168.1.3
[*04/08/2020 03:55:15.2031] Discovery Response from 192.168.1.3
[*04/08/2020 03:55:15.2231] Discovery Response from 192.168.1.3
最后这个log一直反复:*spamApTask2: Apr 08 14:18:43.394: %CAPWAP-3-POST_DECODE_ERR: capwap_ac_sm.c:6548 Post decode processing failed for Config status from AP 00:b0:e1:88:99:80
*spamApTask2: Apr 08 14:18:43.394: %LOG-3-Q_IND: spam_lrad.c:13481 APs 00:b0:e1:88:99:80 country code changed from (UX) to (US )
不知道什么意思,我的设置是US。
27 条回复27
AlexChan21895
1540488497lcj 发表于 2020-4-8 23:23
你好,我怀疑这个问题中了如下这个Bug:Cisco does not support the ap1810 with the vWLC
1810 OEAP ca ...
控制器里的AP状态的确有这么的一条,截图也有,估计是相同问题,那无法解决了。
是的,1810 OEAP无法加入vWLC, 官方已经解释了,这是文档的BUG,文档中说支持,但实际上不在vWLC上支持,且新的文档已经标注了无法在vWLC支持1810,所以可以肯定的是1810无法在vWLC使用了。
Rps-Cheers | If it solves your problem, please mark as answer. Thanks !
AlexChan21895
1540488497lcj 发表于 2020-4-9 09:49
是的,1810 OEAP无法加入vWLC, 官方已经解释了,这是文档的BUG,文档中说支持,但实际上不在vWLC上支持, ...
那请问能脱离AC独立使用吗?就当作一个胖AP那样。我看它设置里面可以设置个人SSID,就是不知道是不是一定要连上控制器才能使用这功能。
AlexChan21895 发表于 2020-4-10 18:50
那请问能脱离AC独立使用吗?就当作一个胖AP那样。我看它设置里面可以设置个人SSID,就是不知道是不是一定 ...
8系列不再称为胖AP,类似地,安装Mobility Express镜像的8系列AP可以单独使用,并管理其他支持的AP,但是AP1810在官网没有ME的镜像,所以应该是无法单独使用的。
如下是支持Mobility Express的AP
AlexChan21895
1540488497lcj 发表于 2020-4-10 21:33
8系列不再称为胖AP,类似地,安装Mobility Express镜像的8系列AP可以单独使用,并管理其他支持的AP,但是 ...
刚才尝试了一下设置个人SSID,可以当普通AP用了,只是还会不停地尝试加入控制器。
wuhao0015
试下这么玩,能注册的时候,设置成flexconnect,设置转发和认证都是本地,撤去控制器应该是可以玩的。。。
大兄弟,已经说的非常明确了:
1-OEAP1810在vWLC不支持,所以总是在尝试加入vWLC而无法稳定注册。
2-可以如@wuhao0015仁兄说的一样,修改为Flexconnect模式,这样local auth & local switching可以用用。
AlexChan21895
试过了,即使我指定了本机地址作为控制器,它在找不到控制器的情况下还是会向内网查找控制器,然后尝试向控制器注册,一切如常。
AlexChan21895 发表于 2020-4-11 13:58
试过了,即使我指定了本机地址作为控制器,它在找不到控制器的情况下还是会向内网查找控制器,然后尝试向 ...
FlexConnect模式的AP,如果使用local auth+local switching,当处于Standalone模式(即和WLC断开)的时候,依然可以提供无线服务。
Wubin2010
通常是国家代码问题了...
wuhao0015
实在不行试下C9800-CL控制器,估计支持1810。控制器支持local和flexconnect,需要许可默认可试用90天。
18653465190
感觉是版本的问题。
349797592@qq.com
老铁,能否加下微信交流一思科无线控制器的问题 ziyoufeix01
快捷链接
