能console接入到pri15的权限吧?
是否有按照官方指南完成初始化?
Option 1. Initial CLI Configuration
Once the EWC partition boots up, a prompt offers to start up an initial configuration wizard. This article covers manual configuration from scratch, without the use of Catalyst Wireless app or web browser wizard:
--- System Configuration Dialog ---
Would you like to enter the initial configuration dialog? [yes/no]: no
Would you like to terminate autoinstall? [yes]: no
WLC2CF8.9B5F.8628#configure terminal
Enter configuration commands, one per line. End with CNTL/Z.
WLC2CF8.9B5F.8628(config)#hostname EWC
######## Cteates local user admin ########
EWC(config)#user-name admin
EWC(config-user-name)#privilege 15
EWC(config-user-name)#password 0 Cisco123
EWC(config-user-name)#exit
######## Specifies credentials used to log into APs joined to this EWC ########
EWC(config)#ap profile default-ap-profile
EWC(config-ap-profile)#mgmtuser username admin password 0 Cisco123 secret 0 Cisco123
EWC(config-ap-profile)#exit
######## Configures management interface IP address and subnet########
EWC(config)#interface gigabitEthernet 0
EWC(config-if)#ip address 192.168.1.15 255.255.255.0
EWC(config-if)#exit
######## Default gateway IP address ########
EWC(config)#ip default-gateway 192.168.1.1
######## Enables web interface of EWC ########
EWC(config)#ip http server
EWC(config)#ip http secure-server
######## Write to memory ########
EWC(config)#end
EWC#write memory
如果还是console进入的话,可以试试配置如下命令:
username <username> privilege 15 password 7 <password>
aaa new-model
aaa authentication login default local
aaa authentication enable default enable
如果还不行,可以采集个show run看看。
