取消
显示结果
搜索替代
您的意思是:
查看次数
有帮助
回复
SSID无法连接,密码正确的,其他两个SSID正常?????
weihunter
环境:WLC3504+AP1815I
版本:8.5.151.0
部署模式:
FlexConnect Local Switching
交换机AP接口的设置:
switchport trunk native vlan 45(45是ap的ip网段)
switchport trunk allowed vlan 45,210,220,250(210-250是三个SSID客户端分配IP的网段)
switchport mode trunk
dhcp是一台windows server并且在vlan做了中继,配置如下(dhcp服务器确认无异常)
interface Vlan250
ip address 10.10.51.254 255.255.252.0
ip helper-address 192.168.1.184
interface Vlan220
description metting_wifi
ip address 10.10.20.254 255.255.255.0
已做故障排查测试:重启了WLC,问题依旧,尝试抓包,但是wifi一直连接不了,也没抓到包。
异常情况:
WLC设置了3个SSID广播,当初部署完成时候全都可以正常使用,正常拿到IP,现在其中一个SSID无法正常连接了,但是以前加入并长期连接的客户端可以自动连接上,新增终端设备无法通过该SSID连接,这期间无修改过任何配置,我检查了日志,也没有相关报错信息(报错的应该是ipv6相关的),日志大致如下,有经验的大神们,方便指导一下接下来的排错思路吗?我现在想不到其他思路,谢谢。
*spamApTask5: Jan 07 10:08:47.267: %CAPWAP-3-DISC_AP_MGR_ERR1: capwap_ac_sm.c:2129 The system is unable to process Primary discovery request from AP c4:f7:d5:c6:cf:00 on interface (1), VLAN (45), could not get IPv6 AP manager
*spamApTask5: Jan 07 10:08:38.643: %CAPWAP-3-DISC_AP_MGR_ERR1: capwap_ac_sm.c:2129 The system is unable to process Primary discovery request from AP a0:93:51:44:13:20 on interface (1), VLAN (45), could not get IPv6 AP manager
*spamApTask5: Jan 07 10:08:37.922: %CAPWAP-3-DISC_AP_MGR_ERR1: capwap_ac_sm.c:2129 The system is unable to process Primary discovery request from AP d4:c9:3c:79:16:80 on interface (1), VLAN (45), could not get IPv6 AP manager
*spamApTask7: Jan 07 10:08:37.895: %CAPWAP-3-DISC_AP_MGR_ERR1: capwap_ac_sm.c:2129 The system is unable to process Primary discovery request from AP 70:ea:1a:02:fc:e0 on interface (1), VLAN (45), could not get IPv6 AP manager
*spamApTask7: Jan 07 10:08:37.640: %CAPWAP-3-DISC_AP_MGR_ERR1: capwap_ac_sm.c:2129 The system is unable to process Primary discovery request from AP 70:ea:1a:02:fc:40 on interface (1), VLAN (45), could not get IPv6 AP manager
*spamApTask6: Jan 07 10:08:37.340: %CAPWAP-3-DISC_AP_MGR_ERR1: capwap_ac_sm.c:2129 The system is unable to process Primary discovery request from AP 70:ea:1a:c1:79:20 on interface (1), VLAN (45), could not get IPv6 AP manager
*spamApTask6: Jan 07 10:08:36.944: %CAPWAP-3-DISC_AP_MGR_ERR1: capwap_ac_sm.c:2129 The system is unable to process Primary discovery request from AP d4:c9:3c:85:ff:40 on interface (1), VLAN (45), could not get IPv6 AP manager
*spamApTask1: Jan 07 10:08:34.592: %CAPWAP-3-DISC_AP_MGR_ERR1: capwap_ac_sm.c:2129 The system is unable to process Primary discovery request from AP d4:c9:3c:df:62:c0 on interface (1), VLAN (45), could not get IPv6 AP manager
*spamApTask2: Jan 07 10:08:34.409: %CAPWAP-3-DISC_AP_MGR_ERR1: capwap_ac_sm.c:2129 The system is unable to process Primary discovery request from AP d4:c9:3c:d3:40:00 on interface (1), VLAN (45), could not get IPv6 AP manager
*spamApTask7: Jan 07 10:08:34.319: %CAPWAP-3-DISC_AP_MGR_ERR1: capwap_ac_sm.c:2129 The system is unable to process Primary discovery request from AP d4:c9:3c:df:2b:a0 on interface (1), VLAN (45), could not get IPv6 AP manager
*spamApTask2: Jan 07 10:08:33.505: %CAPWAP-3-DISC_AP_MGR_ERR1: capwap_ac_sm.c:2129 The system is unable to process Primary discovery request from AP 70:ea:1a:0e:08:c0 on interface (1), VLAN (45), could not get IPv6 AP manager
*spamApTask3: Jan 07 10:08:32.763: %CAPWAP-3-DISC_AP_MGR_ERR1: capwap_ac_sm.c:2129 The system is unable to process Primary discovery request from AP 70:ea:1a:89:1c:40 on interface (1), VLAN (45), could not get IPv6 AP manager
*spamApTask4: Jan 07 10:08:32.652: %CAPWAP-3-DISC_AP_MGR_ERR1: capwap_ac_sm.c:2129 The system is unable to process Primary discovery request from AP d4:c9:3c:75:e8:a0 on interface (1), VLAN (45), could not get IPv6 AP manager
*spamApTask1: Jan 07 10:08:32.446: %CAPWAP-3-DISC_AP_MGR_ERR1: capwap_ac_sm.c:2129 The system is unable to process Primary discovery request from AP 70:ea:1a:0e:09:80 on interface (1), VLAN (45), could not get IPv6 AP manager
*spamApTask4: Jan 07 10:08:32.347: %CAPWAP-3-DISC_AP_MGR_ERR1: capwap_ac_sm.c:2129 The system is unable to process Primary discovery request from AP d4:c9:3c:df:57:00 on interface (1), VLAN (45), could not get IPv6 AP manager
*spamApTask7: Jan 07 10:08:32.022: %CAPWAP-3-DISC_AP_MGR_ERR1: capwap_ac_sm.c:2129 The system is unable to process Primary discovery request from AP 70:ea:1a:0e:11:e0 on interface (1), VLAN (45), could not get IPv6 AP manager
*spamApTask4: Jan 07 10:08:31.709: %CAPWAP-3-DISC_AP_MGR_ERR1: capwap_ac_sm.c:2129 The system is unable to process Primary discovery request from AP 70:ea:1a:89:10:00 on interface (1), VLAN (45), could not get IPv6 AP manager
*spamApTask0: Jan 07 10:08:29.001: %CAPWAP-3-DISC_AP_MGR_ERR1: capwap_ac_sm.c:2129 The system is unable to process Primary discovery request from AP 70:ea:1a:0e:0e:a0 on interface (1), VLAN (45), could not get IPv6 AP manager
*spamApTask6: Jan 07 10:08:28.810: %CAPWAP-3-DISC_AP_MGR_ERR1: capwap_ac_sm.c:2129 The system is unable to process Primary discovery request from AP 70:ea:1a:95:64:20 on interface (1), VLAN (45), could not get IPv6 AP manager
*spamApTask4: Jan 07 10:08:28.538: %CAPWAP-3-DISC_AP_MGR_ERR1: capwap_ac_sm.c:2129 The system is unable to process Primary discovery request from AP 70:ea:1a:02:fa:c0 on interface (1), VLAN (45), could not get IPv6 AP manager
*spamApTask1: Jan 07 10:08:28.013: %CAPWAP-3-DISC_AP_MGR_ERR1: capwap_ac_sm.c:2129 The system is unable to process Primary discovery request from AP 00:ea:bd:ce:dd:a0 on interface (1), VLAN (45), could not get IPv6 AP manager
*spamApTask0: Jan 07 10:08:26.649: %CAPWAP-3-DISC_AP_MGR_ERR1: capwap_ac_sm.c:2129 The system is unable to process Primary discovery request from AP 70:ea:1a:0e:0f:60 on interface (1), VLAN (45), could not get IPv6 AP manager
*Dot1x_NW_MsgTask_7: Jan 07 10:08:26.604: %DOT1X-3-PSK_CONFIG_ERR: 1x_ptsm.c:749 Client 28:b2:bd:b3:14:1f may be using an incorrect PSK
*spamApTask1: Jan 07 10:08:26.375: %CAPWAP-3-DISC_AP_MGR_ERR1: capwap_ac_sm.c:2129 The system is unable to process Primary discovery request from AP 70:ea:1a:0e:0a:a0 on interface (1), VLAN (45), could not get IPv6 AP manager
*spamApTask5: Jan 07 10:08:25.220: %CAPWAP-3-DISC_AP_MGR_ERR1: capwap_ac_sm.c:2129 The system is unable to process Primary discovery request from AP d4:c9:3c:df:35:00 on interface (1), VLAN (45), could not get IPv6 AP manager
*spamApTask7: Jan 07 10:08:24.699: %CAPWAP-3-DISC_AP_MGR_ERR1: capwap_ac_sm.c:2129 The system is unable to process Primary discovery request from AP d4:c9:3c:86:57:40 on interface (1), VLAN (45), could not get IPv6 AP manager
*spamApTask2: Jan 07 10:08:24.573: %CAPWAP-3-DISC_AP_MGR_ERR1: capwap_ac_sm.c:2129 The system is unable to process Primary discovery request from AP d4:c9:3c:e8:d3:a0 on interface (1), VLAN (45), could not get IPv6 AP manager
*spamApTask1: Jan 07 10:08:24.328: %CAPWAP-3-DISC_AP_MGR_ERR1: capwap_ac_sm.c:2129 The system is unable to process Primary discovery request from AP a4:53:0e:20:aa:80 on interface (1), VLAN (45), could not get IPv6 AP manager
*spamApTask1: Jan 07 10:08:21.715: %CAPWAP-3-DISC_AP_MGR_ERR1: capwap_ac_sm.c:2129 The system is unable to process Primary discovery request from AP b0:8b:cf:55:a9:60 on interface (1), VLAN (45), could not get IPv6 AP manager
*spamApTask0: Jan 07 10:08:20.805: %CAPWAP-3-DISC_AP_MGR_ERR1: capwap_ac_sm.c:2129 The system is unable to process Primary discovery request from AP 70:ea:1a:0e:10:80 on interface (1), VLAN (45), could not get IPv6 AP manager
*spamApTask5: Jan 07 10:08:20.103: %CAPWAP-3-DISC_AP_MGR_ERR1: capwap_ac_sm.c:2129 The system is unable to process Primary discovery request from AP 00:ea:bd:dd:79:00 on interface (1), VLAN (45), could not get IPv6 AP manager
*spamApTask0: Jan 07 10:07:50.818: %CAPWAP-3-DISC_AP_MGR_ERR1: capwap_ac_sm.c:2129 The system is unable to process Primary discovery request from AP d4:c9:3c:86:28:20 on interface (1), VLAN (45), could not get IPv6 AP manager
*spamApTask0: Jan 07 10:07:50.166: %CAPWAP-3-DISC_AP_MGR_ERR1: capwap_ac_sm.c:2129 The system is unable to process Primary discovery request from AP 70:ea:1a:89:1d:40 on interface (1), VLAN (45), could not get IPv6 AP manager
*spamApTask4: Jan 07 10:07:49.822: %CAPWAP-3-DISC_AP_MGR_ERR1: capwap_ac_sm.c:2129 The system is unable to process Primary discovery request from AP 70:ea:1a:0d:ff:20 on interface (1), VLAN (45), could not get IPv6 AP manager
*spamApTask7: Jan 07 10:07:49.396: %CAPWAP-3-DISC_AP_MGR_ERR1: capwap_ac_sm.c:2129 The system is unable to process Primary discovery request from AP 70:ea:1a:0e:12:80 on interface (1), VLAN (45), could not get IPv6 AP manager
*spamApTask4: Jan 07 10:07:48.622: %CAPWAP-3-DISC_AP_MGR_ERR1: capwap_ac_sm.c:2129 The system is unable to process Primary discovery request from AP 70:ea:1a:70:d7:a0 on interface (1), VLAN (45), could not get IPv6 AP manager
*spamApTask7: Jan 07 10:07:48.562: %CAPWAP-3-DISC_AP_MGR_ERR1: capwap_ac_sm.c:2129 The system is unable to process Primary discovery request from AP 70:ea:1a:02:fe:40 on interface (1), VLAN (45), could not get IPv6 AP manager
*spamApTask5: Jan 07 10:07:47.891: %CAPWAP-3-DISC_AP_MGR_ERR1: capwap_ac_sm.c:2129 The system is unable to process Primary discovery request from AP d4:c9:3c:3d:a0:40 on interface (1), VLAN (45), could not get IPv6 AP manager
*spamApTask4: Jan 07 10:07:47.798: %CAPWAP-3-DISC_AP_MGR_ERR1: capwap_ac_sm.c:2129 The system is unable to process Primary discovery request from AP b0:8b:cf:0e:a3:00 on interface (1), VLAN (45), could not get IPv6 AP manager
*spamApTask3: Jan 07 10:07:47.382: %CAPWAP-3-DISC_AP_MGR_ERR1: capwap_ac_sm.c:2129 The system is unable to process Primary discovery request from AP d4:c9:3c:78:e8:20 on interface (1), VLAN (45), could not get IPv6 AP manager
*spamApTask3: Jan 07 10:07:24.492: %CAPWAP-3-DISC_AP_MGR_ERR1: capwap_ac_sm.c:2129 The system is unable to process Primary discovery request from AP 70:ea:1a:0e:03:80 on interface (1), VLAN (45), could not get IPv6 AP manager
*spamApTask6: Jan 07 10:07:24.221: %CAPWAP-3-DISC_AP_MGR_ERR1: capwap_ac_sm.c:2129 The system is unable to process Primary discovery request from AP d4:c9:3c:df:30:20 on interface (1), VLAN (45), could not get IPv6 AP manager
*spamApTask2: Jan 07 10:07:24.035: %CAPWAP-3-DISC_AP_MGR_ERR1: capwap_ac_sm.c:2129 The system is unable to process Primary discovery request from AP a8:b4:56:3c:86:20 on interface (1), VLAN (45), could not get IPv6 AP manager
*spamApTask4: Jan 07 10:07:23.947: %CAPWAP-3-DISC_AP_MGR_ERR1: capwap_ac_sm.c:2129 The system is unable to process Primary discovery request from AP d4:c9:3c:75:c6:e0 on interface (1), VLAN (45), could not get IPv6 AP manager
*spamApTask4: Jan 07 10:07:23.571: %CAPWAP-3-DISC_AP_MGR_ERR1: capwap_ac_sm.c:2129 The system is unable to process Primary discovery request from AP 70:ea:1a:0e:01:60 on interface (1), VLAN (45), could not get IPv6 AP manager
*spamApTask5: Jan 07 10:07:21.123: %CAPWAP-3-DISC_AP_MGR_ERR1: capwap_ac_sm.c:2129 The system is unable to process Primary discovery request from AP 70:ea:1a:0d:fa:40 on interface (1), VLAN (45), could not get IPv6 AP manager
*spamApTask1: Jan 07 10:07:20.738: %CAPWAP-3-DISC_AP_MGR_ERR1: capwap_ac_sm.c:2129 The system is unable to process Primary discovery request from AP d4:c9:3c:86:03:80 on interface (1), VLAN (45), could not get IPv6 AP manager
*spamApTask6: Jan 07 10:07:19.663: %CAPWAP-3-DISC_AP_MGR_ERR1: capwap_ac_sm.c:2129 The system is unable to process Primary discovery request from AP 70:ea:1a:0d:f9:60 on interface (1), VLAN (45), could not get IPv6 AP manager
*spamApTask5: Jan 07 10:06:53.206: %CAPWAP-3-DISC_AP_MGR_ERR1: capwap_ac_sm.c:2129 The system is unable to process Primary discovery request from AP c4:f7:d5:c6:cf:00 on interface (1), VLAN (45), could not get IPv6 AP manager
*spamApTask5: Jan 07 10:06:44.760: %CAPWAP-3-DISC_AP_MGR_ERR1: capwap_ac_sm.c:2129 The system is unable to process Primary discovery request from AP a0:93:51:44:13:20 on interface (1), VLAN (45), could not get IPv6 AP manager
*spamApTask5: Jan 07 10:06:43.836: %CAPWAP-3-DISC_AP_MGR_ERR1: capwap_ac_sm.c:2129 The system is unable to process Primary discovery request from AP d4:c9:3c:79:16:80 on interface (1), VLAN (45), could not get IPv6 AP manager
*spamApTask7: Jan 07 10:06:43.776: %CAPWAP-3-DISC_AP_MGR_ERR1: capwap_ac_sm.c:2129 The system is unable to process Primary discovery request from AP 70:ea:1a:02:fc:e0 on interface (1), VLAN (45), could not get IPv6 AP manager
*spamApTask7: Jan 07 10:06:43.597: %CAPWAP-3-DISC_AP_MGR_ERR1: capwap_ac_sm.c:2129 The system is unable to process Primary discovery request from AP 70:ea:1a:02:fc:40 on interface (1), VLAN (45), could not get IPv6 AP manager
*spamApTask6: Jan 07 10:06:43.312: %CAPWAP-3-DISC_AP_MGR_ERR1: capwap_ac_sm.c:2129 The system is unable to process Primary discovery request from AP 70:ea:1a:c1:79:20 on interface (1), VLAN (45), could not get IPv6 AP manager
*spamApTask6: Jan 07 10:06:42.901: %CAPWAP-3-DISC_AP_MGR_ERR1: capwap_ac_sm.c:2129 The system is unable to process Primary discovery request from AP d4:c9:3c:85:ff:40 on interface (1), VLAN (45), could not get IPv6 AP manager
*spamApTask1: Jan 07 10:06:40.876: %CAPWAP-3-DISC_AP_MGR_ERR1: capwap_ac_sm.c:2129 The system is unable to process Primary discovery request from AP d4:c9:3c:df:62:c0 on interface (1), VLAN (45), could not get IPv6 AP manager
*spamApTask7: Jan 07 10:06:40.724: %CAPWAP-3-DISC_AP_MGR_ERR1: capwap_ac_sm.c:2129 The system is unable to process Primary discovery request from AP d4:c9:3c:df:2b:a0 on interface (1), VLAN (45), could not get IPv6 AP manager
*spamApTask2: Jan 07 10:06:40.354: %CAPWAP-3-DISC_AP_MGR_ERR1: capwap_ac_sm.c:2129 The system is unable to process Primary discovery request from AP d4:c9:3c:d3:40:00 on interface (1), VLAN (45), could not get IPv6 AP manager
*spamApTask2: Jan 07 10:06:40.166: %CAPWAP-3-DISC_AP_MGR_ERR1: capwap_ac_sm.c:2129 The system is unable to process Primary discovery request from AP 70:ea:1a:0e:08:c0 on interface (1), VLAN (45), could not get IPv6 AP manager
*spamApTask4: Jan 07 10:06:39.413: %CAPWAP-3-DISC_AP_MGR_ERR1: capwap_ac_sm.c:2129 The system is unable to process Primary discovery request from AP d4:c9:3c:75:e8:a0 on interface (1), VLAN (45), could not get IPv6 AP manager
*spamApTask1: Jan 07 10:06:39.317: %CAPWAP-3-DISC_AP_MGR_ERR1: capwap_ac_sm.c:2129 The system is unable to process Primary discovery request from AP 70:ea:1a:0e:09:80 on interface (1), VLAN (45), could not get IPv6 AP manager
*spamApTask7: Jan 07 10:06:39.057: %CAPWAP-3-DISC_AP_MGR_ERR1: capwap_ac_sm.c:2129 The system is unable to process Primary discovery request from AP 70:ea:1a:0e:11:e0 on interface (1), VLAN (45), could not get IPv6 AP manager
*spamApTask3: Jan 07 10:06:39.043: %CAPWAP-3-DISC_AP_MGR_ERR1: capwap_ac_sm.c:2129 The system is unable to process Primary discovery request from AP 70:ea:1a:89:1c:40 on interface (1), VLAN (45), could not get IPv6 AP manager
*spamApTask4: Jan 07 10:06:38.964: %CAPWAP-3-DISC_AP_MGR_ERR1: capwap_ac_sm.c:2129 The system is unable to process Primary discovery request from AP d4:c9:3c:df:57:00 on interface (1), VLAN (45), could not get IPv6 AP manager
*spamApTask4: Jan 07 10:06:38.892: %CAPWAP-3-DISC_AP_MGR_ERR1: capwap_ac_sm.c:2129 The system is unable to process Primary discovery request from AP 70:ea:1a:89:10:00 on interface (1), VLAN (45), could not get IPv6 AP manager
*spamApTask0: Jan 07 10:06:35.432: %CAPWAP-3-DISC_AP_MGR_ERR1: capwap_ac_sm.c:2129 The system is unable to process Primary discovery request from AP 70:ea:1a:0e:0e:a0 on interface (1), VLAN (45), could not get IPv6 AP manager
*spamApTask6: Jan 07 10:06:35.194: %CAPWAP-3-DISC_AP_MGR_ERR1: capwap_ac_sm.c:2129 The system is unable to process Primary discovery request from AP 70:ea:1a:95:64:20 on interface (1), VLAN (45), could not get IPv6 AP manager
*spamApTask4: Jan 07 10:06:34.906: %CAPWAP-3-DISC_AP_MGR_ERR1: capwap_ac_sm.c:2129 The system is unable to process Primary discovery request from AP 70:ea:1a:02:fa:c0 on interface (1), VLAN (45), could not get IPv6 AP manager
*spamApTask1: Jan 07 10:06:34.144: %CAPWAP-3-DISC_AP_MGR_ERR1: capwap_ac_sm.c:2129 The system is unable to process Primary discovery request from AP 00:ea:bd:ce:dd:a0 on interface (1), VLAN (45), could not get IPv6 AP manager
*spamApTask0: Jan 07 10:06:32.656: %CAPWAP-3-DISC_AP_MGR_ERR1: capwap_ac_sm.c:2129 The system is unable to process Primary discovery request from AP 70:ea:1a:0e:0f:60 on interface (1), VLAN (45), could not get IPv6 AP manager
*spamApTask1: Jan 07 10:06:32.351: %CAPWAP-3-DISC_AP_MGR_ERR1: capwap_ac_sm.c:2129 The system is unable to process Primary discovery request from AP 70:ea:1a:0e:0a:a0 on interface (1), VLAN (45), could not get IPv6 AP manager
*spamApTask5: Jan 07 10:06:31.204: %CAPWAP-3-DISC_AP_MGR_ERR1: capwap_ac_sm.c:2129 The system is unable to process Primary discovery request from AP d4:c9:3c:df:35:00 on interface (1), VLAN (45), could not get IPv6 AP manager
*spamApTask7: Jan 07 10:06:30.654: %CAPWAP-3-DISC_AP_MGR_ERR1: capwap_ac_sm.c:2129 The system is unable to process Primary discovery request from AP d4:c9:3c:86:57:40 on interface (1), VLAN (45), could not get IPv6 AP manager
*spamApTask2: Jan 07 10:06:30.525: %CAPWAP-3-DISC_AP_MGR_ERR1: capwap_ac_sm.c:2129 The system is unable to process Primary discovery request from AP d4:c9:3c:e8:d3:a0 on interface (1), VLAN (45), could not get IPv6 AP manager
*spamApTask1: Jan 07 10:06:30.215: %CAPWAP-3-DISC_AP_MGR_ERR1: capwap_ac_sm.c:2129 The system is unable to process Primary discovery request from AP a4:53:0e:20:aa:80 on interface (1), VLAN (45), could not get IPv6 AP manager
*spamApTask1: Jan 07 10:06:27.668: %CAPWAP-3-DISC_AP_MGR_ERR1: capwap_ac_sm.c:2129 The system is unable to process Primary discovery request from AP b0:8b:cf:55:a9:60 on interface (1), VLAN (45), could not get IPv6 AP manager
*spamApTask0: Jan 07 10:06:26.714: %CAPWAP-3-DISC_AP_MGR_ERR1: capwap_ac_sm.c:2129 The system is unable to process Primary discovery request from AP 70:ea:1a:0e:10:80 on interface (1), VLAN (45), could not get IPv6 AP manager
*spamApTask5: Jan 07 10:06:26.060: %CAPWAP-3-DISC_AP_MGR_ERR1: capwap_ac_sm.c:2129 The system is unable to process Primary discovery request from AP 00:ea:bd:dd:79:00 on interface (1), VLAN (45), could not get IPv6 AP manager
*Dot1x_NW_MsgTask_0: Jan 07 10:06:08.345: %DOT1X-3-PSK_CONFIG_ERR: 1x_ptsm.c:749 Client 6c:8d:c1:41:5d:e0 may be using an incorrect PSK
*spamApTask0: Jan 07 10:05:56.728: %CAPWAP-3-DISC_AP_MGR_ERR1: capwap_ac_sm.c:2129 The system is unable to process Primary discovery request from AP d4:c9:3c:86:28:20 on interface (1), VLAN (45), could not get IPv6 AP manager
*spamApTask0: Jan 07 10:05:56.113: %CAPWAP-3-DISC_AP_MGR_ERR1: capwap_ac_sm.c:2129 The system is unable to process Primary discovery request from AP 70:ea:1a:89:1d:40 on interface (1), VLAN (45), could not get IPv6 AP manager
*spamApTask4: Jan 07 10:05:55.774: %CAPWAP-3-DISC_AP_MGR_ERR1: capwap_ac_sm.c:2129 The system is unable to process Primary discovery request from AP 70:ea:1a:0d:ff:20 on interface (1), VLAN (45), could not get IPv6 AP manager
*Dot1x_NW_MsgTask_7: Jan 07 10:05:55.650: %DOT1X-3-PSK_CONFIG_ERR: 1x_ptsm.c:749 Client 28:b2:bd:b3:14:1f may be using an incorrect PSK
*spamApTask7: Jan 07 10:05:55.329: %CAPWAP-3-DISC_AP_MGR_ERR1: capwap_ac_sm.c:2129 The system is unable to process Primary discovery request from AP 70:ea:1a:0e:12:80 on interface (1), VLAN (45), could not get IPv6 AP manager
4 条回复4
1、FlexConnect出现这样的情况,有可能是“认证down,本地转发”:该状态下,WLAN拒绝任何尝试认证的新的客户端,但是仍然继续发送信标和探测请求以维持现有的客户端。(该状态只在standalone mode(AP断开了WLC)下可以),不会是这样的情况吧?
2、其他两个SSID和这个SSID都是一样的模式吗?在FlexConnect的AP下,认证和转发方式都一样?
3、log信息应该是AP注册的相关信息,应该和该问题的关系不大。
4、是否有尝试过在WLC上执行debug client
Eg: debug client xx:xx:xx:xx:xx:xx
再尝试联系客户端,看看有没有debug信息弹出,如果有,看卡在了哪个阶段?
关闭debug:debug disable-all
Rps-Cheers | If it solves your problem, please mark as answer. Thanks !
weihunter
1540488497lcj 发表于 2020-1-7 11:50
1、FlexConnect出现这样的情况,有可能是“认证down,本地转发”:该状态下,WLAN拒绝任何尝试认证的新的客 ...
谢谢大神解答
1.AP一直都是全部在线的情况下,新客户端仅仅是接入异常的那个SSID才无法接入,接入其他两个SSID可以正常接入
2.其他两个SSID也是一样的模式,认证我都只做密码验证而已,就是WPA2 Encryption AES模式,选择PSK,并没有做RADIUS等验证
3.log确实我也觉得没影响
4.下班后我尝试debug看看,谢谢大佬
weihunter
大佬,对不起,那个ssid密码后来被修改过,然后我忘记了,乌龙。。问题已解决,谢谢。
赞!解决了就好
快捷链接
