取消
显示结果
搜索替代
您的意思是:
查看次数
有帮助
8
回复
Wireless controller HA
CSCO11269440
Wireless controller HA DHCP FAIL 這個目前是debug,
Internal DHCP is not supported when SSO is enabled.<===請問這個多久會修復
WLC 1
Redundancy Mode = SSO ENABLED
Local State = ACTIVE
Peer State = STANDBY HOT
Unit = Primary
Unit ID = CC:EF:48:0C:EB:E0
Redundancy State = SSO (Both AP and Client SSO)
Mobility MAC = CC:EF:48:0C:EB:E0
Average Redundancy Peer Reachability Latency = 448 usecs
Average Management Gateway Reachability Latency = 893 usecs
Redundancy Management IP Address................. 172.20.205.249
Peer Redundancy Management IP Address............ 172.20.205.248
Redundancy Port IP Address....................... 169.254.205.249
Peer Redundancy Port IP Address.................. 169.254.205.248
Peer Service Port IP Address..................... 172.17.1.66
WLC 2
Local State = STANDBY HOT
Peer State = ACTIVE
Unit = Secondary - HA SKU (Inherited AP License Count = 125)
Unit ID = CC:EF:48:B3:25:40
Average Management Gateway Reachability Latency = 539 usecs
Redundancy Management IP Address................. 172.20.205.248
Peer Redundancy Management IP Address............ 172.20.205.249
Redundancy Port IP Address....................... 169.254.205.248
Peer Redundancy Port IP Address.................. 169.254.205.249
8 条回复8
lindawa
控制器运行的软件版本是多少?
CSCO11269440
lindawa 发表于 2014-6-23 15:16 back.gif
控制器运行的软件版本是多少?
AIR-CT5500-K9-7-6-120-0
lindawa
CSCO11269440 发表于 2014-6-23 15:18 back.gif
当SSO开启的时候,内部DHCP不会支持。短期以内也不会有修复。
我们不建议在大型部署环境中使用内部DHCP; 这个功能只是给一些小型部署环境准备的,比如实验环境。
CSCO11269440
Internal DHCP 基本開啟在AP 取的IP使用,變成客戶既有的架構就要修改了。
使用外部DHCP Server取得不到IP,想請問一下DHCP 設定在介面內部的DHCP,因該沒有其他地方可以設定了吧!!
lindawa
CSCO11269440 发表于 2014-6-23 15:57 back.gif
使用外部DHCP Server取得不到IP ...
问题的后半部分没看明白。根据以上描述,我认为你应该排查为什么使用外部DHCP Server取得不到IP。
检查DHCP Server工作是否正常,是配置的问题还是网络原因?
如有必要,建议开TAC case以作进一步排查。
lindawa
764963038cisco
学习思路总结
CSCO11269440
上段設備為N5k,疑似沒有DHCP relay server 設定所以在另外一個網段架設DHCP server無法轉送封包,
目前會再另外再controller 網段架設DHCP Server.
屆時再做測試
N5k設定值
service dhcp
ip dhcp relay
ip dhcp relay information option
ip dhcp relay information option vpn
vpc domain 1
role priority 100
peer-keepalive destination 172.17.1.66 source 172.17.1.65
delay restore 150
peer-gateway
port-profile default max-ports 512
port-profile type vethernet NICv210
switchport access vlan 210
max-ports 32
state enabled
port-profile type vethernet vHBA
switchport mode trunk
switchport trunk native vlan 210
max-ports 32
state enabled
快捷链接
