取消
显示结果
搜索替代
您的意思是:
查看次数
有帮助
22
回复
WLC 2504 7.0升到7.6所遇到的问题
13817778909
IOS 7.0.120.0升7.6.120.0,按正常的流程是可以直接升级的,但此次升级碰到了问题。7.6的IOS刷进FLASH之后,系统提示 Reboot。重启后选择7.6.120.0进入系统,但系统一直停留在(启动镜像)这个阶段,无法启动,如下所示。
WLCNG Boot Loader Version 1.0.16 (Built on Feb 28 2011 at 13:14:54 by cisco)
Board Revision 0.0 (SN: PSZ16440A3A, Type: AIR-CT2504-K9) (W)
Verifying boot loader integrity... OK.
OCTEON CN5230C-SCP pass 2.0, Core clock: 750 MHz, DDR clock: 330 MHz (660 Mhz data rate)
CPU Cores: 4
DRAM: 1024 MB
Flash: 32 MB
Clearing DRAM........ done
Network: octeth0', octeth1, octeth2, octeth3
' - Active interface
E - Environment MAC address override
CF Bus 0 (IDE): OK
IDE device 0:
- Model: 1GB CompactFlash Card Firm: CF B612J Ser#: A191105254A12j5C7VDr
- Type: Hard Disk
- Capacity: 977.4 MB = 0.9 GB (2001888 x 512)
Press now to access the Boot Menu...
Loading primary image (7.6.120.0)
100%
36933676 bytes read
Launching...
Launching images...-----系统一直停留在这里,无法继续启动
后来以为7.6.120.0 IOS校验有问题,就把backup的IOS升到了7.6.130.0,结果也是到了这一步启动镜像就像死机一样,造成Active和Backup镜像都启动不了。后来重启按ESC进入boot menu,选择代码6。
Boot Loader Menu
1. Run primary image (7.6.130.0) - Active
2. Run backup image (Bad image type)
3. Change active boot image
4. Clear configuration
5. Format FLASH Drive
6. Manually update images
Enter selection: 6
Launching...
Launching images...
init started: BusyBox v1.6.0 (2010-05-13 17:50:10 EDT) multi-call binary
Mount failed for selinuxfs on /selinux: No such file or directory
starting pid 655, tty '': '/etc/init.d/rcS'
Use DHCP for ip configuration (Y/n)? n
Enter switch IP address: 10.40.3.2----------WLC Management IP地址
Enter switch netmask: 255.255.255.0------子网掩码
Enter switch gateway: 10.40.3.1-------------该网段的网关地址
Enter TFTP server IP address: 10.40.3.3---TFTP服务器IP
You have entered:
IP Address : 10.40.3.2
Netmask : 255.255.255.0
Gateway : 10.40.3.1
Server Ip Addr : 10.40.3.3
Is this correct(y/N)? y
!!! WARNING updating using .aes or unapproved files will disable this unit !!!
Do you want to update RTOS (y/N)? y
Do you want to update Primary Or Secondary Image (P/s)? s
Enter filename for RTOS update: @注:由于第一次升级时这里填写了WLC的IOS文件,所以导致了上文中的第二个镜像是:Bad image type,这里正确的文件名应该是:AS_5500_RTOS-7.0.116.0
Enter filename for FP update:
注:这里的两个文件是WLC底层的固件,需要CISCO提供,后来Cisco TAC张国敏张老师分享了这个WLC底层固件,恢复了WLC,重新进入了7.0.220.0。系统恢复之后,尝试升级到7.4.120.0,还是遇到了同样的问题。最后只能返厂维修了。
22 条回复22
LEonEmily
chonglin 发表于 2016-9-7 10:16 back.gif
你的是2504还是5508,5508的话
我是2504。
chonglin
LEonEmily 发表于 2016-10-10 23:38 back.gif
我是2504。
7-4-140-0这个版本刷成功了吗
q634153517
chonglin 发表于 2016-8-28 19:27
http://pan.baidu.com/s/1ntqPeh7 这里有这两个文件
兄弟,我2504的控制器使用这个文件升级后停留在跟楼主一样的界面无法继续启动,还有别的版本吗?发我一份1306035193@qq.com,谢谢了!
q634153517
楼主能共享下文件吗?我的是2504控制器 1306035193@qq.com 多谢!
sxsure001
很有用的经验。。。谢谢楼主分享
zhengwei272
感谢LZ分享
fortune
使用到了,好帖子,感谢!
wuleihen
Hello,可否分享下AS_5500_RTOS-7.0.116.0这两个文件镜像啊?我也遇到这问题,873420575@qq.com
快捷链接
