날짜: 05-20-2025 12:51 PM
Hi, I have a problem with slow ssh connection and slow command input on Nexus 9508(nx-os 10.2(1)F).
"show system internal process cpu" vsh.bin has high cpu usage.
Will a restart solve the problem?
What is the restart command, and is there no traffic interruption?
해결되었습니다! 솔루션으로 이동.
날짜: 05-20-2025 01:36 PM
Hello @hkmin
You probably need to reload yes.
So, do that on a maintenance windows....
Bug concern: https://bst.cisco.com/bugsearch/bug/CSCvi94714?rfs=qvlogin
Hello @hkmin
날짜: 05-20-2025 01:56 PM
Would it be a good idea to kill just that process?
날짜: 05-20-2025 03:09 PM
I have no background about killing that process and no idea if you could connect after that...without a reload after all...
날짜: 05-20-2025 05:20 PM
Please kill the PID with "kill background <PID> . But it will re-appear after some time.
Reload the chassis is permanent solution.
날짜: 05-20-2025 05:52 PM
The high vsh.bin CPU usage is likely causing the SSH and command input delay. You can try restarting the shell using restart vshd, which is typically non-disruptive to traffic.
Monitor closely and talk to the Cisco TAC if the issue continues, as it may indicate deeper system performance problems.
I hope it helps.
날짜: 05-26-2025 02:14 PM
I'm planning a reboot and will share the results later.
새로운 아이디어를 발견하고 저장하세요. 전문가 답변, 단계별 가이드, 최근 주제 등 다양한 내용을 확인해 보세요.
처음이신가요? 아래 팁들을 확인해 보세요. 시스코 커뮤니티 사용하기 새 멤버 가이드
