Port Forwarding
Im making as i think it should be , port forwarding but it seems to do not work.
I have a Telco Router with DMZ on WAN ISA 500 WAN PORT, so everithing should arribe to ISA device
I PUT AS ports 44008-44008 UDP/TCP , translated ports 44008 (in label CAMERA), and IP TRANSLATED LAN IP of ip camera
IP Camera is responding on 44408
But i could not gain access to wan ip:44008
No connection
Any idea?
juliomar
Level 3
Level 3
Hi Alberto,
Your port forward ACL shows the policy is from Zone Any to Zone Any.  When I create port forward policy, the corresponding ACL shows from Zone WAN To Zone Any.
My ACL ended up looking as:
Can you try to re-create Port Forward rule to see if you get similar config as I got?
Cheers,
Julio
It worked
Many thanks!
BR
