How to use get access token for using xdr apis
rekha09
Hello
I am new to Cisco Xdr. We need to use xdr api for judgment https://developer.cisco.com/docs/cisco-xdr/global-intel-api-guide/#sample-code
. We are not sure how to get access token ( or api client/secret) for authentication. https://developer.cisco.com/docs/cisco-xdr/authentication/#authentication
Can someone guide in this.
ben.greenbaum
Hi Rekha,
While it's possible to use the Global Intel API to fetch judgements, it may not be the best approach, as it leaves out all of your other XDR modules. Is there a specific reason that you only want results from that source? The better, more complete option would be to use the XDR "deliberate" API
As for getting the access token, you linked to the documentation page for it so I'm not sure what specific questions you may have. In a recent python project, I used the following:
def get_xdr_access_token(client_id, client_secret):
    Obtains an OAuth2 access token from the Cisco XDR API using client credentials flow.
    Args:
        client_id (str): The XDR API client ID.
        client_secret (str): The XDR API client secret.
    Returns:
        str: The access token if successful, None otherwise.
    token_url = f"{XDR_API_BASE_URL}/{XDR_TOKEN_URL_PATH}"
    headers = {
        "Content-Type": "application/x-www-form-urlencoded",
        "Accept": "application/json"
    data = {
        "grant_type": "client_credentials",
        "client_id": client_id,
        "client_secret": client_secret
    try:
        response = requests.post(token_url, headers=headers, data=data)
        response.raise_for_status()  # Raise an exception for HTTP errors (4xx or 5xx)
        token_data = response.json()
        access_token = token_data.get("access_token")
        if access_token:
            return access_token
        else:
            print("Error: Access token not found in the API response.")
            print(f"Full response: {json.dumps(token_data, indent=2)}")
            return None
    except requests.exceptions.HTTPError as e:
        print(f"HTTP error during token acquisition: {e}")
        print(f"Response content: {response.text}")
        return None
    except requests.exceptions.ConnectionError as e:
        print(f"Network connection error during token acquisition: {e}")
        return None
    except json.JSONDecodeError:
        print(f"Error decoding JSON response from token endpoint. Response: {response.text}")
        return None
    except Exception as e:
        print(f"An unexpected error occurred while getting the access token: {e}")
        return None
There are also code examples in github at https://github.com/CiscoSecurity/tr-01-authentication
Hope that helps! If not please describe the exact issues you are running into.
