5.1.1.2 Smart Home Network username and password incorrect in instructions
djones137984307
I hope this is the proper place to ask this question.  I am a student.  I am attempting to complete my Cisco training,
Introduction to Packet Tracer English 0221.  I am stuck on Lab 5.1.1.2.  My Home Gateway Username and Password are said to be incorrect.  The instructions tell me that "admin" is to be used by both.
59 Replies 59
Rizani
I'm stuck too. I'd tried admin/admin, cisco/cisco, admin/cisco, even admin and no pass, but it says that must be pass.
I eventually ended up replacing the Home Gateway device.  Reconnected all the IoT devices and problem was solved.  My lab had a defective Home Gateway device but I do not understand what made it defective and caused it not to accept the username and password.
Cool. Nice to know
I tried what I said about using v7 and in PT7 works perfectly the same exercise. Witchcraft jajajaja
that not true  it doesnt work dont lie ur self
This worked for me too.
When you replaced the gateway did you have to re-configure the device also? Please share details if you did.
It has been a few years but I am pretty sure I reconfigured as well and it worked.
Rizani
After doing some reserch, I'm sure that is a problem of PTC 8. All thanks to a comment at a Youtube video. We have to try at PTC 7
"I discovered you cannot use the newest version of Packet Tracer (8) with this lesson. The username and password do not work to access the gateway from the tablet. You need to use Packet Tracer 7 or lower. This is a serious compatibility issue Cisco needs to resolve!"
Cisco....
This drove me crazy. I also had an issue with the PT Basics Quiz where one of the questions asked you something about the secret message but they apparently took away an activity file which was supposed to go with the quiz.
I had the same issue and it drove me nuts.
Of course you can.
But you need to run mqtbroker in the tablet programming section then: Desktop -> IOT monitor.
100% Solved this problem through your solution.
You Are The MAN!!!!!
This worked for me as well. Thank you!
