cancelar
Mostrando los resultados de
Buscar en lugar de
Quiere decir:
Visitas
ÚTIL
Respuestas
C240 disco compatibles
rony
Buenos dias una consulta amigos especialistas en cisco mire necesito aumentar la capacidad de disco del servidor de mi centro laboral que es un UCS C240 M3 la cual veo en su datasheet que acepta disco A03-D600GA2 UCS 600 GB 10 K SAS 2.5, lo cual por mi zona no hay, asi que mi pregunta es si este equipo se le puede poner un disco hp por ejemplo HP Enterprice 759212-B21 , 600GB, SAS 12Gb/s, 15000 RPM, 2.5". u otro
2 RESPUESTAS 2
Hola verifica la información de los siguientes articulos espero pueda ayudarte
https://www.cisco.com/c/dam/en/us/products/collateral/servers-unified-computing/ucs-c-series-rack-servers/C240M3_LFF_SpecSheet.pdf
https://www.cisco.com/c/dam/en/us/products/collateral/servers-unified-computing/ucs-c-series-rack-servers/c240m3-sff-specsheet.pdf
https://www.cisco.com/c/en/us/products/collateral/servers-unified-computing/ucs-c240-m3-rack-server/data_sheet_c78-700629.html
High-capacity, flexible internal storage
●  Up to 12 LFF or 16/24 SFF front-accessible, hot-swappable, SAS, SATA, or SSD drives for local storage, providing redundancy options and ease of serviceability
●  Balanced performance and capacity to meet application needs:
◦   SATA SSDs
◦   15,000 RPM SAS drives for highest performance
◦   10,000 RPM SAS drives for high performance and value
◦   7200-RPM SATA drives for high capacity and value
RAID 0, 1, 5, 6, 10, 50, and 60 support
A choice of RAID controllers to provide data protection for up to 12 or 24 SAS, SATA, or SSD drives in PCIe and mezzanine card form factors
Cisco UCS C-Series Integrated Management Controller (CIMC)
●  Web user interface for server management; remote keyboard, video, and mouse (KVM); virtual media; and administration
●  Virtual media support for remote CD and DVD drives as if local
●  Intelligent Platform Management Interface (IPMI) 2.0 support for out-of-band management through third‑party enterprise management systems
●  Command-line interface (CLI) for server management
saludos
buenas si gracias por responder si he visto todos esos enlaces pero como no tengo mucha experiencia en estos equipos keria saber con seguridad si puedo colocar un disco de otra marca que cumpla con las caracteristicas mensionjada en el datasheet ● Up to 12 LFF or 16/24 SFF front-accessible, hot-swappable, SAS, SATA, or SSD drives for local storage, providing redundancy options and ease of serviceability ● Balanced performance and capacity to meet application needs: ◦ SATA SSDs ◦ 15,000 RPM SAS drives for highest performance ◦ 10,000 RPM SAS drives for high performance and value ◦ 7200-RPM SATA drives for high capacity and value como por ejemplo ese hp que mensione, ya que no kiero comprar el disco en vano y despues no sea compatible con el equipo, por eso consultaba si alguein ha colocado algun disco de otra marca que no sea cisco en uno de esos equipos a ver si alguien por ahi tiene alguna experiencia con esos equipos con otras marcas de disco que no sea cisco
