cancelar
Mostrar resultados para
Pesquisar em vez de
Queria dizer:
Apresentações
Útil
Respostas
Bundle-Ether and Port-Channel wiht Cisco ASR9K Series and  Cisco ASR900
leandro1977
What´s wrong  between Bundle-Ether and Port-Channel wiht Cisco ASR9K Series and  Cisco ASR900?
O que pode estar errado com a configuração abaixo, pois a Bundle e o Port-Channel continuam down.
R1
interface Bundle-Ether20
mtu 9114
service-policy output PHB-BB-NC03-RT15-VI20-BO30-BP15-BE17
ipv4 address 187.100.150.114 255.255.255.254
bundle maximum-active links 2
load-interval 30
interface GigabitEthernet0/1/0/17
bundle id 20 mode active
bundle port-priority 1
lacp period short
speed 1000
carrier-delay up 200 down 0
load-interval 30
R1
#show interface bundle-ether20
Mon Feb 22 01:29:34.642 BRSPO
Bundle-Ether20 is down, line protocol is down
Interface state transitions: 0
Hardware is Aggregated Ethernet interface(s), address is 00a7.426b.4126
Internet address is 187.100.150.114/31
MTU 9114 bytes, BW 0 Kbit
reliability 255/255, txload Unknown, rxload Unknown
Encapsulation ARPA,
Full-duplex, 0Kb/s
loopback not set,
ARP type ARPA, ARP timeout 04:00:00
No. of members in this bundle: 1
GigabitEthernet0/1/0/17 Full-duplex 1000Mb/s Configured
Last input never, output 00:00:00
30 second input rate 0 bits/sec, 0 packets/sec
30 second output rate 0 bits/sec, 1 packets/sec
0 packets input, 0 bytes, 0 total input drops
0 drops for unrecognized upper-level protocol
Received 0 broadcast packets, 0 multicast packets
0 runts, 0 giants, 0 throttles, 0 parity
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
343 packets output, 42440 bytes, 0 total output drops
Output 0 broadcast packets, 343 multicast packets
0 output errors, 0 underruns, 0 applique, 0 resets
0 carrier transitions
R1
#show interfaces gigabitEthernet 0/1/0/17
Mon Feb 22 04:21:40.361 BRSPO
GigabitEthernet0/1/0/17 is up, line protocol is up
Interface state transitions: 531
Dampening enabled: penalty 0, not suppressed
half-life: 1 reuse: 750
suppress: 2000 max-suppress-time: 4
restart-penalty: 0
Hardware is GigabitEthernet, address is 0896.ad57.d439 (bia 0896.ad57.d439)
MTU 9114 bytes, BW 1000000 Kbit (Max: 1000000 Kbit)
reliability 255/255, txload 0/255, rxload 0/255
Encapsulation ARPA,
Full-duplex, 1000Mb/s, link type is force-up
output flow control is off, input flow control is off
Carrier delay (up) is 2000 msec
loopback not set,
Last link flapped 00:08:29
Last input 00:00:00, output 00:00:00
Last clearing of "show interface" counters 18w5d
5 minute input rate 1000 bits/sec, 2 packets/sec
5 minute output rate 1000 bits/sec, 2 packets/sec
182176101 packets input, 19984788422 bytes, 18598 total input drops
Received 2 broadcast packets, 4988422 multicast packets
388 runts, 628 giants, 0 throttles, 0 parity
17000 input errors, 8010 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
156831778 packets output, 43376079425 bytes, 0 total output drops
Output 52107 broadcast packets, 6024678 multicast packets
248 carrier transitions
R1
#show bundle bundle-ether 20
Mon Feb 22 01:24:53.370 BRSPO
Bundle-Ether20
Status: Down
Local links <active/standby/configured>: 0 / 0 / 1
Local bandwidth <effective/available>: 0 (0) kbps
MAC address (source): 00a7.426b.4126 (Chassis pool)
Inter-chassis link: No
Minimum active links / bandwidth: 1 / 1 kbps
Maximum active links: 2
Wait while timer: 2000 ms
Load balancing: Default
LACP: Operational
Flap suppression timer: Off
Cisco extensions: Disabled
Non-revertive: Disabled
mLACP: Not configured
IPv4 BFD: Not configured
Port Device State Port ID B/W, kbps
Gi0/1/0/17 Local Configured 0x0001, 0x0019 1000000
Link is Defaulted; LACPDUs are not being received from the partner
R2
interface Port-channel20
dampening
mtu 9100
ip address 187.100.150.115 255.255.255.254
no ip redirects
no ip unreachables
no ip proxy-arp
ip router isis
ip pim query-interval 100
ip pim sparse-mode
load-interval 30
carrier-delay msec 0
no negotiation auto
mpls ip
mpls label protocol ldp
mpls ldp igp sync delay 30
bfd interval 750 min_rx 750 multiplier 3
no bfd echo
isis circuit-type level-1
isis network point-to-point
isis metric 2000 level-1
isis authentication mode md5
isis authentication key-chain igp
no isis advertise prefix
service-policy input TRUST-BBONE-SEC-IN
interface GigabitEthernet0/1/3
dampening
mtu 9100
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
load-interval 30
negotiation auto
lacp port-priority 1
lacp rate fast
channel-group 20 mode active
hold-queue 4096 in
R2
#show interface Port-Channel20
Port-channel20 is down, line protocol is down
Hardware is GEChannel, address is 0038.dffd.23d3 (bia 0038.dffd.23d3)
Internet address is 187.100.150.115/31
MTU 9100 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
Keepalive set (10 sec)
Carrier delay is 0 msec
No. of active members in this channel: 0
No. of PF_JUMBO supported members in this channel : 1
Last input never, output never, output hang never
Last clearing of "show interface" counters 00:09:21
Input queue: 0/0/0/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/0 (size/max)
30 second output rate 0 bits/sec, 0 packets/sec
55 packets input, 4602 bytes, 0 no buffer
Received 0 broadcasts (0 IP multicasts)
0 watchdog, 0 multicast, 0 pause input
24 packets output, 3072 bytes, 0 underruns
0 unknown protocol drops
0 lost carrier, 0 no carrier, 0 pause output
R2
#show interface GigabitEthernet0/1/3
GigabitEthernet0/1/3 is up, line protocol is up
Hardware is A900-IMA8S1Z, address is 0038.dffd.23d3 (bia 0038.dffd.238c)
Full Duplex, 1000Mbps, link type is auto, media type is LX
output flow-control is unsupported, input flow-control is on
Last input 00:08:53, output 00:00:19, output hang never
Last clearing of "show interface" counters 00:08:47
Input queue: 0/4096/0/0 (size/max/drops/flushes); Total output drops: 0
Output queue: 0/40 (size/max)
0 watchdog, 55 multicast, 0 pause input
25 packets output, 3200 bytes, 0 underruns
0 output errors, 0 collisions, 1 interface resets
2 RESPOSTAS 2
Jaderson Pessoa
Olá amigo, bom dia!
a informação do seu port-channel mostra que o mesmo está com erro fisico:
Port-channel20 is down, line protocol is down.
Você ativou o mesmo com o "no shutdown".
Jaderson Pessoa
*** Rate All Helpful Responses ***
FGOSILVA
Bom dia,
Olhando o output da interface gigabitEthernet 0/1/0/17, vejo que a mesma está gerando muito CRC, você já chegou a verificar o meio físico ? Problemas com incremento de CRC estão ligados a meio físico, de uma olhada em cabeamento, conectores. Segue abaixo a saída:
R1#
Verificando as demais saídas não identifiquei mais nenhuma divergência.
Att,
