annuler
Affichage des résultats de
Rechercher plutôt
Vouliez-vous dire :
Visites
Compliment
Réponses
Problem accessing Cisco Switch with Ansible
nikuiz
Hi everyone,
I'm currently discovering Ansible and I'm trying to write a simple playbook that prints out the running configuration of a Cisco switch. The IP address of the Switch is 192.168.0.1.
I've set up SSH authentication with a public key, which works perfectly fine from the machine that hosts Ansible ( ssh ANSIBLE@192.168.0.1 works fine, ANSIBLE being the username configured on the Switch ).
Here is my playbook :
Here is my ansible.cfg :
Here is my hosts file :
The problem is that everytime I run the playbook, I get the following error : "Invalid Key". At first I thought the private key I was using was bad, but after seeing the logs on the switch I think there's another problem - when connecting to the switch, ansible doesn't specify any username.
Here are the logs from the switch, first screen is a simple SSH connection ( ssh ANSIBLE@192.168.0.1 ), second one is when i run the playbook :
Why does Ansible doesn't specify any username when connecting to my switch? I've tried several methods to specify it, such as ansible_user: ANSIBLE in vars:, etc...  but none of them actually works.
Thanks for your help!
1 RÉPONSE 1
Quelques remarques:
1) Dans votre configuration je ne vois pas de mot de passe.
2) On peut voir qu'il y a un succes juste avant , il serait possible d'avoir les config en entier ? Ou à défaut vous pouvez refaire un test uniquement avec la config pour un seul switch ?
3) Voici un document de ansible sur ce type de retour
https://docs.ansible.com/ansible/latest/network/user_guide/network_debug_troubleshooting.html#error-authentication-failed
*** Obtenez des réponses techniques plus rapidement : Vidéo (15 min. fr) Visitez mon Blog technique. ***
