annuler
Affichage des résultats de
Rechercher plutôt
Vouliez-vous dire :
Visites
Compliment
Réponses
rip is not working
mkbsalaa
On Router 1, I configured RIP and added the three networks: 11.0.0.0, 10.0.0.0, and 197.10.10.0. However, when I check the routing table, I do not see the other networks. On Routers 0 and 3, everything is okay.
1 SOLUTION APPROUVÉE
Solutions approuvées
luis_cordova
Hello
You assigned the wrong IP addresses to the interfaces.
Try these commands on Router1 to correct this:
Router(config)#interface serial 0/1/0
Router(config-if)#no ip address
Router(config-if)#interface serial 0/1/1
Router(config-if)#interface serial 0/1/0
Router(config-if)# ip address 12.0.0.2 255.0.0.0
Router(config-if)# ip address 11.0.0.2 255.0.0.0
Router(config-if)#exit
I hope this helps.
Voir la solution dans l'envoi d'origine
1 RÉPONSE 1
luis_cordova
Hello
I hope this helps.
