annuler
Affichage des résultats de
Rechercher plutôt
Vouliez-vous dire :
Visites
Compliment
Réponses
Configuration IPSLA group-schedule: suppression automatique des instances - Pourquoi? / Configuration IPSLA group-schedule: auto remove of instances - Why ?
Frederic RIBES
Salut à tous,
Nous sommes confrontés à un problème en raison de la configuration du "global group-schedule" :
ip sla group schedule 1 1-1169 schedule-period 300 start-time now ageout 3600
Comme vous pouvez le voir, le "life parameter" n'est pas défini (= 3600 par défaut). Ici ageout = lige = 3600
Après l'avoir configuré, toutes les instances IPSLA ont été supprimées automatiquement après quelques instants. Pourquoi sont-ils supprimés de la conf en cours?
Si j'ajoute "life forever" au group-schedule, les instances IPSLA ne sont pas supprimées:
ip sla group schedule 1 1-1169 schedule-period 300 life forever start-time now ageout 3600
Je voudrais connaître le rapport entre "ageout" et "life parameter".
Merci de votre aide.
Cordialement.
Selon Cisco doc:
"In the following example, operation 25 begins actively collecting data at 3:00 p.m. on April 5. This operation will age out after 12 hours of inactivity, which can be before it starts or after it has finished with its life. When this operation ages out, all configuration information for the operation is removed (that is, the configuration information is no longer in the running configuration in RAM)."
ip sla monitor schedule 25 life 43200 start-time 15:00 apr 5 ageout 43200
Message d'origine :
Hi all,
We were facing an issue due to the global group-schedule configured:
ip sla group schedule 1 1-1169 schedule-period 300 start-time now ageout 3600.
As you can see, life paramater is not set (=3600 by default). Here ageout = lige = 3600
After having configured it, all the IPSLA instances were removed automatically after a couple of time.
Why are they removed from the running conf ?
If I add "life forever" to the group-schedule, IPSLA instances are not removed:
I would like to know the link between ageout and life paramaters.
Thanks for your help.
Regards.
According to Cisco doc:
2 RÉPONSES 2
Francesco Molino
Bonjour
Le paramètre life définit le temps pendant lequel le sla va récupérer les infos. Le ageout définit le temps que le device garde le IP SLA en mémoire pendant qu'il ne collecte pas d'informations.
Quand vous dites il se supprime (c'est normal que le 1er supprime la config car le life n'est pas configuré en forever), combien de temps il s'est écoulé entre le moment où vous avez mis le ip sla et que la configuration a été effacée?
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
Bonjour Francisco et merci pour ces réponses.
Je pensais que si non défini, le life était de 3600s par défaut comme indiqué dans les docs Cisco.
La solution consiste donc à appliquer le life à forever pour éviter tout désagrément.
Les instances étaient supprimées aléatoirement au bout de quelques minutes et dans l'heure qui suivait généralement de mémoire.
Cordialement.
