annuler
Affichage des résultats de
Rechercher plutôt
Vouliez-vous dire :
Visites
Compliment
Réponses
need help with ACL configuration
Josh KR
In a workshop, I configured dhcp and it was functioning OK, but when I was trying to address a question about adding ACL, I did it, but it appears that it doesn't work, and even dhcp is ineffective now. Could you please help me? I can't find help from colleagues or teacher and I'm lost.
The attached is the project whereby I setup all of the questions.
And the question in the workshop was:
Packet filtering
 Implement the following policy:
 - The Production VLAN does not have Internet access
 - The WiFi VLAN, it has Internet access restricted to services: http, https, dns, smtp and pop3.
 - VLAN Management, it has open Internet access.
 - Only VLAN Management machines are authorized to do ssh on network equipment (switches and routers).
Thank you in advance to anyone who will take the time to help
2 RÉPONSES 2
Bonjour, sur quel routeur faut-il configurer la liste d'accès ?
Bonjour, je vais le configurer sur le switch fédérateur, Merci pour votre aide
