annuler
Affichage des résultats de
Rechercher plutôt
Vouliez-vous dire :
Visites
Compliment
Réponses
Cisco 2821 with VIC2-4FXO to Cisco 2921 with VIC3-4FXS Issue
Bernardin
Le site 2 peut appeler les autres sites. Les autres sites ne peuvent pas l'appeler.
Pour chaque routeur, trouvez ci-dessous les informations ci-jointes
Site 2 can call the others site. The others site can't call it.
For each router, find bellow information attached
sh version, sh license, sh run, sh inventory .....
SITE 1---------------------------------------------------------
SITE1#sh version
Cisco IOS Software, 2800 Software (C2800NM-IPVOICE-M), Version 12.4(13b), RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Tue 24-Apr-07 16:18 by prod_rel_team
ROM: System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
SITE1 uptime is 4 days, 11 hours, 23 minutes
System returned to ROM by reload at 08:49:28 GMT Sat Jan 7 2023
System image file is "flash:c2800nm-ipvoice-mz.124-13b.bin"
Cisco 2821 (revision 53.51) with 247808K/14336K bytes of memory.
Processor board ID FHK1102U03V
2 Gigabit Ethernet interfaces
24 Voice FXO interfaces
4 Voice FXS interfaces
DRAM configuration is 64 bits wide with parity enabled.
239K bytes of non-volatile configuration memory.
125440K bytes of ATA CompactFlash (Read/Write)
SITE1#
SITE1#
SITE1#
SITE1#
SITE1#sh license
SITE1#sh licens
SITE1#sh lice
SITE1#sh inve
SITE1#sh inventory
NAME: "2821 chassis", DESCR: "2821 chassis"
PID: CISCO2821 , VID: V03 , SN: FHK1102U03V
NAME: "2nd generation four port FXO voice interface daughtercard", DESCR: "2nd generation four port FXO voice interface daughtercard"
PID: VIC2-4FXO , VID: V01 , SN: FOC11334P0A
PID: VIC2-4FXO , VID: V03 , SN: FOC12495CUU
PID: VIC2-4FXO , VID: V03 , SN: FOC13020T89
PID: VIC2-4FXO= , VID: V , SN: FOC10014Q1N
NAME: "PVDMII DSP SIMM with Two DSPs", DESCR: "PVDMII DSP SIMM with Two DSPs"
PID: PVDM2-32 , VID: V01 , SN: FOC11295U9X
PID: PVDM2-32 , VID: V01 , SN: FOC12501JCJ
NAME: "High Density Analog Voice Module", DESCR: "High Density Analog Voice Module"
PID: NM-HDA-4FXS= , VID: 5.1, SN: FOC08383EBL
NAME: "Four port FXO voice interface daughtercard", DESCR: "Four port FXO voice interface daughtercard"
PID: EM-HDA-4FXO= , VID: 1.1, SN: FOC08132910
PID: EM-HDA-4FXO= , VID: 1.1, SN: FOC0835395C
SITE 2 -------------------------------------------------------------------------------------------------
SITE2WMP650#sh version
Cisco IOS Software, C2900 Software (C2900-UNIVERSALK9-M), Version 15.7(3)M7, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2020 by Cisco Systems, Inc.
Compiled Tue 01-Sep-20 15:17 by prod_rel_team
ROM: System Bootstrap, Version 15.0(1r)M15, RELEASE SOFTWARE (fc1)
SITE2WMP650 uptime is 1 hour, 25 minutes
System returned to ROM by reload at 20:37:14 GMT Sun Mar 6 2022
System image file is "flash:c2900-universalk9-mz.SPA.157-3.M7.bin"
Last reload type: Normal Reload
Last reload reason: Reload Command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco CISCO2921/K9 (revision 1.0) with 446464K/77824K bytes of memory.
Processor board ID FCZ161120F4
3 Gigabit Ethernet interfaces
2 Serial(sync/async) interfaces
1 terminal line
12 Voice FXS interfaces
255K bytes of non-volatile configuration memory.
250880K bytes of ATA System CompactFlash 0 (Read/Write)
License Info:
License UDI:
Device# PID SN
*1 CISCO2921/K9 FCZ161120F4
Suite License Information for Module:'c2900'
Suite Suite Current Type Suite Next reboot
FoundationSuiteK9 None None None
securityk9
datak9
AdvUCSuiteK9 None None None
uck9
cme-srst
cube
Technology Package License Information for Module:'c2900'
Technology Technology-package Technology-package
Current Type Next reboot
ipbase ipbasek9 Permanent ipbasek9
security None None None
uc uck9 Permanent uck9
data datak9 Permanent datak9
SITE2WMP650#
SITE2WMP650#
SITE2WMP650#sh inv
SITE2WMP650#sh inventory
NAME: "CISCO2921/K9", DESCR: "CISCO2921/K9 chassis, Hw Serial#: FCZ161120F4, Hw Revision: 1.0"
PID: CISCO2921/K9 , VID: V06 , SN: FCZ161120F4
NAME: "WAN Interface Card - HWIC Serial 2T on Slot 0 SubSlot 0", DESCR: "WAN Interface Card - HWIC Serial 2T"
PID: HWIC-2T , VID: V04 , SN: FOC15106DDW
NAME: "3rd generation four port FXS DID voice interface daughtercard on Slot 0 SubSlot 1", DESCR: "3rd generation four port FXS DID voice interface daughtercard"
PID: VIC3-4FXS/DID , VID: V03 , SN: FOC16036FMG
NAME: "3rd generation four port FXS DID voice interface daughtercard on Slot 0 SubSlot 2", DESCR: "3rd generation four port FXS DID voice interface daughtercard"
PID: VIC3-4FXS/DID , VID: V03 , SN: FOC15076U3V
NAME: "3rd generation four port FXS DID voice interface daughtercard on Slot 0 SubSlot 3", DESCR: "3rd generation four port FXS DID voice interface daughtercard"
PID: VIC3-4FXS/DID , VID: V03 , SN: FOC16216VVA
NAME: "PVDM3 DSP DIMM with 32 Channels on Slot 0 SubSlot 4", DESCR: "PVDM3 DSP DIMM with 32 Channels"
PID: PVDM3-32 , VID: V01 , SN: FOC16093R14
NAME: "C2921/C2951 AC Power Supply", DESCR: "C2921/C2951 AC Power Supply"
PID: PWR-2921-51-AC , VID: V03 , SN: QCS1551H0KK
SITE2WMP650#
1 SOLUTION APPROUVÉE
Solutions approuvées
Bernardin
I downgraded ios from (C2900-UNIVERSALK9-M), Version 15.7(3)M7 to  (C2900-UNIVERSALK9-M), Version 15.1(4)M4
Now it's working.
Voir la solution dans l'envoi d'origine
3 RÉPONSES 3
Jimena Saez
Community Manager
Community Manager
@Bernardin
Par hasard, auriez-vous le "sh run" pour les deux sites ?
Merci de les partager aussi !
Jimena
Bernardin
Hi @Jimena Saez
Thanks for your quick response, below is sh run config
SITE2#sh run
Building configuration...
Current configuration : 24385 bytes
! Last configuration change at 21:25:58 GMT Sun Mar 6 2022 by gmbsupport
version 15.7
service nagle
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service compress-config
hostname SITE2
boot-start-marker
boot system flash:c2900-universalk9-mz.SPA.157-3.M7.bin
boot-end-marker
ip name-server 8.8.4.4
ip multicast-routing
ip cef
no ipv6 cef
key chain hsrp
key 1
key-string 7 071B33595D1D4B554742
accept-lifetime local 05:00:01 May 1 2010 infinite
send-lifetime local 05:00:01 May 1 2010 infinite
voice-card 0
voice service voip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback pass-through g711ulaw
cause-code legacy
modem passthrough nse codec g711ulaw
vxml logging-tag
license udi pid CISCO2921/K9 sn FCZ161120F4
license accept end user agreement
license boot module c2900 technology-package datak9
hw-module pvdm 0/0
archive
log config
hidekeys
dial-control-mib retain-timer 30240
dial-control-mib max-size 600
ip telnet source-interface Loopback0
interface Loopback0
ip address 32.37.223.27 255.255.255.255
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
description U;GATOUAWAES001 F0/19
ip address 155.236.161.187 255.255.255.248
ip flow monitor NETFLOW-MONITOR input
ip flow monitor app_monitor output
duplex full
ip ftp source-interface Loopback0
ip tftp source-interface Loopback0
ip route 0.0.0.0 0.0.0.0 155.236.166.66
ip route 127.0.0.0 255.0.0.0 Null0
control-plane
voice-port 0/1/0
input gain 3
connection plar 0015
description extension 8837
voice-port 0/1/1
input gain 3
connection plar 0016
description extension 8838
voice-port 0/1/2
input gain 3
connection plar 0017
description extension 8840
voice-port 0/1/3
input gain 3
connection plar 0018
description extension 8845
voice-port 0/2/0
input gain 3
connection plar 0019
description extension 8846
voice-port 0/2/1
input gain 3
connection plar 0020
description extension 8787
voice-port 0/2/2
input gain 3
connection plar 0021
description extension 8848
voice-port 0/2/3
input gain 3
connection plar 0022
description extension 8849
voice-port 0/3/0
input gain 3
connection plar 0011
description extension 8833
voice-port 0/3/1
input gain 3
connection plar 0012
description extension 8834
voice-port 0/3/2
input gain 3
connection plar 0013
description extension 8835
voice-port 0/3/3
input gain 3
connection plar 0014
description extension 8836
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
dial-peer voice 11 voip
description ;to GARBIGW001
destination-pattern 0011
session target ipv4:155.236.167.2
incoming called-number 8833
dtmf-relay cisco-rtp
dial-peer voice 12 voip
destination-pattern 0012
incoming called-number 8834
dial-peer voice 13 voip
destination-pattern 0013
incoming called-number 8835
dial-peer voice 14 voip
destination-pattern 0014
incoming called-number 8836
dial-peer voice 15 voip
destination-pattern 0015
incoming called-number 8837
dial-peer voice 16 voip
destination-pattern 0016
incoming called-number 8838
dial-peer voice 17 voip
destination-pattern 0017
incoming called-number 8840
dial-peer voice 18 voip
destination-pattern 0018
incoming called-number 8845
dial-peer voice 19 voip
destination-pattern 0019
incoming called-number 8846
dial-peer voice 20 voip
destination-pattern 0020
incoming called-number 8787
ip qos dscp cs5 media
ip qos dscp cs3 signaling
dial-peer voice 21 voip
destination-pattern 0021
incoming called-number 8848
dial-peer voice 22 voip
destination-pattern 0022
incoming called-number 8849
dial-peer voice 8833 pots
destination-pattern 8833
port 0/3/0
dial-peer voice 8834 pots
destination-pattern 8834
port 0/3/1
dial-peer voice 8835 pots
destination-pattern 8835
port 0/3/2
dial-peer voice 8836 pots
destination-pattern 8836
port 0/3/3
dial-peer voice 8837 pots
destination-pattern 8837
port 0/1/0
dial-peer voice 8838 pots
destination-pattern 8838
port 0/1/1
dial-peer voice 8840 pots
destination-pattern 8840
port 0/1/2
dial-peer voice 8845 pots
destination-pattern 8845
port 0/1/3
dial-peer voice 8846 pots
destination-pattern 8846
port 0/2/0
dial-peer voice 8848 pots
destination-pattern 8848
port 0/2/2
dial-peer voice 8849 pots
destination-pattern 8849
port 0/2/3
dial-peer voice 8787 pots
destination-pattern 8787
port 0/2/1
gatekeeper
shutdown
banner motd ^CC
SITE 1 ----------------------------------------------------------------------------------------------
SITE1#sh version
SITE1#
SITE1#
SITE1#
SITE1#
SITE1#sh license
SITE1#sh licens
SITE1#sh lice
SITE1#sh inve
SITE1#sh inventory
*Jan 11 20:17:41.640 GMT: htsp_process_event: [0/1/2, FXOLS_GUARD_OUT, E_HTSP_EVENT_TIMER]fxols_guard_out_timeout
*Jan 11 20:17:41.640 GMT: TGRM: reg_invoke_tgrm_call_update(0, 1, 2, 65535, 1, TGRM_CALL_IDLE, TGRM_CALL_VOICE, TGRM_DIRECTION_OUT)
*Jan 11 20:17:41.640 GMT: dsp_req_sig_state: [0/1/2] packet_len=8 channel_id=134 packet_id=40
*Jan 11 20:17:41.640 GMT: C5510 DPR1: H2D Msg: 0008 0086 0028 041B
*Jan 11 20:17:41.640 GMT: C5510 DPR1: D2H Msg: 000A 0086 00A2 041B 0004
*Jan 11 20:17:41.640 GMT: htsp_dsp_message: SEND/RESP_SIG_STATUS: state=0x4 timestamp=64072 systime=38682461
*Jan 11 20:17:41.640 GMT: htsp_process_event: [0/1/2, FXOLS_ONHOOK, E_DSP_SIG_0100]
*Jan 11 20:17:43.068 GMT: C5510 DPR1: D2H Msg: 000C 0086 00A1 0000 0000 E566
*Jan 11 20:17:43.068 GMT: htsp_dsp_message: SEND/RESP_SIG_STATUS: state=0x0 timestamp=58726 systime=38682604
*Jan 11 20:17:43.068 GMT: htsp_process_event: [0/1/2, FXOLS_ONHOOK, E_DSP_SIG_0000]fxols_onhook_ringing
*Jan 11 20:17:43.068 GMT: TGRM: reg_invoke_tgrm_call_update(0, 1, 2, 65535, 1, TGRM_CALL_PENDING, TGRM_CALL_VOICE, TGRM_DIRECTION_IN)
*Jan 11 20:17:43.068 GMT: htsp_timer - 125 msec
*Jan 11 20:17:43.196 GMT: htsp_process_event: [0/1/2, FXOLS_WAIT_RING_MIN, E_HTSP_EVENT_TIMER]fxols_wait_ring_min_timer
*Jan 11 20:17:43.196 GMT: htsp_timer - 10000 msec
*Jan 11 20:17:44.640 GMT: C5510 DPR1: D2H Msg: 000C 0086 00A1 0000 0004 EB8A
*Jan 11 20:17:44.640 GMT: htsp_dsp_message: SEND/RESP_SIG_STATUS: state=0x4 timestamp=60298 systime=38682761
*Jan 11 20:17:44.640 GMT: htsp_process_event: [0/1/2, FXOLS_RINGING, E_DSP_SIG_0100]
*Jan 11 20:17:44.640 GMT: fxols_ringing_not
*Jan 11 20:17:44.640 GMT: htsp_timer_stop
*Jan 11 20:17:44.640 GMT: htsp_timer_stop3 htsp_setup_ind
*Jan 11 20:17:44.640 GMT: [0/1/2] get_local_station_id calling num= calling name= calling time=01/11 20:17 orig called=
*Jan 11 20:17:44.640 GMT: TGRM: reg_invoke_tgrm_accept_call(1, TGRM_CALL_VOICE, TGRM_DIRECTION_IN, 0, 1, 2, 65535)
*Jan 11 20:17:44.640 GMT: TGRM: Calling vtsp_tsp_call_setup_ind().
*Jan 11 20:17:44.640 GMT: htsp_process_event: [0/1/2, FXOLS_WAIT_SETUP_ACK, E_HTSP_SETUP_ACK]
*Jan 11 20:17:44.640 GMT: fxols_wait_setup_ack:
*Jan 11 20:17:44.640 GMT: htsp_timer - 6000 msec
*Jan 11 20:17:44.648 GMT: htsp_process_event: [0/1/2, FXOLS_PROCEEDING, E_HTSP_PROCEEDING]fxols_offhook_proc
*Jan 11 20:17:44.660 GMT: htsp_pre_connect_disconnect, cdb = 455EB898 cause = 15
SITE2#sh version
SITE2 uptime is 1 hour, 25 minutes
export@cisco.com.
1 terminal line
License Info:
License UDI:
Device# PID SN
securityk9
datak9
uck9
cme-srst
cube
SITE2#
SITE2#
SITE2#sh inv
SITE2#sh inventory
SITE2#
SITE2#
SITE2#sh run
version 15.7
service nagle
no service pad
hostname SITE2
boot-start-marker
boot-end-marker
ip cef
no ipv6 cef
key chain hsrp
key 1
voice-card 0
voice service voip
cause-code legacy
vxml logging-tag
hw-module pvdm 0/0
archive
log config
hidekeys
interface Loopback0
no ip address
shutdown
duplex full
control-plane
voice-port 0/1/0
input gain 3
voice-port 0/1/1
input gain 3
voice-port 0/1/2
input gain 3
voice-port 0/1/3
input gain 3
voice-port 0/2/0
input gain 3
voice-port 0/2/1
input gain 3
voice-port 0/2/2
input gain 3
voice-port 0/2/3
input gain 3
voice-port 0/3/0
input gain 3
voice-port 0/3/1
input gain 3
voice-port 0/3/2
input gain 3
voice-port 0/3/3
input gain 3
port 0/3/0
port 0/3/1
port 0/3/2
port 0/3/3
port 0/1/0
port 0/1/1
port 0/1/2
port 0/1/3
port 0/2/0
port 0/2/2
port 0/2/3
port 0/2/1
gatekeeper
shutdown
banner motd ^CC
Current configuration : 11902 bytes
version 12.4
service nagle
no service pad
hostname GARBIGW001
boot-start-marker
boot system flash:c2800nm-ipvoice-mz.124-13b.bin
boot-end-marker
logging buffered 32768 debugging
no logging console
no aaa new-model
clock timezone GMT 0
voice-card 0
no dspfarm
voice-card 1
no dspfarm
no ip source-route
ip cef
no ip domain lookup
voice service voip
fax protocol t38 ls-redundancy 0 hs-redundancy 0 fallback pass-through g711ulaw
cause-code legacy
interface Loopback0
ip address 155.236.167.2 255.255.255.255
description ;Link to GARBIMP660 G2/0/9
ip address 155.236.167.90 255.255.255.252
ip pim sparse-mode
ip route-cache flow
duplex auto
speed auto
router ospf 100
log-adjacency-changes
network 155.236.167.2 0.0.0.0 area 155.236.167.88
network 155.236.167.88 0.0.0.3 area 155.236.167.88
control-plane
voice-port 0/0/0
input gain 3
connection plar opx 8773
description to GARBIGW002 0/0
voice-port 0/0/1
input gain 3
connection plar opx 8778
description to GARBIGW002 0/1
voice-port 0/0/2
input gain 3
voice-port 0/0/3
input gain 3
voice-port 0/1/0
input gain 3
connection plar opx 8833
description to GATOUAWMP001
voice-port 0/1/1
input gain 3
connection plar opx 8834
voice-port 0/1/2
input gain 3
connection plar opx 8835
voice-port 0/1/3
input gain 3
connection plar opx 8836
voice-port 0/2/0
input gain 3
connection plar opx 8837
voice-port 0/2/1
input gain 3
connection plar opx 8838
voice-port 0/2/2
input gain 3
connection plar opx 8840
voice-port 0/2/3
input gain 3
connection plar opx 8845
voice-port 0/3/0
input gain 3
connection plar opx 8846
voice-port 0/3/1
input gain 3
connection plar opx 8787
description to GATOUAWMP650
voice-port 0/3/2
input gain 3
connection plar opx 8848
voice-port 0/3/3
input gain 3
connection plar opx 8849
voice-port 1/0/0
voice-port 1/0/1
voice-port 1/0/2
voice-port 1/0/3
voice-port 1/0/4
input gain 3
connection plar opx 8737
voice-port 1/0/5
input gain 3
connection plar opx 8611
voice-port 1/0/6
input gain 3
connection plar opx 8682
voice-port 1/0/7
input gain 3
connection plar opx 8683
voice-port 1/0/14
input gain 3
connection plar opx 8684
voice-port 1/0/15
input gain 3
connection plar opx 8685
voice-port 1/0/16
input gain 3
connection plar opx 8680
voice-port 1/0/17
input gain 3
connection plar opx 8681
dial-peer voice 1 pots
description Connected to extension 8737
destination-pattern 0001
port 1/0/4
dial-peer voice 2 pots
description Connected to extension 8611
destination-pattern 0002
port 1/0/5
dial-peer voice 3 pots
description Connected to extension 8682
destination-pattern 0003
port 1/0/6
dial-peer voice 4 pots
description Connected to extension 8683
destination-pattern 0004
port 1/0/7
dial-peer voice 5 pots
description Connected to extension 8684
destination-pattern 0005
port 1/0/14
dial-peer voice 6 pots
description Connected to extension 8685
destination-pattern 0006
port 1/0/15
dial-peer voice 7 pots
description Connected to extension 8680
destination-pattern 0007
port 1/0/16
dial-peer voice 8 pots
description Connected to extension 8681
destination-pattern 0008
port 1/0/17
dial-peer voice 8682 voip
description To Gs-B, GARBIGW007
destination-pattern 8682
session target ipv4:155.236.167.4
incoming called-number 0003
codec g711alaw
dial-peer voice 8683 voip
destination-pattern 8683
incoming called-number 0004
codec g711alaw
dial-peer voice 8737 voip
description To Gs-A, GARBIGW006
destination-pattern 8737
session target ipv4:155.236.167.3
incoming called-number 0001
codec g711alaw
dial-peer voice 8611 voip
destination-pattern 8611
incoming called-number 0002
codec g711alaw
dial-peer voice 8684 voip
description To Gs-C, GARBIGW008
destination-pattern 8684
session target ipv4:155.236.167.5
incoming called-number 0005
codec g711alaw
dial-peer voice 8685 voip
destination-pattern 8685
incoming called-number 0006
codec g711alaw
dial-peer voice 8680 voip
description To Gs-D, GARBIGW009
destination-pattern 8680
session target ipv4:155.236.167.6
incoming called-number 0007
codec g711alaw
dial-peer voice 8681 voip
destination-pattern 8681
incoming called-number 0008
codec g711alaw
dial-peer voice 9 pots
description Connected to extension 8773
destination-pattern 0009
port 0/0/0
dial-peer voice 10 pots
description Connected to extension 8778
destination-pattern 0010
port 0/0/1
dial-peer voice 8773 voip
description ;to IPS store, GARBIGW002
destination-pattern 8773
session target ipv4:155.236.167.9
incoming called-number 0009
codec g711alaw
dial-peer voice 8778 voip
destination-pattern 8778
incoming called-number 0010
codec g711alaw
dial-peer voice 12 pots
description Connected to extension 8834
port 0/1/1
dial-peer voice 13 pots
description Connected to extension 8835
port 0/1/2
dial-peer voice 14 pots
description Connected to extension 8836
port 0/1/3
dial-peer voice 15 pots
description Connected to extension 8837
port 0/2/0
dial-peer voice 16 pots
description Connected to extension 8838
port 0/2/1
dial-peer voice 17 pots
description Connected to extension 8840
port 0/2/2
dial-peer voice 18 pots
description Connected to extension 8845
port 0/2/3
dial-peer voice 19 pots
description Connected to extension 8846
port 0/3/0
dial-peer voice 20 pots
description Connected to extension 8787
port 0/3/1
dial-peer voice 21 pots
description Connected to extension 8848
port 0/3/2
dial-peer voice 22 pots
description Connected to extension 8849
port 0/3/3
dial-peer voice 11 pots
description Connected to extension 8833
port 0/1/0
dial-peer voice 8833 voip
description ;to GATOUAWMP001
session target ipv4:32.37.223.27
incoming called-number 0011
dial-peer voice 8834 voip
incoming called-number 0012
dial-peer voice 8835 voip
incoming called-number 0013
dial-peer voice 8836 voip
incoming called-number 0014
dial-peer voice 8837 voip
incoming called-number 0015
dial-peer voice 8838 voip
incoming called-number 0016
dial-peer voice 8840 voip
incoming called-number 0017
dial-peer voice 8845 voip
incoming called-number 0018
dial-peer voice 8846 voip
incoming called-number 0019
dial-peer voice 8848 voip
incoming called-number 0021
dial-peer voice 8849 voip
incoming called-number 0022
dial-peer voice 8787 voip
description ;to GATOUAWMP650
session target ipv4:155.236.161.187
incoming called-number 0020
banner motd ^CC
Bernardin
Now it's working.
