annuler
Affichage des résultats de
Rechercher plutôt
Vouliez-vous dire :
Visites
Compliment
Réponses
sip trunk - disconnect cause 102
icisse
Hi dears,
We configured a sip trunk with our provider. we successfully registered but incoming calls are not working. We get disconnect cause 102. Can you please help
My router config :
FUIG#sh run
Building configuration...
Current configuration : 19227 bytes
! Last configuration change at 15:10:04 UTC Wed May 15 2024 by dgcpt
version 15.7
service password-encryption
hostname VGW_DI
boot-start-marker
boot system flash:c2900-universalk9-mz.SPA.157-3.M.bin
boot-end-marker
logging buffered 51200 warnings
enable secret 5 $1$6fvY$jMHt8ttegpXnEVKbsTsnG0
aaa new-model
aaa authentication login default local
aaa authentication login GROUP local
aaa session-id common
network-clock-participate wic 1
ip dhcp excluded-address 10.10.10.1
ip dhcp excluded-address 192.168.50.1 192.168.50.10
ip dhcp pool voice
network 192.168.50.0 255.255.255.0
default-router 192.168.50.1
option 150 ip 192.168.20.251
no ip domain lookup
ip domain name yourdomain.com
ip host ims.sonatel.sn 10.131.1.6
ip name-server 192.168.92.2
ip cef
no ipv6 cef
isdn switch-type vn3
isdn voice-call-failure 0
isdn tei-negotiation first-call
cts logging verbose
quit
voice-card 0
dspfarm
dsp services dspfarm
voice hunt user-busy
voice call send-alert
voice call convert-discpi-to-prog always
voice rtp send-recv
voice service voip
ip address trusted list
ipv4 0.0.0.0 0.0.0.0
qsig decode
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
redirect ip2ip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
h323
sip
bind control source-interface GigabitEthernet0/0.20
bind media source-interface GigabitEthernet0/0.20
header-passing
voice class codec 1
codec preference 1 g711alaw
codec preference 2 g711ulaw
codec preference 3 g729r8
voice class codec 99
voice class sip-profiles 10
request REGISTER sip-header SIP-Req-URI modify "(sip:)ims.sonatel.sn:5060" "\1ims.sonatel.sn"
voice class tenant 2200
registrar dns:ims.sonatel.sn expires 3600
credentials number +221339212200 username +221339212200 password 7 0354693F352A7318 realm ims.sonatel.sn
authentication username +221339212200 password 7 075F13787D2C4B51 realm ims.sonatel.sn
no remote-party-id
timers connect 100
timers buffer-invite 10000
sip-server ipv4:10.131.1.6
connection-reuse
audio forced
bind control source-interface GigabitEthernet0/1
bind media source-interface GigabitEthernet0/1
no pass-thru content custom-sdp
sip-profiles 10
early-offer forced
voice class tenant 2201
voice register global
default mode
no allow-hash-in-dn
voice translation-rule 1
rule 1 /8400/ /1015/
rule 2 /8401/ /1003/
rule 3 /8402/ /1033/
rule 4 /8406/ /1039/
rule 5 /8414/ /1037/
rule 6 /8415/ /1004/
rule 7 /8408/ /1005/
rule 8 /8404/ /1036/
rule 9 /8407/ /1034/
rule 10 /8403/ /1040/
rule 11 /8409/ /1171/
voice translation-rule 2
rule 1 /1015/ /8400/
rule 2 /1003/ /8401/
rule 3 /1033/ /8402/
rule 4 /1039/ /8406/
rule 5 /1037/ /8414/
rule 6 /1004/ /8415/
rule 7 /1005/ /8408/
rule 8 /1036/ /8404/
rule 9 /1034/ /8407/
rule 10 /1040/ /8403/
rule 11 /1171/ /8409/
voice translation-rule 13
rule 2 /\+\(.*\)/ /1175/
voice translation-profile AAA
translate called 13
voice translation-profile SDA
translate called 1
voice translation-profile SORTANT
translate calling 2
redundancy
interface Tunnel4
ip address 172.16.100.9 255.255.255.252
tunnel source 10.7.107.253
tunnel mode ipip
tunnel destination 10.232.5.1
interface Tunnel6
ip address 172.16.200.10 255.255.255.252
tunnel source 10.6.19.250
tunnel mode ipip
tunnel destination 10.7.106.1
interface Tunnel10
description DI VERS DGCPT
ip address 172.16.200.6 255.255.255.252
tunnel mode ipip
tunnel destination 10.6.0.46
interface Tunnel183
description vers_DSP
ip address 172.16.255.5 255.255.255.252
tunnel mode ipip
tunnel destination 10.7.36.251
interface Tunnel251
ip address 172.16.255.2 255.255.255.252
tunnel mode ipip
tunnel destination 10.6.19.251
interface Tunnel252
description Vers R-DCI
ip address 172.16.254.2 255.255.255.0
tunnel mode ipip
tunnel destination 10.6.19.252
interface Tunnel253
ip address 172.16.253.1 255.255.255.0
tunnel mode ipip
interface Embedded-Service-Engine0/0
no ip address
shutdown
description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-GE 0/0$
no ip address
duplex auto
speed auto
interface GigabitEthernet0/0.1
encapsulation dot1Q 1 native
ip address 10.6.5.3 255.255.255.0
interface GigabitEthernet0/0.10
encapsulation dot1Q 10
ip address 10.7.107.253 255.255.255.0
encapsulation dot1Q 20
ip address 192.168.50.254 255.255.255.0
h323-gateway voip interface
h323-gateway voip bind srcaddr 192.168.50.254
interface GigabitEthernet0/0.876
encapsulation dot1Q 876
ip address 10.6.19.250 255.255.255.0
ip address 192.168.92.2 255.255.255.0
duplex auto
speed auto
interface BRI0/1/0
no ip address
isdn point-to-point-setup
isdn incoming-voice voice
isdn sending-complete
isdn outgoing-voice info-transfer-capability 3.1kHz-audio
interface BRI0/1/1
no ip address
ip forward-protocol nd
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip dns server
ip rtcp report interval 3000
ip route 0.0.0.0 0.0.0.0 192.168.50.1
ip route 10.6.0.0 255.255.255.0 192.168.50.1
ip route 10.6.13.0 255.255.255.192 Tunnel6
ip route 10.7.36.0 255.255.255.0 10.7.107.2
ip route 10.7.114.0 255.255.255.0 10.7.107.2
ip route 10.7.115.0 255.255.255.0 10.7.107.2
ip route 10.7.183.0 255.255.255.0 Tunnel183
ip route 10.131.1.6 255.255.255.255 192.168.92.1
ip route 10.232.5.0 255.255.255.0 10.7.107.2
ip route 41.83.115.164 255.255.255.255 192.168.92.1
ip route 192.168.20.0 255.255.255.0 Tunnel10
ip route 192.168.200.0 255.255.255.0 Tunnel4
control-plane
voice-port 0/0/0
voice-port 0/0/1
voice-port 0/0/2
voice-port 0/0/3
voice-port 0/1/0
translation-profile incoming SDA
translation-profile outgoing SORTANT
echo-cancel coverage 32
no vad
compand-type a-law
no comfort-noise
cptone FR
bearer-cap Speech
voice-port 0/1/1
no vad
compand-type a-law
no comfort-noise
cptone FR
bearer-cap Speech
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
sccp local GigabitEthernet0/0.20
sccp ccm 192.168.20.251 identifier 1 version 7.0
sccp
sccp ccm group 1
bind interface GigabitEthernet0/0.20
associate ccm 1 priority 1
associate profile 1 register TR-CONF
ccm-manager sccp local GigabitEthernet0/0.20
dspfarm profile 1 mtp
description MTP for TRESORDI
codec g711ulaw
maximum sessions software 100
associate application SCCP
dial-peer voice 1 pots
tone ringback alert-no-PI
incoming called-number .
direct-inward-dial
port 0/1/0
dial-peer voice 13 pots
preference 1
direct-inward-dial
port 0/1/1
dial-peer voice 2 pots
description ***vers dakar et regions***
destination-pattern 93[0,3].......
progress_ind setup enable 3
progress_ind alert enable 8
port 0/1/0
forward-digits 9
dial-peer voice 14 pots
preference 1
port 0/1/1
forward-digits 9
dial-peer voice 3 pots
description ***vers mobiles***
destination-pattern 97[0,6,7,8].......
port 0/1/0
forward-digits 9
dial-peer voice 15 pots
preference 1
port 0/1/1
forward-digits 9
dial-peer voice 4 pots
description ***vers urgences***
destination-pattern 91[7,8]
port 0/1/0
forward-digits 2
dial-peer voice 16 pots
preference 1
port 0/1/1
forward-digits 2
dial-peer voice 5 pots
description ***vers internationale***
destination-pattern 9.0T
port 0/1/0
dial-peer voice 17 pots
preference 1
port 0/1/1
dial-peer voice 6 pots
description ***vers serveurs vocaux***
destination-pattern 988.......
port 0/1/0
forward-digits 9
dial-peer voice 18 pots
preference 1
port 0/1/1
forward-digits 9
dial-peer voice 7 pots
destination-pattern 9800......
port 0/1/0
forward-digits 9
dial-peer voice 19 pots
preference 1
port 0/1/1
forward-digits 9
dial-peer voice 8 voip
destination-pattern 1...
session target ipv4:192.168.20.251
voice-class codec 1
dial-peer voice 9 pots
destination-pattern 91441
port 0/1/0
forward-digits 4
dial-peer voice 20 pots
preference 1
port 0/1/1
forward-digits 4
dial-peer voice 10 pots
destination-pattern 91413
port 0/1/0
forward-digits 4
dial-peer voice 21 pots
preference 1
port 0/1/1
forward-digits 4
dial-peer voice 11 pots
description ***vers Informations***
destination-pattern 91212
port 0/1/0
forward-digits 4
dial-peer voice 22 pots
preference 1
port 0/1/1
forward-digits 4
dial-peer voice 12 voip
destination-pattern 2..
session protocol sipv2
session target ipv4:172.16.100.1
dtmf-relay sip-notify rtp-nte
codec g711ulaw
no vad
dial-peer voice 23 pots
port 0/1/0
forward-digits 9
dial-peer voice 24 pots
preference 1
port 0/1/1
forward-digits 9
dial-peer voice 212200 voip
translation-profile incoming AAA
session target ipv4:10.131.1.6
voice-class codec 99
voice-class sip profiles 10
voice-class sip tenant 2200
no vad
dial-peer voice 2200 voip
destination-pattern 212200
voice-class sip tenant 2201
no vad
dial-peer voice 212202 voip
translation-profile outgoing AAA
destination-pattern +221339212200
voice-class codec 1
voice-class sip bind control source-interface GigabitEthernet0/0.20
voice-class sip bind media source-interface GigabitEthernet0/0.20
dtmf-relay rtp-nte
gateway
media-inactivity-criteria all
timer receive-rtcp 5
timer receive-rtp 1200
sip-ua
retry invite 2
retry response 3
retry bye 2
retry prack 6
retry register 2
gatekeeper
shutdown
telephony-service
sdspfarm units 10
sdspfarm transcode sessions 100
sdspfarm tag 1 mtp
conference hardware
calling-number initiator
max-conferences 16 gain -6
transfer-system full-consult
1 RÉPONSE 1
icisse
debug messages :
*May 15 14:25:06.810: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_create: created msg=0x23C6A8B4 with refCount = 1
*May 15 14:25:06.810: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_create: created msg=0x3A0C2900 with refCount = 1
*May 15 14:25:06.810: //-1/xxxxxxxxxxxx/SIP/Info/critical/1024/httpish_msg_process_network_msg: MSG LINE READ FAILURE DUE TO RS->EOF
*May 15 14:25:06.810: //-1/xxxxxxxxxxxx/SIP/Info/critical/1024/ccsip_process_network_message: process_network_msg: not complete
*May 15 14:25:06.810: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_free: Freed msg=0x3A0C2900
*May 15 14:25:06.810: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
hello
*May 15 14:25:06.810: //-1/xxxxxxxxxxxx/SIP/Error/HandleUdpIPv4SocketReads:
SIP Message incomplete, trashed
*May 15 14:25:06.810: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_free: Freed msg=0x23C6A8B4
*May 15 14:25:14.658: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_create: created msg=0x23C6A8B4 with refCount = 1
*May 15 14:25:14.658: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_create: created msg=0x3A0C2900 with refCount = 1
*May 15 14:25:14.658: //-1/xxxxxxxxxxxx/SIP/Info/verbose/4096/HandleUdpIPv4SocketReads: Msg enqueued for SPI with IP addr: [10.131.1.6]:5060, local_address:[192.168.92.2]
*May 15 14:25:14.658: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_free: Freed msg=0x23C6A8B4
*May 15 14:25:14.658: //-1/xxxxxxxxxxxx/SIP/Info/info/4096/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
*May 15 14:25:14.658: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x0
*May 15 14:25:14.658: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:+221339212200@192.168.92.2:5060 SIP/2.0
Via: SIP/2.0/UDP 10.131.1.6:5060;branch=z9hG4bK3mxmxbmw3uubqk5txj3kkbkk5;Role=3;Hpt=8e72_36
Call-ID: sbcthLNQQVSvVpvSSiQpiqG4QlMp4pMSM6GIvMpF@BI.BLB.B.BVL
From: <sip:781260948@ims.sonatel.net;user=phone;noa=national;srvattri=national>;tag=l6FQvQQp
To: <tel:+221339212200>
CSeq: 1 INVITE
Allow: INVITE,ACK,BYE,CANCEL,UPDATE,INFO,PRACK,NOTIFY,REFER,SUBSCRIBE,OPTIONS,MESSAGE
Contact: <sip:10.131.1.6:5060;Dpt=eaea-200;Hpt=8e72_16;CxtId=4;TRC=ffffffff-ffffffff>
Max-Forwards: 25
Supported: timer,100rel,histinfo,early-session
Session-Expires: 1800
Min-SE: 600
P-Asserted-Identity: <tel:781260948>
P-Called-Party-ID: <tel:+221339212200>
P-Early-Media: gated
Content-Length: 325
Content-Type: application/sdp
v=0
o=- 45312217 45312217 IN IP4 10.131.1.6
s=SBC call
c=IN IP4 10.131.1.6
t=0 0
m=audio 40370 RTP/AVP 8 103 0 18 102 108
a=rtpmap:103 AMR/16000
a=fmtp:103 mode-change-neighbor=0;mode-change-period=1;octet-align=0
a=rtpmap:102 GSM-HR/8000
a=rtpmap:108 telephone-event/16000
a=fmtp:108 0-15
a=ptime:20
a=sendrecv
*May 15 14:25:14.658: //-1/xxxxxxxxxxxx/SIP/Info/verbose/4096/ccsip_new_msg_preprocessor: Checking Invite Dialog
*May 15 14:25:14.658: //-1/xxxxxxxxxxxx/SIP/Info/verbose/4096/sipSPIAddContextToTable: Added context(0x3F2BD4C0) with key=[832] to table
*May 15 14:25:14.662: //-1/000000000000/SIP/Info/info/4096/ccsip_ipip_media_service_init:
*May 15 14:25:14.662: //-1/000000000000/SIP/Info/info/4096/ccsip_tdmip_media_service_init:
*May 15 14:25:14.662: //-1/000000000000/SIP/Info/verbose/36864/ccsip_ipip_media_forking_init: MF: Queue is initialised..
*May 15 14:25:14.662: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Dialog Transaction Address 10.131.1.6,Port 5060, Transport 1, SentBy Port 5060vrfid 0
*May 15 14:25:14.662: //-1/xxxxxxxxxxxx/SIP/Info/verbose/512/ccsip_get_vrf_from_sip_bind: vrfid 0 for tag 0, sip_vrfid 0, voice_vrfid 0
*May 15 14:25:14.662: //-1/000000000000/SIP/Info/info/8192/resolve_sig_ip_address_to_bind: VRF id = 0
*May 15 14:25:14.662: //-1/xxxxxxxxxxxx/SIP/Info/info/8192/ccsip_get_ifaddress: ip_address IPv4 192.168.50.254 for SIP
*May 15 14:25:14.662: //-1/xxxxxxxxxxxx/SIP/Info/info/8192/resolve_ip_address_to_bind: ip_get_ifaddress IPv4 192.168.50.254 for SIP
*May 15 14:25:14.662: //-1/000000000000/SIP/Info/info/8192/resolve_sig_ip_address_to_bind: signaling bind address : 192.168.50.254
*May 15 14:25:14.662: //-1/xxxxxxxxxxxx/SIP/Info/info/8192/resolve_sig_ip_address_to_bind: return addr 192.168.50.254
*May 15 14:25:14.662: //-1/C7B3E483880D/SIP/State/sipSPIChangeState: 0x3F2BD4C0 : State change from (STATE_NONE, SUBSTATE_NONE) to (STATE_IDLE, SUBSTATE_NONE)
*May 15 14:25:14.662: //-1/xxxxxxxxxxxx/SIP/Info/verbose/8192/sipSPISetDateHeader: Clock Time Zone is UTC, same as GMT: Using GMT
*May 15 14:25:14.662: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_lock: Increment msg (0x3A0C2900) counter, current msg->refCount = 2
*May 15 14:25:14.662: //-1/xxxxxxxxxxxx/SIP/Error/httpish_msg_free:
Freeing NULL pointer!
*May 15 14:25:14.662: //-1/C7B3E483880D/SIP/Info/verbose/4096/sipSPIAssignCcbLastRequest: Current ccb(0x3F2BD4C0)->last_request = 0x3A0C2900, refCount = 2
*May 15 14:25:14.662: //-1/C7B3E483880D/SIP/Info/info/8192/sipSPIProcessSessionID: SessionID header not present - create uuid
*May 15 14:25:14.662: //-1/C7B3E483880D/SIP/Info/info/8192/sipSPIGenerateSessionUUID: Generate uuid
*May 15 14:25:14.662: //-1/C7B3E483880D/SIP/Info/info/8192/sipSPIGenerateSessionUUID: Initial Invite SIP-TDM /MF case
*May 15 14:25:14.662: //-1/C7B3E483880D/SIP/Info/info/8192/sipSPIGenerateSessionUUID: generated uuid - 252143cdc2bd594e8123849c8ca0eeb3
*May 15 14:25:14.662: //-1/C7B3E483880D/SIP/Info/notify/8192/sipSPI_Add_SessionIDtoTDContainer: localUUID - 252143cdc2bd594e8123849c8ca0eeb3remoteUUID - 00000000000000000000000000000000
*May 15 14:25:14.662: //-1/xxxxxxxxxxxx/SIP/Info/info/2048/sipSPICheckIpip: VOIP dialpeer (peer=0x3D3E2544) found for sip_user: +221339212200
*May 15 14:25:14.662: //-1/C7B3E483880D/SIP/Info/info/2048/sipSPICheckAssertedIdConfig: Dialpeer match is not yet done
*May 15 14:25:14.662: //-1/C7B3E483880D/SIP/Info/info/36864/sipSPIUpdateIdentity: MF: PAI url is present & make a copy..
*May 15 14:25:14.662: //-1/C7B3E483880D/SIP/Info/info/4096/sipSPIUpdateIdentity: PAI genUrl is present..
*May 15 14:25:14.662: //-1/C7B3E483880D/SIP/Info/info/4096/sipSPISetCallingInfo: calling host comes from From: ims.sonatel.net
*May 15 14:25:14.662: //-1/xxxxxxxxxxxx/SIP/Info/critical/4096/sipSPIGetContentGTD: No GTD found in inbound container
*May 15 14:25:14.662: //-1/xxxxxxxxxxxx/SIP/Info/critical/4096/sipSPIGetContentCSTA: No CSTA found in inbound container
*May 15 14:25:14.662: //-1/C7B3E483880D/SIP/Info/verbose/4096/sipSPIUaddCcbToTable: Added to table. ccb=0x3F2BD4C0 key=sbcthLNQQVSvVpvSSiQpiqG4QlMp4pMSM6GIvMpF@BI.BLB.B.BVL221339212200 balance 1
*May 15 14:25:14.662: //-1/C7B3E483880D/SIP/Info/info/8192/sipSPIMatchSrcIpGroup: Match not found on carrier id
*May 15 14:25:14.662: //-1/C7B3E483880D/SIP/Info/critical/8192/sipSPIMatchSrcIpGroup: Match not found on Incoming called number: +221339212200
*May 15 14:25:14.662: //-1/C7B3E483880D/SIP/Info/critical/8192/sipSPIMatchSrcIpGroup: Match not found on destination pattern: 781260948
*May 15 14:25:14.662: //-1/C7B3E483880D/SIP/Info/info/12288/ccsipUpdateIncomingCallParams: ccCallInfo: Calling name , number 781260948, Calling oct3 0x00, oct_3a 0x81, Called number +221339212200
*May 15 14:25:14.662: //-1/C7B3E483880D/SIP/Info/verbose/1024/sipSPIGetViaHostInURLFormat: VIA URL:sip:10.131.1.6:5060, Host:10.131.1.6
*May 15 14:25:14.662: //-1/C7B3E483880D/SIP/Info/verbose/67584/sipSPIGetShrlPeer: Try match incoming dialpeer for Calling number: : 781260948
*May 15 14:25:14.666: //-1/C7B3E483880D/SIP/Info/critical/10240/sipSPIGetCallConfig: No match found for P-Called-Party-ID
*May 15 14:25:14.666: //-1/C7B3E483880D/SIP/Info/info/1024/ccsip_validate_and_update_calling_info: PAI/PPI not configuredi for this dial-peer(0), use RPID/FROM header data
*May 15 14:25:14.666: //-1/C7B3E483880D/SIP/Info/verbose/4096/sipSPIUpdateCallingInfoUsingRpidOrFrom: Updating Calling Info with FROM header data
*May 15 14:25:14.666: //-1/C7B3E483880D/SIP/Info/info/2048/sipSPISetAudioForcedConfig: audio forced config is set to FALSE
*May 15 14:25:14.666: //-1/C7B3E483880D/SIP/Info/verbose/1024/sipSPIGetCallConfig: Precondition tag absent in Require/Supported header
*May 15 14:25:14.666: //-1/C7B3E483880D/SIP/Info/verbose/2048/sipSPIGetCallConfig: Media Antitrombone disabled
*May 15 14:25:14.666: //-1/C7B3E483880D/SIP/Info/info/8192/sipSPISetMediaFlowMode: Storing the configured mode as FLOW-THROUGH
*May 15 14:25:14.666: //-1/C7B3E483880D/SIP/Info/info/2304/sipSPISetMediaFlowMode: xcoder high-density disabled
*May 15 14:25:14.666: //-1/C7B3E483880D/SIP/Info/info/8192/sipSPISetMediaFlowMode: Flow Mode set to FLOW_THROUGH
*May 15 14:25:14.666: //-1/C7B3E483880D/SIP/Info/info/10240/sipSPIGetCallConfig: Non dial peer leg - using RTP Supported Codecs
*May 15 14:25:14.666: //-1/C7B3E483880D/SIP/Info/info/10240/sipSPIGetCallConfig: RTP Preferred Codecs supported by GW 18
*May 15 14:25:14.666: //-1/C7B3E483880D/SIP/Info/info/10240/sipSPIGetCallConfig: RTP Preferred Codecs supported by GW 0
*May 15 14:25:14.666: //-1/C7B3E483880D/SIP/Info/info/10240/sipSPIGetCallConfig: RTP Preferred Codecs supported by GW 8
*May 15 14:25:14.666: //-1/C7B3E483880D/SIP/Info/info/10240/sipSPIGetCallConfig: RTP Preferred Codecs supported by GW 9
*May 15 14:25:14.666: //-1/C7B3E483880D/SIP/Info/info/10240/sipSPIGetCallConfig: RTP Preferred Codecs supported by GW 4
*May 15 14:25:14.666: //-1/C7B3E483880D/SIP/Info/info/10240/sipSPIGetCallConfig: RTP Preferred Codecs supported by GW 2
*May 15 14:25:14.666: //-1/C7B3E483880D/SIP/Info/info/10240/sipSPIGetCallConfig: RTP Preferred Codecs supported by GW 15
*May 15 14:25:14.666: //-1/C7B3E483880D/SIP/Info/info/10240/sipSPIGetCallConfig: RTP Preferred Codecs supported by GW 255
*May 15 14:25:14.666: //-1/C7B3E483880D/SIP/Info/critical/32768/ccsip_ipip_media_forking_update_preferred_codec: MF: Not a Forked SIP leg..
*May 15 14:25:14.666: //-1/C7B3E483880D/SIP/Info/verbose/1/ccsip_set_srtp_config: No Srtp configure for this leg.
*May 15 14:25:14.666: //-1/C7B3E483880D/SIP/Info/verbose/12288/sipSPIGetModemInfoPerCall: peer_callID=0
*May 15 14:25:14.666: //-1/C7B3E483880D/SIP/Error/ccsip_ipip_media_forking_anchor_leg_config:
MF: Dial-peer is absent..
*May 15 14:25:14.666: //-1/C7B3E483880D/SIP/Info/info/36864/sipSPIMFChangeState: MF: Prev state = 0 & New state = -1
*May 15 14:25:14.666: //-1/C7B3E483880D/SIP/Info/info/32768/ccsip_ipip_media_forking_anchor_leg_reset: MF: Anchor leg config reset done...
*May 15 14:25:14.666: //-1/C7B3E483880D/SIP/Error/ccsip_ipip_media_forking_intra_frame_request_config:
MF:video profile Dial-peer is absent..
*May 15 14:25:14.666: //-1/C7B3E483880D/SIP/Info/verbose/8192/sipSPICheckFAAnatAssymetricOrDO2EO: Not a SIP-SIP call or not in FA mode
*May 15 14:25:14.666: //-1/C7B3E483880D/SIP/Info/info/2049/populate_vcc_data: Non dial peer leg - using RTP Supported Codecs
*May 15 14:25:14.666: //-1/C7B3E483880D/SIP/Info/info/1/populate_vcc_data: RTP Preferred Codecs supported by GW 18
*May 15 14:25:14.666: //-1/C7B3E483880D/SIP/Info/info/1/populate_vcc_data: RTP Preferred Codecs supported by GW 0
*May 15 14:25:14.666: //-1/C7B3E483880D/SIP/Info/info/1/populate_vcc_data: RTP Preferred Codecs supported by GW 8
*May 15 14:25:14.666: //-1/C7B3E483880D/SIP/Info/info/1/populate_vcc_data: RTP Preferred Codecs supported by GW 9
*May 15 14:25:14.666: //-1/C7B3E483880D/SIP/Info/info/1/populate_vcc_data: RTP Preferred Codecs supported by GW 4
*May 15 14:25:14.666: //-1/C7B3E483880D/SIP/Info/info/1/populate_vcc_data: RTP Preferred Codecs supported by GW 2
*May 15 14:25:14.666: //-1/C7B3E483880D/SIP/Info/info/1/populate_vcc_data: RTP Preferred Codecs supported by GW 15
*May 15 14:25:14.666: //-1/C7B3E483880D/SIP/Info/info/1/populate_vcc_data: RTP Preferred Codecs supported by GW 255
*May 15 14:25:14.666: //-1/C7B3E483880D/SIP/Info/notify/8192/sipSPISetOverlapConfiguration: Overlap signaling: FALSE: Endpt: SIP Trunk
*May 15 14:25:14.666: //-1/C7B3E483880D/SIP/Info/verbose/10240/sipSPI_ipip_GetHdrPassthruCfg: Hdr passthrough config:1 tag:0
*May 15 14:25:14.666: //-1/C7B3E483880D/SIP/Info/verbose/2048/sipSPI_ipip_GetCopyListCfg: Copy-list config:2 tag:0
*May 15 14:25:14.666: //-1/C7B3E483880D/SIP/Info/info/2048/sipSPIGetExtensionCfg: SIP extension config:1, check sys cfg:1
*May 15 14:25:14.666: //-1/C7B3E483880D/SIP/Info/notify/10240/sipSPI_ipip_build_consolidated_header_list: Both passthru and copylist are disabled
*May 15 14:25:14.666: //-1/C7B3E483880D/SIP/Info/info/4096/sipSPIContinueNewMsgInvite: Calling name , number 781260948, Calling oct3 0x00, oct_3a 0x80, ext_priv 0x00, Called number +221339212200, oct3 0x00
*May 15 14:25:14.666: //-1/C7B3E483880D/SIP/Info/info/4096/sipSPIContinueNewMsgInvite: Carrier id code , prev_cid NONE, next_cid NONE, prev_tgrp NONE, next_tgrp NONE
*May 15 14:25:14.666: //-1/C7B3E483880D/SIP/Info/info/4096/sipSPIContinueNewMsgInvite: Requires reliable-provisional support
*May 15 14:25:14.666: //-1/C7B3E483880D/SIP/Info/critical/10240/sipSPIValidateRequestUri: Not Enabled
*May 15 14:25:14.666: //-1/C7B3E483880D/SIP/Info/info/131072/sipSPIRscmsmAvail: Value returned by check is = 0
*May 15 14:25:14.666: //1184/C7B3E483880D/SIP/Info/critical/4096/sipSPICheckOutBoundDpProvisioning: Cannot obtain the the header bitmap
*May 15 14:25:14.666: //1184/C7B3E483880D/SIP/Info/critical/8192/sipSPI_ipip_IsSDPPassthruEnabled: - 0
*May 15 14:25:14.666: //1184/C7B3E483880D/SIP/Info/info/8192/sipSPIProcessSessionID: SessionID header not present - create uuid
*May 15 14:25:14.666: //1184/C7B3E483880D/SIP/Info/info/8192/sipSPIGenerateSessionUUID: Generate uuid
*May 15 14:25:14.666: //1184/C7B3E483880D/SIP/Info/info/8192/sipSPIGenerateSessionUUID: Initial Invite SIP-TDM /MF case
*May 15 14:25:14.666: //1184/C7B3E483880D/SIP/Info/info/8192/sipSPIGenerateSessionUUID: generated uuid - a66a2161774154229e9d5a9cb7bf1ee2
*May 15 14:25:14.666: //1184/C7B3E483880D/SIP/Info/notify/8192/sipSPI_Add_SessionIDtoTDContainer: localUUID - a66a2161774154229e9d5a9cb7bf1ee2remoteUUID - 00000000000000000000000000000000
*May 15 14:25:14.666: //1184/C7B3E483880D/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_REQ
*May 15 14:25:14.666: //1184/C7B3E483880D/SIP/Event/Session-Timer/sipSTSLMain: dir:2, method:102, resp_code:0, container:3F47FC9C
*May 15 14:25:14.666: //1184/C7B3E483880D/SIP/Info/info/8192/Session-Timer/sipSTSLExtractSessionExpiresHdr:
Session-Expires value: 1800 refresher: none
*May 15 14:25:14.666: //1184/C7B3E483880D/SIP/Info/info/8192/Session-Timer/sipSTSLExtractMinSEHdr: Min-SE Duration: 600
*May 15 14:25:14.666: //1184/C7B3E483880D/SIP/Info/info/8192/Session-Timer/sipSTSLGetInternalSREvent: E_STSL_INITIAL_SR_REQ
*May 15 14:25:14.666: //1184/C7B3E483880D/SIP/Info/verbose/8192/Session-Timer/sipSTSLInitialSRReqPeerEventGen: sending received session expires to the peer leg
*May 15 14:25:14.666: //1184/C7B3E483880D/SIP/Event/Session-Timer/sipSTSLPrintTDContainer: Peer-Event: E_STSL_PASS_ST_PARAMS, SE Value:1800, SE Refresher:none, Min-SE Value:1800, flags:2001
*May 15 14:25:14.666: //1184/C7B3E483880D/SIP/Info/info/8192/Session-Timer/sipSTSLMain:
SE: 1800;refresher:none peer refresher:none, flags:2001, posted event:E_STSL_INVALID_PEER_EVENT, reason:4
Configured SE:1800, Configured Min-SE:1800
*May 15 14:25:14.666: //1184/C7B3E483880D/SIP/Info/critical/1024/sipSPIProcessHistoryInfoHeader: No HI headers recvd from app container
*May 15 14:25:14.666: //1184/C7B3E483880D/SIP/Info/critical/1024/sipSPIProcessDiversionHeader: No diversion headers recvd from app container
*May 15 14:25:14.666: //1184/C7B3E483880D/SIP/Info/critical/16384/sipSPIProcessReplacesHeader: No replaces hdr found
*May 15 14:25:14.666: //-1/xxxxxxxxxxxx/SIP/Info/verbose/1024/sipSPIGetContentCPA: No CPA found in inbound container
*May 15 14:25:14.666: //1184/C7B3E483880D/SIP/Info/verbose/1024/sipSPIProcessCPA: No x-cisco-cpa content found
*May 15 14:25:14.670: //1184/C7B3E483880D/SIP/Info/verbose/1/sipSPIDoMediaNegotiation: Number of m-lines = 1
*May 15 14:25:14.670: //1184/C7B3E483880D/SIP/Info/verbose/1/sipSPIValidateConnectionAddress: Dest port = 40370
SIP: (1184) Attribute mid, level 1 instance 1 not found.
*May 15 14:25:14.670: //1184/C7B3E483880D/SIP/Info/notify/6/sipSPIValidateStreamAddrType: stream:1, Mode : 1
*May 15 14:25:14.670: //1184/C7B3E483880D/SIP/Info/verbose/513/resolve_media_ip_address_to_bind: peer_tag=0
*May 15 14:25:14.670: //-1/xxxxxxxxxxxx/SIP/Info/verbose/512/ccsip_get_vrf_from_sip_bind: vrfid 0 for tag 0, sip_vrfid 0, voice_vrfid 0
*May 15 14:25:14.670: //-1/xxxxxxxxxxxx/SIP/Info/info/8192/resolve_media_ip_address_to_bind: VRF id = 0
*May 15 14:25:14.670: //-1/xxxxxxxxxxxx/SIP/Info/info/8192/ccsip_get_ifaddress: ip_address IPv4 192.168.50.254 for SIP
*May 15 14:25:14.670: //-1/xxxxxxxxxxxx/SIP/Info/info/8192/resolve_ip_address_to_bind: ip_get_ifaddress IPv4 192.168.50.254 for SIP
*May 15 14:25:14.670: //1184/C7B3E483880D/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 192.168.50.254
*May 15 14:25:14.670: //-1/xxxxxxxxxxxx/SIP/Info/notify/1/sipSPICheckDynPayloadUse: Dynamic payload(103) reserved for codec gsmamr-nb
*May 15 14:25:14.670: //-1/xxxxxxxxxxxx/SIP/Info/notify/1/sipSPICheckDynPayloadUse: Dynamic payload(102) reserved for codec No Codec
*May 15 14:25:14.670: //-1/xxxxxxxxxxxx/SIP/Info/info/1/sipSPIUpdateDynamicPayloadunused: Unreserving dynamic payload type 96
*May 15 14:25:14.670: //-1/xxxxxxxxxxxx/SIP/Info/notify/1/sipSPICheckDynPayloadUse: Dynamic payload(108) reserved for codec No Codec
*May 15 14:25:14.670: //1184/C7B3E483880D/SIP/Info/notify/1/sipSPIDoAudioNegotiation: Codec (g711alaw) Negotiation Successful on Static Payload for m-line 1
*May 15 14:25:14.670: //1184/C7B3E483880D/SIP/Info/verbose/1/sipSPIDoPtimeNegotiation: One ptime attribute found - value:20
*May 15 14:25:14.670: //-1/xxxxxxxxxxxx/SIP/Info/notify/1/convert_ptime_to_codec_bytes: Values :Codec: g711alaw ptime :20, codecbytes: 160
*May 15 14:25:14.670: //-1/xxxxxxxxxxxx/SIP/Info/notify/1/convert_codec_bytes_to_ptime: Values :Codec: g711alaw codecbytes :160, ptime: 20
*May 15 14:25:14.670: //1184/C7B3E483880D/SIP/Media/sipSPIDoPtimeNegotiation: Offered ptime:20, Negotiated ptime:20 Negotiated codec bytes: 160 for codec g711alaw
*May 15 14:25:14.670: //1184/C7B3E483880D/SIP/Info/info/8/sipSPISetFaxFlags: FAX_PASSTHROUGH = 0, END_FAX_PASSTHROUGH = 0
*May 15 14:25:14.670: //1184/C7B3E483880D/SIP/Info/info/1/sipSPIDoDTMFRelayNegotiation: m-line index 1
*May 15 14:25:14.670: //1184/C7B3E483880D/SIP/Info/notify/1/sipSPIReserveRtpNtePayload: Reserved the payload type 108 for RTP-NTE
*May 15 14:25:14.670: //1184/C7B3E483880D/SIP/Info/info/32/sipSPIDoDTMFRelayNegotiation: RTP-NTE DTMF relay option
*May 15 14:25:14.670: //1184/C7B3E483880D/SIP/Info/info/1/sipSPIDoDTMFRelayNegotiation: Case of partial named event(NE) match in fmtp list of events.
*May 15 14:25:14.670: //-1/xxxxxxxxxxxx/SIP/Info/info/8193/sip_sdp_get_modem_relay_cap_params: ptype is 103
*May 15 14:25:14.670: //-1/xxxxxxxxxxxx/SIP/Info/info/8193/sip_sdp_get_modem_relay_cap_params: encname is AMR
*May 15 14:25:14.670: //-1/xxxxxxxxxxxx/SIP/Info/info/8193/sip_sdp_get_modem_relay_cap_params: ptype is 102
*May 15 14:25:14.670: //-1/xxxxxxxxxxxx/SIP/Info/info/8193/sip_sdp_get_modem_relay_cap_params: encname is GSM-HR
*May 15 14:25:14.670: //-1/xxxxxxxxxxxx/SIP/Info/info/8193/sip_sdp_get_modem_relay_cap_params: ptype is 108
*May 15 14:25:14.670: //-1/xxxxxxxxxxxx/SIP/Info/info/8193/sip_sdp_get_modem_relay_cap_params: encname is telephone-event
*May 15 14:25:14.670: //-1/xxxxxxxxxxxx/SIP/Info/info/8209/sip_sdp_get_modem_relay_cap_params: mer_dtmf_found 0
*May 15 14:25:14.670: //-1/xxxxxxxxxxxx/SIP/Info/info/8209/sip_sdp_get_modem_relay_cap_params: V150 NSE payload = 0, SSE payload = 0, SPRT payload=0
*May 15 14:25:14.670: //1184/C7B3E483880D/SIP/Info/critical/8193/sip_select_modem_relay_params: X-tmr not present in SDP. Disable modem relay
*May 15 14:25:14.670: //1184/C7B3E483880D/SIP/Info/info/1/sipSPIGetSDPDirectionAttribute: No direction attribute present or multiple direction attributes that can't be handled for m-line:1 and num-a-lines:0
*May 15 14:25:14.670: //1184/C7B3E483880D/SIP/Info/notify/1/sipSPIDoAudioNegotiation: Codec negotiation successful for media line 1
payload_type=8, codec_bytes=160, codec=g711alaw, dtmf_relay=rtp-nte
stream_type=voice+dtmf (1), dest_ip_address=10.131.1.6, dest_port=40370
*May 15 14:25:14.670: //1184/C7B3E483880D/SIP/State/sipSPIChangeStreamState: Stream (callid = -1) State changed from (STREAM_DEAD) to (STREAM_ADDING)
*May 15 14:25:14.670: //-1/xxxxxxxxxxxx/SIP/Info/sipSPI_Check_If_ICE_Needed: CANDIDATE attribute, level 1not found.
*May 15 14:25:14.670: //1184/C7B3E483880D/SIP/Media/sipSPIUpdCallWithSdpInfo:
Preferred Codec : g729r8, bytes :20
Preferred DTMF relay : rtp-nte
Preferred NTE payload : 108
Early Media : No
Delayed Media : No
Bridge Done : No
New Media : No
DSP DNLD Reqd : No
*May 15 14:25:14.670: //1184/C7B3E483880D/SIP/Info/verbose/513/resolve_media_ip_address_to_bind: Media already bound, use existing source_media_ip_addr
*May 15 14:25:14.670: //1184/C7B3E483880D/SIP/Info/info/4096/ccsip_offer_ans_handle_rcvd_sdp:
*May 15 14:25:14.670: //1184/C7B3E483880D/SIP/State/ccsip_cnfsm_debugs: OA:cur_container:ccsip_offer_ans_main_container, cur_state:S_SIP_EARLY_DIALOG_IDLE, event:E_SIP_INVITE_SDP_RCVD
*May 15 14:25:14.670: //1184/C7B3E483880D/SIP/Info/info/4096/ccsip_offer_ans_is_invite_offer_valid: TRUE
*May 15 14:25:14.670: //1184/C7B3E483880D/SIP/Info/info/4096/ccsip_offer_ans_common_offer_rcvd_hdlr:
*May 15 14:25:14.670: //1184/C7B3E483880D/SIP/Info/info/4096/ccsip_iwf_handle_network_event:
*May 15 14:25:14.670: //1184/C7B3E483880D/SIP/State/ccsip_cnfsm_debugs: IWF:cur_container:sip_iwf_default_early_dialog_container, cur_state:S_SIP_IWF_SDP_IDLE, event:E_SIP_IWF_EV_RCVD_SDP
*May 15 14:25:14.670: //1184/C7B3E483880D/SIP/Info/info/4096/sip_iwf_def_ed_rcvd_sdp_hdlr:
*May 15 14:25:14.670: //1184/C7B3E483880D/SIP/Info/info/1/sipSPIAssignStreamCallId: Assigning streamid 1184 to stream 1. Old streamid = -1
*May 15 14:25:14.670: //1184/C7B3E483880D/SIP/Info/info/1/sipSPI_initialize_audio_channelInfo_from_sdp: stream_callid = 1184, peer_stream_callid = -1
SIP: (1184) setup attribute, level 1 instance 1 not found.
SIP: (1184) connection attribute, level 1 instance 1 not found.
SIP: (1184) Attribute label, level 1 instance 1 not found.
SIP: (1184) a=framerate attribute, level 1 instance 1 not found.
*May 15 14:25:14.670: //1184/C7B3E483880D/SIP/Info/verbose/1025/sipSPI_initialize_audio_channelInfo_from_sdp: Populating Address in channelInfo
*May 15 14:25:14.670: //1184/C7B3E483880D/SIP/Info/info/1/sipSPI_initialize_audio_channelInfo_from_sdp: Media dest addr for stream 1='10.131.1.6', port=40370
*May 15 14:25:14.670: //1184/C7B3E483880D/SIP/Info/info/1/sip_iwf_sip_copy_audio_sdp_to_local_channelInfo: Processing Media line = 1; Codec = g711alaw; PType = 8
*May 15 14:25:14.670: //1184/C7B3E483880D/SIP/Info/verbose/1/codec_found: Codec to be matched: g711alaw(6)
*May 15 14:25:14.670: //1184/C7B3E483880D/SIP/Info/verbose/1/codec_found: Match Found at index 2.
*May 15 14:25:14.670: //1184/C7B3E483880D/SIP/Info/verbose/1/sip_iwf_sip_copy_audio_sdp_to_local_channelInfo: Add Channel for Codec g711alaw
*May 15 14:25:14.670: //1184/C7B3E483880D/SIP/Info/notify/1/sip_iwf_sip_copy_audio_sdp_to_local_channelInfo: Media negotiation done for m-line=1: negotiated_ptime=20, negotiated_codec_bytes=160
*May 15 14:25:14.670: //1184/C7B3E483880D/SIP/Info/info/1/sipSPI_ipip_update_codec_params_in_stream_channelInfo: Adding negotiated codec g711alaw ptype 8 time 20, bytes 160 as channel 0 mline 1 ss 1
*May 15 14:25:14.670: //1184/C7B3E483880D/SIP/Info/info/131073/sipSPIBwCacCalcAudioBandwidth: calculated audio bandwidth : codec g711alaw bw 64000
*May 15 14:25:14.670: //1184/C7B3E483880D/SIP/Info/info/1/sip_iwf_sip_copy_audio_sdp_to_local_channelInfo: Processing Media line = 1; Codec = gsmamr-nb; PType = 103
*May 15 14:25:14.670: //1184/C7B3E483880D/SIP/Info/verbose/1/codec_found: Codec to be matched: gsmamr-nb(32)
*May 15 14:25:14.670: //1184/C7B3E483880D/SIP/Info/notify/1/codec_found: Match Not Found for gsmamr-nb.
*May 15 14:25:14.670: //1184/C7B3E483880D/SIP/Info/info/1/sip_iwf_sip_copy_audio_sdp_to_local_channelInfo: Processing Media line = 1; Codec = g711ulaw; PType = 0
*May 15 14:25:14.670: //1184/C7B3E483880D/SIP/Info/verbose/1/codec_found: Codec to be matched: g711ulaw(5)
*May 15 14:25:14.670: //1184/C7B3E483880D/SIP/Info/verbose/1/codec_found: Match Found at index 1.
*May 15 14:25:14.670: //1184/C7B3E483880D/SIP/Info/verbose/1/sip_iwf_sip_copy_audio_sdp_to_local_channelInfo: Add Channel for Codec g711ulaw
*May 15 14:25:14.670: //-1/xxxxxxxxxxxx/SIP/Info/notify/1/convert_ptime_to_codec_bytes: Values :Codec: g711ulaw ptime :20, codecbytes: 160
*May 15 14:25:14.670: //1184/C7B3E483880D/SIP/Info/info/1/sipSPI_ipip_update_codec_params_in_stream_channelInfo: Adding negotiated codec g711ulaw ptype 0 time 20, bytes 160 as channel 1 mline 1 ss 1
*May 15 14:25:14.670: //1184/C7B3E483880D/SIP/Info/info/131073/sipSPIBwCacCalcAudioBandwidth: calculated audio bandwidth : codec g711ulaw bw 64000
*May 15 14:25:14.670: //1184/C7B3E483880D/SIP/Media/sipSPISelectCodecVersion: Codec (g729br8) is not in preferred list
*May 15 14:25:14.670: //1184/C7B3E483880D/SIP/Info/notify/1/sipSPI_ipip_update_static_codec_params: An exact codec match not configured, using interoperable codec g729r8
*May 15 14:25:14.670: //1184/C7B3E483880D/SIP/Info/info/1/sip_iwf_sip_copy_audio_sdp_to_local_channelInfo: Processing Media line = 1; Codec = g729r8; PType = 18
*May 15 14:25:14.670: //1184/C7B3E483880D/SIP/Info/verbose/1/codec_found: Codec to be matched: g729r8(16)
*May 15 14:25:14.670: //1184/C7B3E483880D/SIP/Info/verbose/1/codec_found: Match Found at index 0.
*May 15 14:25:14.670: //1184/C7B3E483880D/SIP/Info/verbose/1/sip_iwf_sip_copy_audio_sdp_to_local_channelInfo: Add Channel for Codec g729r8
*May 15 14:25:14.670: //-1/xxxxxxxxxxxx/SIP/Info/notify/1/convert_ptime_to_codec_bytes: Values :Codec: g729r8 ptime :20, codecbytes: 20
*May 15 14:25:14.670: //1184/C7B3E483880D/SIP/Info/info/1/sipSPI_ipip_update_codec_params_in_stream_channelInfo: Adding negotiated codec g729r8 ptype 18 time 20, bytes 20 as channel 2 mline 1 ss 1
*May 15 14:25:14.670: //1184/C7B3E483880D/SIP/Info/info/131073/sipSPIBwCacCalcAudioBandwidth: calculated audio bandwidth : codec g729r8 bw 8000
*May 15 14:25:14.670: //1184/C7B3E483880D/SIP/Info/info/1/sip_iwf_sip_copy_audio_sdp_to_local_channelInfo: Processing Media line = 1; Codec = No Codec ; PType = 102
*May 15 14:25:14.670: //1184/C7B3E483880D/SIP/Info/info/32/sipSPI_ipip_upd_2833_dtmf_params: setting ipip_caps DTMF to RFC2833: callid = 1184, dtmf = 6
*May 15 14:25:14.670: //1184/C7B3E483880D/SIP/Info/info/1/sip_iwf_sip_copy_audio_sdp_to_local_channelInfo: Processing Media line = 1; Codec = No Codec ; PType = 108
*May 15 14:25:14.670: //1184/C7B3E483880D/SIP/Info/verbose/16/sipSPIGetPreferredSrtpSuiteForBw: Return : 0
*May 15 14:25:14.670: //-1/xxxxxxxxxxxx/SIP/Info/verbose/16/sipSPIBwCacGetSrtpOverhead: Return: 0
*May 15 14:25:14.670: //1184/C7B3E483880D/SIP/Media/sipSPIDisplayStreamInfo:
Stream type : voice+dtmf
Media line : 1
State : STREAM_ADDING (2)
Stream address type : 1
Callid : 1184
Peer Callid : -1
RTP/SRTP Negotiated : 8
Negotiated Codec : g711alaw, bytes :160
Nego. Codec payload : 8 (tx), 8 (rx)
Negotiated DTMF relay : rtp-nte
Negotiated NTE payload : 108 (tx), 108 (rx)
Negotiated CN payload : 0
Media Srce Addr/Port : [192.168.50.254]:0
Media Dest Addr/Port : [10.131.1.6]:40370
*May 15 14:25:14.674: //1184/C7B3E483880D/SIP/Info/verbose/4097/sipSPI_ipip_calculate_channel_count: Number of streams to report = 1
*May 15 14:25:14.674: //1184/C7B3E483880D/SIP/Info/critical/1/sip_iwf_sip_copy_sdp_to_stream_channelInfo: Not updating call entry.
*May 15 14:25:14.674: //1184/C7B3E483880D/SIP/Info/info/1/sip_iwf_def_ed_rcvd_sdp_hdlr: Setting media_direction to 4
*May 15 14:25:14.674: //1184/C7B3E483880D/SIP/Info/info/131072/sipSPIBwCacUpdateAccountedBw: bwcac update accounted BW Option 0 flow mode flow-through
audio bw 80000 bps video bw 0 bps fax bw 0 bps total bw 80000 bps accounted bw 0 bps
*May 15 14:25:15.622: //1184/C7B3E483880D/SIP/Info/info/8192/Session-Timer/sipSTSLMain:
*May 15 14:25:15.622: //1184/C7B3E483880D/SIP/Info/verbose/4096/ccsip_buffer_media_event: Buffering event SIPSPI_EV_CC_MEDIA_EVENT - Purpose 1: FALSE
*May 15 14:25:16.114: //1184/C7B3E483880D/SIP/Info/info/4096/sipSPIResendInviteResponse: resending 180 response due to no PRACK
*May 15 14:25:16.114: //1184/C7B3E483880D/SIP/Info/verbose/4096/sipSPISendInviteResponse: Dialog State: [1]
*May 15 14:25:16.114: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_create: created msg=0x3A01A90C with refCount = 1
*May 15 14:25:16.114: //1184/C7B3E483880D/SIP/Event/sipSPICreateRpid: Received Octet3A=0x00 -> Setting ;screen=no ;privacy=off
*May 15 14:25:16.114: //1184/C7B3E483880D/SIP/Info/info/4096/sipSPISendInviteResponse: Associated container=0x3F47CBCC to Invite Response 180
*May 15 14:25:16.114: //-1/xxxxxxxxxxxx/SIP/Info/verbose/8192/sipSPIAppHandleContainerBody: sipSPIAppHandleContainerBody len 0
*May 15 14:25:16.114: //1184/C7B3E483880D/SIP/Transport/sipSPISendInviteResponse: Sending 180 Response to the Transport Layer
*May 15 14:25:16.114: //1184/C7B3E483880D/SIP/Transport/sipSPITransportSendMessage: msg=0x3A01A90C, addr=10.131.1.6, port=5060, sentBy_port=5060, local_addr=192.168.50.254, is_req=0, transport=1, switch=0, callBack=0x0
*May 15 14:25:16.114: //1184/C7B3E483880D/SIP/Info/info/2048/sipSPIGetExtensionCfg: SIP extension config:1, check sys cfg:1
*May 15 14:25:16.114: //1184/C7B3E483880D/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
*May 15 14:25:16.114: //1184/C7B3E483880D/SIP/Transport/sipTransportLogicSendMsg: Trying to send resp=0x3A01A90C to default port=5060
*May 15 14:25:16.114: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerGetConnection: connection required for raddr:10.131.1.6, rport:5060 with laddr:192.168.50.254
*May 15 14:25:16.114: //-1/xxxxxxxxxxxx/SIP/Transport/sipInstanceGetConnectionId: gcb=0x3F2BD4C0 is already on connection=0x3EC0C0A4 context_list
*May 15 14:25:16.114: //1184/C7B3E483880D/SIP/Transport/sipTransportLogicSendMsg: Connection obtained...sending msg=0x3A01A90C
*May 15 14:25:16.114: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x3A01A90C, addr=10.131.1.6, port=5060, local_addr=192.168.50.254, connId=4 vrfid=0 for UDP
*May 15 14:25:16.114: //1184/C7B3E483880D/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 180 Ringing
To: <tel:+221339212200>;tag=23921EF8-1F8A
Date: Wed, 15 May 2024 14:25:15 GMT
CSeq: 1 INVITE
Require: 100rel
RSeq: 1364
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
Allow-Events: telephone-event
Remote-Party-ID: <sip:1175@192.168.50.254>;party=called;screen=no;privacy=off
Contact: <sip:+221339212200@192.168.50.254:5060>
Server: Cisco-SIPGateway/IOS-15.7.3.M
Session-ID: a66a2161774154229e9d5a9cb7bf1ee2;remote=00000000000000000000000000000000
Content-Length: 0
*May 15 14:25:16.114: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_free: Freed msg=0x3A01A90C
*May 15 14:25:16.410: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_create: created msg=0x3A01A90C with refCount = 1
*May 15 14:25:16.410: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_create: created msg=0x3A0A3044 with refCount = 1
*May 15 14:25:16.410: //-1/xxxxxxxxxxxx/SIP/Info/verbose/4096/HandleUdpIPv4SocketReads: Msg enqueued for SPI with IP addr: [10.131.1.6]:5060, local_address:[192.168.92.2]
*May 15 14:25:16.410: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_free: Freed msg=0x3A01A90C
*May 15 14:25:16.410: //-1/xxxxxxxxxxxx/SIP/Info/info/4096/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
*May 15 14:25:16.410: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x0
*May 15 14:25:16.410: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
CSeq: 1 INVITE
Max-Forwards: 25
Min-SE: 600
Content-Length: 325
v=0
s=SBC call
c=IN IP4 10.131.1.6
t=0 0
a=fmtp:108 0-15
a=ptime:20
a=sendrecv
*May 15 14:25:16.414: //-1/xxxxxxxxxxxx/SIP/Info/verbose/4096/ccsip_new_msg_preprocessor: Checking Invite Dialog
*May 15 14:25:16.414: //1184/C7B3E483880D/SIP/Info/verbose/4096/sipSPIFindCcbUASReqTable: *****CCB found in UAS Request table. ccb=0x3F2BD4C0
*May 15 14:25:16.414: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_lock: Increment msg (0x3A0A3044) counter, current msg->refCount = 2
*May 15 14:25:16.414: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Dialog Transaction Address 10.131.1.6,Port 5060, Transport 1, SentBy Port 5060vrfid 0
*May 15 14:25:16.414: //-1/xxxxxxxxxxxx/SIP/Info/verbose/8192/sipSPISetDateHeader: Clock Time Zone is UTC, same as GMT: Using GMT
*May 15 14:25:16.414: //1184/C7B3E483880D/SIP/Info/info/4096/sipSPISetCallingInfo: calling host comes from From: ims.sonatel.net
*May 15 14:25:16.414: //1184/C7B3E483880D/SIP/Info/verbose/4096/sipSPIUpdateCallingInfoUsingRpidOrFrom: Updating Calling Info with FROM header data
*May 15 14:25:16.414: //1184/C7B3E483880D/SIP/Info/verbose/4096/sipSPISendInviteResponse: Dialog State: [1]
*May 15 14:25:16.414: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_create: created msg=0x3A01A90C with refCount = 1
*May 15 14:25:16.414: //1184/C7B3E483880D/SIP/Event/sipSPICreateRpid: Received Octet3A=0x00 -> Setting ;screen=no ;privacy=off
*May 15 14:25:16.414: //1184/C7B3E483880D/SIP/Info/info/4096/sipSPISendInviteResponse: Associated container=0x3F47CBCC to Invite Response 180
*May 15 14:25:16.414: //-1/xxxxxxxxxxxx/SIP/Info/verbose/8192/sipSPIAppHandleContainerBody: sipSPIAppHandleContainerBody len 0
*May 15 14:25:16.414: //1184/C7B3E483880D/SIP/Transport/sipSPISendInviteResponse: Sending 180 Response to the Transport Layer
*May 15 14:25:16.414: //1184/C7B3E483880D/SIP/Transport/sipSPITransportSendMessage: msg=0x3A01A90C, addr=10.131.1.6, port=5060, sentBy_port=5060, local_addr=192.168.50.254, is_req=0, transport=1, switch=0, callBack=0x0
*May 15 14:25:16.414: //1184/C7B3E483880D/SIP/Info/info/2048/sipSPIGetExtensionCfg: SIP extension config:1, check sys cfg:1
*May 15 14:25:16.414: //1184/C7B3E483880D/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
*May 15 14:25:16.414: //1184/C7B3E483880D/SIP/Transport/sipTransportLogicSendMsg: Trying to send resp=0x3A01A90C to default port=5060
*May 15 14:25:16.414: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerGetConnection: connection required for raddr:10.131.1.6, rport:5060 with laddr:192.168.50.254
*May 15 14:25:16.414: //-1/xxxxxxxxxxxx/SIP/Transport/sipInstanceGetConnectionId: gcb=0x3F2BD4C0 is already on connection=0x3EC0C0A4 context_list
*May 15 14:25:16.414: //1184/C7B3E483880D/SIP/Transport/sipTransportLogicSendMsg: Connection obtained...sending msg=0x3A01A90C
*May 15 14:25:16.414: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x3A01A90C, addr=10.131.1.6, port=5060, local_addr=192.168.50.254, connId=4 vrfid=0 for UDP
*May 15 14:25:16.414: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_free: Decrement msg (0x3A0A3044) counter, current msg->refCount = 1
*May 15 14:25:16.414: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_free: Freed msg=0x3A0A3044
*May 15 14:25:16.414: //1184/C7B3E483880D/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 180 Ringing
Date: Wed, 15 May 2024 14:25:16 GMT
CSeq: 1 INVITE
Require: 100rel
RSeq: 1364
Content-Length: 0
*May 15 14:25:16.414: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_free: Freed msg=0x3A01A90C
*May 15 14:25:17.290: //1184/C7B3E483880D/SIP/Info/info/4096/sipSPIResendInviteResponse: resending 180 response due to no PRACK
*May 15 14:25:17.290: //1184/C7B3E483880D/SIP/Info/verbose/4096/sipSPISendInviteResponse: Dialog State: [1]
*May 15 14:25:17.290: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_create: created msg=0x3A01A90C with refCount = 1
*May 15 14:25:17.290: //1184/C7B3E483880D/SIP/Event/sipSPICreateRpid: Received Octet3A=0x00 -> Setting ;screen=no ;privacy=off
*May 15 14:25:17.290: //1184/C7B3E483880D/SIP/Info/info/4096/sipSPISendInviteResponse: Associated container=0x3F47CBCC to Invite Response 180
*May 15 14:25:17.290: //-1/xxxxxxxxxxxx/SIP/Info/verbose/8192/sipSPIAppHandleContainerBody: sipSPIAppHandleContainerBody len 0
*May 15 14:25:17.290: //1184/C7B3E483880D/SIP/Transport/sipSPISendInviteResponse: Sending 180 Response to the Transport Layer
*May 15 14:25:17.290: //1184/C7B3E483880D/SIP/Transport/sipSPITransportSendMessage: msg=0x3A01A90C, addr=10.131.1.6, port=5060, sentBy_port=5060, local_addr=192.168.50.254, is_req=0, transport=1, switch=0, callBack=0x0
*May 15 14:25:17.290: //1184/C7B3E483880D/SIP/Info/info/2048/sipSPIGetExtensionCfg: SIP extension config:1, check sys cfg:1
*May 15 14:25:17.290: //1184/C7B3E483880D/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
*May 15 14:25:17.290: //1184/C7B3E483880D/SIP/Transport/sipTransportLogicSendMsg: Trying to send resp=0x3A01A90C to default port=5060
*May 15 14:25:17.290: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerGetConnection: connection required for raddr:10.131.1.6, rport:5060 with laddr:192.168.50.254
*May 15 14:25:17.290: //-1/xxxxxxxxxxxx/SIP/Transport/sipInstanceGetConnectionId: gcb=0x3F2BD4C0 is already on connection=0x3EC0C0A4 context_list
*May 15 14:25:17.290: //1184/C7B3E483880D/SIP/Transport/sipTransportLogicSendMsg: Connection obtained...sending msg=0x3A01A90C
*May 15 14:25:17.290: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x3A01A90C, addr=10.131.1.6, port=5060, local_addr=192.168.50.254, connId=4 vrfid=0 for UDP
*May 15 14:25:17.290: //1184/C7B3E483880D/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 180 Ringing
CSeq: 1 INVITE
Require: 100rel
RSeq: 1364
Content-Length: 0
*May 15 14:25:17.290: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_free: Freed msg=0x3A01A90C
*May 15 14:25:18.242: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_create: created msg=0x3A01A90C with refCount = 1
*May 15 14:25:18.242: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_create: created msg=0x3A09DFEC with refCount = 1
*May 15 14:25:18.242: //-1/xxxxxxxxxxxx/SIP/Info/verbose/4096/HandleUdpIPv4SocketReads: Msg enqueued for SPI with IP addr: [10.131.1.6]:5060, local_address:[192.168.92.2]
*May 15 14:25:18.242: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_free: Freed msg=0x3A01A90C
*May 15 14:25:18.242: //-1/xxxxxxxxxxxx/SIP/Info/info/4096/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
*May 15 14:25:18.242: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x0
*May 15 14:25:18.242: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
CSeq: 1 INVITE
Max-Forwards: 25
Min-SE: 600
Content-Length: 325
v=0
s=SBC call
c=IN IP4 10.131.1.6
t=0 0
a=fmtp:108 0-15
a=ptime:20
a=sendrecv
*May 15 14:25:18.242: //-1/xxxxxxxxxxxx/SIP/Info/verbose/4096/ccsip_new_msg_preprocessor: Checking Invite Dialog
*May 15 14:25:18.242: //1184/C7B3E483880D/SIP/Info/verbose/4096/sipSPIFindCcbUASReqTable: *****CCB found in UAS Request table. ccb=0x3F2BD4C0
*May 15 14:25:18.242: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_lock: Increment msg (0x3A09DFEC) counter, current msg->refCount = 2
*May 15 14:25:18.242: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Dialog Transaction Address 10.131.1.6,Port 5060, Transport 1, SentBy Port 5060vrfid 0
*May 15 14:25:18.242: //-1/xxxxxxxxxxxx/SIP/Info/verbose/8192/sipSPISetDateHeader: Clock Time Zone is UTC, same as GMT: Using GMT
*May 15 14:25:18.242: //1184/C7B3E483880D/SIP/Info/info/4096/sipSPISetCallingInfo: calling host comes from From: ims.sonatel.net
*May 15 14:25:18.242: //1184/C7B3E483880D/SIP/Info/verbose/4096/sipSPIUpdateCallingInfoUsingRpidOrFrom: Updating Calling Info with FROM header data
*May 15 14:25:18.242: //1184/C7B3E483880D/SIP/Info/verbose/4096/sipSPISendInviteResponse: Dialog State: [1]
*May 15 14:25:18.242: //1184/C7B3E483880D/SIP/Event/sipSPICreateRpid: Received Octet3A=0x00 -> Setting ;screen=no ;privacy=off
*May 15 14:25:18.246: //1184/C7B3E483880D/SIP/Info/info/4096/sipSPISendInviteResponse: Associated container=0x3F47CBCC to Invite Response 180
*May 15 14:25:18.246: //-1/xxxxxxxxxxxx/SIP/Info/verbose/8192/sipSPIAppHandleContainerBody: sipSPIAppHandleContainerBody len 0
*May 15 14:25:18.246: //1184/C7B3E483880D/SIP/Transport/sipSPISendInviteResponse: Sending 180 Response to the Transport Layer
*May 15 14:25:18.246: //1184/C7B3E483880D/SIP/Transport/sipSPITransportSendMessage: msg=0x3A01A90C, addr=10.131.1.6, port=5060, sentBy_port=5060, local_addr=192.168.50.254, is_req=0, transport=1, switch=0, callBack=0x0
*May 15 14:25:18.246: //1184/C7B3E483880D/SIP/Info/info/2048/sipSPIGetExtensionCfg: SIP extension config:1, check sys cfg:1
*May 15 14:25:18.246: //1184/C7B3E483880D/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
*May 15 14:25:18.246: //1184/C7B3E483880D/SIP/Transport/sipTransportLogicSendMsg: Trying to send resp=0x3A01A90C to default port=5060
*May 15 14:25:18.246: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerGetConnection: connection required for raddr:10.131.1.6, rport:5060 with laddr:192.168.50.254
*May 15 14:25:18.246: //-1/xxxxxxxxxxxx/SIP/Transport/sipInstanceGetConnectionId: gcb=0x3F2BD4C0 is already on connection=0x3EC0C0A4 context_list
*May 15 14:25:18.246: //1184/C7B3E483880D/SIP/Transport/sipTransportLogicSendMsg: Connection obtained...sending msg=0x3A01A90C
*May 15 14:25:18.246: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x3A01A90C, addr=10.131.1.6, port=5060, local_addr=192.168.50.254, connId=4 vrfid=0 for UDP
*May 15 14:25:18.246: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_free: Decrement msg (0x3A09DFEC) counter, current msg->refCount = 1
*May 15 14:25:18.246: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_free: Freed msg=0x3A09DFEC
*May 15 14:25:18.246: //1184/C7B3E483880D/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 180 Ringing
Date: Wed, 15 May 2024 14:25:18 GMT
CSeq: 1 INVITE
Require: 100rel
RSeq: 1364
Content-Length: 0
*May 15 14:25:18.246: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_free: Freed msg=0x3A01A90C
*May 15 14:25:19.110: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_MEDIA_EVENT
*May 15 14:25:19.110: //-1/xxxxxxxxxxxx/SIP/Info/info/4096/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 3 for event 29
*May 15 14:25:19.110: //1184/C7B3E483880D/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SPI_EVENT
*May 15 14:25:19.110: //1184/C7B3E483880D/SIP/Info/info/8192/Session-Timer/sipSTSLMain:
*May 15 14:25:19.110: //1184/C7B3E483880D/SIP/Info/verbose/4096/ccsip_buffer_media_event: Buffering event SIPSPI_EV_CC_MEDIA_EVENT - Purpose 1: FALSE
*May 15 14:25:19.118: //1184/C7B3E483880D/SIP/Info/info/4096/sipSPIResendInviteResponse: resending 180 response due to no PRACK
*May 15 14:25:19.118: //1184/C7B3E483880D/SIP/Info/verbose/4096/sipSPISendInviteResponse: Dialog State: [1]
*May 15 14:25:19.118: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_create: created msg=0x3FC76FC8 with refCount = 1
*May 15 14:25:19.118: //1184/C7B3E483880D/SIP/Event/sipSPICreateRpid: Received Octet3A=0x00 -> Setting ;screen=no ;privacy=off
*May 15 14:25:19.118: //1184/C7B3E483880D/SIP/Info/info/4096/sipSPISendInviteResponse: Associated container=0x3F47CBCC to Invite Response 180
*May 15 14:25:19.118: //-1/xxxxxxxxxxxx/SIP/Info/verbose/8192/sipSPIAppHandleContainerBody: sipSPIAppHandleContainerBody len 0
*May 15 14:25:19.118: //1184/C7B3E483880D/SIP/Transport/sipSPISendInviteResponse: Sending 180 Response to the Transport Layer
*May 15 14:25:19.118: //1184/C7B3E483880D/SIP/Transport/sipSPITransportSendMessage: msg=0x3FC76FC8, addr=10.131.1.6, port=5060, sentBy_port=5060, local_addr=192.168.50.254, is_req=0, transport=1, switch=0, callBack=0x0
*May 15 14:25:19.118: //1184/C7B3E483880D/SIP/Info/info/2048/sipSPIGetExtensionCfg: SIP extension config:1, check sys cfg:1
*May 15 14:25:19.118: //1184/C7B3E483880D/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
*May 15 14:25:19.118: //1184/C7B3E483880D/SIP/Transport/sipTransportLogicSendMsg: Trying to send resp=0x3FC76FC8 to default port=5060
*May 15 14:25:19.118: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerGetConnection: connection required for raddr:10.131.1.6, rport:5060 with laddr:192.168.50.254
*May 15 14:25:19.118: //-1/xxxxxxxxxxxx/SIP/Transport/sipInstanceGetConnectionId: gcb=0x3F2BD4C0 is already on connection=0x3EC0C0A4 context_list
*May 15 14:25:19.118: //1184/C7B3E483880D/SIP/Transport/sipTransportLogicSendMsg: Connection obtained...sending msg=0x3FC76FC8
*May 15 14:25:19.118: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x3FC76FC8, addr=10.131.1.6, port=5060, local_addr=192.168.50.254, connId=4 vrfid=0 for UDP
*May 15 14:25:19.122: //1184/C7B3E483880D/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 180 Ringing
CSeq: 1 INVITE
Require: 100rel
RSeq: 1364
Content-Length: 0
*May 15 14:25:19.122: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_free: Freed msg=0x3FC76FC8
*May 15 14:25:22.158: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_create: created msg=0x3A01A90C with refCount = 1
*May 15 14:25:22.158: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_create: created msg=0x3FC76FC8 with refCount = 1
*May 15 14:25:22.158: //-1/xxxxxxxxxxxx/SIP/Info/verbose/4096/HandleUdpIPv4SocketReads: Msg enqueued for SPI with IP addr: [10.131.1.6]:5060, local_address:[192.168.92.2]
*May 15 14:25:22.158: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_free: Freed msg=0x3A01A90C
*May 15 14:25:22.158: //-1/xxxxxxxxxxxx/SIP/Info/info/4096/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
*May 15 14:25:22.158: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x0
*May 15 14:25:22.158: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
CSeq: 1 INVITE
Max-Forwards: 25
Min-SE: 600
Content-Length: 325
v=0
s=SBC call
c=IN IP4 10.131.1.6
t=0 0
a=fmtp:108 0-15
a=ptime:20
a=sendrecv
*May 15 14:25:22.158: //-1/xxxxxxxxxxxx/SIP/Info/verbose/4096/ccsip_new_msg_preprocessor: Checking Invite Dialog
*May 15 14:25:22.158: //1184/C7B3E483880D/SIP/Info/verbose/4096/sipSPIFindCcbUASReqTable: *****CCB found in UAS Request table. ccb=0x3F2BD4C0
*May 15 14:25:22.162: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_lock: Increment msg (0x3FC76FC8) counter, current msg->refCount = 2
*May 15 14:25:22.162: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Dialog Transaction Address 10.131.1.6,Port 5060, Transport 1, SentBy Port 5060vrfid 0
*May 15 14:25:22.162: //-1/xxxxxxxxxxxx/SIP/Info/verbose/8192/sipSPISetDateHeader: Clock Time Zone is UTC, same as GMT: Using GMT
*May 15 14:25:22.162: //1184/C7B3E483880D/SIP/Info/info/4096/sipSPISetCallingInfo: calling host comes from From: ims.sonatel.net
*May 15 14:25:22.162: //1184/C7B3E483880D/SIP/Info/verbose/4096/sipSPIUpdateCallingInfoUsingRpidOrFrom: Updating Calling Info with FROM header data
*May 15 14:25:22.162: //1184/C7B3E483880D/SIP/Info/verbose/4096/sipSPISendInviteResponse: Dialog State: [1]
*May 15 14:25:22.162: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_create: created msg=0x3A01A90C with refCount = 1
*May 15 14:25:22.162: //1184/C7B3E483880D/SIP/Event/sipSPICreateRpid: Received Octet3A=0x00 -> Setting ;screen=no ;privacy=off
*May 15 14:25:22.162: //1184/C7B3E483880D/SIP/Info/info/4096/sipSPISendInviteResponse: Associated container=0x3F47CBCC to Invite Response 180
*May 15 14:25:22.162: //-1/xxxxxxxxxxxx/SIP/Info/verbose/8192/sipSPIAppHandleContainerBody: sipSPIAppHandleContainerBody len 0
*May 15 14:25:22.162: //1184/C7B3E483880D/SIP/Transport/sipSPISendInviteResponse: Sending 180 Response to the Transport Layer
*May 15 14:25:22.162: //1184/C7B3E483880D/SIP/Transport/sipSPITransportSendMessage: msg=0x3A01A90C, addr=10.131.1.6, port=5060, sentBy_port=5060, local_addr=192.168.50.254, is_req=0, transport=1, switch=0, callBack=0x0
*May 15 14:25:22.162: //1184/C7B3E483880D/SIP/Info/info/2048/sipSPIGetExtensionCfg: SIP extension config:1, check sys cfg:1
*May 15 14:25:22.162: //1184/C7B3E483880D/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
*May 15 14:25:22.162: //1184/C7B3E483880D/SIP/Transport/sipTransportLogicSendMsg: Trying to send resp=0x3A01A90C to default port=5060
*May 15 14:25:22.162: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerGetConnection: connection required for raddr:10.131.1.6, rport:5060 with laddr:192.168.50.254
*May 15 14:25:22.162: //-1/xxxxxxxxxxxx/SIP/Transport/sipInstanceGetConnectionId: gcb=0x3F2BD4C0 is already on connection=0x3EC0C0A4 context_list
*May 15 14:25:22.162: //1184/C7B3E483880D/SIP/Transport/sipTransportLogicSendMsg: Connection obtained...sending msg=0x3A01A90C
*May 15 14:25:22.162: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x3A01A90C, addr=10.131.1.6, port=5060, local_addr=192.168.50.254, connId=4 vrfid=0 for UDP
*May 15 14:25:22.162: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_free: Decrement msg (0x3FC76FC8) counter, current msg->refCount = 1
*May 15 14:25:22.162: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_free: Freed msg=0x3FC76FC8
*May 15 14:25:22.162: //1184/C7B3E483880D/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 180 Ringing
Date: Wed, 15 May 2024 14:25:22 GMT
CSeq: 1 INVITE
Require: 100rel
RSeq: 1364
Content-Length: 0
*May 15 14:25:22.162: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_free: Freed msg=0x3A01A90C
*May 15 14:25:23.446: //1184/C7B3E483880D/SIP/Info/info/4096/sipSPIResendInviteResponse: resending 180 response due to no PRACK
*May 15 14:25:23.446: //1184/C7B3E483880D/SIP/Info/verbose/4096/sipSPISendInviteResponse: Dialog State: [1]
*May 15 14:25:23.446: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_create: created msg=0x3A01A90C with refCount = 1
*May 15 14:25:23.446: //1184/C7B3E483880D/SIP/Event/sipSPICreateRpid: Received Octet3A=0x00 -> Setting ;screen=no ;privacy=off
*May 15 14:25:23.446: //1184/C7B3E483880D/SIP/Info/info/4096/sipSPISendInviteResponse: Associated container=0x3F47CBCC to Invite Response 180
*May 15 14:25:23.446: //-1/xxxxxxxxxxxx/SIP/Info/verbose/8192/sipSPIAppHandleContainerBody: sipSPIAppHandleContainerBody len 0
*May 15 14:25:23.446: //1184/C7B3E483880D/SIP/Transport/sipSPISendInviteResponse: Sending 180 Response to the Transport Layer
*May 15 14:25:23.446: //1184/C7B3E483880D/SIP/Transport/sipSPITransportSendMessage: msg=0x3A01A90C, addr=10.131.1.6, port=5060, sentBy_port=5060, local_addr=192.168.50.254, is_req=0, transport=1, switch=0, callBack=0x0
*May 15 14:25:23.446: //1184/C7B3E483880D/SIP/Info/info/2048/sipSPIGetExtensionCfg: SIP extension config:1, check sys cfg:1
*May 15 14:25:23.446: //1184/C7B3E483880D/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
*May 15 14:25:23.446: //1184/C7B3E483880D/SIP/Transport/sipTransportLogicSendMsg: Trying to send resp=0x3A01A90C to default port=5060
*May 15 14:25:23.446: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerGetConnection: connection required for raddr:10.131.1.6, rport:5060 with laddr:192.168.50.254
*May 15 14:25:23.446: //-1/xxxxxxxxxxxx/SIP/Transport/sipInstanceGetConnectionId: gcb=0x3F2BD4C0 is already on connection=0x3EC0C0A4 context_list
*May 15 14:25:23.446: //1184/C7B3E483880D/SIP/Transport/sipTransportLogicSendMsg: Connection obtained...sending msg=0x3A01A90C
*May 15 14:25:23.446: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x3A01A90C, addr=10.131.1.6, port=5060, local_addr=192.168.50.254, connId=4 vrfid=0 for UDP
*May 15 14:25:23.450: //1184/C7B3E483880D/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 180 Ringing
CSeq: 1 INVITE
Require: 100rel
RSeq: 1364
Content-Length: 0
*May 15 14:25:23.450: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_free: Freed msg=0x3A01A90C
*May 15 14:25:27.118: //1184/C7B3E483880D/SIP/Info/info/4096/sipSPIResendInviteResponse: resending 180 response due to no PRACK
*May 15 14:25:27.118: //1184/C7B3E483880D/SIP/Info/verbose/4096/sipSPISendInviteResponse: Dialog State: [1]
*May 15 14:25:27.118: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_create: created msg=0x3A01A90C with refCount = 1
*May 15 14:25:27.118: //1184/C7B3E483880D/SIP/Event/sipSPICreateRpid: Received Octet3A=0x00 -> Setting ;screen=no ;privacy=off
*May 15 14:25:27.118: //1184/C7B3E483880D/SIP/Info/info/4096/sipSPISendInviteResponse: Associated container=0x3F47CBCC to Invite Response 180
*May 15 14:25:27.118: //-1/xxxxxxxxxxxx/SIP/Info/verbose/8192/sipSPIAppHandleContainerBody: sipSPIAppHandleContainerBody len 0
*May 15 14:25:27.118: //1184/C7B3E483880D/SIP/Transport/sipSPISendInviteResponse: Sending 180 Response to the Transport Layer
*May 15 14:25:27.118: //1184/C7B3E483880D/SIP/Transport/sipSPITransportSendMessage: msg=0x3A01A90C, addr=10.131.1.6, port=5060, sentBy_port=5060, local_addr=192.168.50.254, is_req=0, transport=1, switch=0, callBack=0x0
*May 15 14:25:27.118: //1184/C7B3E483880D/SIP/Info/info/2048/sipSPIGetExtensionCfg: SIP extension config:1, check sys cfg:1
*May 15 14:25:27.118: //1184/C7B3E483880D/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
*May 15 14:25:27.118: //1184/C7B3E483880D/SIP/Transport/sipTransportLogicSendMsg: Trying to send resp=0x3A01A90C to default port=5060
*May 15 14:25:27.118: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerGetConnection: connection required for raddr:10.131.1.6, rport:5060 with laddr:192.168.50.254
*May 15 14:25:27.118: //-1/xxxxxxxxxxxx/SIP/Transport/sipInstanceGetConnectionId: gcb=0x3F2BD4C0 is already on connection=0x3EC0C0A4 context_list
*May 15 14:25:27.118: //1184/C7B3E483880D/SIP/Transport/sipTransportLogicSendMsg: Connection obtained...sending msg=0x3A01A90C
*May 15 14:25:27.118: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x3A01A90C, addr=10.131.1.6, port=5060, local_addr=192.168.50.254, connId=4 vrfid=0 for UDP
*May 15 14:25:27.118: //1184/C7B3E483880D/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 180 Ringing
CSeq: 1 INVITE
Require: 100rel
RSeq: 1364
Content-Length: 0
*May 15 14:25:27.118: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_free: Freed msg=0x3A01A90C
*May 15 14:25:29.138: //1184/C7B3E483880D/SIP/Info/notify/1/ccsip_query_codec_info: Negotiated codec = 6
*May 15 14:25:29.138: //1184/C7B3E483880D/SIP/Info/verbose/8192/sipSPI_ipip_codec_byte_transrating: NOT SIP-SIP CALL. Will be addressed in future.
*May 15 14:25:29.142: //1184/C7B3E483880D/SIP/Info/info/8192/ccsip_call_statistics: Stats are not supported for IPIP call.
*May 15 14:25:29.142: //1184/C7B3E483880D/SIP/Info/verbose/4096/ccsip_ipip_media_service_get_event_data: Event id = 34
*May 15 14:25:29.142: //1184/C7B3E483880D/SIP/Info/critical/4096/ccsip_ipip_mf_create_xml_metadata_for_disconnect: MF: Not a Forked leg..
*May 15 14:25:29.142: //1184/C7B3E483880D/SIP/Info/critical/32768/ccsip_ipip_media_forking_post_event: MF: Not a Anchor SIP leg..
*May 15 14:25:29.142: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_DISCONNECT
*May 15 14:25:29.142: //-1/xxxxxxxxxxxx/SIP/Info/info/4096/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 3 for event 8
*May 15 14:25:29.142: //1184/C7B3E483880D/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SPI_EVENT
*May 15 14:25:29.142: //1184/C7B3E483880D/SIP/Info/info/8192/Session-Timer/sipSTSLMain:
*May 15 14:25:29.142: //1184/C7B3E483880D/SIP/Info/info/131072/sipSPIBwCacReleaseInterfaceBw: bwcac releasing interface GigabitEthernet0/0 bw 80 Kbps
*May 15 14:25:29.142: //1184/C7B3E483880D/SIP/Info/info/131072/sipSPIBwCacReleaseAccountedBw: bwcac released accounted bw 80000 bps
*May 15 14:25:29.142: //1184/C7B3E483880D/SIP/Error/act_sentalert_disconnect:
Disconnect cause from ccapi :47 and sip_disc_cause: 503
*May 15 14:25:29.142: //1184/C7B3E483880D/SIP/Info/verbose/4096/sipSPISendInviteResponse: Dialog State: [1]
*May 15 14:25:29.142: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_create: created msg=0x3A01A90C with refCount = 1
*May 15 14:25:29.142: //1184/C7B3E483880D/SIP/Info/notify/8192/sipSPIAddSessionID: localUUID - a66a2161774154229e9d5a9cb7bf1ee2 remoteUUID - 00000000000000000000000000000000
*May 15 14:25:29.142: //1184/C7B3E483880D/SIP/Info/notify/8192/sipSPIAddSessionID: Session-ID header 00000000000000000000000000000000;remote=a66a2161774154229e9d5a9cb7bf1ee2
*May 15 14:25:29.142: //1184/C7B3E483880D/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_RESP
*May 15 14:25:29.142: //1184/C7B3E483880D/SIP/Event/Session-Timer/sipSTSLMain: dir:1, method:102, resp_code:503, container:3F47D2AC
SE: 1800;refresher:none peer refresher:none, flags:1, posted event:E_STSL_INVALID_PEER_EVENT, reason:4
*May 15 14:25:29.142: //1184/C7B3E483880D/SIP/Info/info/4096/sipSPISendInviteResponse: Associated container=0x3F47D2AC to Invite Response 503
*May 15 14:25:29.142: //-1/xxxxxxxxxxxx/SIP/Info/verbose/8192/sipSPIAppHandleContainerBody: sipSPIAppHandleContainerBody len 0
*May 15 14:25:29.142: //1184/C7B3E483880D/SIP/Transport/sipSPITransportSendMessage: msg=0x3A01A90C, addr=10.131.1.6, port=5060, sentBy_port=5060, local_addr=192.168.50.254, is_req=0, transport=1, switch=0, callBack=0x35A191E8
*May 15 14:25:29.142: //1184/C7B3E483880D/SIP/Info/info/2048/sipSPIGetExtensionCfg: SIP extension config:1, check sys cfg:1
*May 15 14:25:29.142: //1184/C7B3E483880D/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
*May 15 14:25:29.142: //1184/C7B3E483880D/SIP/Transport/sipTransportLogicSendMsg: Trying to send resp=0x3A01A90C to default port=5060
*May 15 14:25:29.142: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerGetConnection: connection required for raddr:10.131.1.6, rport:5060 with laddr:192.168.50.254
*May 15 14:25:29.142: //-1/xxxxxxxxxxxx/SIP/Transport/sipInstanceGetConnectionId: gcb=0x3F2BD4C0 is already on connection=0x3EC0C0A4 context_list
*May 15 14:25:29.142: //1184/C7B3E483880D/SIP/Transport/sipTransportLogicSendMsg: Connection obtained...sending msg=0x3A01A90C
*May 15 14:25:29.142: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x3A01A90C, addr=10.131.1.6, port=5060, local_addr=192.168.50.254, connId=4 vrfid=0 for UDP
*May 15 14:25:29.142: //1184/C7B3E483880D/SIP/Info/critical/512/sentErrResDisconnecting: Sent an 3456XX Error Response
*May 15 14:25:29.142: //1184/C7B3E483880D/SIP/State/sipSPIChangeState: 0x3F2BD4C0 : State change from (STATE_SENT_ALERTING, SUBSTATE_NONE) to (STATE_DISCONNECTING, SUBSTATE_NONE)
*May 15 14:25:29.142: //1184/C7B3E483880D/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 503 Service Unavailable
CSeq: 1 INVITE
Reason: Q.850;cause=47
Session-ID: 00000000000000000000000000000000;remote=a66a2161774154229e9d5a9cb7bf1ee2
Content-Length: 0
*May 15 14:25:29.142: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_free: Freed msg=0x3A01A90C
*May 15 14:25:29.642: //1184/C7B3E483880D/SIP/Info/verbose/4096/sipSPISendInviteResponse: Dialog State: [0]
*May 15 14:25:29.642: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_create: created msg=0x3A01A90C with refCount = 1
*May 15 14:25:29.642: //1184/C7B3E483880D/SIP/Info/info/4096/sipSPISendInviteResponse: Associated container=0x3F47D2AC to Invite Response 503
*May 15 14:25:29.642: //-1/xxxxxxxxxxxx/SIP/Info/verbose/8192/sipSPIAppHandleContainerBody: sipSPIAppHandleContainerBody len 0
*May 15 14:25:29.642: //1184/C7B3E483880D/SIP/Transport/sipSPITransportSendMessage: msg=0x3A01A90C, addr=10.131.1.6, port=5060, sentBy_port=5060, local_addr=192.168.50.254, is_req=0, transport=1, switch=0, callBack=0x0
*May 15 14:25:29.642: //1184/C7B3E483880D/SIP/Info/info/2048/sipSPIGetExtensionCfg: SIP extension config:1, check sys cfg:1
*May 15 14:25:29.642: //1184/C7B3E483880D/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
*May 15 14:25:29.642: //1184/C7B3E483880D/SIP/Transport/sipTransportLogicSendMsg: Trying to send resp=0x3A01A90C to default port=5060
*May 15 14:25:29.642: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerGetConnection: connection required for raddr:10.131.1.6, rport:5060 with laddr:192.168.50.254
*May 15 14:25:29.642: //-1/xxxxxxxxxxxx/SIP/Transport/sipInstanceGetConnectionId: gcb=0x3F2BD4C0 is already on connection=0x3EC0C0A4 context_list
*May 15 14:25:29.642: //1184/C7B3E483880D/SIP/Transport/sipTransportLogicSendMsg: Connection obtained...sending msg=0x3A01A90C
*May 15 14:25:29.642: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x3A01A90C, addr=10.131.1.6, port=5060, local_addr=192.168.50.254, connId=4 vrfid=0 for UDP
*May 15 14:25:29.642: //1184/C7B3E483880D/SIP/Msg/ccsipDisplayMsg:
Sent:
CSeq: 1 INVITE
Content-Length: 0
*May 15 14:25:29.642: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_free: Freed msg=0x3A01A90C
*May 15 14:25:30.866: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_create: created msg=0x3A01A90C with refCount = 1
*May 15 14:25:30.866: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_create: created msg=0x3DAAB090 with refCount = 1
*May 15 14:25:30.866: //-1/xxxxxxxxxxxx/SIP/Info/verbose/4096/HandleUdpIPv4SocketReads: Msg enqueued for SPI with IP addr: [10.131.1.6]:5060, local_address:[192.168.92.2]
*May 15 14:25:30.866: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_free: Freed msg=0x3A01A90C
*May 15 14:25:30.870: //-1/xxxxxxxxxxxx/SIP/Info/info/4096/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
*May 15 14:25:30.870: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x0
*May 15 14:25:30.870: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:+221339212200@192.168.92.2:5060 SIP/2.0
Via: SIP/2.0/UDP 10.131.1.6:5060;branch=z9hG4bK3mxmxbmw3uubqk5txj3kkbkk5;Role=3;Hpt=8e72_36
Call-ID: sbcthLNQQVSvVpvSSiQpiqG4QlMp4pMSM6GIvMpF@BI.BLB.B.BVL
From: <sip:781260948@ims.sonatel.net;user=phone;noa=national;srvattri=national>;tag=l6FQvQQp
CSeq: 1 INVITE
Allow: INVITE,ACK,BYE,CANCEL,UPDATE,INFO,PRACK,NOTIFY,REFER,SUBSCRIBE,OPTIONS,MESSAGE
Contact: <sip:10.131.1.6:5060;Dpt=eaea-200;Hpt=8e72_16;CxtId=4;TRC=ffffffff-ffffffff>
Max-Forwards: 25
Supported: timer,100rel,histinfo,early-session
Session-Expires: 1800
Min-SE: 600
P-Asserted-Identity: <tel:781260948>
P-Called-Party-ID: <tel:+221339212200>
P-Early-Media: gated
Content-Length: 325
Content-Type: application/sdp
v=0
o=- 45312217 45312217 IN IP4 10.131.1.6
s=SBC call
c=IN IP4 10.131.1.6
t=0 0
m=audio 40370 RTP/AVP 8 103 0 18 102 108
a=rtpmap:103 AMR/16000
a=fmtp:103 mode-change-neighbor=0;mode-change-period=1;octet-align=0
a=rtpmap:102 GSM-HR/8000
a=rtpmap:108 telephone-event/16000
a=fmtp:108 0-15
a=ptime:20
a=sendrecv
*May 15 14:25:30.870: //-1/xxxxxxxxxxxx/SIP/Info/verbose/4096/ccsip_new_msg_preprocessor: Checking Invite Dialog
*May 15 14:25:30.870: //1184/C7B3E483880D/SIP/Info/verbose/4096/sipSPIFindCcbUASReqTable: *****CCB found in UAS Request table. ccb=0x3F2BD4C0
*May 15 14:25:30.870: //1184/C7B3E483880D/SIP/Info/info/4096/sippmh_cmp_tags: An Invite request retransmission is received in the COMPLETED state.
*May 15 14:25:30.870: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_lock: Increment msg (0x3DAAB090) counter, current msg->refCount = 2
*May 15 14:25:30.870: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Subsq Transaction Address 10.131.1.6,Port 5060, Transport 1, SentBy Port 5060vrfid 0
*May 15 14:25:30.870: //-1/xxxxxxxxxxxx/SIP/Info/verbose/8192/sipSPISetDateHeader: Clock Time Zone is UTC, same as GMT: Using GMT
*May 15 14:25:30.870: //1184/C7B3E483880D/SIP/Info/info/4096/sipSPISetCallingInfo: calling host comes from From: ims.sonatel.net
*May 15 14:25:30.870: //1184/C7B3E483880D/SIP/Info/verbose/4096/sipSPIUpdateCallingInfoUsingRpidOrFrom: Updating Calling Info with FROM header data
*May 15 14:25:30.870: //1184/C7B3E483880D/SIP/Info/verbose/4096/sipSPISendInviteResponse: Dialog State: [0]
*May 15 14:25:30.870: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_create: created msg=0x3A01A90C with refCount = 1
*May 15 14:25:30.870: //1184/C7B3E483880D/SIP/Info/notify/8192/sipSPIAddSessionID: localUUID - a66a2161774154229e9d5a9cb7bf1ee2 remoteUUID - 00000000000000000000000000000000
*May 15 14:25:30.870: //1184/C7B3E483880D/SIP/Info/notify/8192/sipSPIAddSessionID: Session-ID header 00000000000000000000000000000000;remote=a66a2161774154229e9d5a9cb7bf1ee2
*May 15 14:25:30.870: //1184/C7B3E483880D/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_RESP
*May 15 14:25:30.870: //1184/C7B3E483880D/SIP/Event/Session-Timer/sipSTSLMain: dir:1, method:102, resp_code:503, container:3F47D1A4
*May 15 14:25:30.870: //1184/C7B3E483880D/SIP/Info/info/8192/Session-Timer/sipSTSLMain:
*May 15 14:25:30.870: //1184/C7B3E483880D/SIP/Info/info/4096/sipSPISendInviteResponse: Associated container=0x3F47D1A4 to Invite Response 503
*May 15 14:25:30.870: //-1/xxxxxxxxxxxx/SIP/Info/verbose/8192/sipSPIAppHandleContainerBody: sipSPIAppHandleContainerBody len 0
*May 15 14:25:30.870: //1184/C7B3E483880D/SIP/Transport/sipSPITransportSendMessage: msg=0x3A01A90C, addr=10.131.1.6, port=5060, sentBy_port=5060, local_addr=192.168.50.254, is_req=0, transport=1, switch=0, callBack=0x0
*May 15 14:25:30.870: //1184/C7B3E483880D/SIP/Info/info/2048/sipSPIGetExtensionCfg: SIP extension config:1, check sys cfg:1
*May 15 14:25:30.870: //1184/C7B3E483880D/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
*May 15 14:25:30.870: //1184/C7B3E483880D/SIP/Transport/sipTransportLogicSendMsg: Trying to send resp=0x3A01A90C to default port=5060
*May 15 14:25:30.870: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerGetConnection: connection required for raddr:10.131.1.6, rport:5060 with laddr:192.168.50.254
*May 15 14:25:30.870: //-1/xxxxxxxxxxxx/SIP/Transport/sipInstanceGetConnectionId: gcb=0x3F2BD4C0 is already on connection=0x3EC0C0A4 context_list
*May 15 14:25:30.870: //1184/C7B3E483880D/SIP/Transport/sipTransportLogicSendMsg: Connection obtained...sending msg=0x3A01A90C
*May 15 14:25:30.870: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x3A01A90C, addr=10.131.1.6, port=5060, local_addr=192.168.50.254, connId=4 vrfid=0 for UDP
*May 15 14:25:30.874: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_free: Decrement msg (0x3DAAB090) counter, current msg->refCount = 1
*May 15 14:25:30.874: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_free: Freed msg=0x3DAAB090
*May 15 14:25:30.874: //1184/C7B3E483880D/SIP/Info/verbose/4096/sipSPISendInviteResponse: Dialog State: [0]
*May 15 14:25:30.874: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_create: created msg=0x3DAAB090 with refCount = 1
*May 15 14:25:30.874: //1184/C7B3E483880D/SIP/Info/info/4096/sipSPISendInviteResponse: Associated container=0x3F47D2AC to Invite Response 503
*May 15 14:25:30.874: //-1/xxxxxxxxxxxx/SIP/Info/verbose/8192/sipSPIAppHandleContainerBody: sipSPIAppHandleContainerBody len 0
*May 15 14:25:30.874: //1184/C7B3E483880D/SIP/Transport/sipSPITransportSendMessage: msg=0x3DAAB090, addr=10.131.1.6, port=5060, sentBy_port=5060, local_addr=192.168.50.254, is_req=0, transport=1, switch=0, callBack=0x0
*May 15 14:25:30.874: //1184/C7B3E483880D/SIP/Info/info/2048/sipSPIGetExtensionCfg: SIP extension config:1, check sys cfg:1
*May 15 14:25:30.874: //1184/C7B3E483880D/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
*May 15 14:25:30.874: //1184/C7B3E483880D/SIP/Transport/sipTransportLogicSendMsg: Trying to send resp=0x3DAAB090 to default port=5060
*May 15 14:25:30.874: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerGetConnection: connection required for raddr:10.131.1.6, rport:5060 with laddr:192.168.50.254
*May 15 14:25:30.874: //-1/xxxxxxxxxxxx/SIP/Transport/sipInstanceGetConnectionId: gcb=0x3F2BD4C0 is already on connection=0x3EC0C0A4 context_list
*May 15 14:25:30.874: //1184/C7B3E483880D/SIP/Transport/sipTransportLogicSendMsg: Connection obtained...sending msg=0x3DAAB090
*May 15 14:25:30.874: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x3DAAB090, addr=10.131.1.6, port=5060, local_addr=192.168.50.254, connId=4 vrfid=0 for UDP
*May 15 14:25:31.050: //1184/C7B3E483880D/SIP/Msg/ccsipDisplayMsg:
Sent:
Date: Wed, 15 May 2024 14:25:30 GMT
CSeq: 1 INVITE
Content-Length: 0
*May 15 14:25:31.050: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_free: Freed msg=0x3A01A90C
Sent:
CSeq: 1 INVITE
Content-Length: 0
*May 15 14:25:31.050: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_free: Freed msg=0x3DAAB090
*May 15 14:25:33.018: //1184/C7B3E483880D/SIP/Info/verbose/4096/sipSPISendInviteResponse: Dialog State: [0]
*May 15 14:25:33.018: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_create: created msg=0x3A01A90C with refCount = 1
*May 15 14:25:33.018: //1184/C7B3E483880D/SIP/Info/info/4096/sipSPISendInviteResponse: Associated container=0x3F47D2AC to Invite Response 503
*May 15 14:25:33.018: //-1/xxxxxxxxxxxx/SIP/Info/verbose/8192/sipSPIAppHandleContainerBody: sipSPIAppHandleContainerBody len 0
*May 15 14:25:33.018: //1184/C7B3E483880D/SIP/Transport/sipSPITransportSendMessage: msg=0x3A01A90C, addr=10.131.1.6, port=5060, sentBy_port=5060, local_addr=192.168.50.254, is_req=0, transport=1, switch=0, callBack=0x0
*May 15 14:25:33.018: //1184/C7B3E483880D/SIP/Info/info/2048/sipSPIGetExtensionCfg: SIP extension config:1, check sys cfg:1
*May 15 14:25:33.018: //1184/C7B3E483880D/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
*May 15 14:25:33.018: //1184/C7B3E483880D/SIP/Transport/sipTransportLogicSendMsg: Trying to send resp=0x3A01A90C to default port=5060
*May 15 14:25:33.018: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerGetConnection: connection required for raddr:10.131.1.6, rport:5060 with laddr:192.168.50.254
*May 15 14:25:33.018: //-1/xxxxxxxxxxxx/SIP/Transport/sipInstanceGetConnectionId: gcb=0x3F2BD4C0 is already on connection=0x3EC0C0A4 context_list
*May 15 14:25:33.018: //1184/C7B3E483880D/SIP/Transport/sipTransportLogicSendMsg: Connection obtained...sending msg=0x3A01A90C
*May 15 14:25:33.018: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x3A01A90C, addr=10.131.1.6, port=5060, local_addr=192.168.50.254, connId=4 vrfid=0 for UDP
*May 15 14:25:33.018: //1184/C7B3E483880D/SIP/Msg/ccsipDisplayMsg:
Sent:
CSeq: 1 INVITE
Content-Length: 0
*May 15 14:25:33.018: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_free: Freed msg=0x3A01A90C
*May 15 14:25:36.074: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_create: created msg=0x3A01A90C with refCount = 1
*May 15 14:25:36.074: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_create: created msg=0x3DAAB090 with refCount = 1
*May 15 14:25:36.074: //-1/xxxxxxxxxxxx/SIP/Info/critical/1024/httpish_msg_process_network_msg: MSG LINE READ FAILURE DUE TO RS->EOF
*May 15 14:25:36.074: //-1/xxxxxxxxxxxx/SIP/Info/critical/1024/ccsip_process_network_message: process_network_msg: not complete
*May 15 14:25:36.074: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_free: Freed msg=0x3DAAB090
*May 15 14:25:36.074: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
hello
*May 15 14:25:36.074: //-1/xxxxxxxxxxxx/SIP/Error/HandleUdpIPv4SocketReads:
SIP Message incomplete, trashed
*May 15 14:25:36.074: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_free: Freed msg=0x3A01A90C
*May 15 14:25:36.874: //1184/C7B3E483880D/SIP/Error/act_disconnecting_wait_ack:
Out of retries
*May 15 14:25:36.874: //1184/C7B3E483880D/SIP/Info/info/4096/sipSPISetCommonTimer: Started generic timer type 2 for 240000 millisecs
*May 15 14:25:36.874: //1184/C7B3E483880D/SIP/Info/verbose/8192/sipSPIDeferCallClose: Not split dataplane, bail
*May 15 14:25:36.874: //1184/C7B3E483880D/SIP/Info/verbose/8192/sipSPIWaitForStatsBforeCallClose: Not split dataplane, bail
*May 15 14:25:36.874: //1184/C7B3E483880D/SIP/Info/verbose/4096/sipSPICallCloseAfterFinalStat:
*May 15 14:25:36.874: //1184/C7B3E483880D/SIP/Info/info/12288/sipSPIIcpifUpdate: CallState: 2 Playout: 0 DiscTime:59680000 ConnTime 0
*May 15 14:25:36.874: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_free: Decrement msg (0x3A0C2900) counter, current msg->refCount = 1
*May 15 14:25:36.874: //1184/C7B3E483880D/SIP/State/sipSPIChangeState: 0x3F2BD4C0 : State change from (STATE_DISCONNECTING, SUBSTATE_NONE) to (STATE_DEAD, SUBSTATE_NONE)
*May 15 14:25:36.874: //1184/C7B3E483880D/SIP/Call/sipSPICallInfo:
The Call Setup Information is:
Call Control Block (CCB) : 0x0x3F2BD4C0
State of The Call : STATE_DEAD
TCP Sockets Used : NO
Calling Number : 781260948
Called Number : +221339212200
Source IP Address (Sig 192.168.50.254
Destn SIP Req Addr:Port : 10.131.1.6:5060
Destn SIP Resp Addr:Port : 10.131.1.6:5060
Destination Name : 10.131.1.6
*May 15 14:25:36.874: //1184/C7B3E483880D/SIP/Call/sipSPIMediaCallInfo:
Number of Media Streams: 1
Media Stream : 1
Negotiated Codec Bytes : 160
Negotiated Dtmf-relay : 6
Dtmf-relay Payload : 108 (tx), 108 (rx)
Source IP Address (Media): 192.168.50.254
Source IP Port (Media): 17556
Destn IP Address (Media): 10.131.1.6
Destn IP Port (Media): 40370
Orig Destn IP Address:Port (Media): [ - ]:0
Disconnect Cause (CC) : 47
Disconnect Cause (SIP) : 503
*May 15 14:25:36.874: //1184/C7B3E483880D/SIP/Info/verbose/4096/sipSPIUdeleteccCallIdFromTable: Removing call id 4A0
*May 15 14:25:36.874: //-1/xxxxxxxxxxxx/SIP/Info/verbose/4096/sipSPIDeleteContextFromTable: Context for key=[832] removed.
*May 15 14:25:36.874: //1184/C7B3E483880D/SIP/Info/info/4096/sipSPIStopCommonTimer: Stopping Generic Timer 2
*May 15 14:25:36.874: //1184/C7B3E483880D/SIP/Info/verbose/4096/sipSPIUdeleteCcbFromTable: Deleting from table. ccb=0x3F2BD4C0 key=sbcthLNQQVSvVpvSSiQpiqG4QlMp4pMSM6GIvMpF@BI.BLB.B.BVL221339212200
*May 15 14:25:36.874: //1184/C7B3E483880D/SIP/Info/verbose/4096/sipSPIUdeleteCcbFromTable: Deleting from table. ccb=0x3F2BD4C0 key=sbcthLNQQVSvVpvSSiQpiqG4QlMp4pMSM6GIvMpF@BI.BLB.B.BVL23921EF8-1F8A
*May 15 14:25:36.874: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_free: Freed msg=0x3A0C2900
*May 15 14:25:36.874: //1184/C7B3E483880D/SIP/Info/verbose/4096/sipSPIFlushEventBufferQueue: There are 0 events on the internal queue that are going to be free'd
*May 15 14:25:36.874: //1184/C7B3E483880D/SIP/Error/sipSPIFlushDeferredQueue:
Invalid deferredQueue
*May 15 14:25:36.874: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerUnregisterCtxtInConnection: gConnTab=0x22A1E738, addr=10.131.1.6, port=5060, local_addr=192.168.50.254, unregistering context=0x3F2BD4C0
*May 15 14:25:36.874: //-1/xxxxxxxxxxxx/SIP/Transport/sipInstancePurgeContextInConnection: Purging context gcb=0x3F2BD4C0 from the connection=0x3EC0C0A4 context list
*May 15 14:25:36.874: //1184/C7B3E483880D/SIP/Info/verbose/1/sipSPI_ipip_free_codec_profile: Codec Profiles Freed
*May 15 14:25:36.874: //1184/C7B3E483880D/SIP/Info/info/8192/sipSPIStopOverlapInfoTimer: Stopping Overlap Info Timer
*May 15 14:25:36.874: //1184/C7B3E483880D/SIP/Info/verbose/4096/sipSPIUfreeOneCCB: Freeing ccb 0x3F2BD4C0u
*May 15 14:25:46.162: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_create: created msg=0x210C3B94 with refCount = 1
*May 15 14:25:46.162: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_create: created msg=0x23C6A8B4 with refCount = 1
*May 15 14:25:46.162: //-1/xxxxxxxxxxxx/SIP/Info/verbose/4096/HandleUdpIPv4SocketReads: Msg enqueued for SPI with IP addr: [10.131.1.6]:5060, local_address:[192.168.92.2]
*May 15 14:25:46.162: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_free: Freed msg=0x210C3B94
*May 15 14:25:46.162: //-1/xxxxxxxxxxxx/SIP/Info/info/4096/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
*May 15 14:25:46.166: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x0
*May 15 14:25:46.166: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
CSeq: 1 INVITE
Max-Forwards: 25
Min-SE: 600
Content-Length: 325
v=0
s=SBC call
c=IN IP4 10.131.1.6
t=0 0
a=fmtp:108 0-15
a=ptime:20
a=sendrecv
*May 15 14:25:46.166: //-1/xxxxxxxxxxxx/SIP/Info/verbose/4096/ccsip_new_msg_preprocessor: Checking Invite Dialog
*May 15 14:25:46.166: //-1/xxxxxxxxxxxx/SIP/Info/verbose/4096/sipSPIAddContextToTable: Added context(0x3F2BD4C0) with key=[833] to table
*May 15 14:25:46.166: //-1/000000000000/SIP/Info/info/4096/ccsip_ipip_media_service_init:
*May 15 14:25:46.166: //-1/000000000000/SIP/Info/info/4096/ccsip_tdmip_media_service_init:
*May 15 14:25:46.166: //-1/000000000000/SIP/Info/verbose/36864/ccsip_ipip_media_forking_init: MF: Queue is initialised..
*May 15 14:25:46.166: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Dialog Transaction Address 10.131.1.6,Port 5060, Transport 1, SentBy Port 5060vrfid 0
*May 15 14:25:46.166: //-1/xxxxxxxxxxxx/SIP/Info/verbose/512/ccsip_get_vrf_from_sip_bind: vrfid 0 for tag 0, sip_vrfid 0, voice_vrfid 0
*May 15 14:25:46.166: //-1/000000000000/SIP/Info/info/8192/resolve_sig_ip_address_to_bind: VRF id = 0
*May 15 14:25:46.166: //-1/xxxxxxxxxxxx/SIP/Info/info/8192/ccsip_get_ifaddress: ip_address IPv4 192.168.50.254 for SIP
*May 15 14:25:46.166: //-1/xxxxxxxxxxxx/SIP/Info/info/8192/resolve_ip_address_to_bind: ip_get_ifaddress IPv4 192.168.50.254 for SIP
*May 15 14:25:46.166: //-1/000000000000/SIP/Info/info/8192/resolve_sig_ip_address_to_bind: signaling bind address : 192.168.50.254
*May 15 14:25:46.166: //-1/xxxxxxxxxxxx/SIP/Info/info/8192/resolve_sig_ip_address_to_bind: return addr 192.168.50.254
*May 15 14:25:46.166: //-1/DA7B066E8813/SIP/State/sipSPIChangeState: 0x3F2BD4C0 : State change from (STATE_NONE, SUBSTATE_NONE) to (STATE_IDLE, SUBSTATE_NONE)
*May 15 14:25:46.166: //-1/xxxxxxxxxxxx/SIP/Info/verbose/8192/sipSPISetDateHeader: Clock Time Zone is UTC, same as GMT: Using GMT
*May 15 14:25:46.166: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_lock: Increment msg (0x23C6A8B4) counter, current msg->refCount = 2
*May 15 14:25:46.166: //-1/xxxxxxxxxxxx/SIP/Error/httpish_msg_free:
Freeing NULL pointer!
*May 15 14:25:46.166: //-1/DA7B066E8813/SIP/Info/verbose/4096/sipSPIAssignCcbLastRequest: Current ccb(0x3F2BD4C0)->last_request = 0x23C6A8B4, refCount = 2
*May 15 14:25:46.166: //-1/DA7B066E8813/SIP/Info/info/8192/sipSPIProcessSessionID: SessionID header not present - create uuid
*May 15 14:25:46.166: //-1/DA7B066E8813/SIP/Info/info/8192/sipSPIGenerateSessionUUID: Generate uuid
*May 15 14:25:46.166: //-1/DA7B066E8813/SIP/Info/info/8192/sipSPIGenerateSessionUUID: Initial Invite SIP-TDM /MF case
*May 15 14:25:46.166: //-1/DA7B066E8813/SIP/Info/info/8192/sipSPIGenerateSessionUUID: generated uuid - 3b6a3f11e11b5ebba0c7491e938b29ea
*May 15 14:25:46.166: //-1/DA7B066E8813/SIP/Info/notify/8192/sipSPI_Add_SessionIDtoTDContainer: localUUID - 3b6a3f11e11b5ebba0c7491e938b29earemoteUUID - 00000000000000000000000000000000
*May 15 14:25:46.166: //-1/xxxxxxxxxxxx/SIP/Info/info/2048/sipSPICheckIpip: VOIP dialpeer (peer=0x3D3E2544) found for sip_user: +221339212200
*May 15 14:25:46.166: //-1/DA7B066E8813/SIP/Info/info/2048/sipSPICheckAssertedIdConfig: Dialpeer match is not yet done
*May 15 14:25:46.166: //-1/DA7B066E8813/SIP/Info/info/36864/sipSPIUpdateIdentity: MF: PAI url is present & make a copy..
*May 15 14:25:46.166: //-1/DA7B066E8813/SIP/Info/info/4096/sipSPIUpdateIdentity: PAI genUrl is present..
*May 15 14:25:46.166: //-1/DA7B066E8813/SIP/Info/info/4096/sipSPISetCallingInfo: calling host comes from From: ims.sonatel.net
*May 15 14:25:46.166: //-1/xxxxxxxxxxxx/SIP/Info/critical/4096/sipSPIGetContentGTD: No GTD found in inbound container
*May 15 14:25:46.166: //-1/xxxxxxxxxxxx/SIP/Info/critical/4096/sipSPIGetContentCSTA: No CSTA found in inbound container
*May 15 14:25:46.166: //-1/DA7B066E8813/SIP/Info/verbose/4096/sipSPIUaddCcbToTable: Added to table. ccb=0x3F2BD4C0 key=sbcthLNQQVSvVpvSSiQpiqG4QlMp4pMSM6GIvMpF@BI.BLB.B.BVL221339212200 balance 1
*May 15 14:25:46.166: //-1/DA7B066E8813/SIP/Info/info/8192/sipSPIMatchSrcIpGroup: Match not found on carrier id
*May 15 14:25:46.166: //-1/DA7B066E8813/SIP/Info/critical/8192/sipSPIMatchSrcIpGroup: Match not found on Incoming called number: +221339212200
*May 15 14:25:46.166: //-1/DA7B066E8813/SIP/Info/critical/8192/sipSPIMatchSrcIpGroup: Match not found on destination pattern: 781260948
*May 15 14:25:46.166: //-1/DA7B066E8813/SIP/Info/info/12288/ccsipUpdateIncomingCallParams: ccCallInfo: Calling name , number 781260948, Calling oct3 0x00, oct_3a 0x81, Called number +221339212200
*May 15 14:25:46.166: //-1/DA7B066E8813/SIP/Info/verbose/1024/sipSPIGetViaHostInURLFormat: VIA URL:sip:10.131.1.6:5060, Host:10.131.1.6
*May 15 14:25:46.170: //-1/DA7B066E8813/SIP/Info/verbose/67584/sipSPIGetShrlPeer: Try match incoming dialpeer for Calling number: : 781260948
*May 15 14:25:46.170: //-1/DA7B066E8813/SIP/Info/critical/10240/sipSPIGetCallConfig: No match found for P-Called-Party-ID
*May 15 14:25:46.170: //-1/DA7B066E8813/SIP/Info/info/1024/ccsip_validate_and_update_calling_info: PAI/PPI not configuredi for this dial-peer(0), use RPID/FROM header data
*May 15 14:25:46.170: //-1/DA7B066E8813/SIP/Info/verbose/4096/sipSPIUpdateCallingInfoUsingRpidOrFrom: Updating Calling Info with FROM header data
*May 15 14:25:46.170: //-1/DA7B066E8813/SIP/Info/info/2048/sipSPISetAudioForcedConfig: audio forced config is set to FALSE
*May 15 14:25:46.170: //-1/DA7B066E8813/SIP/Info/verbose/1024/sipSPIGetCallConfig: Precondition tag absent in Require/Supported header
*May 15 14:25:46.170: //-1/DA7B066E8813/SIP/Info/verbose/2048/sipSPIGetCallConfig: Media Antitrombone disabled
*May 15 14:25:46.170: //-1/DA7B066E8813/SIP/Info/info/8192/sipSPISetMediaFlowMode: Storing the configured mode as FLOW-THROUGH
*May 15 14:25:46.170: //-1/DA7B066E8813/SIP/Info/info/2304/sipSPISetMediaFlowMode: xcoder high-density disabled
*May 15 14:25:46.170: //-1/DA7B066E8813/SIP/Info/info/8192/sipSPISetMediaFlowMode: Flow Mode set to FLOW_THROUGH
*May 15 14:25:46.170: //-1/DA7B066E8813/SIP/Info/info/10240/sipSPIGetCallConfig: Non dial peer leg - using RTP Supported Codecs
*May 15 14:25:46.170: //-1/DA7B066E8813/SIP/Info/info/10240/sipSPIGetCallConfig: RTP Preferred Codecs supported by GW 18
*May 15 14:25:46.170: //-1/DA7B066E8813/SIP/Info/info/10240/sipSPIGetCallConfig: RTP Preferred Codecs supported by GW 0
*May 15 14:25:46.170: //-1/DA7B066E8813/SIP/Info/info/10240/sipSPIGetCallConfig: RTP Preferred Codecs supported by GW 8
*May 15 14:25:46.170: //-1/DA7B066E8813/SIP/Info/info/10240/sipSPIGetCallConfig: RTP Preferred Codecs supported by GW 9
*May 15 14:25:46.170: //-1/DA7B066E8813/SIP/Info/info/10240/sipSPIGetCallConfig: RTP Preferred Codecs supported by GW 4
*May 15 14:25:46.170: //-1/DA7B066E8813/SIP/Info/info/10240/sipSPIGetCallConfig: RTP Preferred Codecs supported by GW 2
*May 15 14:25:46.170: //-1/DA7B066E8813/SIP/Info/info/10240/sipSPIGetCallConfig: RTP Preferred Codecs supported by GW 15
*May 15 14:25:46.170: //-1/DA7B066E8813/SIP/Info/info/10240/sipSPIGetCallConfig: RTP Preferred Codecs supported by GW 255
*May 15 14:25:46.170: //-1/DA7B066E8813/SIP/Info/critical/32768/ccsip_ipip_media_forking_update_preferred_codec: MF: Not a Forked SIP leg..
*May 15 14:25:46.170: //-1/DA7B066E8813/SIP/Info/verbose/1/ccsip_set_srtp_config: No Srtp configure for this leg.
*May 15 14:25:46.170: //-1/DA7B066E8813/SIP/Info/verbose/12288/sipSPIGetModemInfoPerCall: peer_callID=0
*May 15 14:25:46.170: //-1/DA7B066E8813/SIP/Error/ccsip_ipip_media_forking_anchor_leg_config:
MF: Dial-peer is absent..
*May 15 14:25:46.170: //-1/DA7B066E8813/SIP/Info/info/36864/sipSPIMFChangeState: MF: Prev state = 0 & New state = -1
*May 15 14:25:46.170: //-1/DA7B066E8813/SIP/Info/info/32768/ccsip_ipip_media_forking_anchor_leg_reset: MF: Anchor leg config reset done...
*May 15 14:25:46.170: //-1/DA7B066E8813/SIP/Error/ccsip_ipip_media_forking_intra_frame_request_config:
MF:video profile Dial-peer is absent..
*May 15 14:25:46.170: //-1/DA7B066E8813/SIP/Info/verbose/8192/sipSPICheckFAAnatAssymetricOrDO2EO: Not a SIP-SIP call or not in FA mode
*May 15 14:25:46.170: //-1/DA7B066E8813/SIP/Info/info/2049/populate_vcc_data: Non dial peer leg - using RTP Supported Codecs
*May 15 14:25:46.170: //-1/DA7B066E8813/SIP/Info/info/1/populate_vcc_data: RTP Preferred Codecs supported by GW 18
*May 15 14:25:46.170: //-1/DA7B066E8813/SIP/Info/info/1/populate_vcc_data: RTP Preferred Codecs supported by GW 0
*May 15 14:25:46.170: //-1/DA7B066E8813/SIP/Info/info/1/populate_vcc_data: RTP Preferred Codecs supported by GW 8
*May 15 14:25:46.170: //-1/DA7B066E8813/SIP/Info/info/1/populate_vcc_data: RTP Preferred Codecs supported by GW 9
*May 15 14:25:46.170: //-1/DA7B066E8813/SIP/Info/info/1/populate_vcc_data: RTP Preferred Codecs supported by GW 4
*May 15 14:25:46.170: //-1/DA7B066E8813/SIP/Info/info/1/populate_vcc_data: RTP Preferred Codecs supported by GW 2
*May 15 14:25:46.170: //-1/DA7B066E8813/SIP/Info/info/1/populate_vcc_data: RTP Preferred Codecs supported by GW 15
*May 15 14:25:46.170: //-1/DA7B066E8813/SIP/Info/info/1/populate_vcc_data: RTP Preferred Codecs supported by GW 255
*May 15 14:25:46.170: //-1/DA7B066E8813/SIP/Info/notify/8192/sipSPISetOverlapConfiguration: Overlap signaling: FALSE: Endpt: SIP Trunk
*May 15 14:25:46.170: //-1/DA7B066E8813/SIP/Info/verbose/10240/sipSPI_ipip_GetHdrPassthruCfg: Hdr passthrough config:1 tag:0
*May 15 14:25:46.170: //-1/DA7B066E8813/SIP/Info/verbose/2048/sipSPI_ipip_GetCopyListCfg: Copy-list config:2 tag:0
*May 15 14:25:46.170: //-1/DA7B066E8813/SIP/Info/info/2048/sipSPIGetExtensionCfg: SIP extension config:1, check sys cfg:1
*May 15 14:25:46.170: //-1/DA7B066E8813/SIP/Info/notify/10240/sipSPI_ipip_build_consolidated_header_list: Both passthru and copylist are disabled
*May 15 14:25:46.170: //-1/DA7B066E8813/SIP/Info/info/4096/sipSPIContinueNewMsgInvite: Calling name , number 781260948, Calling oct3 0x00, oct_3a 0x80, ext_priv 0x00, Called number +221339212200, oct3 0x00
*May 15 14:25:46.170: //-1/DA7B066E8813/SIP/Info/info/4096/sipSPIContinueNewMsgInvite: Carrier id code , prev_cid NONE, next_cid NONE, prev_tgrp NONE, next_tgrp NONE
*May 15 14:25:46.170: //-1/DA7B066E8813/SIP/Info/info/4096/sipSPIContinueNewMsgInvite: Requires reliable-provisional support
*May 15 14:25:46.170: //-1/DA7B066E8813/SIP/Info/critical/10240/sipSPIValidateRequestUri: Not Enabled
*May 15 14:25:46.170: //-1/DA7B066E8813/SIP/Info/info/131072/sipSPIRscmsmAvail: Value returned by check is = 0
*May 15 14:25:46.170: //1186/DA7B066E8813/SIP/Info/critical/4096/sipSPICheckOutBoundDpProvisioning: Cannot obtain the the header bitmap
*May 15 14:25:46.170: //1186/DA7B066E8813/SIP/Info/critical/8192/sipSPI_ipip_IsSDPPassthruEnabled: - 0
*May 15 14:25:46.170: //1186/DA7B066E8813/SIP/Info/info/8192/sipSPIProcessSessionID: SessionID header not present - create uuid
*May 15 14:25:46.170: //1186/DA7B066E8813/SIP/Info/info/8192/sipSPIGenerateSessionUUID: Generate uuid
*May 15 14:25:46.170: //1186/DA7B066E8813/SIP/Info/info/8192/sipSPIGenerateSessionUUID: Initial Invite SIP-TDM /MF case
*May 15 14:25:46.170: //1186/DA7B066E8813/SIP/Info/info/8192/sipSPIGenerateSessionUUID: generated uuid - df176f7108365170afcc384fdbb05994
*May 15 14:25:46.170: //1186/DA7B066E8813/SIP/Info/notify/8192/sipSPI_Add_SessionIDtoTDContainer: localUUID - df176f7108365170afcc384fdbb05994remoteUUID - 00000000000000000000000000000000
*May 15 14:25:46.170: //1186/DA7B066E8813/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_REQ
*May 15 14:25:46.170: //1186/DA7B066E8813/SIP/Event/Session-Timer/sipSTSLMain: dir:2, method:102, resp_code:0, container:3F47D14C
*May 15 14:25:46.170: //1186/DA7B066E8813/SIP/Info/info/8192/Session-Timer/sipSTSLExtractSessionExpiresHdr:
Session-Expires value: 1800 refresher: none
*May 15 14:25:46.174: //1186/DA7B066E8813/SIP/Info/info/8192/Session-Timer/sipSTSLExtractMinSEHdr: Min-SE Duration: 600
*May 15 14:25:46.174: //1186/DA7B066E8813/SIP/Info/info/8192/Session-Timer/sipSTSLGetInternalSREvent: E_STSL_INITIAL_SR_REQ
*May 15 14:25:46.174: //1186/DA7B066E8813/SIP/Info/verbose/8192/Session-Timer/sipSTSLInitialSRReqPeerEventGen: sending received session expires to the peer leg
*May 15 14:25:46.174: //1186/DA7B066E8813/SIP/Event/Session-Timer/sipSTSLPrintTDContainer: Peer-Event: E_STSL_PASS_ST_PARAMS, SE Value:1800, SE Refresher:none, Min-SE Value:1800, flags:2001
*May 15 14:25:46.174: //1186/DA7B066E8813/SIP/Info/info/8192/Session-Timer/sipSTSLMain:
SE: 1800;refresher:none peer refresher:none, flags:2001, posted event:E_STSL_INVALID_PEER_EVENT, reason:4
Configured SE:1800, Configured Min-SE:1800
*May 15 14:25:46.174: //1186/DA7B066E8813/SIP/Info/critical/1024/sipSPIProcessHistoryInfoHeader: No HI headers recvd from app container
*May 15 14:25:46.174: //1186/DA7B066E8813/SIP/Info/critical/1024/sipSPIProcessDiversionHeader: No diversion headers recvd from app container
*May 15 14:25:46.174: //1186/DA7B066E8813/SIP/Info/critical/16384/sipSPIProcessReplacesHeader: No replaces hdr found
*May 15 14:25:46.174: //-1/xxxxxxxxxxxx/SIP/Info/verbose/1024/sipSPIGetContentCPA: No CPA found in inbound container
*May 15 14:25:46.174: //1186/DA7B066E8813/SIP/Info/verbose/1024/sipSPIProcessCPA: No x-cisco-cpa content found
*May 15 14:25:46.174: //1186/DA7B066E8813/SIP/Info/verbose/1/sipSPIDoMediaNegotiation: Number of m-lines = 1
*May 15 14:25:46.174: //1186/DA7B066E8813/SIP/Info/verbose/1/sipSPIValidateConnectionAddress: Dest port = 40370
SIP: (1186) Attribute mid, level 1 instance 1 not found.
*May 15 14:25:46.174: //1186/DA7B066E8813/SIP/Info/notify/6/sipSPIValidateStreamAddrType: stream:1, Mode : 1
*May 15 14:25:46.174: //1186/DA7B066E8813/SIP/Info/verbose/513/resolve_media_ip_address_to_bind: peer_tag=0
*May 15 14:25:46.174: //-1/xxxxxxxxxxxx/SIP/Info/verbose/512/ccsip_get_vrf_from_sip_bind: vrfid 0 for tag 0, sip_vrfid 0, voice_vrfid 0
*May 15 14:25:46.174: //-1/xxxxxxxxxxxx/SIP/Info/info/8192/resolve_media_ip_address_to_bind: VRF id = 0
*May 15 14:25:46.174: //-1/xxxxxxxxxxxx/SIP/Info/info/8192/ccsip_get_ifaddress: ip_address IPv4 192.168.50.254 for SIP
*May 15 14:25:46.174: //-1/xxxxxxxxxxxx/SIP/Info/info/8192/resolve_ip_address_to_bind: ip_get_ifaddress IPv4 192.168.50.254 for SIP
*May 15 14:25:46.174: //1186/DA7B066E8813/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 192.168.50.254
*May 15 14:25:46.174: //-1/xxxxxxxxxxxx/SIP/Info/notify/1/sipSPICheckDynPayloadUse: Dynamic payload(103) reserved for codec gsmamr-nb
*May 15 14:25:46.174: //-1/xxxxxxxxxxxx/SIP/Info/notify/1/sipSPICheckDynPayloadUse: Dynamic payload(102) reserved for codec No Codec
*May 15 14:25:46.174: //-1/xxxxxxxxxxxx/SIP/Info/info/1/sipSPIUpdateDynamicPayloadunused: Unreserving dynamic payload type 96
*May 15 14:25:46.174: //-1/xxxxxxxxxxxx/SIP/Info/notify/1/sipSPICheckDynPayloadUse: Dynamic payload(108) reserved for codec No Codec
*May 15 14:25:46.174: //1186/DA7B066E8813/SIP/Info/notify/1/sipSPIDoAudioNegotiation: Codec (g711alaw) Negotiation Successful on Static Payload for m-line 1
*May 15 14:25:46.174: //1186/DA7B066E8813/SIP/Info/verbose/1/sipSPIDoPtimeNegotiation: One ptime attribute found - value:20
*May 15 14:25:46.174: //-1/xxxxxxxxxxxx/SIP/Info/notify/1/convert_ptime_to_codec_bytes: Values :Codec: g711alaw ptime :20, codecbytes: 160
*May 15 14:25:46.174: //-1/xxxxxxxxxxxx/SIP/Info/notify/1/convert_codec_bytes_to_ptime: Values :Codec: g711alaw codecbytes :160, ptime: 20
*May 15 14:25:46.174: //1186/DA7B066E8813/SIP/Media/sipSPIDoPtimeNegotiation: Offered ptime:20, Negotiated ptime:20 Negotiated codec bytes: 160 for codec g711alaw
*May 15 14:25:46.174: //1186/DA7B066E8813/SIP/Info/info/8/sipSPISetFaxFlags: FAX_PASSTHROUGH = 0, END_FAX_PASSTHROUGH = 0
*May 15 14:25:46.174: //1186/DA7B066E8813/SIP/Info/info/1/sipSPIDoDTMFRelayNegotiation: m-line index 1
*May 15 14:25:46.174: //1186/DA7B066E8813/SIP/Info/notify/1/sipSPIReserveRtpNtePayload: Reserved the payload type 108 for RTP-NTE
*May 15 14:25:46.174: //1186/DA7B066E8813/SIP/Info/info/32/sipSPIDoDTMFRelayNegotiation: RTP-NTE DTMF relay option
*May 15 14:25:46.174: //1186/DA7B066E8813/SIP/Info/info/1/sipSPIDoDTMFRelayNegotiation: Case of partial named event(NE) match in fmtp list of events.
*May 15 14:25:46.174: //-1/xxxxxxxxxxxx/SIP/Info/info/8193/sip_sdp_get_modem_relay_cap_params: ptype is 103
*May 15 14:25:46.174: //-1/xxxxxxxxxxxx/SIP/Info/info/8193/sip_sdp_get_modem_relay_cap_params: encname is AMR
*May 15 14:25:46.174: //-1/xxxxxxxxxxxx/SIP/Info/info/8193/sip_sdp_get_modem_relay_cap_params: ptype is 102
*May 15 14:25:46.174: //-1/xxxxxxxxxxxx/SIP/Info/info/8193/sip_sdp_get_modem_relay_cap_params: encname is GSM-HR
*May 15 14:25:46.174: //-1/xxxxxxxxxxxx/SIP/Info/info/8193/sip_sdp_get_modem_relay_cap_params: ptype is 108
*May 15 14:25:46.174: //-1/xxxxxxxxxxxx/SIP/Info/info/8193/sip_sdp_get_modem_relay_cap_params: encname is telephone-event
*May 15 14:25:46.174: //-1/xxxxxxxxxxxx/SIP/Info/info/8209/sip_sdp_get_modem_relay_cap_params: mer_dtmf_found 0
*May 15 14:25:46.174: //-1/xxxxxxxxxxxx/SIP/Info/info/8209/sip_sdp_get_modem_relay_cap_params: V150 NSE payload = 0, SSE payload = 0, SPRT payload=0
*May 15 14:25:46.174: //1186/DA7B066E8813/SIP/Info/critical/8193/sip_select_modem_relay_params: X-tmr not present in SDP. Disable modem relay
*May 15 14:25:46.174: //1186/DA7B066E8813/SIP/Info/info/1/sipSPIGetSDPDirectionAttribute: No direction attribute present or multiple direction attributes that can't be handled for m-line:1 and num-a-lines:0
*May 15 14:25:46.174: //1186/DA7B066E8813/SIP/Info/notify/1/sipSPIDoAudioNegotiation: Codec negotiation successful for media line 1
payload_type=8, codec_bytes=160, codec=g711alaw, dtmf_relay=rtp-nte
stream_type=voice+dtmf (1), dest_ip_address=10.131.1.6, dest_port=40370
*May 15 14:25:46.174: //1186/DA7B066E8813/SIP/State/sipSPIChangeStreamState: Stream (callid = -1) State changed from (STREAM_DEAD) to (STREAM_ADDING)
*May 15 14:25:46.174: //-1/xxxxxxxxxxxx/SIP/Info/sipSPI_Check_If_ICE_Needed: CANDIDATE attribute, level 1not found.
*May 15 14:25:46.174: //1186/DA7B066E8813/SIP/Media/sipSPIUpdCallWithSdpInfo:
Preferred Codec : g729r8, bytes :20
Preferred DTMF relay : rtp-nte
Preferred NTE payload : 108
Early Media : No
Delayed Media : No
Bridge Done : No
New Media : No
DSP DNLD Reqd : No
*May 15 14:25:46.174: //1186/DA7B066E8813/SIP/Info/verbose/513/resolve_media_ip_address_to_bind: Media already bound, use existing source_media_ip_addr
*May 15 14:25:46.174: //1186/DA7B066E8813/SIP/Info/info/4096/ccsip_offer_ans_handle_rcvd_sdp:
*May 15 14:25:46.174: //1186/DA7B066E8813/SIP/State/ccsip_cnfsm_debugs: OA:cur_container:ccsip_offer_ans_main_container, cur_state:S_SIP_EARLY_DIALOG_IDLE, event:E_SIP_INVITE_SDP_RCVD
*May 15 14:25:46.174: //1186/DA7B066E8813/SIP/Info/info/4096/ccsip_offer_ans_is_invite_offer_valid: TRUE
*May 15 14:25:46.174: //1186/DA7B066E8813/SIP/Info/info/4096/ccsip_offer_ans_common_offer_rcvd_hdlr:
*May 15 14:25:46.174: //1186/DA7B066E8813/SIP/Info/info/4096/ccsip_iwf_handle_network_event:
*May 15 14:25:46.174: //1186/DA7B066E8813/SIP/State/ccsip_cnfsm_debugs: IWF:cur_container:sip_iwf_default_early_dialog_container, cur_state:S_SIP_IWF_SDP_IDLE, event:E_SIP_IWF_EV_RCVD_SDP
*May 15 14:25:46.174: //1186/DA7B066E8813/SIP/Info/info/4096/sip_iwf_def_ed_rcvd_sdp_hdlr:
*May 15 14:25:46.174: //1186/DA7B066E8813/SIP/Info/info/1/sipSPIAssignStreamCallId: Assigning streamid 1186 to stream 1. Old streamid = -1
*May 15 14:25:46.174: //1186/DA7B066E8813/SIP/Info/info/1/sipSPI_initialize_audio_channelInfo_from_sdp: stream_callid = 1186, peer_stream_callid = -1
SIP: (1186) setup attribute, level 1 instance 1 not found.
SIP: (1186) connection attribute, level 1 instance 1 not found.
SIP: (1186) Attribute label, level 1 instance 1 not found.
SIP: (1186) a=framerate attribute, level 1 instance 1 not found.
*May 15 14:25:46.174: //1186/DA7B066E8813/SIP/Info/verbose/1025/sipSPI_initialize_audio_channelInfo_from_sdp: Populating Address in channelInfo
*May 15 14:25:46.174: //1186/DA7B066E8813/SIP/Info/info/1/sipSPI_initialize_audio_channelInfo_from_sdp: Media dest addr for stream 1='10.131.1.6', port=40370
*May 15 14:25:46.174: //1186/DA7B066E8813/SIP/Info/info/1/sip_iwf_sip_copy_audio_sdp_to_local_channelInfo: Processing Media line = 1; Codec = g711alaw; PType = 8
*May 15 14:25:46.174: //1186/DA7B066E8813/SIP/Info/verbose/1/codec_found: Codec to be matched: g711alaw(6)
*May 15 14:25:46.174: //1186/DA7B066E8813/SIP/Info/verbose/1/codec_found: Match Found at index 2.
*May 15 14:25:46.174: //1186/DA7B066E8813/SIP/Info/verbose/1/sip_iwf_sip_copy_audio_sdp_to_local_channelInfo: Add Channel for Codec g711alaw
*May 15 14:25:46.174: //1186/DA7B066E8813/SIP/Info/notify/1/sip_iwf_sip_copy_audio_sdp_to_local_channelInfo: Media negotiation done for m-line=1: negotiated_ptime=20, negotiated_codec_bytes=160
*May 15 14:25:46.174: //1186/DA7B066E8813/SIP/Info/info/1/sipSPI_ipip_update_codec_params_in_stream_channelInfo: Adding negotiated codec g711alaw ptype 8 time 20, bytes 160 as channel 0 mline 1 ss 1
*May 15 14:25:46.174: //1186/DA7B066E8813/SIP/Info/info/131073/sipSPIBwCacCalcAudioBandwidth: calculated audio bandwidth : codec g711alaw bw 64000
*May 15 14:25:46.174: //1186/DA7B066E8813/SIP/Info/info/1/sip_iwf_sip_copy_audio_sdp_to_local_channelInfo: Processing Media line = 1; Codec = gsmamr-nb; PType = 103
*May 15 14:25:46.174: //1186/DA7B066E8813/SIP/Info/verbose/1/codec_found: Codec to be matched: gsmamr-nb(32)
*May 15 14:25:46.174: //1186/DA7B066E8813/SIP/Info/notify/1/codec_found: Match Not Found for gsmamr-nb.
*May 15 14:25:46.174: //1186/DA7B066E8813/SIP/Info/info/1/sip_iwf_sip_copy_audio_sdp_to_local_channelInfo: Processing Media line = 1; Codec = g711ulaw; PType = 0
*May 15 14:25:46.174: //1186/DA7B066E8813/SIP/Info/verbose/1/codec_found: Codec to be matched: g711ulaw(5)
*May 15 14:25:46.174: //1186/DA7B066E8813/SIP/Info/verbose/1/codec_found: Match Found at index 1.
*May 15 14:25:46.174: //1186/DA7B066E8813/SIP/Info/verbose/1/sip_iwf_sip_copy_audio_sdp_to_local_channelInfo: Add Channel for Codec g711ulaw
*May 15 14:25:46.178: //-1/xxxxxxxxxxxx/SIP/Info/notify/1/convert_ptime_to_codec_bytes: Values :Codec: g711ulaw ptime :20, codecbytes: 160
*May 15 14:25:46.178: //1186/DA7B066E8813/SIP/Info/info/1/sipSPI_ipip_update_codec_params_in_stream_channelInfo: Adding negotiated codec g711ulaw ptype 0 time 20, bytes 160 as channel 1 mline 1 ss 1
*May 15 14:25:46.178: //1186/DA7B066E8813/SIP/Info/info/131073/sipSPIBwCacCalcAudioBandwidth: calculated audio bandwidth : codec g711ulaw bw 64000
*May 15 14:25:46.178: //1186/DA7B066E8813/SIP/Media/sipSPISelectCodecVersion: Codec (g729br8) is not in preferred list
*May 15 14:25:46.178: //1186/DA7B066E8813/SIP/Info/notify/1/sipSPI_ipip_update_static_codec_params: An exact codec match not configured, using interoperable codec g729r8
*May 15 14:25:46.178: //1186/DA7B066E8813/SIP/Info/info/1/sip_iwf_sip_copy_audio_sdp_to_local_channelInfo: Processing Media line = 1; Codec = g729r8; PType = 18
*May 15 14:25:46.178: //1186/DA7B066E8813/SIP/Info/verbose/1/codec_found: Codec to be matched: g729r8(16)
*May 15 14:25:46.178: //1186/DA7B066E8813/SIP/Info/verbose/1/codec_found: Match Found at index 0.
*May 15 14:25:46.178: //1186/DA7B066E8813/SIP/Info/verbose/1/sip_iwf_sip_copy_audio_sdp_to_local_channelInfo: Add Channel for Codec g729r8
*May 15 14:25:46.178: //-1/xxxxxxxxxxxx/SIP/Info/notify/1/convert_ptime_to_codec_bytes: Values :Codec: g729r8 ptime :20, codecbytes: 20
*May 15 14:25:46.178: //1186/DA7B066E8813/SIP/Info/info/1/sipSPI_ipip_update_codec_params_in_stream_channelInfo: Adding negotiated codec g729r8 ptype 18 time 20, bytes 20 as channel 2 mline 1 ss 1
*May 15 14:25:46.178: //1186/DA7B066E8813/SIP/Info/info/131073/sipSPIBwCacCalcAudioBandwidth: calculated audio bandwidth : codec g729r8 bw 8000
*May 15 14:25:46.178: //1186/DA7B066E8813/SIP/Info/info/1/sip_iwf_sip_copy_audio_sdp_to_local_channelInfo: Processing Media line = 1; Codec = No Codec ; PType = 102
*May 15 14:25:46.178: //1186/DA7B066E8813/SIP/Info/info/32/sipSPI_ipip_upd_2833_dtmf_params: setting ipip_caps DTMF to RFC2833: callid = 1186, dtmf = 6
*May 15 14:25:46.178: //1186/DA7B066E8813/SIP/Info/info/1/sip_iwf_sip_copy_audio_sdp_to_local_channelInfo: Processing Media line = 1; Codec = No Codec ; PType = 108
*May 15 14:25:46.178: //1186/DA7B066E8813/SIP/Info/verbose/16/sipSPIGetPreferredSrtpSuiteForBw: Return : 0
*May 15 14:25:46.178: //-1/xxxxxxxxxxxx/SIP/Info/verbose/16/sipSPIBwCacGetSrtpOverhead: Return: 0
*May 15 14:25:46.178: //-1/xxxxxxxxxxxx/SIP/Info/notify/1/convert_codec_bytes_to_ptime: Values :Codec: g711alaw codecbytes :160, ptime: 20
*May 15 14:25:46.178: //1186/DA7B066E8813/SIP/Media/sipSPIDisplayStreamInfo:
Stream type : voice+dtmf
Media line : 1
State : STREAM_ADDING (2)
Stream address type : 1
Callid : 1186
Peer Callid : -1
RTP/SRTP Negotiated : 8
Negotiated Codec : g711alaw, bytes :160
Nego. Codec payload : 8 (tx), 8 (rx)
Negotiated DTMF relay : rtp-nte
Negotiated NTE payload : 108 (tx), 108 (rx)
Negotiated CN payload : 0
Media Srce Addr/Port : [192.168.50.254]:0
Media Dest Addr/Port : [10.131.1.6]:40370
*May 15 14:25:46.178: //1186/DA7B066E8813/SIP/Info/verbose/4097/sipSPI_ipip_calculate_channel_count: Number of streams to report = 1
*May 15 14:25:46.178: //1186/DA7B066E8813/SIP/Info/critical/1/sip_iwf_sip_copy_sdp_to_stream_channelInfo: Not updating call entry.
*May 15 14:25:46.178: //1186/DA7B066E8813/SIP/Info/info/1/sip_iwf_def_ed_rcvd_sdp_hdlr: Setting media_direction to 4
*May 15 14:25:46.178: //1186/DA7B066E8813/SIP/Info/info/131072/sipSPIBwCacUpdateAccountedBw: bwcac update accounted BW Option 0 flow mode flow-through
audio bw 80000 bps video bw 0 bps fax bw 0 bps total bw 80000 bps accounted bw 0 bpsa
*May 15 14:25:46.770: //1186/DA7B066E8813/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SPI_EVENT
*May 15 14:25:46.770: //1186/DA7B066E8813/SIP/Info/info/8192/Session-Timer/sipSTSLMain:
*May 15 14:25:46.770: //1186/DA7B066E8813/SIP/Info/verbose/4096/ccsip_buffer_media_event: Buffering event SIPSPI_EV_CC_MEDIA_EVENT - Purpose 1: FALSE
*May 15 14:25:47.350: //1186/DA7B066E8813/SIP/Info/info/4096/sipSPIResendInviteResponse: resending 180 response due to no PRACK
*May 15 14:25:47.350: //1186/DA7B066E8813/SIP/Info/verbose/4096/sipSPISendInviteResponse: Dialog State: [1]
*May 15 14:25:47.350: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_create: created msg=0x3A01A90C with refCount = 1
*May 15 14:25:47.350: //1186/DA7B066E8813/SIP/Event/sipSPICreateRpid: Received Octet3A=0x00 -> Setting ;screen=no ;privacy=off
*May 15 14:25:47.350: //1186/DA7B066E8813/SIP/Info/info/4096/sipSPISendInviteResponse: Associated container=0x3F47D56C to Invite Response 180
*May 15 14:25:47.350: //-1/xxxxxxxxxxxx/SIP/Info/verbose/8192/sipSPIAppHandleContainerBody: sipSPIAppHandleContainerBody len 0
*May 15 14:25:47.350: //1186/DA7B066E8813/SIP/Transport/sipSPISendInviteResponse: Sending 180 Response to the Transport Layer
*May 15 14:25:47.350: //1186/DA7B066E8813/SIP/Transport/sipSPITransportSendMessage: msg=0x3A01A90C, addr=10.131.1.6, port=5060, sentBy_port=5060, local_addr=192.168.50.254, is_req=0, transport=1, switch=0, callBack=0x0
*May 15 14:25:47.350: //1186/DA7B066E8813/SIP/Info/info/2048/sipSPIGetExtensionCfg: SIP extension config:1, check sys cfg:1
*May 15 14:25:47.350: //1186/DA7B066E8813/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
*May 15 14:25:47.350: //1186/DA7B066E8813/SIP/Transport/sipTransportLogicSendMsg: Trying to send resp=0x3A01A90C to default port=5060
*May 15 14:25:47.350: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerGetConnection: connection required for raddr:10.131.1.6, rport:5060 with laddr:192.168.50.254
*May 15 14:25:47.350: //-1/xxxxxxxxxxxx/SIP/Transport/sipInstanceGetConnectionId: gcb=0x3F2BD4C0 is already on connection=0x3EC0C0A4 context_list
*May 15 14:25:47.350: //1186/DA7B066E8813/SIP/Transport/sipTransportLogicSendMsg: Connection obtained...sending msg=0x3A01A90C
*May 15 14:25:47.350: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x3A01A90C, addr=10.131.1.6, port=5060, local_addr=192.168.50.254, connId=4 vrfid=0 for UDP
*May 15 14:25:47.350: //1186/DA7B066E8813/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 180 Ringing
To: <tel:+221339212200>;tag=239298A8-1D5A
Date: Wed, 15 May 2024 14:25:46 GMT
CSeq: 1 INVITE
Require: 100rel
RSeq: 3345
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
Allow-Events: telllephone-event
Remote-Party-ID: <sip:1175@192.168.50.254>;party=called;screen=no;privacy=off
Contact: <sip:+221339212200@192.168.50.254:5060>
Server: Cisco-SIPGateway/IOS-15.7.3.M
Session-ID: df176f7108365170afcc384fdbb05994;remote=00000000000000000000000000000000
Content-Length: 0
*May 15 14:25:47.350: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_free: Freed msg=0x3A01A90C
*May 15 14:25:48.430: //1186/DA7B066E8813/SIP/Info/info/4096/sipSPIResendInviteResponse: resending 180 response due to no PRACK
*May 15 14:25:48.430: //1186/DA7B066E8813/SIP/Info/verbose/4096/sipSPISendInviteResponse: Dialog State: [1]
*May 15 14:25:48.430: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_create: created msg=0x3A01A90C with refCount = 1
*May 15 14:25:48.430: //1186/DA7B066E8813/SIP/Event/sipSPICreateRpid: Received Octet3A=0x00 -> Setting ;screen=no ;privacy=off
*May 15 14:25:48.430: //1186/DA7B066E8813/SIP/Info/info/4096/sipSPISendInviteResponse: Associated container=0x3F47D56C to Invite Response 180
*May 15 14:25:48.430: //-1/xxxxxxxxxxxx/SIP/Info/verbose/8192/sipSPIAppHandleContainerBody: sipSPIAppHandleContainerBody len 0
*May 15 14:25:48.430: //1186/DA7B066E8813/SIP/Transport/sipSPISendInviteResponse: Sending 180 Response to the Transport Layer
*May 15 14:25:48.430: //1186/DA7B066E8813/SIP/Transport/sipSPITransportSendMessage: msg=0x3A01A90C, addr=10.131.1.6, port=5060, sentBy_port=5060, local_addr=192.168.50.254, is_req=0, transport=1, switch=0, callBack=0x0
*May 15 14:25:48.430: //1186/DA7B066E8813/SIP/Info/info/2048/sipSPIGetExtensionCfg: SIP extension config:1, check sys cfg:1
*May 15 14:25:48.430: //1186/DA7B066E8813/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
*May 15 14:25:48.430: //1186/DA7B066E8813/SIP/Transport/sipTransportLogicSendMsg: Trying to send resp=0x3A01A90C to default port=5060
*May 15 14:25:48.430: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerGetConnection: connection required for raddr:10.131.1.6, rport:5060 with laddr:192.168.50.254
*May 15 14:25:48.430: //-1/xxxxxxxxxxxx/SIP/Transport/sipInstanceGetConnectionId: gcb=0x3F2BD4C0 is already on connection=0x3EC0C0A4 context_list
*May 15 14:25:48.430: //1186/DA7B066E8813/SIP/Transport/sipTransportLogicSendMsg: Connection obtained...sending msg=0x3A01A90C
*May 15 14:25:48.430: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x3A01A90C, addr=10.131.1.6, port=5060, local_addr=192.168.50.254, connId=4 vrfid=0 for UDP
*May 15 14:25:48.430: //1186/DA7B066E8813/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 180 Ringing
CSeq: 1 INVITE
Require: 100rel
RSeq: 3345
Allow-Events: telephone-event
Content-Length: 0
*May 15 14:25:48.430: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_free: Freed msg=0x3A01A90C
*May 15 14:25:49.270: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_MEDIA_EVENT
*May 15 14:25:49.270: //-1/xxxxxxxxxxxx/SIP/Info/info/4096/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 3 for event 29
*May 15 14:25:49.270: //1186/DA7B066E8813/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SPI_EVENT
*May 15 14:25:49.270: //1186/DA7B066E8813/SIP/Info/info/8192/Session-Timer/sipSTSLMain:
*May 15 14:25:49.270: //1186/DA7B066E8813/SIP/Info/verbose/4096/ccsip_buffer_media_event: Buffering event SIPSPI_EV_CC_MEDIA_EVENT - Purpose 1: FALSE
*May 15 14:25:50.434: //1186/DA7B066E8813/SIP/Info/info/4096/sipSPIResendInviteResponse: resending 180 response due to no PRACK
*May 15 14:25:50.434: //1186/DA7B066E8813/SIP/Info/verbose/4096/sipSPISendInviteResponse: Dialog State: [1]
*May 15 14:25:50.434: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_create: created msg=0x3A01A90C with refCount = 1
*May 15 14:25:50.434: //1186/DA7B066E8813/SIP/Event/sipSPICreateRpid: Received Octet3A=0x00 -> Setting ;screen=no ;privacy=off
*May 15 14:25:50.434: //1186/DA7B066E8813/SIP/Info/info/4096/sipSPISendInviteResponse: Associated container=0x3F47D56C to Invite Response 180
*May 15 14:25:50.434: //-1/xxxxxxxxxxxx/SIP/Info/verbose/8192/sipSPIAppHandleContainerBody: sipSPIAppHandleContainerBody len 0
*May 15 14:25:50.434: //1186/DA7B066E8813/SIP/Transport/sipSPISendInviteResponse: Sending 180 Response to the Transport Layer
*May 15 14:25:50.434: //1186/DA7B066E8813/SIP/Transport/sipSPITransportSendMessage: msg=0x3A01A90C, addr=10.131.1.6, port=5060, sentBy_port=5060, local_addr=192.168.50.254, is_req=0, transport=1, switch=0, callBack=0x0
*May 15 14:25:50.434: //1186/DA7B066E8813/SIP/Info/info/2048/sipSPIGetExtensionCfg: SIP extension config:1, check sys cfg:1
*May 15 14:25:50.434: //1186/DA7B066E8813/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
*May 15 14:25:50.434: //1186/DA7B066E8813/SIP/Transport/sipTransportLogicSendMsg: Trying to send resp=0x3A01A90C to default port=5060
*May 15 14:25:50.434: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerGetConnection: connection required for raddr:10.131.1.6, rport:5060 with laddr:192.168.50.254
*May 15 14:25:50.434: //-1/xxxxxxxxxxxx/SIP/Transport/sipInstanceGetConnectionId: gcb=0x3F2BD4C0 is already on connection=0x3EC0C0A4 context_list
*May 15 14:25:50.434: //1186/DA7B066E8813/SIP/Transport/sipTransportLogicSendMsg: Connection obtained...sending msg=0x3A01A90C
*May 15 14:25:50.434: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x3A01A90C, addr=10.131.1.6, port=5060, local_addr=192.168.50.254, connId=4 vrfid=0 for UDP
*May 15 14:25:50.438: //1186/DA7B066E8813/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 180 Ringing
CSeq: 1 INVITE
Require: 100rel
RSeq: 3345
Content-Length: 0
*May 15 14:25:50.438: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_free: Freed msg=0x3A01A90C
*May 15 14:25:54.266: //1186/DA7B066E8813/SIP/Info/info/4096/sipSPIResendInviteResponse: resending 180 response due to no PRACK
*May 15 14:25:54.266: //1186/DA7B066E8813/SIP/Info/verbose/4096/sipSPISendInviteResponse: Dialog State: [1]
*May 15 14:25:54.266: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_create: created msg=0x3A01A90C with refCount = 1
*May 15 14:25:54.266: //1186/DA7B066E8813/SIP/Event/sipSPICreateRpid: Received Octet3A=0x00 -> Setting ;screen=no ;privacy=off
*May 15 14:25:54.266: //1186/DA7B066E8813/SIP/Info/info/4096/sipSPISendInviteResponse: Associated container=0x3F47D56C to Invite Response 180
*May 15 14:25:54.266: //-1/xxxxxxxxxxxx/SIP/Info/verbose/8192/sipSPIAppHandleContainerBody: sipSPIAppHandleContainerBody len 0
*May 15 14:25:54.266: //1186/DA7B066E8813/SIP/Transport/sipSPISendInviteResponse: Sending 180 Response to the Transport Layer
*May 15 14:25:54.266: //1186/DA7B066E8813/SIP/Transport/sipSPITransportSendMessage: msg=0x3A01A90C, addr=10.131.1.6, port=5060, sentBy_port=5060, local_addr=192.168.50.254, is_req=0, transport=1, switch=0, callBack=0x0
*May 15 14:25:54.266: //1186/DA7B066E8813/SIP/Info/info/2048/sipSPIGetExtensionCfg: SIP extension config:1, check sys cfg:1
*May 15 14:25:54.266: //1186/DA7B066E8813/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
*May 15 14:25:54.266: //1186/DA7B066E8813/SIP/Transport/sipTransportLogicSendMsg: Trying to send resp=0x3A01A90C to default port=5060
*May 15 14:25:54.266: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerGetConnection: connection required for raddr:10.131.1.6, rport:5060 with laddr:192.168.50.254
*May 15 14:25:54.266: //-1/xxxxxxxxxxxx/SIP/Transport/sipInstanceGetConnectionId: gcb=0x3F2BD4C0 is already on connection=0x3EC0C0A4 context_list
*May 15 14:25:54.266: //1186/DA7B066E8813/SIP/Transport/sipTransportLogicSendMsg: Connection obtained...sending msg=0x3A01A90C
*May 15 14:25:54.266: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x3A01A90C, addr=10.131.1.6, port=5060, local_addr=192.168.50.254, connId=4 vrfid=0 for UDP
*May 15 14:25:54.266: //1186/DA7B066E8813/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 180 Ringing
CSeq: 1 INVITE
Require: 100rel
RSeq: 3345
Content-Length: 0
*May 15 14:25:54.266: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_free: Freed msg=0x3A01A90C
*May 15 14:25:58.266: //1186/DA7B066E8813/SIP/Info/info/4096/sipSPIResendInviteResponse: resending 180 response due to no PRACK
*May 15 14:25:58.266: //1186/DA7B066E8813/SIP/Info/verbose/4096/sipSPISendInviteResponse: Dialog State: [1]
*May 15 14:25:58.266: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_create: created msg=0x3A01A90C with refCount = 1
*May 15 14:25:58.266: //1186/DA7B066E8813/SIP/Event/sipSPICreateRpid: Received Octet3A=0x00 -> Setting ;screen=no ;privacy=off
*May 15 14:25:58.266: //1186/DA7B066E8813/SIP/Info/info/4096/sipSPISendInviteResponse: Associated container=0x3F47D56C to Invite Response 180
*May 15 14:25:58.266: //-1/xxxxxxxxxxxx/SIP/Info/verbose/8192/sipSPIAppHandleContainerBody: sipSPIAppHandleContainerBody len 0
*May 15 14:25:58.266: //1186/DA7B066E8813/SIP/Transport/sipSPISendInviteResponse: Sending 180 Response to the Transport Layer
*May 15 14:25:58.266: //1186/DA7B066E8813/SIP/Transport/sipSPITransportSendMessage: msg=0x3A01A90C, addr=10.131.1.6, port=5060, sentBy_port=5060, local_addr=192.168.50.254, is_req=0, transport=1, switch=0, callBack=0x0
*May 15 14:25:58.266: //1186/DA7B066E8813/SIP/Info/info/2048/sipSPIGetExtensionCfg: SIP extension config:1, check sys cfg:1
*May 15 14:25:58.266: //1186/DA7B066E8813/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
*May 15 14:25:58.266: //1186/DA7B066E8813/SIP/Transport/sipTransportLogicSendMsg: Trying to send resp=0x3A01A90C to default port=5060
*May 15 14:25:58.266: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerGetConnection: connection required for raddr:10.131.1.6, rport:5060 with laddr:192.168.50.254
*May 15 14:25:58.266: //-1/xxxxxxxxxxxx/SIP/Transport/sipInstanceGetConnectionId: gcb=0x3F2BD4C0 is already on connection=0x3EC0C0A4 context_list
*May 15 14:25:58.266: //1186/DA7B066E8813/SIP/Transport/sipTransportLogicSendMsg: Connection obtained...sending msg=0x3A01A90C
*May 15 14:25:58.266: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x3A01A90C, addr=10.131.1.6, port=5060, local_addr=192.168.50.254, connId=4 vrfid=0 for UDP
*May 15 14:25:58.266: //1186/DA7B066E8813/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 180 Ringing
CSeq: 1 INVITE
Require: 100rel
RSeq: 3345
Content-Length: 0
*May 15 14:25:58.266: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_free: Freed msg=0x3A01A90C
*May 15 14:26:00.002: //1186/DA7B066E8813/SIP/Info/notify/1/ccsip_query_codec_info: Negotiated codec = 6
*May 15 14:26:00.002: //1186/DA7B066E8813/SIP/Info/verbose/8192/sipSPI_ipip_codec_byte_transrating: NOT SIP-SIP CALL. Will be addressed in future.
*May 15 14:26:00.006: //1186/DA7B066E8813/SIP/Info/info/8192/ccsip_call_statistics: Stats are not supported for IPIP call.
*May 15 14:26:00.006: //1186/DA7B066E8813/SIP/Info/verbose/4096/ccsip_ipip_media_service_get_event_data: Event id = 34
*May 15 14:26:00.006: //1186/DA7B066E8813/SIP/Info/critical/4096/ccsip_ipip_mf_create_xml_metadata_for_disconnect: MF: Not a Forked leg..
*May 15 14:26:00.006: //1186/DA7B066E8813/SIP/Info/critical/32768/ccsip_ipip_media_forking_post_event: MF: Not a Anchor SIP leg..
*May 15 14:26:00.006: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_DISCONNECT
*May 15 14:26:00.006: //-1/xxxxxxxxxxxx/SIP/Info/info/4096/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 3 for event 8
*May 15 14:26:00.006: //1186/DA7B066E8813/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SPI_EVENT
*May 15 14:26:00.006: //1186/DA7B066E8813/SIP/Info/info/8192/Session-Timer/sipSTSLMain:
*May 15 14:26:00.006: //1186/DA7B066E8813/SIP/Info/info/131072/sipSPIBwCacReleaseInterfaceBw: bwcac releasing interface GigabitEthernet0/0 bw 80 Kbps
*May 15 14:26:00.006: //1186/DA7B066E8813/SIP/Info/info/131072/sipSPIBwCacReleaseAccountedBw: bwcac released accounted bw 80000 bps
*May 15 14:26:00.006: //1186/DA7B066E8813/SIP/Error/act_sentalert_disconnect:
Disconnect cause from ccapi :47 and sip_disc_cause: 503
*May 15 14:26:00.006: //1186/DA7B066E8813/SIP/Info/verbose/4096/sipSPISendInviteResponse: Dialog State: [1]
*May 15 14:26:00.006: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_create: created msg=0x3A01A90C with refCount = 1
*May 15 14:26:00.006: //1186/DA7B066E8813/SIP/Info/notify/8192/sipSPIAddSessionID: localUUID - df176f7108365170afcc384fdbb05994 remoteUUID - 00000000000000000000000000000000
*May 15 14:26:00.006: //1186/DA7B066E8813/SIP/Info/notify/8192/sipSPIAddSessionID: Session-ID header 00000000000000000000000000000000;remote=df176f7108365170afcc384fdbb05994
*May 15 14:26:00.006: //1186/DA7B066E8813/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_RESP
*May 15 14:26:00.006: //1186/DA7B066E8813/SIP/Event/Session-Timer/sipSTSLMain: dir:1, method:102, resp_code:503, container:3F47C9BC
SE: 1800;refresher:none peer refresher:none, flags:1, posted event:E_STSL_INVALID_PEER_EVENT, reason:4
*May 15 14:26:00.010: //1186/DA7B066E8813/SIP/Info/info/4096/sipSPISendInviteResponse: Associated container=0x3F47C9BC to Invite Response 503
*May 15 14:26:00.010: //-1/xxxxxxxxxxxx/SIP/Info/verbose/8192/sipSPIAppHandleContainerBody: sipSPIAppHandleContainerBody len 0
*May 15 14:26:00.010: //1186/DA7B066E8813/SIP/Transport/sipSPITransportSendMessage: msg=0x3A01A90C, addr=10.131.1.6, port=5060, sentBy_port=5060, local_addr=192.168.50.254, is_req=0, transport=1, switch=0, callBack=0x35A191E8
*May 15 14:26:00.010: //1186/DA7B066E8813/SIP/Info/info/2048/sipSPIGetExtensionCfg: SIP extension config:1, check sys cfg:1
*May 15 14:26:00.010: //1186/DA7B066E8813/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
*May 15 14:26:00.010: //1186/DA7B066E8813/SIP/Transport/sipTransportLogicSendMsg: Trying to send resp=0x3A01A90C to default port=5060
*May 15 14:26:00.010: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerGetConnection: connection required for raddr:10.131.1.6, rport:5060 with laddr:192.168.50.254
*May 15 14:26:00.010: //-1/xxxxxxxxxxxx/SIP/Transport/sipInstanceGetConnectionId: gcb=0x3F2BD4C0 is already on connection=0x3EC0C0A4 context_list
*May 15 14:26:00.010: //1186/DA7B066E8813/SIP/Transport/sipTransportLogicSendMsg: Connection obtained...sending msg=0x3A01A90C
*May 15 14:26:00.010: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x3A01A90C, addr=10.131.1.6, port=5060, local_addr=192.168.50.254, connId=4 vrfid=0 for UDP
*May 15 14:26:00.010: //1186/DA7B066E8813/SIP/Info/critical/512/sentErrResDisconnecting: Sent an 3456XX Error Response
*May 15 14:26:00.010: //1186/DA7B066E8813/SIP/State/sipSPIChangeState: 0x3F2BD4C0 : State change from (STATE_SENT_ALERTING, SUBSTATE_NONE) to (STATE_DISCONNECTING, SUBSTATE_NONE)
*May 15 14:26:00.010: //1186/DA7B066E8813/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 503 Service Unavailable
CSeq: 1 INVITE
Reason: Q.850;cause=47
Session-ID: 00000000000000000000000000000000;remote=df176f7108365170afcc384fdbb05994
Content-Length: 0
*May 15 14:26:00.010: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_free: Freed msg=0x3A01A90C
*May 15 14:26:00.818: //1186/DA7B066E8813/SIP/Info/verbose/4096/sipSPISendInviteResponse: Dialog State: [0]
*May 15 14:26:00.818: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_create: created msg=0x3A01A90C with refCount = 1
*May 15 14:26:00.818: //1186/DA7B066E8813/SIP/Info/info/4096/sipSPISendInviteResponse: Associated container=0x3F47C9BC to Invite Response 503
*May 15 14:26:00.818: //-1/xxxxxxxxxxxx/SIP/Info/verbose/8192/sipSPIAppHandleContainerBody: sipSPIAppHandleContainerBody len 0
*May 15 14:26:00.818: //1186/DA7B066E8813/SIP/Transport/sipSPITransportSendMessage: msg=0x3A01A90C, addr=10.131.1.6, port=5060, sentBy_port=5060, local_addr=192.168.50.254, is_req=0, transport=1, switch=0, callBack=0x0
*May 15 14:26:00.818: //1186/DA7B066E8813/SIP/Info/info/2048/sipSPIGetExtensionCfg: SIP extension config:1, check sys cfg:1
*May 15 14:26:00.818: //1186/DA7B066E8813/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
*May 15 14:26:00.818: //1186/DA7B066E8813/SIP/Transport/sipTransportLogicSendMsg: Trying to send resp=0x3A01A90C to default port=5060
*May 15 14:26:00.818: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerGetConnection: connection required for raddr:10.131.1.6, rport:5060 with laddr:192.168.50.254
*May 15 14:26:00.818: //-1/xxxxxxxxxxxx/SIP/Transport/sipInstanceGetConnectionId: gcb=0x3F2BD4C0 is already on connection=0x3EC0C0A4 context_list
*May 15 14:26:00.818: //1186/DA7B066E8813/SIP/Transport/sipTransportLogicSendMsg: Connection obtained...sending msg=0x3A01A90C
*May 15 14:26:00.818: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x3A01A90C, addr=10.131.1.6, port=5060, local_addr=192.168.50.254, connId=4 vrfid=0 for UDP
*May 15 14:26:00.822: //1186/DA7B066E8813/SIP/Msg/ccsipDisplayMsg:
Sent:
CSeq: 1 INVITE
Content-Length: 0
*May 15 14:26:00.822: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_free: Freed msg=0x3A01A90C
*May 15 14:26:01.654: //1186/DA7B066E8813/SIP/Info/verbose/4096/sipSPISendInviteResponse: Dialog State: [0]
*May 15 14:26:01.654: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_create: created msg=0x3A01A90C with refCount = 1
*May 15 14:26:01.654: //1186/DA7B066E8813/SIP/Info/info/4096/sipSPISendInviteResponse: Associated container=0x3F47C9BC to Invite Response 503
*May 15 14:26:01.654: //-1/xxxxxxxxxxxx/SIP/Info/verbose/8192/sipSPIAppHandleContainerBody: sipSPIAppHandleContainerBody len 0
*May 15 14:26:01.654: //1186/DA7B066E8813/SIP/Transport/sipSPITransportSendMessage: msg=0x3A01A90C, addr=10.131.1.6, port=5060, sentBy_port=5060, local_addr=192.168.50.254, is_req=0, transport=1, switch=0, callBack=0x0
*May 15 14:26:01.654: //1186/DA7B066E8813/SIP/Info/info/2048/sipSPIGetExtensionCfg: SIP extension config:1, check sys cfg:1
*May 15 14:26:01.654: //1186/DA7B066E8813/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
*May 15 14:26:01.654: //1186/DA7B066E8813/SIP/Transport/sipTransportLogicSendMsg: Trying to send resp=0x3A01A90C to default port=5060
*May 15 14:26:01.654: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerGetConnection: connection required for raddr:10.131.1.6, rport:5060 with laddr:192.168.50.254
*May 15 14:26:01.654: //-1/xxxxxxxxxxxx/SIP/Transport/sipInstanceGetConnectionId: gcb=0x3F2BD4C0 is already on connection=0x3EC0C0A4 context_list
*May 15 14:26:01.654: //1186/DA7B066E8813/SIP/Transport/sipTransportLogicSendMsg: Connection obtained...sending msg=0x3A01A90C
*May 15 14:26:01.654: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x3A01A90C, addr=10.131.1.6, port=5060, local_addr=192.168.50.254, connId=4 vrfid=0 for UDP
*May 15 14:26:01.654: //1186/DA7B066E8813/SIP/Msg/ccsipDisplayMsg:
Sent:
VGW_DI#undebug all SIP/2.0 503 Service Unavailable
Via: SIP/2.0/UDP 10.131.1.6:5060;branch=z9hG4bK3mxmxbmw3uubqk5txj3kkbkk5;Role=3;Hpt=8e72_36
From: <sip:781260948@ims.sonatel.net;user=phone;noa=national;srvattri=national>;tag=l6FQvQQp
Call-ID: sbcthLNQQVSvVpvSSiQpiqG4QlMp4pMSM6GIvMpF@BI.BLB.B.BVL
CSeq: 1 INVITE
Content-Length: 0
*May 15 14:26:01.658: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_free: Freed msg=0x3A01A90C
*May 15 14:26:03.510: //1186/DA7B066E8813/SIP/Info/verbose/4096/sipSPISendInviteResponse: Dialog State: [0]
*May 15 14:26:03.510: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_create: created msg=0x3A01A90C with refCount = 1
*May 15 14:26:03.510: //1186/DA7B066E8813/SIP/Info/info/4096/sipSPISendInviteResponse: Associated container=0x3F47C9BC to Invite Response 503
*May 15 14:26:03.510: //-1/xxxxxxxxxxxx/SIP/Info/verbose/8192/sipSPIAppHandleContainerBody: sipSPIAppHandleContainerBody len 0
*May 15 14:26:03.510: //1186/DA7B066E8813/SIP/Transport/sipSPITransportSendMessage: msg=0x3A01A90C, addr=10.131.1.6, port=5060, sentBy_port=5060, local_addr=192.168.50.254, is_req=0, transport=1, switch=0, callBack=0x0
*May 15 14:26:03.510: //1186/DA7B066E8813/SIP/Info/info/2048/sipSPIGetExtensionCfg: SIP extension config:1, check sys cfg:1
*May 15 14:26:03.510: //1186/DA7B066E8813/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
*May 15 14:26:03.510: //1186/DA7B066E8813/SIP/Transport/sipTransportLogicSendMsg: Trying to send resp=0x3A01A90C to default port=5060
*May 15 14:26:03.510: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerGetConnection: connection required for raddr:10.131.1.6, rport:5060 with laddr:192.168.50.254
*May 15 14:26:03.510: //-1/xxxxxxxxxxxx/SIP/Transport/sipInstanceGetConnectionId: gcb=0x3F2BD4C0 is already on connection=0x3EC0C0A4 context_list
*May 15 14:26:03.510: //1186/DA7B066E8813/SIP/Transport/sipTransportLogicSendMsg: Connection obtained...sending msg=0x3A01A90C
*May 15 14:26:03.510: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x3A01A90C, addr=10.131.1.6, port=5060, local_addr=192.168.50.254, connId=4 vrfid=0 for UDP
*May 15 14:26:03.510: //1186/DA7B066E8813/SIP/Msg/ccsipDisplayMsg:
Sent:
All possible debugging has been turned off
VGW_DI#SIP/2.0 503 Service Unavailable
CSeq: 1 INVITE
Content-Length: 0
