annuler
Affichage des résultats de
Rechercher plutôt
Vouliez-vous dire :
Visites
Compliment
16
Réponses
control plane option
alain-chavanne
hi all
can i use a c2960x-48-ts-l  to use control plane option. If yes, which is the IOS to install?
tq
16 RÉPONSES 16
M02@rt37
Hello @alain-chavanne
c2960x-48-ts-l
-l mean lan-base
As concernerd C2960-X (and -XR), CoPP is supported only on LAN BASE, IP Lite, and IP Service licenses and you need release 15.2(4)E. COPP is introduced introduced in Cisco IOS Release 15.2(4)E.
It is better to perform an upgrade from 152-2.E3 to 15.2(4)E.
References:
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst2960x/software/15-2_5_e/configuration_guide/b_1525e_consolidated_2960x_cg/b_1525e_consolidated_2960x_cg_chapter_0111111.html
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst2960x/software/15-2_4_e/releasenotes/rn-1524e-2960x-xr.html
Best regards
Hello
I'm back
I installed the new version you proposed me but I can't modify the running conf to make this c2960x running as the c2960G installed.
I know c2960x is level2 but if it use it, I do have not modify the original running configuration (which is running with c2960g).
If I understood well, no way to force c2960x to act as c2960g.
