annuler
Affichage des résultats de
Rechercher plutôt
Vouliez-vous dire :
Visites
Compliment
Réponses
[CUCM] Partition description max length
jules_
We can see that in the CUCM interface we can write a description with a maximum length of 50 characters, but on the database we can see that the maximum length of this field is 200 characters.
When we use the API to push a description of more than 50 characters we only see the first 50 characters and we lose the excess is this a normal behavior?
1 SOLUTION APPROUVÉE
Solutions approuvées
M02@rt37
Hello @jules_,
Yes, this is a normal behavior in CUCM. Even though the database field for the description can hold up to 200 characters, the maximum length of the description that can be displayed in the CUCM user interface is limited to 50 characters. When you use the API to push a description longer than 50 characters, the excess characters are truncated and only the first 50 characters are displayed in the user interface.
It seems to be a known limitation in CUCM and is not configurable.
Best regards
Voir la solution dans l'envoi d'origine
1 RÉPONSE 1
M02@rt37
Hello @jules_,
Best regards
