I trying to setup a P-5GS6-GL module, the simcard attaches to the network but on the cellular 0/2/0 there's no ip.
The profile is showing the error 241 but seems a Cisco generic error.
The initial default APN is the same for data connectivity, wbdata. In fact, the initial default APN is not required by the network but i cannot set the profile without entering an APN. Shouldn't allow to configure without APN?
Sharing the relevant part of the config:
Lab#sh cellular 0/2/0 hardware
Modem Firmware Version = M0H.020202
Host Firmware Version = A0H.000292
Device Model ID = FN980
International Mobile Subscriber Identity (IMSI) = 20801xxxxxxxxxx
International Mobile Equipment Identity (IMEI) = 3515339200xxxxx
Integrated Circuit Card ID (ICCID) = 89xxxxxxxxxxxxxxxxx
Mobile Subscriber Integrated Services
Digital Network-Number (MSISDN) =
Modem Status = Modem Online
Current Modem Temperature = 32 deg C
PRI version = 0811-111, Carrier = Generic PTCRB
OEM PRI version = 0811-111
Lab#
sh run controller cellular 0/2/0
Building configuration...
Current configuration : 107 bytes
controller Cellular 0/2/0
lte sim data-profile 2 attach-profile 3 slot 0
lte gps mode standalone
end
Lab#
Lab#
Lab#sh cellular 0/2/0 profile
Profile password Encryption level = 7
Profile 2 = INACTIVE* **
PDP Type = IPv4
Access Point Name (APN) = wbdata
Authentication = None
* - Default profile
** - LTE attach profile
Configured default profile for active SIM 0 is profile 2.
Lab#sh cellular 0/2/0 conn
Lab#sh cellular 0/2/0 connection
Profile 1, Packet Session Status = INACTIVE
Profile 2, Packet Session Status = INACTIVE
Call end mode = unknown technology
Session disconnect reason type = unknown reason type(2)
Session disconnect reason = unknown reason(241)
Cellular is available
Profile 3, Packet Session Status = INACTIVE
Profile 4, Packet Session Status = INACTIVE
Profile 5, Packet Session Status = INACTIVE
Profile 6, Packet Session Status = INACTIVE
Profile 7, Packet Session Status = INACTIVE
Profile 8, Packet Session Status = INACTIVE
Profile 9, Packet Session Status = INACTIVE
Profile 10, Packet Session Status = INACTIVE
Profile 11, Packet Session Status = INACTIVE
Profile 12, Packet Session Status = INACTIVE
Profile 13, Packet Session Status = INACTIVE
Profile 14, Packet Session Status = INACTIVE
Profile 15, Packet Session Status = INACTIVE
Profile 16, Packet Session Status = INACTIVE
Lab#sh ip int brie
GigabitEthernet0/0/0 10.1.2.1 YES NVRAM down down
GigabitEthernet0/0/1 unassigned YES NVRAM administratively down down
GigabitEthernet0/1/0 unassigned YES unset down down
GigabitEthernet0/1/1 unassigned YES unset down down
GigabitEthernet0/1/2 unassigned YES unset down down
GigabitEthernet0/1/3 unassigned YES unset down down
GigabitEthernet0/1/4 unassigned YES unset down down
GigabitEthernet0/1/5 unassigned YES unset down down
GigabitEthernet0/1/6 unassigned YES unset down down
GigabitEthernet0/1/7 unassigned YES unset up up
Cellular0/2/0 unassigned YES IPCP up up
Cellular0/2/1 unassigned YES manual administratively down down
Lab#debug cellular 0/2/0 messages callcontrol
CALLCONTROL debugging is on
Lab#
Sep 26 08:03:26.472 CEST: debug information ipc sent successfully
Sep 26 08:03:26.472 CEST: Debug information set successfully module=16,mask=65536
Sep 26 08:03:29.157 CEST: cwan_hwif_state_change: Cellular0/2/0
Sep 26 08:03:42.156 CEST: back off timer is not running for PDN 0
Sep 26 08:03:42.157 CEST: api_manage_packet_session: Cellular0/2/0 profile 255 activate 1
Sep 26 08:03:42.201 CEST: irrelevant error code 241
Sep 26 08:04:14.157 CEST: cwan_hwif_state_change: Cellular0/2/0
Sep 26 08:04:27.157 CEST: back off timer is not running for PDN 0
Sep 26 08:04:27.157 CEST: api_manage_packet_session: Cellular0/2/0 profile 255 activate 1
Sep 26 08:04:27.194 CEST: irrelevant error code 241
Lab#u all
All possible debugging has been turned off
Lab#
Thank you in advance!
