Browser Compatibility for Tech Docs
BENJAMIN TAN
Try opening this link in IE 8 (release notes for IOS XE)
http://www.cisco.com/en/US/docs/ios/ios_xe/2/release/notes/rnasr21.html
Crashes IE8 (both 32 and 64)on Win7 x64. Crashes IE8 on XP-32. Ok in IE8 on W2K3-64 and W2K8-64.
ok in Firefox.
I don't see any other pattern.
BENJAMIN TAN
Correction: Crashes on MOST (3 out of 4 PCs that I've tested) Win7 x64. I'm still trying to find some pattern.
Please tell me that I'm not the only one to experience browser crashes when opening:
Hi Benjamin,
Thanks for letting us know about your problem. We’ve asked our IT and tool support teams to investigate whether there might be a compatibility issue. In the meantime, I can email you a PDF file of the Cisco IOS XE release notes if you would like to provide me your email address ([email protected]). I’d also like to ask if the release notes file is the only document you have a problem opening on Cisco.com with IE 8 on Windows 7, or have you had similar problems opening other Cisco docs?
-Mary
